- 10-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Mirroring commands
- 12-sFlow commands
- 13-Information center commands
- 14-VCF fabric commands
- 15-Cloud connection commands
- 16-SmartMC commands
- 17-WiNet commands
- 18-EPA commands
11-Mirroring commands | 85.00 KB |
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 4.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
remote-destination: Specifies remote destination groups.
remote-source: Specifies remote source groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
GigabitEthernet1/0/1 Inbound
Monitor port: GigabitEthernet1/0/2
Mirroring group |
Number of the mirroring group. |
Type |
Type of the mirroring group: · Local. · Remote source. · Remote destination. |
Status |
Status of the mirroring group: · Active—The mirroring group has taken effect. · Incomplete—The mirroring group configuration is not complete and does not take effect. |
Mirroring port |
Source port. |
Monitor port |
Destination port. |
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is 1 to 4.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
You can configure source ports only for local mirroring groups and remote source groups.
A Layer 2 aggregate interface cannot be configured as a source port for a mirroring group.
Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
The device supports only one mirroring group for outbound or bidirectional traffic mirroring
A port can act as a source port for only one mirroring group.
A source port cannot be used as a reflector port, monitor port, or egress port.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
# Create remote source group 2 to monitor the bidirectional traffic of the port GigabitEthernet 1/0/2.
[Sysname] mirroring-group 2 remote-source
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 mirroring-port both
mirroring-group
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
The device supports only one mirroring group for outbound or bidirectional traffic mirroring.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 1/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
# Create remote source group 2 to monitor the bidirectional traffic of GigabitEthernet 1/0/2.
[Sysname] mirroring-group 2 mirroring-port gigabitethernet 1/0/2 both
mirroring-group
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
· Spanning tree.
· 802.1X.
· IGMP snooping.
· Static ARP.
· MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
The member port of an aggregate interface cannot be configured as an egress port.
# Create remote source group 1. Configure GigabitEthernet 1/0/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress gigabitethernet 1/0/1
# Create remote source group 2. Configure GigabitEthernet 1/0/2 as its egress port in interface view.
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 monitor-egress
mirroring-group
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
You can configure monitor ports only for local mirroring groups and remote destination groups.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
For an aggregate interface configured as the monitor port of a mirroring group, do not configure its member ports as source ports of the mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
Only one monitor port can be configured for a mirroring group.
# Create local mirroring group 1 and configure GigabitEthernet 1/0/1 as its monitor port.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
# Create remote destination group 2 and configure GigabitEthernet 1/0/2 as its monitor port.
[Sysname] mirroring-group 2 remote-destination
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 monitor-port
mirroring-group
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
[Sysname] mirroring-group 2 monitor-port gigabitethernet 1/0/2
mirroring-group
Use mirroring-group reflector-port to configure the reflector port for a remote source group.
Use undo mirroring-group reflector-port to restore the default.
In system view:
mirroring-group group-id reflector-port interface-type interface-number
undo mirroring-group group-id reflector-port interface-type interface-number
In interface view:
No reflector port is configured for a mirroring group.
Interface view
CAUTION: · The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port. · When a port is configured as a reflector port, the port restores to the factory default settings. You cannot configure other features on a reflector port. · If an IRF port is bound to only one physical interface, do not configure the physical interface as a reflector port. Otherwise, the IRF might split. |
You can configure reflector ports only for remote source groups.
You cannot change the duplex mode, MDI settings, or speed for a reflector port.
The member port of an aggregate interface cannot be configured as a reflector port.
# Create remote source group 1. Configure GigabitEthernet 1/0/1 as its reflector port in system view.
[Sysname] mirroring-group 1 reflector-port gigabitethernet 1/0/1
# Create remote source group 2. Configure GigabitEthernet 1/0/2 as its reflector port in interface view.
[Sysname-GigabitEthernet1/0/2] mirroring-group 2 reflector-port
mirroring-group
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
The device supports only one remote probe VLAN.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
You can execute the mirror-to interface interface-type interface-number command multiple times for a traffic behavior to mirror traffic to different interfaces.
You can configure a maximum of four traffic behaviors that contain mirroring actions. If you configure more than four such traffic behaviors, only the first four traffic behaviors take effect.
You can use the mirror-to interface interface-type interface-number command to mirror traffic to only one interface in a traffic behavior. If you execute the command for a traffic behavior multiple times, the most recent configuration takes effect.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1
