17-Network Management and Monitoring Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R6728-6W10017-Network Management and Monitoring Command Reference
24-GOLD commands
24-GOLD commands 88.13 KB
GOLD commands
Support for the diagnostic tests depends on the device model. To get the names of diagnostic tests supported by the device, enter ? at the test name position in a GOLD command. The diagnostic test names used in the following command examples are for illustration only.
diagnostic event-log size
Use diagnostic event-log size to configure the maximum number of GOLD log entries.
Use undo diagnostic event-log size to restore the default.
diagnostic event-log size number
GOLD can save up to 512 log entries.
number: Specifies the maximum number of log entries, in the range of 0 to 1024.
If you specify a number smaller than the number of existing log entries, the system automatically deletes the oldest excess entries.
When the number of GOLD log entries exceeds the configured log buffer size, the system automatically deletes the oldest excess entries.
# Set the maximum number of log entries to 600.
[Sysname] diagnostic event-log size 600
diagnostic monitor action
Use diagnostic monitor action to configure the recovery action to take upon detection of an error for monitoring diagnostic tests.
Use undo diagnostic monitor action to restore the default.
In standalone mode:
diagnostic monitor action [ test test-name ] mode { none | self-reboot | service-restart | switchover | system-reboot }
undo diagnostic monitor action [ test test-name ]
In IRF mode:
diagnostic monitor action slot slot-number-list  [ test test-name ] mode { none | self-reboot | service-restart | switchover | system-reboot }
undo diagnostic monitor action slot slot-number-list [ test test-name ]
By default, the settings for this command vary by test. Use the display diagnostic content verbose command to view the recovery action for a test. If a test does not support any recovery action, its recovery action is displayed as -NA-.
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command specifies all monitoring diagnostic tests.
none: Does not take any action.
self-reboot: Reboots faulty devices or cards.
service-restart: Restarts faulty services.
switchover: Performs an IRF master/subordinate switchover or an active/standby MPU switchover.
system-reboot: Reboots the device where an error is detected.
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies an IRF member device by its member ID or specifies a range of IRF member devices in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
# (In standalone mode.) Set the recovery action to self-reboot for test MonitorTest.
[Sysname] diagnostic monitor action test MonitorTest mode self-reboot
# (In IRF mode.) Set the recovery action to self-reboot for test MonitorTest on slot 1.
[Sysname] diagnostic monitor action slot 1 test MonitorTest mode self-reboot
diagnostic monitor enable
Use diagnostic monitor enable to enable monitoring diagnostics.
Use undo diagnostic monitor enable to disable monitoring diagnostics.
In standalone mode:
diagnostic monitor enable [ test test-name ]
undo diagnostic monitor enable [ test test-name ]
In IRF mode:
diagnostic monitor enable slot slot-number-list [ test test-name ]
undo diagnostic monitor enable slot slot-number-list [ test test-name ]
Monitoring diagnostics are enabled.
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command enables all monitoring diagnostic tests.
Monitoring diagnostics enable the system to periodically run diagnostic tests to detect hardware faults and record test results. Monitoring diagnostics execute only non-disruptive tests.
Disruptive diagnostic tests that are being executed affect device operation or even disable certain functions, but non-disruptive diagnostic tests do not.
The system automatically executes enabled monitoring diagnostic tests after the device starts. Use the diagnostic monitor enable command to enable diagnostic tests that are disabled by default.
# (In standalone mode.) Enable test MonitorTest.
[Sysname] diagnostic monitor enable test MonitorTest
# (In IRF mode.) Enable test MonitorTest on the specified slot.
[Sysname] diagnostic monitor enable slot 1 test MonitorTest
diagnostic monitor interval
Use diagnostic monitor interval to configure an execution interval for monitoring diagnostic tests.
Use undo diagnostic monitor interval to restore the default.
In standalone mode:
diagnostic monitor interval [ test test-name ] time interval
undo diagnostic monitor interval [ test test-name ]
In IRF mode:
diagnostic monitor interval slot slot-number-list [ test test-name ] time interval
undo diagnostic monitor interval slot slot-number-list [ test test-name ]
The execution interval varies by monitoring diagnostic test. To display the execution interval of a monitoring diagnostic test, execute the display diagnostic content command.
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command applies to all monitoring diagnostic tests.
interval: Sets an execution interval in the form of hh:mm:ss. The value range for the hh argument is 0 to 23. The value range for the mm and ss arguments is both 0 to 59. If you specify only the hh argument, you can omit the mm and ss segments. If you specify only the hh and mm arguments, you can omit the ss segment. For example, to specify 01:00:00, you can enter 1.
Use this command to configure the interval at which the system automatically executes enabled monitoring diagnostic tests.
The configured interval cannot be smaller than the minimum execution interval of the tests. Use the display diagnostic content verbose command to view the minimum execution interval of the tests.
# (In standalone mode.) Set the execution interval to 1 minute for test MonitorTest.
[Sysname] diagnostic monitor interval test MonitorTest time 00:01:00
# (In IRF mode.) Set the execution interval to 1 minute for test MonitorTest on the specified slot.
<Sysname> system-view.
[Sysname] diagnostic monitor interval slot 1 test MonitorTest time 00:01:00
diagnostic simulation
Use diagnostic simulation to simulate diagnostic tests.
Use undo diagnostic simulation to restore the default.
In standalone mode:
diagnostic simulation test test-name { failure | random-failure | success }
undo diagnostic simulation test test-name
In IRF mode:
diagnostic simulation slot slot-number-list test test-name { failure | random-failure | success }
undo diagnostic simulation slot slot-number-list test test-name
All diagnostic tests are executed instead of simulated.
failure: Configures the system to generate failure results.
random-failure: Configures the system to randomly generate results.
success: Configures the system to generate success results.
Test simulation is used to verify GOLD frame functionality. After you execute this command, the system simulates the specified test if the execution requirements for the test are met. The test is not actually executed and does not trigger hardware correcting actions.
# (In standalone mode.) Simulate test MonitorTest as failed.
<Sysname> diagnostic simulation test MonitorTest failure
# (In IRF mode.) Simulate test MonitorTest as failed on the specified slot.
<Sysname> diagnostic simulation slot 1 test MonitorTest failure
display diagnostic simulation
Use display diagnostic content to display information about diagnostic tests.
In standalone mode:
display diagnostic content [ verbose ]
In IRF mode:
display diagnostic content [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command applies to all member devices. (In IRF mode.)
verbose: Displays detailed information about diagnostic tests. If you do not specify this keyword, the command displays brief information about the diagnostic tests.
# (In standalone mode.) Display brief information about all diagnostic tests.
<Sysname> display diagnostic content
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Name                            Attributes             Interval
MonitorTest                     **M*PA                 01:00:00
# (In standalone mode.) Display detailed information about all diagnostic tests.
<Sysname> display diagnostic content verbose
Test name        : MonitorTest
Test attributes  : **M*PA
Test interval    : 01:00:00
Min interval     : 00:00:06
Correct-action   : -NA-
Description      : A Real-time test, enabled by default that checks board status
 between local master and other local boards.
Exec             : -NA-
# (In IRF mode.) Display brief information about all diagnostic tests on the specified slot.
<Sysname> display diagnostic content slot 1
Slot 1:
# (In IRF mode.) Display detailed information about all diagnostic tests on the specified slot.
<Sysname> display diagnostic content slot 1 verbose
Slot 1:
Exec             : -NA-
B/*
(This field is not supported in the current software version.)Boot-up/Not boot-up.
O/*
(This field is not supported in the current software version.)On-demand/Not on-demand.
M/*
Monitoring/Not monitoring.
D/*
(This field is not supported in the current software version.)Disruptive/Non-disruptive.
P/*
Port-related/Not port-related.
A/I/*
Active and monitoring/Inactive and monitoring/Not monitoring.
Name
Name of the diagnostic test.
Attributes
Attributes of the diagnostic test. The characters from left to right indicate whether or not the test is boot-up, on-demand, monitoring, disruptive, port-related, or active. The asterisks (*) indicate that the test does not have the corresponding attributes.
Interval
Execution interval for the test. If the execution interval for the test is not set, –NA–is displayed.
Test name
Test attributes
Test interval
Min interval
Minimum execution interval for the test. If the test does not have a minimum execution interval, –NA–is displayed.
Correct-action
Correcting action triggered by failure of the test.
Description for the test.
Exec
Path of the executed scripts. If the test does not run scripts, –NA–is displayed.
display diagnostic event-log
Use display diagnostic event-log to display GOLD log entries.
display diagnostic event-log [ error | info ]
error: Displays all error log entries.
info: Displays all log entries except error log entries.
If you do not specify the error and info keywords, the command displays all GOLD log entries.
The system records information about test execution in the form of logs. A log entry contains test name, execution time, test result, and failure cause. Log entries are generated for every execution. To reduce the burden of the information center, GOLD logs are not sent to the information center.
(In standalone mode.) GOLD logs are cleared when the device restarts.
(In IRF mode.) GOLD logs are cleared when the device restarts or when a master/subordinate device switchover occurs.
# (In standalone mode.) Display all GOLD log entries.
<Sysname> display diagnostic event-log
Event: E_INFO, Wed Jan  7 11:39:53:314 2017, TestName->IPCMonitor, Event_INFO: Result->Success.
# (In IRF mode.) Display all GOLD log entries.
Event: E_INFO, Wed Jan  7 11:39:53:314 2017, -Slot=1 TestName->IPCMonitor, Event_INFO: Result->Success.
display diagnostic result
Use display diagnostic result to display test results.
In standalone mode:
display diagnostic result [ test test-name ] [ verbose ]
In IRF mode:
display diagnostic result [ slot slot-number [ test test-name ] ] [ verbose ]
test test-name: Specifies a test by its name, a case-sensitive character string. You can use the test ? command to verify the value range of the test name. If you do not specify this option, the command applies to all diagnostic tests.
verbose: Displays detailed test results for diagnostic tests that are enabled or executed. (Statistics are not included.) If you do not specify this parameter, the command displays brief test results for the diagnostic tests.
# (In standalone mode.) Display brief test results for all diagnostic tests.
<Sysname> display diagnostic result
  Name                            Run count    Failure count    Last result
  MonitorTest                     386          0                Success
# (In standalone mode.) Display detailed test results for all diagnostic tests.
<Sysname> display diagnostic result verbose
  Total run count          : 386
  Total failure count      : 0
  Consecutive failure count: 0
  Last execution time      : Fri Nov 21 23:00:01 2014
  First failure time       : -NA-
  Last failure time        : -NA-
  Last pass time           : Fri Nov 21 23:00:01 2014
  Last execution result    : Success
  Last failure reason      : -NA-
  Next execution time      : Sat Nov 22 00:00:07 2014
  Slot  check status : Normal
# (In IRF mode.) Display brief test results for all diagnostic tests on the specified slot.
<Sysname> display diagnostic result slot 1
Slot 1:
# (In IRF mode.) Display detailed test results for all diagnostic tests.
Slot 1:
Name
Name of the test.
Run count
Total number of executions.
Failure count
Total number of failed tests.
Last result
Most recent test result.
Test name
Name of the test.
Total run count
Total failure count
Number of consecutive failed tests.
Last execution time
Most recent execution time.
First failure time
First failed test time. If no failure occurs, –NA– is displayed.
Last failure time
Most recent failed test time. If no failure occurs, –NA– is displayed.
Last pass time
Most recent success test time. If no success occurs, –NA– is displayed.
Last failure reason
Cause for the most recent failed test. If the failed test is simulated, Simulated Test is displayed. If no failure occurs, –NA– is displayed.
Next execution time
Time for the next execution.If the test is a monitoring diagnostic test, its next execution time is the most recent execution time plus the execution interval.
Use display diagnostic simulation to display configurations for simulated diagnostic tests.
In standalone mode:
In IRF mode:
display diagnostic simulation [ slot slot-number ]
# (In standalone mode.) Display configurations for all simulated diagnostic tests.
<Sysname> display diagnostic simulation
  Name                            Mode
  MonitorTest                     failure
# (In IRF mode.) Display configurations for all simulated diagnostic tests on the specified slot.
<Sysname> display diagnostic simulation slot 1
Slot 1:
  Name                            Mode
  MonitorTest                     failure
reset diagnostic event-log
Use reset diagnostic event-log to clear GOLD logs.
# Clear GOLD logs.
<Sysname> reset diagnostic event-log
reset diagnostic result
Use reset diagnostic result to clear test results.
In standalone mode:
reset diagnostic result [ test test-name ]
In IRF mode:
reset diagnostic result [ slot slot-number [ test test-name ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command applies to all IRF member devices. (In IRF mode.)
This command does not clear the next execution time.
# (In standalone mode.) Clear test results for test MonitorTest.
<Sysname> reset diagnostic result test MonitorTest
# (In IRF mode.) Clear test results for test MonitorTest on the specified slot.
<Sysname> reset diagnostic result slot 1 test MonitorTest
