17-Network Management and Monitoring Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R6728-6W10017-Network Management and Monitoring Command Reference
17-IPv6 NetStream commands
17-IPv6 NetStream commands 168.02 KB
display ipv6 netstream cache
Use display ipv6 netstream cache to display IPv6 NetStream entry information.
In standalone mode:
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ]
In IRF mode:
display ipv6 netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ slot slot-number ]
verbose: Displays detailed information about IPv6 NetStream entries. If you do not specify this keyword, this command displays brief information about IPv6 NetStream entries.
type: Specifies the IPv6 NetStream entry type. If you do not specify this keyword, this command displays information about all types of IPv6 NetStream entries.
ip: Specifies IP flow NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 flow NetStream entries.
l2: Specifies Layer 2 flow NetStream entries.
mpls: Specifies MPLS flow NetStream entries.
label-position1 label-value1: Specifies a label by its position and value. The value range for the label-position1 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value1 argument is 0 to 1048575.
label-position2 label-value2: Specifies a label by its position and value. The value range for the label-position2 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value2 argument is 0 to 1048575.
label-position3 label-value3: Specifies a label by its position and value. The value range for the label-position3 argument is 1 to 6, representing labels from the outermost to the innermost. The value range for the label-value3 argument is 0 to 1048575.
destination destination-ipv6: Specifies a destination IPv6 address. If you specify this option, this command does not display Layer 2 NetStream entries.
destination-port destination-port: Specifies a destination port number in the range of 0 to 65535. If you specify this option, this command does not display Layer 2 NetStream entries.
protocol protocol: Specifies a protocol by its number in the range of 0 to 255 or by its name such as GRE, OSPF, TCP, or UDP. If you specify this option, this command does not display Layer 2 NetStream entries.
source source-ipv6: Specifies a source IPv6 address. If you specify this option, this command does not display Layer 2 NetStream entries.
source-port source-port: Specifies a source port number in the range of 0 to 65535. If you specify this option, this command does not display Layer 2 NetStream entries.
arrived-time: Specifies an arrived time range to display IPv6 NetStream entries. If you do not specify this keyword, the arrived time is not used as a criterion for filtering the IPv6 NetStream entries to be displayed.
start-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
start-time: Specifies the start time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the start time of 0 indicates 00:00:00.
end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
end-time: Specifies the end time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the end time of 0 indicates 00:00:00.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about IPv6 NetStream entries for all member devices. (In IRF mode.)
Statistics about version 9 packets containing IP headers are classified as ipl2 (Layer 2 and Layer 3) NetStream entries. Statistics about packets without IP headers are classified as l2 (Layer 2) NetStream entries.
# Display information about IPv6 NetStream entries arrived at the IPv6 NetStream cache between 14:19:03 and 14:23:03 on July 28, 2017.
<Sysname> display ipv6 netstream cache arrived-time 7/28/2017 14:19:03 7/28/2017 14:23:03
Type DstIP(Port)         SrcIP(Port)      Pro TC  FlowLbl  APPID  If(Direct)   Pkts
     DstMAC(VLAN)           SrcMAC(VLAN)
     TopLblType(IP/Mask)    Lbl-Exp-S-List
IP   2001::1(1024)       2002::1(21)      6   0   0x6000   0x0    GE1/0/1(I)  42996
     First packet arrived: 7/28/2017, 14:20:03
     Last packet arrived:  7/28/2017, 14:21:03
     SRv6 policy NID:      2150629379
MPLS LDP(3.3.3.3/24)        1:18-6-0      17  0   0x12345  0x0     GE1/0/2(O)  291
                            2:24-6-0
                            3:30-6-1
     First packet arrived: 7/28/2017, 14:20:01
# Display detailed information about IPv6 NetStream entries.
<Sysname> display ipv6 netstream cache verbose
IPv6 NetStream cache information:
  Active flow timeout             : 60 min
  Inactive flow timeout           : 10 sec
  Max number of entries           : 1000
  IPv6 active flow entries        : 1
  MPLS active flow entries        : 1
  IPL2 active flow entries        : 0
  IPv6 flow entries counted       : 10
  MPLS flow entries counted       : 20
  IPL2 flow entries counted       : 20
  Last statistics resetting time  : 01/01/2000 at 00:01:02
IPv6 packet size distribution (1103746 packets in total):
1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
.249 .694 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .027 .000 .027 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86        49        27
TCP-FTP         5900082      86        9        9        11        33
TCP-FTPD        3200453    1006        5      193        45        33
TCP-WWW       546778274   11170      887       12         8        32
TCP-other      49148540    3752       79       47        30        32
UDP-DNS       117240379     570      190        3         7        34
UDP-other      45502422    2272       73       30         8        37
ICMP           14837957     125       24        5        12        34
IP-other          77406       5        0       47        52        27
     TopLblType(IP/MASK) Lbl-Exp-S-List
     TcpFlag:    0x1b
     DstMask:      24   SrcMask:      24
     DstAS:         0   SrcAS:         0
     NextHop:           2001::2
     BGPNextHop:        0:0:0:0:0:0:0:0
     InVRF:      mvp
     SamplerMode:   0  SamplerInt:    0
     Active:      120   Bytes/Pkt:   152
     First packet arrived: 10/28/2013, 14:10:03
     Last packet arrived:  10/28/2013, 14:21:03
MPLS LDP(3.3.3.3/24)    1:18-6-0         6   0    0x6000   0x0     GE1/0/2(O)  291
                        2:24-6-0
                        3:30-6-1
     Active:      660   Bytes/Pkt:   100
Active flow timeout
Aging timer for active flows, in minutes.
Aging timer for inactive flows, in seconds.
Maximum number of IPv6 flows allowed in the cache.
Number of active IPv6 flows in the cache.
Number of active IPv6 MPLS flows in the cache.
Number of active Layer 2 flows with IPv6 protocol information.
Number of IPv6 flows that have been counted.
Number of MPLS flows that have been counted.
Number of Layer 2 flows (with IPv6 protocol information) that have been counted.
Last time the reset ipv6 netstream statistics command was executed. This field displays Never if you have never executed this command.
IPv6 packet size distribution (1103746packets in total):
Distribution of IPv6 packets by packet size, and the bracketed number is the total number of IPv6 packets.
The value is displayed in the proportion of the number of IPv6 packets of the specified sizes to the total number of IPv6 packets. The value is displayed with three decimal places.
320  352  384  416  448  480 512  544  576
Range of IPv6 packet length (excluding data link layer header).
·     For the values in the range of 1 to 576 bytes, the range increases in the step of 32 bytes. For example, 1-32 shows the number of packets with the size of 1 to 32 bytes. 64 shows the number of packets with the size of 33 to 64 bytes.
·     For the values greater than 1024 bytes, the range increases in the step of 512 bytes. For example, 1536 shows the number of packets with the size of 1025 to 1536 bytes.
·     Packets with the size of 577 to 1024 bytes are recorded in the 1024 entry.
Protocol     Total Flows     Packets/Sec
Flow/Sec   Packets/flow
Active(sec)/ flow   Idle(sec)/flow
Statistics of packets by protocol type:
·     Protocol type.
·     Total number of flows.
·     Number of packets per second.
·     Number of flows per second.
·     Number of packets per flow.
·     Active time (in seconds) of each flow.
·     Inactive time (in seconds) of each flow.
Statistics of the active flows in the current cache:
·     Flow type. Flows are classified into the following types:
¡     IP flows.
¡     Layer 2 flows with IPv6 protocol information (IPL2).
¡     MPLS flows without IP options (MPLS).
¡     MPLS flows with IP options (IP&MPLS).
·     Destination IPv6 address (destination port).
·     Source IPv6 address (source port).
·     Protocol number.
·     Traffic classification.
·     Flow label.
·     Application ID.
·     Interface name (direction).
·     Number of packets.
ICMPv6 packets do not contain port number fields, so the type and code fields are captured. The value for the destination port represents these two fields:
·     The highest 8 bits represent the type field.
·     The lowest 8 bits represent the code field.
The value for the source port is set to 0 and does not indicate any statistics.
Layer 2 information for the active flows in the current cache:
·     Destination MAC address.
·     Destination VLAN ID.
·     Source MAC address.
·     Source VLAN ID.
Information about the active MPLS flows in the current cache:
·     Type of the labels at the top of the label stack:
¡     IP address associated with the label.
¡     Mask associated with the label.
·     Label list:
¡     Lbl—20-bit label value.
¡     Exp—3-bit field for implementing QoS.
¡     S—1-bit bottom of stack flag. The S field is set to 1 if the label is the bottom label and set to 0 if not.
TcpFlag:
DstMask:   SrcMask:
DstAS:       SrcAS:
NextHop:
BGPNextHop:
OutVRF:     InVRF:
SamplerMode:                  SamplerInt:
Active:       Bytes/Pkt:
SRv6 policy NID:
Other information about the active flows in the cache:
·     TCPFlag—TCP flag.
·     TTL.
·     DstMask—Destination mask.
·     SrcMask—Source mask.
·     DstAS—Destination AS.
·     SrcAS—Source AS.
·     NextHop—Routing next hop.
·     BGPNextHop—BGP next hop.
·     OutVRF—VPN to which the outbound packets belong.
·     InVRF—VPN to which the inbound packets belong.
·     SamplerMode—Sampling mode. IPv6 NetStream supports the following sampling modes:
¡     0—No sampling.
¡     1—Fixed sampling.
¡     2—Random sampling.
·     SamplerInt—Sampling interval.
·     Active—Flow's active time.
·     Bytes/Pkt—Number of bytes per packet.
·     First packet arrived—Arrival time of the first packet of the flow.
·     Last packet arrived—Arrival time of the last packet of the flow.
·     SRv6 policy NID—NHLFE entry index for the SRv6 TE policy.
display ipv6 netstream cache archive
Use display ipv6 netstream cache archive to display the locally archived IPv6 NetStream entries.
In standalone mode:
display ipv6 netstream cache archive [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ]
In IRF mode:
display ipv6 netstream cache archive [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | destination-port destination-port | interface interface-type interface-number | protocol protocol | source source-ip | source-port source-port ] * [ arrived-time start-date start-time end-date end-time ] [ slot slot-number ]
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware
Command compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
Yes
MSR810-LMS, MSR810-LUS
Yes
MSR810-LMS-EA, MSR810-LME
Yes
MSR1004S-5G
Yes
MSR2600-6-X1, MSR2600-10-X1, MSR2600-15-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
verbose: Displays detailed IPv6 NetStream entry information.
type: Specifies the IPv6 NetStream entry type. If you do not specify this keyword, this commands displays information about all types of IPv6 NetStream entries.
ip: Specifies Layer 3 NetStream entries.
ipl2: Specifies Layer 2 and Layer 3 NetStream entries.
l2: Specifies Layer 2 NetStream entries.
mpls: Specifies MPLS NetStream entries.
arrived-time: Specifies an arrived time range to display NetStream entries. If you do not specify this keyword, the arrived time is not used as a criterion for filtering the NetStream entries to be displayed.
·     start-date: Specifies the start date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
·     start-time: Specifies the start time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the start time of 0 indicates 00:00:00.
·     end-date: Specifies the end date in the format of MM/DD/YYYY or YYYY/MM/DD, where MM is in the range of 1 to 12 and YYYY is in the range of 2000 to 2035. The value range for DD varies by the value of MM.
·     end-time: Specifies the end time in the format of HH:MM:SS, where HH is in the range of 0 to 23, MM and SS are in the range of 0 to 59. The SS element can be omitted if its value is 00. Both the SS and MM elements can be omitted if their values are 0. For example, the end time of 0 indicates 00:00:00.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about NetStream entries for all member devices. (In IRF mode.)
# Display information about the NetStream entries archived between 14:10:03 and 14:23:03 on July 28, 2017.
<Sysname> display ipv6 netstream cache archive arrived-time 7/28/2017 14:10:03 7/28/2017 14:23:03
MPLS LDP(3.3.3.3/24)        1:18-6-0      12  0   0x12345  0x0     GE1/0/2(O)  291
                            2:24-6-0
                            3:30-6-1
See Table 1 for the command output description.
ip netstream cache archive enable
display ipv6 netstream export
Use display ipv6 netstream export to display information about the IPv6 NetStream data export.
IP NetStream export information varies by aggregation mode. This command displays IPv6 NetStream export information for all the configured aggregation modes.
# Display information about the IPv6 NetStream data export.
<Sysname> display ipv6 netstream export
protocol-port aggregation export information:
  Flow source interface                              : GigabitEthernet1/0/1
  Flow destination VPN instance                      : VPN1
  Flow destination IPv6 address (UDP)                : 40::1 (30000)
  Version  9 exported flow number                    : 16
  Version  9 exported UDP datagram number (failed)   : 2 (0)
IPv6 export information:
  Version  9 exported UDP datagram number (failed)   : 16 (0)
MPLS export information:
  Version  9 exported flow number                    : 20
Statistics of IPv6 NetStream protocol-port aggregation in the version 9 format.
Information about the IPv6 NetStream data export.
Source interface from which the IPv6 NetStream data is exported.
VPN to which the destination address of the IPv6 NetStream data export belongs.
Destination IP address and UDP port number of the IPv6 NetStream data export.
Number of flows that are exported in the version 9 format.
Number of UDP packets that are sent in the version 9 format. The value in the parentheses displays the number of UDP packets that failed to be sent.
Statistics of the MPLS-aware IPv6 NetStream data export in version 9.
display ipv6 netstream template
Use display ipv6 netstream template to display IPv6 NetStream template information.
In standalone mode:
In IRF mode:
display ipv6 netstream template [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 NetStream template information for the master device. (In IRF mode.)
IPv6 NetStream templates vary by aggregation mode. This command displays IPv6 NetStream template information for all the configured aggregation modes.
# Display IPv6 NetStream template information.
<Sysname> display ipv6 netstream template
 Flow template refresh frequency            : 20
 Flow template refresh interval             : 30 min
 Active flow templates                      : 2
 Created flow templates                     : 2
L3 outbound template:
 Template ID                : 3282
 Packets                    : 0
 Last template export time  : 12/19/2017 at 10:43:24
 Field count                : 29
 Field type                   Field length (bytes)
 Out packets                  8
 Out bytes                    8
 First forwarded              4
 Last forwarded               4
 Input interface index        4
 Output interface index       4
 Source IPv6 address          16
 Destination IPv6 address     16
 Next hop IPv6 address        16
 PAD                          1
 IPv6 flow label              3
 Source AS                    4
 Destination AS               4
 L4 source port               2
 L4 destination port          2
 IP protocol version          1
 TCP flags                    1
 Protocol                     1
 Source ToS                   1
 Source address mask          1
 Destination address mask     1
 Direction                    1
 Forwarding status            1
 Out VPN ID                   2
 Sampling algorithm           1
 PAD                          1
 Sampling interval            4
 App ID                       4
 App name                     65535
 VPN instance name            65535
L3 inbound template:
 Template ID                : 3281
 Packets                    : 0
 Field count                : 29
 In packets                   8
 In bytes                     8
 First forwarded              4
 Last forwarded               4
 PAD                          1
 IPv6 flow label              3
 Source AS                    4
 Destination AS               4
 L4 source port               2
 TCP flags                    1
 Protocol                     1
 Source ToS                   1
 Direction                    1
 Forwarding status            1
 In VPN ID                    2
 PAD                          1
 Sampling interval            4
 App ID                       4
 App name                     65535
Refresh frequency at which the templates are sent, in packets.
Refresh interval at which the templates are sent, in minutes.
Number of active IPv6 NetStream templates.
Number of templates that have been created.
Information of the Layer 3 template in the outbound direction.
L3 inbound template
Information of the Layer 3 template in the inbound direction.
Packets
Number of packets sent by using the template.
Time when the template was exported most recently.
Field count
Total number of fields in the template.
Field type
Type of a field in the template.
Length of a field in bytes.
Out packets
Number of sent packets.
In packets
Number of received packets.
Out bytes
Number of sent bytes.
In bytes
Number of received bytes.
First forwarded
System time when the first packet was forwarded, accurate to milliseconds.
Last forwarded
System time when the last packet was forwarded, accurate to milliseconds.
PAD
Padding string.
L4 source port
Source port number.
L4 destination port
Destination port number.
TCP flags
TCP flag of the flow.
Protocol
Layer 4 protocol type.
Direction
Traffic direction.
Out VPN ID
Name of the VPN instance to which the egress interface of the packets belong.
In VPN ID
Name of the VPN instance to which the ingress interface of the packets belong.
Sampling algorithm
Sampling algorithm.
Sampling interval
Sampling rate.
App ID
Application ID.
App name
Application name.
VPN instance name
VPN instance name. If the packets belong to the public network, this field displays N/A.
SRv6 policy color
Color for the SRv6 TE policy.
SRv6 policy endpoint
IPv6 address of the destination node for the SRv6 TE policy.
SRv6 policy name
Name of the SRv6 TE policy.
enable
Use enable to enable an IPv6 NetStream aggregation mode.
Use undo enable to disable an IPv6 NetStream aggregation mode.
enable
undo enable
No IPv6 NetStream aggregation mode is enabled.
IPv6 NetStream aggregation mode view
# Enable IPv6 NetStream destination-prefix aggregation mode.
[Sysname] ipv6 netstream aggregation destination-prefix
[Sysname-ns6-aggregation-dstpre] enable
ipv6 netstream
Use ipv6 netstream to enable IPv6 NetStream on an interface.
Use undo ipv6 netstream to disable IPv6 NetStream on an interface.
ipv6 netstream [ inbound | outbound ]
undo ipv6 netstream [ inbound | outbound ]
IPv6 NetStream is disabled on an interface.
Interface view
inbound: Enables IPv6 NetStream for incoming traffic.
outbound: Enables IPv6 NetStream for outgoing traffic.
If you configure this command without specifying a traffic direction, IPv6 NetStream is enabled on the interface for both incoming and outgoing traffic.
# Enable IPv6 NetStream for inbound traffic on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 netstream inbound
Use ipv6 netstream aggregation to specify an IPv6 NetStream aggregation mode and enter its view.
Use undo ipv6 netstream aggregation to remove the configuration for an IPv6 NetStream aggregation mode.
ipv6 netstream aggregation { as | bgp-nexthop | destination-prefix | prefix | protocol-port | source-prefix }
undo ipv6 netstream aggregation { as | bgp-nexthop | destination-prefix | prefix | protocol-port | source-prefix }
No IPv6 NetStream aggregation mode is specified.
as: Specifies the AS aggregation by source AS number, destination AS number, input interface index, and output interface index.
bgp-nexthop: Specifies the BGP nexthop aggregation by BGP next hop IPv6 address and output interface index.
destination-prefix: Specifies the destination-prefix aggregation by destination AS number, destination address mask length, destination prefix, and output interface index.
prefix: Specifies the source and destination prefix aggregation by the following criteria:
·     Source AS number.
·     Destination AS number.
·     Source address mask length.
·     Destination address mask length.
·     Source prefix.
·     Destination prefix.
·     Input interface index.
·     Output interface index.
protocol-port: Specifies the protocol-port aggregation by protocol number, source port, and destination port.
source-prefix: Specifies the source-prefix aggregation by source AS number, source address mask length, source prefix, and input interface index.
In IPv6 NetStream aggregation mode view, you can perform the following tasks:
·     Enable or disable the specified IPv6 NetStream aggregation mode.
·     Configure source interface, destination IPv6 address, and destination port for the IPv6 NetStream data export.
A flow matching multiple aggregation modes is counted as multiple aggregate flows.
# Set the IPv6 NetStream aggregation mode to destination-prefix, and enter IPv6 NetStream destination-prefix aggregation mode view.
enable
ipv6 netstream export host
ipv6 netstream export source
Use ipv6 netstream export host to specify a destination host for IPv6 NetStream data export.
Use undo ipv6 netstream export host to remove the specified destination host or all destination hosts that are configured in the current view.
ipv6 netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ]
undo ipv6 netstream export host [ ipv4-address | ipv6-address ] [ vpn-instance vpn-instance-name ]
No destination host is specified.
ipv4-address: Specifies the destination IPv4 address.
ipv6-address: Specifies the destination IPv6 address.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination is on the public network, do not specify this option.
You can specify the same destination host address and UDP port in different IPv6 NetStream aggregation mode views. If an aggregation mode is not enabled, the display ipv6 netstream export command cannot display the destination host configuration for the mode.
If no destination host is specified in an IPv6 NetStream aggregation mode view, the destination host in system view applies. If destination hosts are specified in an IPv6 NetStream aggregation view and system view, the destination hosts in aggregation view take effect.
In system view or in IPv6 NetStream aggregation mode view, you can specify a maximum of four IPv4 destination hosts and four IPv6 destination hosts, respectively. If you specify a destination host with the same destination address but different UDP ports in the same view, the most recent configuration takes effect. You can specify destination hosts with the same destination address and UDP port but different VPN instances.
IPv6 NetStream traditional data is exported to all destination hosts in system view. IPv6 NetStream aggregation data is exported to all destination hosts in the related aggregation view. If you expect only IPv6 NetStream aggregation data, specify destination hosts only in the IPv6 NetStream aggregation mode view. Aggregation data export reduces bandwidth usage.
# In system view, specify 40::1 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Sysname] ipv6 netstream export host 40::1 5000
ipv6 netstream export rate
Use ipv6 netstream export rate to limit the IPv6 NetStream data export rate.
Use undo ipv6 netstream export rate to restore the default.
ipv6 netstream export rate rate
The export rate of IPv6 NetStream data is not limited.
rate: Specifies the export rate in the range of 1 to 1000.
This command sets the maximum number of IPv6 NetStream packets that can be exported per second. Packets that cannot be exported due to the export rate limit are buffered for later export. When the buffer is full, the system will temporarily invalidate the rate limit and export packets as fast as possible until the buffer has space for new packets.
# Allow a maximum of 10 packets to be exported per second.
[Sysname] ipv6 netstream export rate 10
Use ipv6 netstream export source to specify the source interface for data packets sent to NetStream servers. The IPv6 address of the interface is used as the source IPv6 address of the data packets.
Use undo ipv6 netstream export source to restore the default.
ipv6 netstream export source interface interface-type interface-number
The packets take the IPv6 address of the output interface as the source IPv6 address.
interface-type interface-number: Specifies a source interface by its type and number for the IPv6 NetStream data export.
You can configure different source interfaces in different IPv6 NetStream aggregation mode views.
If no source interface is configured in IPv6 NetStream aggregation mode view, the source interface in system view applies.
As a best practice, connect the management Ethernet interface to a NetStream server, and configure the interface as the source interface.
# In system view, specify GigabitEthernet 1/0/1 as the source interface for IPv6 NetStream traditional data packets.
[Sysname] ipv6 netstream export source interface gigabitethernet 1/0/1
# In destination-prefix aggregation mode view, specify GigabitEthernet 1/0/2 as the source interface for IPv6 NetStream aggregation data packets.
[Sysname-ns6-aggregation-dstpre] ipv6 netstream export source interface gigabitethernet 1/0/2
ipv6 netstream export v9-template refresh-rate
Use ipv6 netstream export v9-template refresh-rate to set the refresh rate for the IPv6 NetStream version 9 template.
Use undo ipv6 netstream export v9-template refresh-rate to restore the default.
ipv6 netstream export v9-template refresh-rate { packet packets | time minutes }
undo ipv6 netstream export v9-template refresh-rate { packet | time }
The packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes.
packet packets: Specifies the number of packets that are sent before the template is sent. The value range is 1 to 600.
time minutes: Specifies the interval at which the template is sent, in the range of 1 to 3600 minutes.
Version 9 is template-based and supports user-defined formats. An IPv6 NetStream device must send the version 9 template to NetStream servers regularly, because the servers do not permanently save template.
The refresh rate can be packet count-based or time-based. If both settings are configured, the template is sent when either of the conditions is met.
# Configure the device to send the IPv6 NetStream version 9 template every 100 packets.
[Sysname] ipv6 netstream export v9-template refresh-rate packet 100
ipv6 netstream export version
Use ipv6 netstream export version 9 to export IPv6 NetStream data in the version 9 format and choose whether to record AS and BGP next hop information.
Use undo ipv6 netstream export version to restore the default.
ipv6 netstream export version 9 { origin-as | peer-as } [ bgp-nexthop ]
The version 9 format is used to export IPv6 NetStream data.
The peer AS numbers are recorded. The BGP next hop is not recorded.
origin-as: Records the source AS of the source address and the destination AS of the destination address.
peer-as: Records the ASs before and after the AS where the NetStream device resides as the source AS and destination AS, respectively.
bgp-nexthop: Records BGP next hops.
Only one version format can take effect on the device. If you execute the  ipv6 netstream export version command multiple times, the most recent configuration takes effect.
An IPv6 NetStream entry records the source IPv6 address, destination IPv6 address, and two AS numbers for each address. You can choose to configure which AS numbers are to be exported as the source AS and destination AS.
In the version 9 format, you can also choose whether to record the BGP next hop information.
# Configure the device to export IPv6 NetStream data in the version 9 format, and specify the IPv6 NetStream data to include the source AS and destination AS.
[Sysname] ipv6 netstream export version 9 origin-as
ipv6 netstream filter
Use ipv6 netstream filter to enable IPv6 NetStream filtering on an interface.
Use undo ipv6 netstream filter to disable IPv6 NetStream filtering on an interface.
ipv6 netstream { inbound | outbound } filter acl ipv6-acl-number
undo ipv6 netstream { inbound | outbound } filter
IPv6 NetStream filtering is disabled. IPv6 NetStream collects statistics about all IPv6 packets passing through an interface.
Interface view
inbound: Filters incoming traffic.
outbound: Filters outgoing traffic.
acl ipv6-acl-number: Specifies an IPv6 ACL by its number. The value range is 2000 to 2999 for basic ACLs, 3000 to 3999 for advanced ACLs, and 4000 to 4999 for Layer 2 ACLs.
IPv6 NetStream filtering uses an ACL to identify intended packets.
·     If you want to collect data for specific flows, use the ACL permit statements to identify the flows. IPv6 NetStream collects data only for these flows.
·     If you do not want to collect data for specific flows, use the ACL deny statements to identify the flows. IPv6 NetStream does not collect data for these flows.
# Use ACL 2003 for outbound IPv6 NetStream filtering on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 netstream outbound
[Sysname-GigabitEthernet1/0/1] ipv6 netstream outbound filter acl 2003
ipv6 netstream ipsec raw-packet
Use ipv6 netstream ipsec raw-packet to configure IPv6 NetStream to collect statistics for outgoing IPsec packets before IPsec encapsulation.
Use undo ipv6 netstream raw-packet to restore the default.
undo ipv6 netstream ipsec raw-packet
IPv6 NetStream collects statistics for outgoing IPsec packets after IPsec encapsulation.
Interface view
IPv6 NetStream collects statistics for outgoing IPsec packets on an interface either before or after IPsec encapsulation.
For NetStream to collects statistics for outgoing IPsec packets on an interface, you must enable NetStream in the outbound direction of the interface.
# Enable IPv6 NetStream to collect statistics for outgoing IPsec packets before IPsec encapsulation on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 netstream ipsec raw-packet
ipv6 netstream max-entry
Use ipv6 netstream max-entry to set the upper limit for IPv6 NetStream entries or specify the processing method when the upper limit is reached.
Use undo ipv6 netstream max-entry to restore the default.
ipv6 netstream max-entry { max-entries | aging | disable-caching }
A maximum of 10000 IPv6 NetStream entries can be cached.
max-entries: Specifies the upper limit for IPv6 NetStream entries that the cache can accommodate. The value range for this argument is 1000 to 100000.
aging: Ages out the oldest entries when the upper limit is reached.
disable-caching: Disables creation of a new entry when the upper limit is reached.
The max-entries argument takes effect on each IRF member device.
If you execute the ipv6 netstream max-entry max-entries command multiple times, the most recent configuration takes effect.
If you execute the ipv6 netstream max-entry { aging | disable-caching } command multiple times, the most recent configuration takes effect.
# Set the upper limit to 5000 for IPv6 NetStream entries.
[Sysname] ipv6 netstream max-entry 5000
# Disable creation of a new entry when the upper limit is reached.
[Sysname] ipv6 netstream max-entry disable-caching
# Configure the device to age out the oldest entries when the upper limit is reached.
[Sysname] ipv6 netstream max-entry aging
ipv6 netstream outbound srv6-policy
Use ipv6 netstream outbound srv6-policy to enable IPv6 NetStream for an SRv6 TE policy.
Use undo ipv6 netstream outbound srv6-policy to disable IPv6 NetStream for an SRv6 TE policy.
ipv6 netstream outbound srv6-policy end-point ipv6 ipv6-address color color-value
undo ipv6 netstream outbound srv6-policy end-point ipv6 ipv6-address color color-value
Hardware
Yes
No
No
MSR1004S-5G
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
IPv6 NetStream is disabled for an SRv6 TE policy.
end-point ipv6 ipv6-address: Specifies the IPv6 address of the destination node for an SRv6 TE policy.
color color-value: Specifies the color for an SRv6 TE policy, in the range of 0 to 4294967295.
Execute this command on the ingress node for an SRv6 TE policy to enable IPv6 NetStream to collect statistics about the outgoing traffic forwarded based on that SRv6 TE policy. For more information about SRv6 TE policies, see Segment Routing Configuration Guide.
# Enable IPv6 NetStream for the SRv6 TE policy whose destination node is at 1000::1 and color is 10.
[Sysname] ipv6 netstream outbound srv6-policy endpoint ipv6 1000::1 color 10
ipv6 netstream sampler
Use ipv6 netstream sampler to enable IPv6 NetStream sampling.
Use undo ipv6 netstream sampler to disable IPv6 NetStream sampling.
ipv6 netstream [ inbound | outbound ] sampler sampler-name
undo ipv6 netstream [ inbound | outbound ] sampler
IPv6 NetStream sampling is disabled.
Interface view
inbound: Enables IPv6 NetStream sampling in the inbound direction.
outbound: Enables IPv6 NetStream sampling in the outbound direction.
sampler sampler-name: Specifies a sampler by its name. The name is a case-insensitive string of 1 to 31 characters.
By default, IPv6 NetStream collects all data of target flows. If the flow traffic is heavy, IPv6 NetStream is resource-consuming and can cause high CPU usage, which impacts the device forwarding performance. IPv6 NetStream sampling is helpful to decrease the NetStream traffic volume. If the collected statistics can basically reflect the network status, you can enable this feature and set a proper sampling rate. The higher the sampling rate, the less impact on device performance.
If you configure this command without specifying a traffic direction, IPv6 NetStream sampling is enabled on the interface for both inbound and outbound traffic.
# Use sampler abc for inbound IPv6 NetStream sampling on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 netstream inbound sampler abc
ipv6 netstream timeout active
Use ipv6 netstream timeout active to set the aging timer for active flows.
Use undo ipv6 netstream timeout active to restore the default.
ipv6 netstream timeout active minutes
By default, the aging timer for active flows is 30 minutes.
minutes: Sets the aging timer for active flows, in the range of 1 to 60 minutes.
A flow is considered active if packets for the IPv6 NetStream entry arrive before the timer set by this command expires.
# Set the aging timer to 4 minutes for active flows.
[Sysname] ipv6 netstream timeout active 4
ipv6 netstream timeout inactive
Use ipv6 netstream timeout inactive to set the aging timer for inactive flows.
Use undo ipv6 netstream timeout inactive to restore the default.
ipv6 netstream timeout inactive seconds
By default, the aging timer for inactive flows is 30 seconds.
seconds: Sets the aging timer for inactive flows, in the range of 10 to 600 seconds.
A flow is considered inactive if no packet for the IPv6 NetStream entry arrives before the timer set by this command expires.
# Set the aging timer to 60 seconds for inactive flows.
[Sysname] ipv6 netstream timeout inactive 60
Use reset ipv6 netstream statistics to age out all flows in the cache and export IPv6 NetStream data.
Usage guide
It takes the system several minutes to execute the command. During this period, the system does not collect IPv6 NetStream data.
# Age out and export all IPv6 NetStream data.
<Sysname> reset ipv6 netstream statistics
This process may take a few minutes.
NetStream statistic function is disabled during this process.
