17-Network Management and Monitoring Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R6728-6W10017-Network Management and Monitoring Command Reference
15-Mirroring commands
15-Mirroring commands 117.92 KB
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
group-id: Specifies a mirroring group by its ID.
The following compatibility matrixes show the value ranges for the mirroring group ID:
Hardware
Value range
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
1 to 6
MSR810-LMS, MSR810-LUS
1 to 6
MSR810-LMS-EA, MSR810-LME
1 to 6
MSR1004S-5G
1 to 6
MSR2600-6-X1, MSR2600-10-X1, MSR2600-15-X1
1 to 6
MSR 2630
1 to 6
MSR3600-28, MSR3600-51
1 to 6
MSR3600-28-SI, MSR3600-51-SI
1 to 6
1 to 6
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
1 to 6
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
1 to 6
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
1 to 6
MSR3610-G, MSR3620-G
1 to 6
MSR3640-X1-HI
1 to 4
Hardware
Value range
MSR810-W-WiNet, MSR810-LM-WiNet
1 to 6
MSR830-4LM-WiNet
1 to 6
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
1 to 6
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
1 to 6
MSR2600-10-X1-WiNet
1 to 6
MSR2630-WiNet
1 to 6
MSR3600-28-WiNet
1 to 6
MSR3610-X1-WiNet
1 to 6
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
1 to 6
Hardware
Value range
MSR2630-XS
1 to 6
MSR3600-28-XS
1 to 6
MSR3610-XS
1 to 6
MSR3620-XS
1 to 6
MSR3610-I-XS
1 to 6
MSR3610-IE-XS
1 to 6
MSR3620-X1-XS
1 to 6
MSR3640-XS
1 to 6
MSR3660-XS
1 to 4
Hardware
Value range
MSR810-LM-GL
1 to 6
MSR810-W-LM-GL
1 to 6
MSR830-6EI-GL
1 to 6
MSR830-10EI-GL
1 to 6
MSR830-6HI-GL
1 to 6
MSR830-10HI-GL
1 to 6
MSR1004S-5G-GL
1 to 6
MSR2600-6-X1-GL
1 to 6
MSR3600-28-SI-GL
1 to 6
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        GigabitEthernet1/0/1  Inbound
    Monitor port: GigabitEthernet1/0/2
Mirroring group
ID of the mirroring group.
Type of the mirroring group:
Local.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Mirroring port
Source port.
Monitor port
Destination port.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
group-id: Specifies a mirroring group ID.The value range for this argument varies by device model. For more information, see the group-id argument for the display mirroring-group command.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
Hardware
Value range
1 to 6
1 to 6
1 to 6
MSR1004S-5G
1 to 6
1 to 6
MSR 2630
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
MSR3640-X1-HI
1 to 4
Hardware
Value range
1 to 6
MSR830-4LM-WiNet
1 to 6
1 to 6
1 to 6
MSR2600-10-X1-WiNet
1 to 6
MSR2630-WiNet
1 to 6
MSR3600-28-WiNet
1 to 6
MSR3610-X1-WiNet
1 to 6
1 to 6
Hardware
Value range
MSR2630-XS
1 to 6
MSR3600-28-XS
1 to 6
MSR3610-XS
1 to 6
MSR3620-XS
1 to 6
MSR3610-I-XS
1 to 6
MSR3610-IE-XS
1 to 6
MSR3620-X1-XS
1 to 6
MSR3640-XS
1 to 6
MSR3660-XS
1 to 4
Hardware
Value range
MSR810-LM-GL
1 to 6
MSR810-W-LM-GL
1 to 6
MSR830-6EI-GL
1 to 6
MSR830-10EI-GL
1 to 6
MSR830-6HI-GL
1 to 6
MSR830-10HI-GL
1 to 6
MSR1004S-5G-GL
1 to 6
MSR2600-6-X1-GL
1 to 6
MSR3600-28-SI-GL
1 to 6
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
A source port cannot be used as a monitor port.
If you configure a software forwarding interface as a source port for a mirroring group, the following rules apply:
·     If the software forwarding interface operates in Layer 2 mode, the inbound and outbound IPv4 traffic, IPv6 traffic, and MPLS traffic of the interface will be mirrored.
·     If the software forwarding interface operates in Layer 3 mode, the inbound and outbound IPv4 traffic, IPv6 traffic, and MPLS traffic of the interface will be mirrored. Make sure the interface has an IP address.
A software forwarding interface is an Ethernet interface. You can use the port link-mode command to change the link mode of an Ethernet interface. For more information, see Ethernet interface configuration in Interface Configuration Guide.
Whether a hardware forwarding interface can be configured as a source port for a mirroring group depends on the device model.
# Create local mirroring group 1 to monitor the bidirectional traffic of port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
Hardware
Value range
1 to 6
1 to 6
1 to 6
MSR1004S-5G
1 to 6
1 to 6
MSR 2630
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
MSR3640-X1-HI
1 to 4
Hardware
Value range
1 to 6
MSR830-4LM-WiNet
1 to 6
1 to 6
1 to 6
MSR2600-10-X1-WiNet
1 to 6
MSR2630-WiNet
1 to 6
MSR3600-28-WiNet
1 to 6
MSR3610-X1-WiNet
1 to 6
1 to 6
Hardware
Value range
MSR2630-XS
1 to 6
MSR3600-28-XS
1 to 6
MSR3610-XS
1 to 6
MSR3620-XS
1 to 6
MSR3610-I-XS
1 to 6
MSR3610-IE-XS
1 to 6
MSR3620-X1-XS
1 to 6
MSR3640-XS
1 to 6
MSR3660-XS
1 to 4
Hardware
Value range
MSR810-LM-GL
1 to 6
MSR810-W-LM-GL
1 to 6
MSR830-6EI-GL
1 to 6
MSR830-10EI-GL
1 to 6
MSR830-6HI-GL
1 to 6
MSR830-10HI-GL
1 to 6
MSR1004S-5G-GL
1 to 6
MSR2600-6-X1-GL
1 to 6
MSR3600-28-SI-GL
1 to 6
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
A port can act as a source port for only one mirroring group.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 1/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
Hardware
Value range
1 to 6
1 to 6
1 to 6
MSR1004S-5G
1 to 6
1 to 6
MSR 2630
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
MSR3640-X1-HI
1 to 4
Hardware
Value range
1 to 6
MSR830-4LM-WiNet
1 to 6
1 to 6
1 to 6
MSR2600-10-X1-WiNet
1 to 6
MSR2630-WiNet
1 to 6
MSR3600-28-WiNet
1 to 6
MSR3610-X1-WiNet
1 to 6
1 to 6
Hardware
Value range
MSR2630-XS
1 to 6
MSR3600-28-XS
1 to 6
MSR3610-XS
1 to 6
MSR3620-XS
1 to 6
MSR3610-I-XS
1 to 6
MSR3610-IE-XS
1 to 6
MSR3620-X1-XS
1 to 6
MSR3640-XS
1 to 6
MSR3660-XS
1 to 4
Hardware
Value range
MSR810-LM-GL
1 to 6
MSR810-W-LM-GL
1 to 6
MSR830-6EI-GL
1 to 6
MSR830-10EI-GL
1 to 6
MSR830-6HI-GL
1 to 6
MSR830-10HI-GL
1 to 6
MSR1004S-5G-GL
1 to 6
MSR2600-6-X1-GL
1 to 6
MSR3600-28-SI-GL
1 to 6
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
# Create local mirroring group 1 and configure GigabitEthernet 1/0/1 as its monitor port.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 monitor-port
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Hardware
Value range
1 to 6
1 to 6
1 to 6
MSR1004S-5G
1 to 6
1 to 6
MSR 2630
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
1 to 6
MSR3640-X1-HI
1 to 4
Hardware
Value range
1 to 6
MSR830-4LM-WiNet
1 to 6
1 to 6
1 to 6
MSR2600-10-X1-WiNet
1 to 6
MSR2630-WiNet
1 to 6
MSR3600-28-WiNet
1 to 6
MSR3610-X1-WiNet
1 to 6
1 to 6
Hardware
Value range
MSR2630-XS
1 to 6
MSR3600-28-XS
1 to 6
MSR3610-XS
1 to 6
MSR3620-XS
1 to 6
MSR3610-I-XS
1 to 6
MSR3610-IE-XS
1 to 6
MSR3620-X1-XS
1 to 6
MSR3640-XS
1 to 6
MSR3660-XS
1 to 4
Hardware
Value range
MSR810-LM-GL
1 to 6
MSR810-W-LM-GL
1 to 6
MSR830-6EI-GL
1 to 6
MSR830-10EI-GL
1 to 6
MSR830-6HI-GL
1 to 6
MSR830-10HI-GL
1 to 6
MSR1004S-5G-GL
1 to 6
MSR2600-6-X1-GL
1 to 6
MSR3600-28-SI-GL
1 to 6
Do not enable the spanning tree feature on the monitor port of a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
mirroring-group
Flow mirroring commands
Flow mirroring does not support mirroring traffic to Layer 3 Ethernet interfaces.
The following compatibility matrixes show the support of hardware platforms for flow mirroring:
Hardware
Flow mirroring compatibility
Yes
Yes
Yes
MSR1004S-5G
Yes
Yes
MSR 2630
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
MSR2600-6-WiNet , MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR1004S-5G-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
Syntax 1:
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
Syntax 2:
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address } [ erspan-id erspan-id-value | dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address }
The following matrixes show support of hardware platforms for syntax 2:
Models
Compatibility
No
No
No
MSR1004S-5G
No
No
MSR 2630
No
No
No
No
No
No
Yes
No
Models
Compatibility
No
MSR830-4LM-WiNet
No
No
No
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
Yes
Models
Compatibility
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
Models
Compatibility
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
No mirroring actions exist to mirror traffic to interfaces.
Traffic behavior view
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
erspan-id erspan-id-value: Specifies the ERSPAN ID for the mirrored packets in the range of 1 to 1023.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 2.
Table 2 DSCP keywords and values
Keyword
DSCP value in binary
DSCP value in decimal
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
vlan vlan-id: Specifies the VLAN ID for the mirrored packets in the range of 1 to 4094.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
destination-mac mac-address: Specifies the destination MAC address for mirrored packets sent to the interface. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to dynamically get the destination MAC address for the mirrored packets.
You can mirror traffic to only one interface. If you execute this command for a traffic behavior multiple times, the most recent configuration takes effect.
To mirror traffic to the specified interface, use syntax 1.
To mirror traffic to interfaces based on routes matching the specified destination IP address, use syntax 2. When receiving packets that meet the flow mirroring criteria, the device performs the following tasks:
1.     Encapsulates the packets based on the configured encapsulation parameters, including the source and destination IP addresses.
2.     Searches the routing table for routes matching the configured destination IP address.
3.     If ECMP load-balancing is configured, multiple matching ECMP routes might be found for the specified destination IP address.
4.     Sends the mirrored packets out of the output interfaces in the matching routes to the final destination.
5.     If a selected output interface goes down, the device will send the mirrored packets out of another interface based on the routing metric recalculations.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0/1 for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1
# Create traffic behavior 1, and configure the action of mirroring traffic to GigabitEthernet 1/0/1 for the traffic behavior. Specify the following parameters for the mirrored packets sent to GigabitEthernet 1/0/1:
·     Specify 1.1.1.1 and 2.2.2.2 as the destination address and source address, respectively.
·     Specify 20, 100, and vrf1 as the DSCP value, VLAN, and the VPN instance name, respectively.
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
