11-ACL and QoS Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R6728-6W10011-ACL and QoS Command Reference
04-FR QoS commands
04-FR QoS commands 95.71 KB
FR QoS commands
The following compatibility matrixes show the support of hardware platforms for FR QoS:
Hardware
FR QoS compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
No
MSR810-LMS, MSR810-LUS
Yes
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G
No
MSR2600-6-X1, MSR2600-10-X1, MSR2600-15-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
MSR3640-X1-HI
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
cir allow
Use cir allow to set the CIR ALLOW for an FR class.
Use undo cir allow to delete the CIR ALLOW setting of an FR class.
cir allow [ inbound | outbound ] committed-information-rate
undo cir allow [ inbound | outbound ]
The CIR ALLOW of an FR class is 56000 bps.
FR class view
inbound: Sets the CIR ALLOW for incoming packets. The inbound CBS ALLOW takes effect only for FRTP.
outbound: Sets the CIR ALLOW for outgoing packets. The outbound CBS ALLOW takes effect only for FRTS.
committed-information-rate: Specifies the CIR ALLOW in bps.The value range for this argument is 1000 to 45000000.
The outbound CIR ALLOW must be greater than or equal to the CIR.
If you do not specify the inbound or outbound keyword, the set CIR ALLOW takes effect on both incoming and outgoing packets.
# Set the CIR ALLOW to 64000 bps for FR class test1.
[Sysname] fr class test1
[Sysname-fr-class-test1] cir allow 64000
display fr class-map
Use display fr class-map to display the associations between FR classes and interfaces (including subinterfaces and PVCs).
display fr class-map [ fr-class class-name | interface interface-type interface-number ]
fr-class class-name: Specifies an FR class by its name, a case-sensitive string of 1 to 30 characters.
interface interface-type interface-number: Specifies an interface (main interface or subinterface) by its type and number. If you specify a main interface, the command displays the associations between the following elements:
·     The FR class and the main interface.
·     The FR classes and the subinterfaces on the main interface.
·     The FR classes and the PVCs on the main interface.
·     The FR classes and the PVCs on each subinterface.
If you specify a subinterface, the command displays the associations between the following elements:
·     The FR class and the subinterface.
·     The FR classes and the PVCs on the subinterface.
If you do not specify an FR class or an interface, the command displays all associations between FR classes and interfaces.
# Display the associations between Serial 2/1/1 and FR classes.
<Sysname> display fr class-map interface serial 2/1/1
Serial2/1/1
  fr-class ts1
  fr dlci 100
    fr-class ts
Serial2/1/1.1
  fr-class ts2
  fr dlci 222
    fr-class ts
# Display the associations between FR class ts and interfaces.
<Sysname> display fr class-map fr-class ts
Serial2/1/1
  fr dlci 100
    fr-class ts
Serial2/1/1.1
  fr dlci 222
    fr-class ts
Serial2/1/1
  fr-class ts1
FR interface and the FR class associated with the FR interface.
fr dlci 100
  fr-class ts
PVC on the FR interface and the FR class associated with the PVC.
Serial2/1/1.1
  fr-class ts2
FR subinterface and the FR class associated with the FR subinterface.
fr dlci 222
  fr-class ts
PVC on the FR subinterface and the FR class associated with the PVC.
ebs
Use ebs to set the EBS for an FR class.
Use undo ebs to delete the EBS setting of an FR class.
ebs [ inbound | outbound ] excess-burst-size
undo ebs [ inbound | outbound ]
The EBS for an FR class is 0 bits.
FR class view
inbound: Sets the EBS for incoming packets. The inbound EBS takes effect only for FRTP.
outbound: Sets the EBS for outgoing packets. The outbound EBS takes effect only for FRTS.
excess-burst-size: Specifies the EBS in the range of 0 to 16000000 bits.
If you do not specify the inbound or outbound keyword, the set EBS takes effect on both incoming and outgoing packets.
# Set the EBS to 32000 bits for FR class test1.
[Sysname-fr-class-test1] ebs 32000
cbs
cir
cir allow
fifo queue-length
Use fifo queue-length to set the FIFO queue length for an FR class.
Use undo fifo queue-length to restore the default.
fifo queue-length queue-length
The FIFO queue length for an FR class is 75.
FR class view
queue-length: Specifies the maximum number of packets allowed in the FIFO queue, in the range of 1 to 1024.
# Set the FIFO queue length to 80 for FR class test1.
[Sysname-fr-class-test1] fifo queue-length 80
fr class
Use fr class to create an FR class and enter its view, or enter the view of an existing FR class.
Use undo fr class to delete an FR class.
fr class class-name
undo fr class class-name
No FR classes exist.
class-name: Specifies the name of the FR class, a case-sensitive string of 1 to 30 characters.
For the FR class parameters to take effect, associate the FR class with an interface or PVC and enable FR QoS on the interface.
When an FR class is deleted, all associations between this FR class and interfaces are released.
# Create an FR class named test1.
fr-class
fr de del
Use fr de del to apply a DE rule list to an FR PVC.
Use undo fr de del to remove a DE rule list from an FR PVC.
fr de del list-number dlci dlci-number
undo fr de del list-number dlci dlci-number
No DE rule list is applied to an FR PVC.
FR interface view
MFR interface view
list-number: Specifies a DE rule list by its number in the range of 1 to 10.
dlci-number: Specifies a FR PVC by its number in the range of 16 to 1007.
If you specify a PVC of a subinterface on the main interface, the DE rule list can be successfully applied to the specified PVC.
After a DE rule list is applied to an FR PVC, the DE bits of packets matching the DE rule list are set to 1.
# Apply DE rule list 3 to DLCI 100 of Serial 2/1/1.
[Sysname] interface Serial 2/1/1
[Sysname-Serial2/1/1] fr dlci 100
[Sysname-Serial2/1/1-fr-dlci-100] quit
[Sysname-Serial2/1/1] fr de del 3 dlci 100
[Sysname-Serial2/0] fr de del 3 dlci 100
fr del inbound-interface
fr del protocol
Use fr del inbound-interface to create a DE rule list and add an interface-based DE rule.
Use undo fr del inbound-interface to delete an interface-based DE rule from a DE rule list.
fr del list-number inbound-interface interface-type interface-number
undo fr del list-number inbound-interface interface-type interface-number
No DE rule lists exist.
list-number: Specifies a DE rule list number in the range of 1 to 10.
This command sets the DE bits of packets that are received on the specified interface to 1.
You can add a maximum of 100 rules for a DE rule list.
When the last DE rule in a DE rule list is deleted, the DE rule list is also deleted.
# Add a rule to DE rule list 1. The rule sets the DE bits of incoming packets on Serial 2/1/1 to 1.
[Sysname] fr del 1 inbound-interface serial 2/1/1
fr de del
fr del protocol
fr del protocol
Use fr del protocol ip to create a DE rule list and add an IP protocol-based DE rule.
Use undo fr del protocol ip to delete an IP protocol-based DE rule from a DE rule list.
fr del list-number protocol ip [ acl acl-number | fragments | greater-than min-number | less-than max-number | tcp-port tcpport-number | udp-port udpport-number ]
undo fr del list-number protocol ip [ fragments | acl acl-number | less-than bytes | greater-than min-number | less-than max-number | tcp-port tcpport-number | udp-port udpport-number ]
acl acl-number: Specifies the IP packets matching the ACL specified by its number in the range of 2000 to 3999.
fragments: Specifies all fragmented IP packets.
greater-than min-number: Specifies the IP packets that are greater than the specified number of bytes. The value range for the min-number argument is 0 to 65535.
less-than max-number: Specifies the IP packets that smaller than the specified number of bytes. The value range for the max-number argument is 0 to 65535.
tcp-port tcpport-number: Specifies the IP packets with the specified source or destination TCP port number. The value range for the tcpport-number argument is 0 to 65535. The tcpport-number argument can be either an upper-layer application name or the associated port number.
Table 2 Application names and TCP port numbers
Application name
TCP port number
bgp
179
chargen
19
cmd
514
daytime
13
discard
9
domain
53
echo
7
exec
512
finger
79
ftp
21
ftp-data
20
gopher
70
hostname
101
ident
113
irc
194
klogin
543
kshell
544
login
513
lpd
515
nntp
119
pop2
109
pop3
110
smtp
25
sunrpc
111
tacacs
49
talk
517
telnet
23
time
37
uucp
540
whois
43
www
80
udp-port udpport-number: Specifies the IP packets with the specified source or destination UDP port number. The value range for the udpport-number argument is 0 to 65535. The udpport-number argument can be either an upper-layer application name or the associated port number.
Table 3 Application names and UDP port numbers
Application name
UDP port number
biff
512
bootpc
68
bootps
67
discard
9
dnsix
195
domain
53
echo
7
mobile-ip
434
nameserver
42
netbios-dgm
138
netbios-ns
137
ntp
123
rip
520
snmp
161
snmptrap
162
sunrpc
111
syslog
514
tacacs
49
talk
517
tftp
69
time
37
who
513
xdmcp
177
If you do not specify any parameters, this command applies to all IP packets.
To add more IP-protocol-based DE rules to a DE rule list, repeat this command. A DE rule list can contain both interface-based DE rules and IP-protocol-based DE rules.
# Add a rule to DE rule list 1 that sets the DE bits of all IP packets to 1.
[Sysname] fr del 1 protocol ip
fr de del
fr traffic-policing
Use fr traffic-policing to enable FRTP.
Use undo fr traffic-policing to disable FRTP.
fr traffic-policing
FRTP is disabled.
FR interface view
MFR interface view
FRTP is applicable only to the ingress interfaces on the DCE of an FR network.
# Enable FRTP on Serial 2/1/1.
[Sysname-Serial2/1/1] fr traffic-policing
fr class
fr traffic-shaping
Use fr traffic-shaping to enable FRTS.
Use undo fr traffic-shaping to disable FRTS.
fr traffic-shaping
FRTS is disabled.
FR interface view
FRTS is applied to the outgoing interfaces and is typically used on the DTEs of an FR network.
FRTS cannot be enabled on an FR interface when fragmentation is enabled on the interface.
# Enable FRTS on Serial 2/1/1.
[Sysname] interface serial 2/1/1
[Sysname-Serial2/1/1] fr traffic-shaping
fragment enable
Use fragment enable to enable end-to-end FRF.12 fragmentation for an FR class.
Use undo fragment enable to disable end-to-end FRF.12 fragmentation for an FR class.
fragment enable
End-to-end FRF.12 fragmentation is disabled for an FR class.
FR class view
This command enables end-to-end FRF.12 fragmentation on all PVCs associated with an FR class or PVCs of all interfaces associated with an FR class.
# Enable Frame Relay FRF.12 fragmentation for FR class test1.
[Sysname-fr-class-test1] fragment enable
fragment size
Use fragment size to set the fragment size allowed for an FR class.
Use undo fragment size to restore the default.
fragment size size
undo fragment size
The fragment size allowed for an FR class is 45 bytes.
FR class view
size: Specifies the fragment size in the range 16 to 1600 bytes.
# Set the fragment size to 128 bytes for FR class test1.
[Sysname-fr-class-test1] fragment size 128
fr-class
Use fr-class to associate an FR class with an FR interface or FR PVC.
Use undo fr-class to cancel the association.
fr-class class-name
undo fr-class class-name
An FR class is not associated with any FR interface or FR PVC.
FR interface (main interface or subinterface) view
FR PVC view
class-name: Specifies an FR class by its name, a case-sensitive string of 1 to 30 characters. The FR class must already exist.
For an interface associated with an FR class, all PVCs on the interface inherit the FR QoS parameters in the FR class.
# Associate FR class test1 with an FR PVC with DLCI 200.
[Sysname-Serial2/1/1] fr dlci 200
[Sysname-Serial2/1/1-fr-dlci-200] fr-class test1
fr class
traffic-shaping adaptation
Use traffic-shaping adaptation to enable FRTS adaptation for an FR class.
Use undo traffic-shaping adaptation to disable FRTS adaptation for an FR class.
traffic-shaping adaptation { becn | interface-congestion number }
undo traffic-shaping adaptation { becn | interface-congestion }
FRTS adaptation is disabled for an FR class.
FR class view
becn: Adjusts the traffic rate in response to BECNs.
interface-congestion number: Adjusts the traffic rate in response to the number of packets in the output queue on the interface. The value range for the number argument is 1 to 40.
For BECN-based adaptation, the router reduces the transmission rates of all FRTS-enabled PVCs associated with the FR class when it receives packets with the BECN bit set. When the router does not receive packets with the BECN bit set within 125 milliseconds, it increases the transmission rates of those PVCs.
For interface congestion-based adaptation, the router reduces the transmission rates of all FRTS-enabled PVCs associated with the FR class when the number of packets in the output queue reaches the threshold. When the number of packets drops below the threshold, the router increases the transmission rates of those PVCs.
# Enable FRTS adaptation to adjust the traffic rate in response to BECNs.
[Sysname-fr-class-test1] traffic-shaping adaptation becn
fr traffic-shaping
traffic-shaping adaptation percentage
Use traffic-shaping adaptation percentage to set the rate adjustment percentage for FRTS adaptation.
Use undo traffic-shaping adaptation percentage to restore the default.
traffic-shaping adaptation percentage number
The rate adjustment percentage for FRTS adaptation is 25%.
FR class view
number: Specifies the rate adjustment percentage, in the range of 1 to 30.
When rate adjustment is triggered, the router reduces or increases the traffic rate by the set percentage of the current rate. The adjusted rate must be between the CIR and the CIR ALLOW. For example, the current rate is 3000 bps, the rate adjustment percentage is 20%, and the CIR is 2500 bps. The rate is  reduced to 2400 bps (3000 – 3000 x 20%). Because the adjusted rate cannot be lower than the CIR, the adjusted rate should be 2500 bps.
# Set the rate adjustment percentage to 20%.
[Sysname-fr-class-test1] traffic-shaping adaptation percentage 20
fr traffic-shaping
