01-ACL commands | 277.23 KB |
display packet-filter statistics
display packet-filter statistics sum
packet-filter (Ethernet service instance view)
packet-filter (interface view)
reset packet-filter statistics
ACL commands
acl
Use acl to create an ACL and enter its view, or enter the view of an existing ACL.
Use undo acl to delete the specified or all ACLs.
Command for creating an IPv4, or Layer 2 ACL by specifying a number:
acl { name acl-name | number acl-number [ name acl-name ] [ match-order { auto | config } ] }
undo acl { all | name acl-name | number acl-number }
Command for creating an IPv6 ACL by specifying a number:
acl ipv6 { name acl-name | number acl-number [ name acl-name ] [ match-order { auto | config } ] }
undo acl ipv6 { all | name acl-name | number acl-number }
Commands for creating ACLs by specifying the related keywords:
· Command for creating an IPv4 ACL by specifying the advanced or basic keyword:
acl { advanced | basic } { acl-number | name acl-name } [ match-order { auto | config } ]
undo acl { all | { advanced | basic } { acl-number | name acl-name } }
· Command for creating an IPv6 ACL by specifying the advanced or basic keyword:
acl ipv6 { advanced | basic } { acl-number | name acl-name } [ match-order { auto | config } ]
undo acl ipv6 { all | { advanced | basic } { acl-number | name acl-name } }
· Command for creating a Layer 2 ACL by specifying the mac keyword:
acl mac { acl-number | name acl-name } [ match-order { auto | config } ]
undo acl mac { all | acl-number | name acl-name }
No ACLs exist.
ipv6: Specifies the IPv6 ACL type. To specify the IPv4 ACL type, do not use this keyword.
basic: Specifies the basic ACL type.
advanced: Specifies the advanced ACL type.
mac: Specifies the Layer 2 ACL type.
number acl-number: Assigns a number to the ACL. The following are available value ranges:
· 2000 to 2999 for basic ACLs.
· 3000 to 3999 for advanced ACLs.
· 4000 to 4999 for Layer 2 ACLs.
name acl-name: Assigns a name to the ACL. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
match-order: Specifies the order in which ACL rules are compared against packets.
auto: Compares ACL rules in depth-first order.
config: Compares ACL rules in ascending order of rule ID. The rule with a smaller ID has a higher priority. If you do not specify a match order, the config order applies by default.
all: Specifies all ACLs of the specified type.
If you create a numbered ACL, you can enter the view of the ACL by using either of the following commands:
· The acl [ ipv6 ] number acl-number command.
· The acl { [ ipv6 ] { advanced | basic } | mac } acl-number command.
If you create a ACL by using the acl [ ipv6 ] number acl-number name acl-name command, you can enter the view of the ACL by using either of the following commands:
· acl [ ipv6 ] name acl-name (for only basic ACLs and advanced ACLs).
· acl [ ipv6 ] number acl-number [ name acl-name ].
· acl { [ ipv6 ] { advanced | basic } | mac } name acl-name.
If you create a named ACL by using the acl { [ ipv6 ] { advanced | basic } | mac } name acl-name command, you can enter the view of the ACL by using either of the following commands:
You can change the match order only for ACLs that do not contain any rules.
# Create IPv4 basic ACL 2000 and enter its view.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000]
# Create IPv4 basic ACL flow and enter its view.
[Sysname] acl basic name flow
[Sysname-acl-ipv4-basic-flow]
# Create IPv4 advanced ACL 3000 and enter its view.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000]
# Create IPv6 basic ACL 2000 and enter its view.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000]
# Create IPv6 basic ACL flow and enter its view.
[Sysname] acl ipv6 basic name flow
[Sysname-acl-ipv6-basic-flow]
# Create IPv6 advanced ACL abc and enter its view.
[Sysname] acl ipv6 advanced name abc
[Sysname-acl-ipv6-adv-abc]
# Create Layer 2 ACL 4000 and enter its view.
[Sysname] acl mac 4000
[Sysname-acl-mac-4000]
# Create Layer 2 ACL flow and enter its view.
[Sysname] acl mac name flow
[Sysname-acl-mac-flow]
display acl
acl copy
Use acl copy to create an ACL by copying an ACL that already exists.
acl [ ipv6 | mac ] copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
source-acl-number: Specifies an existing source ACL by its number. The following are available value ranges:
name source-acl-name: Specifies an existing source ACL by its name. The source-acl-name argument is a case-insensitive string of 1 to 63 characters.
dest-acl-number: Assigns a unique number to the new ACL. The following are available value ranges:
name dest-acl-name: Assigns a unique name to the new ACL. The dest-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
The new ACL and the source ACL must be the same type.
When specifying an ACL by its number, follow these rules:
· To specify an IPv6 ACL, you must specify both its ACL number and the ipv6 keyword.
· To specify a Layer 2 ACL, you can specify its ACL number without the mac keyword.
To specify an IPv6 ACL or Layer 2 ACL by a name, you must specify both the ACL name and the ipv6 or mac keyword.
The new ACL has the same properties and content as the source ACL, but uses a different number or name from the source ACL.
# Create IPv4 basic ACL 2002 by copying IPv4 basic ACL 2001.
[Sysname] acl copy 2001 to 2002
# Create IPv4 basic ACL paste by copying IPv4 basic ACL test.
[Sysname] acl copy name test to name paste
acl logging interval
Use acl logging interval to enable logging for packet filtering and set the interval.
Use undo acl logging interval to restore the default.
acl logging interval interval
The interval is 0. The device does not generate log entries for packet filtering.
interval: Specifies the interval at which log entries are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable the logging, set the value to 0.
The logging feature is available for IPv4 or IPv6 ACL rules that have the logging keyword.
You can configure the ACL module to generate log entries for packet filtering and output them to the information center at the output interval. The log entry records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a log entry for this packet. When the output interval ends, the device outputs a log entry for subsequent matching packets of the flow. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering log entries every 10 minutes.
[Sysname] acl logging interval 10
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
acl trap interval
Use acl trap interval to enable SNMP notifications for packet filtering and set the interval.
Use undo acl interval to restore the default.
acl trap interval interval
undo acl trap interval
The interval is 0. The device does not generate SNMP notifications for packet filtering.
interval: Specifies the interval at which SNMP notifications are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable SNMP notifications, set the value to 0.
The SNMP notifications feature is available for IPv4 or IPv6 ACL rules that have the logging keyword.
You can configure the ACL module to generate SNMP notifications for packet filtering and output them to the SNMP module at the output interval. The notification records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a notification for this packet. When the output interval ends, the device outputs a notification for subsequent matching packets of the flow. For more information about SNMP, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering SNMP notifications every 10 minutes.
[Sysname] acl trap interval 10
description
Use description to configure a description for an ACL.
Use undo description to delete an ACL description.
An ACL does not have a description.
IPv4 basic/advanced ACL view
IPv6 basic/advanced ACL view
Layer 2 ACL view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure a description for IPv4 basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] description This is an IPv4 basic ACL.
display acl
display acl
Use display acl to display ACL configuration and match statistics.
display acl [ ipv6 | mac ] { acl-number | all | name acl-name }
acl-number: Specifies an ACL by its number. The following are available value ranges:
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
This command displays ACL rules in config or auto order, whichever is configured.
To specify the IPv4 ACL type, do not specify the ipv6 or mac keyword.
# Display configuration and match statistics for IPv4 basic ACL 2001.
<Sysname> display acl 2001
Basic IPv4 ACL 2001, 1 rule, match-order is auto,
ACL's step is 5, start ID is 0
rule 5 permit source 1.1.1.1 0
rule 5 comment This rule is used on Ten-GigabitEthernet1/0/1.
Basic IPv4 ACL 2001 |
Type and number of the ACL. The following field information is about IPv4 basic ACL 2001. |
1 rule |
The ACL contains one rule. |
match-order is auto |
The match order for the ACL is auto, which sorts ACL rules in depth-first order. This field is not displayed when the match order is config. |
This is an IPv4 basic ACL. |
Description of the ACL. |
ACL's step is 5 |
The rule numbering step is 5. |
start ID is 0 |
The start rule ID is 0. |
rule 5 permit source 1.1.1.1 0 |
Content of rule 5. The rule permits packets sourced from the IP address 1.1.1.1. |
rule 5 comment This rule is used on Ten-GigabitEthernet1/0/1. |
Comment of rule 5. |
Use display packet-filter to display ACL application information for packet filtering.
display packet-filter { interface [ interface-type interface-number ] | l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] } [ inbound | outbound ] [ slot slot-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays ACL application information for packet filtering on all interfaces. If you specify an Ethernet interface, you do not need to specify the slot slot-number option.
l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ]: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument represents the interface type and number. The instance-id argument represents the ID of the Ethernet service instance, in the range of 1 to 4096. If you do not specify an interface, this command displays ACL application information for all Ethernet service instances on all interfaces. If you specify an interface but do not specify an Ethernet service instance, this command displays ACL application information for all Ethernet service instances on the specified interface.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ACL application information for packet filtering for the master device.
If neither the inbound keyword nor the outbound keyword is specified, this command displays ACL application information for packet filtering in both directions.
# Display ACL application information for inbound packet filtering on interface Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter interface ten-gigabitethernet 1/0/1 inbound
Inbound policy:
IPv4 ACL 2001r
IPv6 ACL 2002 (Failed)
MAC ACL 4003
# Display ACL application information for inbound packet filtering on Ethernet service instance 1 of Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet1/0/1 Service Instance ID: 1
Inbound policy:
IPv4 ACL 2001
MAC ACL 4003, Hardware-count (Failed)
Interface to which the ACL applies. |
Interface: Ten-GigabitEthernet1/0/1 Service Instance ID: 1 |
Ethernet service instance to which the ACL applies. Ten-GigabitEthernet1/0/1 is the interface where the Ethernet service instance resides. |
Inbound policy |
ACL used for filtering incoming traffic. |
Outbound policy |
ACL used for filtering outgoing traffic. |
IPv4 ACL 2001 |
IPv4 basic ACL 2001 has been successfully applied. |
IPv6 ACL 2002 (Failed) |
The device has failed to apply IPv6 basic ACL 2002. |
Hardware-count |
ACL rule match counting in hardware has been successfully enabled. |
Hardware-count (Failed) |
The device has failed to enable counting ACL rule matches in hardware. |
IPv4 default action |
Packet filter default action for packets that do not match any IPv4 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions. · Permit—The default action permit has been successfully applied for packet filtering. |
IPv6 default action |
Packet filter default action for packets that do not match any IPv6 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions. · Permit—The default action permit has been successfully applied for packet filtering. |
MAC default action |
Packet filter default action for packets that do not match any Layer 2 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Deny (Failed)—The device has failed to apply the default action deny for packet filtering. The action permit still functions. · Permit—The default action permit has been successfully applied for packet filtering. |
Use display packet-filter statistics to display packet filtering statistics.
display packet-filter statistics { interface interface-type interface-number | l2vpn-ac interface interface-type interface-number service-instance instance-id } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ brief ]
l2vpn-ac interface interface-type interface-number service-instance instance-id: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument represents the interface type and number. The instance-id argument represents the ID of the Ethernet service instance, in the range of 1 to 4096.
brief: Displays brief statistics.
If you do not specify any parameters, this command displays packet filtering statistics for all ACLs.
# Display packet filtering statistics for all ACLs on incoming packets of Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter statistics interface ten-gigabitethernet 1/0/1 inbound
Inbound policy:
IPv4 ACL 2001, Hardware-count
From 2011-06-04 10:25:21 to 2011-06-04 10:35:57
rule 0 permit source 2.2.2.2 0 (2 packets)
rule 5 permit source 1.1.1.1 0 (Failed)
rule 10 permit vpn-instance test (No resource)
Totally 2 packets permitted, 0 packets denied
Totally 100% permitted, 0% denied
IPv6 ACL 2000
MAC ACL 4000
rule 0 permit
# Display packet filtering statistics for all ACLs on incoming packets on Ethernet service instance 1 of Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter statistics l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Inbound policy:
MAC ACL 4000
From 2011-06-04 10:25:34 to 2011-06-04 10:35:57
rule 0 permit
IPv6 ACL 2000
Inbound policy |
Outbound policy |
IPv4 ACL 2001 |
IPv4 ACL 2002 (Failed) |
The device has failed to apply IPv4 basic ACL 2002. |
Hardware-count |
From 2011-06-04 10:25:21 to 2011-06-04 10:35:57 |
Start time and end time of the statistics. The start time is the time when the packet filter was deployed to the member device. |
2 packets |
Two packets matched the rule. This field is not displayed when no packets matched the rule. |
No resource |
Resources are not enough for counting matches for the rule. In packet filtering statistics, this field is displayed for a rule when resources are not sufficient for rule match counting. |
rule 5 permit source 1.1.1.1 0 (Failed) |
The device has failed to apply rule 5. |
Totally 2 packets permitted, 0 packets denied |
Number of packets permitted and denied by the ACL. |
Totally 100% permitted, 0% denied |
Ratios of permitted and denied packets to all packets. |
Use display packet-filter statistics sum to display accumulated packet filtering statistics for an ACL.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac ] { acl-number | name acl-name } [ brief ]
# Display accumulated packet filtering statistics for IPv4 basic ACL 2001 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2001
Sum:
Inbound policy:
IPv4 ACL 2001
# Display brief accumulated packet filtering statistics for IPv4 basic ACL 2000 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2000 brief
Sum:
Inbound policy:
IPv4 ACL 2000
Sum |
Accumulated packet filtering statistics. |
Inbound policy |
Accumulated packet filtering statistics in the inbound direction. |
Outbound policy |
Accumulated packet filtering statistics in the outbound direction. |
IPv4 ACL 2001 |
Accumulated packet filtering statistics of IPv4 basic ACL 2001. |
2 packets |
display packet-filter verbose
Use display packet-filter verbose to display ACL application details for packet filtering.
display packet-filter verbose { interface interface-type interface-number | l2vpn-ac interface interface-type interface-number service-instance instance-id } { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ] [ slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. The slot slot-number option is not available for an Ethernet interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ACL application details for packet filtering for the master device.
If acl-number, name acl-name, ipv6 or mac is not specified, this command displays application details of all ACLs for packet filtering.
# Display application details of all ACLs for inbound packet filtering on Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter verbose interface ten-gigabitethernet 1/0/1 inbound
Inbound policy:
IPv4 ACL 2001
rule 0 permit
IPv6 ACL 2000
rule 0 permit
MAC ACL 4000
IPv4 default action: Deny
MAC default action: Deny
# Display application details of all ACLs for inbound packet filtering on Ethernet service instance 1 of Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-filter verbose l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Inbound policy:
IPv4 ACL 2001
rule 0 permit
rule 10 permit vpn-instance test (Failed)
IPv6 ACL 2000
rule 0 permit
MAC ACL 4000
IPv6 default action: Deny
Table 5 Command output
Inbound policy |
Outbound policy |
IPv4 ACL 2001 |
Hardware-count |
display qos-acl resource
Use display qos-acl resource to display QoS and ACL resource usage.
display qos-acl resource [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS and ACL resource usage for all member devices.
This command does not display any usage data if the specified device does not support counting QoS and ACL resources.
The total number of QoS and ACL resources varies by operating mode. You can use the switch-mode command to set the operating mode and the display qos-acl resource command to display the total number of QoS and ACL resources. For more information about the switch-mode command, see device management commands in Fundamentals Command Reference.
# Display QoS and ACL resource usage.
<Sysname> display qos-acl resource
Interfaces: XGE1/0/1 to XGE1/0/48, HGE1/0/49
HGE1/0/50 (slot 1)
Type Total Reserved Configured Remaining Usage
TTI ACL 3072 0 2 3070 0%
IPCL0 ACL 768 9 0 759 1%
IPCL1 ACL 256 0 0 256 0%
IPCL2 ACL 256 30 0 226 11%
IPCL Counter 4096 35 0 4061 0%
EPCL ACL 256 0 0 256 0%
EPCL Counter 1024 0 0 1024 0%
IPCL Meter 4888 0 0 4888 0%
EPCL Meter 4096 0 0 4096 0%
Table 6 Command output
Interfaces |
Interface range for the resources. |
Type |
Resource type: · TTI ACL—ACL resources used for tunnel termination and interfaces. · IPCL ACL—ACL resources used for inbound policies. · IPCL Counter—Accounting resources used for inbound policies. · EPCL ACL—ACL resources used for outbound policies. · EPCL Counter—Accounting resources used for outbound policies. · IPCL Meter—Traffic policing resources used in inbound QoS policies. · EPCL Meter—Traffic policing resources used in outbound QoS policies. |
Total |
Total number of resources. |
Reserved |
Number of reserved resources. |
Configured |
Number of resources that has been applied. |
Remaining |
Number of resources that you can apply. |
Usage |
Configured and reserved resources as a percentage of total resources. If the percentage is not an integer, this field displays the integer part. For example, if the actual usage is 50.8%, this field displays 50%. |
Use packet-filter to apply an ACL to an Ethernet service instance to filter packets.
Use undo packet-filter to remove an ACL from an Ethernet service instance.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ]
undo packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound }
No ACL is applied to an Ethernet service instance to filter packets.
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
hardware-count: Enables counting ACL rule matches performed in hardware. If you do not specify this keyword, rule matches for the ACL are not counted in hardware.
For information about configuring Ethernet service instances, see MPLS L2VPN or VPLS in MPLS Configuration Guide or see VXLAN Configuration Guide.
If you use the acl-number argument to specify an ACL, follow these guidelines:
· To specify an IPv4 ACL, use the acl-number argument directly.
· To specify an IPv6 ACL, specify the ipv6 keyword, and then the acl-number argument.
· To specify a Layer 2 ACL, the mac keyword is not a must. You can either specify the mac keyword and then the acl-number argument or specify only the acl-number argument.
If you use the name acl-name option to specify an ACL, follow these guidelines:
· To specify an IPv4 ACL, use the name acl-name option.
· To specify an IPv6 or Layer 2 ACL, specify the related keyword and then the name acl-name option.
For an ACL applied to an Ethernet service instance, if the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public network and private network packets.
The hardware-count keyword in this command enables match counting in hardware for all rules in an ACL, and the counting keyword in the rule command enables match counting specific to rules.
To disable ACL rule match counting in hardware when resources are insufficient, you must execute the undo packet-filter command, and then reconfigure the packet-filter command without specifying the hardware-count keyword.
To disable ACL rule match counting in hardware when resources are sufficient, you can directly reconfigure the packet-filter command without specifying the hardware-count keyword.
# Apply IPv4 advanced ACL 3001 to filter incoming traffic on Ethernet service instance 1 of Ten-GigabitEthernet 1/0/1, and enable counting ACL rule matches performed in hardware.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] packet-filter 3001 inbound hardware-count
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
No ACL is applied to an interface to filter packets.
VLAN interface view
VSI interface view
For an ACL applied to an interface, if the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public network and private network packets.
To disable ACL rule match counting in hardware when resources are insufficient, you must execute the undo packet-filter command and then reconfigure the packet-filter command without specifying the hardware-count keyword.
To the same direction of an interface, you can apply a maximum of three ACLs: one IPv4 ACL, one IPv6 ACL, and one Layer 2 ACL.
The packet filtering configured on a VLAN interface filters only packets forwarded at Layer 3.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on Ten-GigabitEthernet 1/0/1, and enable counting ACL rule matches performed in hardware.
[Sysname-Ten-GigabitEthernet1/0/1] packet-filter 2001 inbound hardware-count
packet-filter default deny
Use packet-filter default deny to set the packet filtering default action to deny. The packet filter denies packets that do not match any ACL rule.
Use undo packet-filter default deny to restore the default.
The packet filtering default action is permit. The packet filter permits packets that do not match any ACL rule.
The packet filter applies the default action to all ACL applications for packet filtering. The default action appears in the display command output for packet filtering.
# Set the packet filter default action to deny.
[Sysname] packet-filter default deny
packet-filter filter
Use packet-filter filter to specify the applicable scope of packet filtering on a VLAN interface.
Use undo packet-filter filter to restore the default.
packet-filter filter { route | all }
The packet filtering filters packets forwarded at Layer 3.
VLAN interface view
route: Filters packets forwarded at Layer 3 by the VLAN interface.
all: Filters all packets, including packets forwarded at Layer 3 by the VLAN interface and packets forwarded at Layer 2 by the physical ports associated with the VLAN interface.
# Configure the packet filtering on VLAN-interface 2 to filter packets forwarded at Layer 3.
[Sysname-Vlan-interface2] packet-filter filter route
reset acl counter
Use reset acl counter to clear statistics for ACLs.
reset acl [ ipv6 | mac ] counter { acl-number | all | name acl-name }
all: Clears statistics for all ACLs of the specified type.
name acl-name: Clears statistics of an ACL specified by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
To specify an IPv6 ACL or Layer 2 ACL ACL by a name, you must specify both the ACL name and the ipv6 or mac keyword.
# Clear statistics for IPv4 basic ACL 2001.
display acl
Use reset packet-filter statistics to clear the packet filtering statistics.
reset packet-filter statistics { interface [ interface-type interface-number ] | l2vpn-ac [ interface interface-type interface-number service-instance instance-id ] } { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet filtering statistics for all interfaces.
l2vpn-ac [ interface interface-type interface-number service-instance instance-id ]: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument represents the interface type and number. The instance-id argument represents the ID of the Ethernet service instance, in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command clears packet filtering statistics for all Ethernet service instances.
If acl-number, name acl-name, ipv6 or macis not specified, this command clears the packet filtering statistics for all ACLs.
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering on Ten-GigabitEthernet 1/0/1.
<Sysname> reset packet-filter statistics interface ten-gigabitethernet 1/0/1 inbound 2001
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering on Ethernet service instance 1 of Ten-GigabitEthernet 1/0/1.
<Sysname> reset packet-filter statistics interface ten-gigabitethernet 1/0/1 service-instance 1 inbound 2001
Use rule to create or edit an IPv4 advanced ACL rule.
Use undo rule to delete an entire IPv4 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { microsegment microsegment-id [ mask-length mask-length ] | dest-address dest-wildcard | any } | destination-port operator port1 [ port2 ] | { dscp dscp | { precedence precedence | tos tos } * } | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | [ flow-logging | logging ] | source { microsegment microsegment-id [ mask-length mask-length ] | source-address source-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | { dscp | { precedence | tos } * | fragment | icmp-type | [ flow-logging | logging ] | source | source-port | time-range | vpn-instance ] *
undo rule { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { microsegment microsegment-id [ mask-length mask-length ] | dest-address dest-wildcard | any } | destination-port operator port1 [ port2 ] | { dscp dscp | { precedence precedence | tos tos } * | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | [ flow-logging | logging ] | source { microsegment microsegment-id [ mask-length mask-length ] | source-address source-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-range-name | vpn-instance vpn-instance-name ] *
No IPv4 advanced ACL rules exist.
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from the start rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the rule is numbered 30.
deny: Denies matching packets.
permit: Allows matching packets to pass.
protocol: Specifies a protocol carried over IPv4 by its number in the range of 0 to 255 or by its keyword, as shown in Table 7.
Table 7 Protocols carried over IPv4
Number |
Keyword |
N/A |
ip |
Matches IPv4 packets. |
1 |
icmp |
Matches ICMP packets. |
2 |
igmp |
Matches IGMP packets. |
4 |
ipinip |
Matches IP-in-IP packets. |
6 |
tcp |
Matches TCP packets. |
17 |
udp |
Matches UDP packets. |
47 |
gre |
Matches GRE packets. For information about GRE, see Layer 3—IP Services Configuration Guide. |
89 |
ospf |
Matches OSPF packets. |
Table 8 describes the parameters that you can specify, regardless of the value for the protocol argument.
Table 8 Match criteria and other rule information for IPv4 advanced ACL rules
Parameters |
Function |
Specifies a source address. |
(Only the S5560X-HI and S6520X-HI switch series support the microsegment parameter.) The microsegment-id argument specifies a source microsegment ID in the range of 0 to 65535. Microsegment 0 is a system-defined microsegment, and it is insignificant. The mask-length mask-length option specifies a mask length for an aggregate microsegment. The value range for the mask-length argument is 1 to the number of contiguous 0s of the decimal number converted from the aggregate microsegment ID. If a mask length is specified, the microsegment-id argument must be an even number other than 0. For more information about microsegments, see Security Configuration Guide. The source-address source-wildcard arguments specify a source IP address and a wildcard mask in dotted decimal notation. An all-zero wildcard represents a host address. The any keyword specifies any source IP address. |
destination { microsegment microsegment-id [ mask-length mask-length ] | |
Specifies a destination address. |
(Only the S5560X-HI and S6520X-HI switch series support the microsegment parameter.) The microsegment-id argument specifies a destination microsegment ID in the range of 0 to 65535. Microsegment 0 is a system-defined microsegment, and it is insignificant. The mask-length mask-length option specifies a mask length for an aggregate microsegment. The value range for the mask-length argument is 1 to the number of contiguous 0s of the decimal number converted from the aggregate microsegment ID. For more information about microsegments, see Security Configuration Guide. The dest-address dest-wildcard arguments specify a destination IP address and a wildcard mask in dotted decimal notation. An all-zero wildcard mask represents a host address. The any keyword represents any destination IP address. |
counting |
Enables rule match counting in software. |
The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter command enables match counting in hardware for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted in software. |
Specifies an IP precedence value. |
The precedence argument can be a number in the range of 0 to 7, or in words: routine (0), priority (1), immediate (2), flash (3), flash-override (4), critical (5), internet (6), or network (7). |
tos tos |
Specifies a ToS preference. |
The tos argument can be a number in the range of 0 to 15, or in words: max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0). |
dscp dscp |
Specifies a DSCP priority. |
The dscp argument can be a number in the range of 0 to 63, or in words: af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46). |
fragment |
Applies the rule only to fragments. |
If you do not specify this keyword, the rule applies to all fragments and non-fragments. |
flow-logging |
Logs matching packets on a per-flow basis. The log information includes the number of matching packets, and the source IP address, destination IP address, source port number, and destination port number of the matching flow. |
This feature requires that the module (for example, packet filtering) that uses the ACL supports logging. |
logging |
Logs the number of matching packets. |
Specifies a time range for the rule. |
The time-range-name argument is a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule. However, the rule using the time range can take effect only after you configure the time range. For more information about time range, see ACL and QoS Configuration Guide. |
vpn-instance vpn-instance-name |
Applies the rule to an MPLS L3VPN instance. |
The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. For an ACL used to filter packets, if you do not specify a VPN instance, the rule applies to both non-VPN packets and VPN packets. For an ACL used by other features, if you do not specify a VPN instance, the implementation varies by feature. For more information, see the configuration guide of the feature. |
If the protocol argument is tcp (6) or udp (17), set the parameters shown in Table 9.
Table 9 TCP/UDP-specific parameters for IPv4 advanced ACL rules
Parameters |
Function |
Specifies one or more UDP or TCP source ports. |
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range). The port1 and port2 arguments are TCP or UDP port numbers in the range of 0 to 65535. The port2 argument is needed only when the operator argument is range. TCP port numbers can be represented as: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), dns (53), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80). UDP port numbers can be represented as: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177). |
Specifies one or more UDP or TCP destination ports. |
Specifies one or more TCP flags including ACK, FIN, PSH, RST, SYN, and URG. |
Parameters specific to TCP. The value for each argument can be 0 (flag bit not set) or 1 (flag bit set). The TCP flags in a rule are ANDed. For example, a rule configured with ack 0 psh 1 matches packets that have the ACK flag bit not set and the PSH flag bit set. |
established |
Specifies the flags for indicating the established status of a TCP connection. |
Parameter specific to TCP. The rule matches TCP connection packets with the ACK or RST flag bit set. |
If the protocol argument is icmp (1), set the parameters shown in Table 10.
Table 10 ICMP-specific parameters for IPv4 advanced ACL rules
Parameters |
Function |
icmp-type { icmp-type icmp-code | icmp-message } |
Specifies the ICMP message type and code. |
The icmp-type argument is in the range of 0 to 255. The icmp-code argument is in the range of 0 to 255. The icmp-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 11. |
Table 11 ICMP message names supported in IPv4 advanced ACL rules
ICMP message name |
ICMP message type |
ICMP message code |
echo |
8 |
0 |
echo-reply |
0 |
0 |
fragmentneed-DFset |
3 |
4 |
host-redirect |
5 |
1 |
host-tos-redirect |
5 |
3 |
host-unreachable |
3 |
1 |
information-reply |
16 |
0 |
information-request |
15 |
0 |
net-redirect |
5 |
0 |
net-tos-redirect |
5 |
2 |
net-unreachable |
3 |
0 |
parameter-problem |
12 |
0 |
port-unreachable |
3 |
3 |
protocol-unreachable |
3 |
2 |
reassembly-timeout |
11 |
1 |
source-quench |
4 |
0 |
source-route-failed |
3 |
5 |
timestamp-reply |
14 |
0 |
timestamp-request |
13 |
0 |
ttl-exceeded |
11 |
0 |
Within an ACL, the permit or deny statement of each rule must be unique. If the rule you are creating or editing has the same deny or permit statement as another rule in the ACL, the rule will not be created or changed.
You can edit ACL rules only when the match order is config.
If an IPv4 advanced ACL is used for QoS traffic classification or packet filtering in a VXLAN network, the ACL matches packets as follows:
· On a VTEP, the ACL can only match the incoming packets of Ethernet service instances.
· On an intermediate transport device, the ACL can match both incoming packets and outgoing packets.
To view the existing IPv4 basic and advanced ACL rules, use the display acl all command.
The undo rule rule-id command without any optional parameters deletes an entire rule. If you specify optional parameters, the undo rule rule-id command deletes the specified attributes for the rule.
The undo rule { deny | permit } command can only be used to delete an entire rule. You must specify all the attributes of the rule for the command.
# Create an IPv4 advanced ACL rule to permit TCP packets with the destination port 80 from 129.9.0.0/16 to 202.38.160.0/24.
[Sysname-acl-ipv4-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
# Create IPv4 advanced ACL rules to permit all IP packets but the ICMP packets destined for 192.168.1.0/24.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule deny icmp destination 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] rule permit ip
# Create IPv4 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl advanced 3002
[Sysname-acl-ipv4-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl-ipv4-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl-ipv4-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl-ipv4-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv4 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl advanced 3003
[Sysname-acl-ipv4-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl-ipv4-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl-ipv4-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl-ipv4-adv-3003] rule permit udp destination-port eq snmptrap
# Create an IPv4 advanced ACL rule to permit the IP packets with its source IP address as a member of microsegment 1 and its destination IP address as a member of microsegment 2.
[Sysname] acl advanced 3005
[Sysname-acl-adv-3005] rule permit ip source microsegment 1 destination microsegment 2
acl
display acl
microsegment (Security Command Reference)
microsegment aggregation (Security Command Reference)
step
time-range
Use rule to create or edit an IPv4 basic ACL rule.
Use undo rule to delete an entire IPv4 basic ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | [ flow-logging | logging ] | source { source-address source-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ counting | fragment | [ flow-logging | logging ] | source | time-range | vpn-instance ] *
undo rule { deny | permit } [ counting | fragment | [ flow-logging | logging ] | source { source-address source-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
No IPv4 basic ACL rules exist.
IPv4 basic ACL view
counting: Enables rule match counting in software. If you do not specify this keyword, matches for the rule are not counted in software.
fragment: Applies the rule only to fragments. If you do not specify this keyword, the rule applies to both fragments and non-fragments.
flow-logging: Logs matching packets on a per-flow basis. The log information includes the number of matching packets, and the source IP address, destination IP address, source port number, and destination port number of the matching flow. This feature is available only when the module (for example, packet filtering) that uses the ACL supports the logging feature.
logging: Logs the number of matching packets. This feature is available only when the application module (for example, packet filtering) that uses the ACL supports the logging feature.
source { source-address source-wildcard | any }: Matches a source address. The source-address and source-wildcard arguments specify a source IP address and a wildcard mask in dotted decimal notation. A wildcard mask of zeros represents a host address. The any keyword represents any source IP address.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument is a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule. However, the rule using the time range can take effect only after you configure the time range. For more information about time range, see ACL and QoS Configuration Guide.
vpn-instance vpn-instance-name: Applies the rule to an MPLS L3VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. For an ACL used to filter packets, if you do not specify a VPN instance, the rule applies to both non-VPN packets and VPN packets. For an ACL used by other features, if you do not specify a VPN instance, the implementation varies by feature. For more information, see the configuration guide of the feature.
If an IPv4 basic ACL is used for QoS traffic classification or packet filtering in a VXLAN network, the ACL matches packets as follows:
The counting keyword in this command enables match counting specific to rules, and the hardware-count keyword in the packet-filter command enables match counting in hardware for all rules in an ACL.
# Create a rule in IPv4 basic ACL 2000 to deny the packets from any source IP subnet but 10.0.0.0/8, 172.17.0.0/16, or 192.168.1.0/24.
[Sysname-acl-ipv4-basic-2000] rule permit source 10.0.0.0 0.255.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 172.17.0.0 0.0.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
acl
display acl
step
time-range
Use rule to create or edit an IPv6 advanced ACL rule.
Use undo rule to delete an entire IPv6 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { microsegment microsegment-id [ mask-length mask-length ] | dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port operator port | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | [ flow-logging | logging ] | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { microsegment microsegment-id [ mask-length mask-length ] | source-address source-prefix | source-address/source-prefix | any } | source-port operator port | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | dscp | flow-label | fragment | icmp6-type | [ flow-logging | logging ] | routing | hop-by-hop | source | source-port | time-range | vpn-instance ] *
undo rule { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { microsegment microsegment-id [ mask-length mask-length ] | dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port operator port | dscp dscp| flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | [ flow-logging | logging ] | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { microsegment microsegment-id [ mask-length mask-length ] | source-address source-prefix | source-address/source-prefix | any } | source-port operator port | time-range time-range-name | vpn-instance vpn-instance-name ] *
No IPv6 advanced ACL rules exist.
protocol: Specifies a protocol carried over IPv6 by its number in the range of 0 to 255 or by its keyword, as shown in Table 12.
Table 12 Protocols carried over IPv6
Number |
Keyword |
N/A |
ipv6 |
Matches IPv6 packets. |
1 |
icmpv6 |
Matches ICMPv6 packets. |
2 |
igmp |
4 |
ipinip |
6 |
tcp |
17 |
udp |
47 |
gre |
50 |
ipv6-esp |
Matches IPv6-ESP packets. |
51 |
ipv6-ah |
Matches IPv6-AH packets. |
89 |
ospf |
Table 13 describes the parameters that you can specify, regardless of the value for the protocol argument.
Table 13 Match criteria and other rule information for IPv6 advanced ACL rules
Parameters |
Function |
Specifies a source IPv6 address. |
(Only the S5560X-HI and S6520X-HI switch series support the microsegment parameter.) The microsegment-id argument specifies a source microsegment ID in the range of 0 to 65535. Microsegment 0 is a system-defined microsegment, and it is insignficant. The mask-length mask-length option specifies a mask length for an aggregate microsegment. The value range for the mask-length argument is 1 to the number of contiguous 0s of the decimal number converted from the aggregate microsegment ID. If a mask length is specified, the microsegment-id argument must be an even number other than 0. For more information about microsegments, see Security Configuration Guide. The source-address argument specifies an IPv6 source address. The source-prefix argument specifies a prefix length in the range of 1 to 128. The any keyword represents any IPv6 source address. |
Specifies a destination IPv6 address. |
(Only the S5560X-HI and S6520X-HI switch series support the microsegment parameter.) The microsegment-id argument specifies a source microsegment ID in the range of 0 to 65535. Microsegment 0 is a system-defined microsegment, and it is insignficant. The mask-length mask-length option specifies a mask length for an aggregate microsegment. The value range for the mask-length argument is 1 to the number of contiguous 0s of the decimal number converted from the aggregate microsegment ID. If a mask length is specified, the microsegment-id argument must be an even number other than 0. For more information about microsegments, see Security Configuration Guide. The dest-address argument specifies a destination IPv6 address. The dest-prefix argument specifies a prefix length in the range of 1 to 128. The any keyword represents any IPv6 destination address. |
counting |
The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter ipv6 command enables match counting in hardware for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted in software. |
dscp dscp |
Specifies a DSCP preference. |
The dscp argument can be a number in the range of 0 to 63, or in words, af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46). |
Specifies a flow label value in an IPv6 packet header. |
The flow-label-value argument is in the range of 0 to 1048575. |
fragment |
flow-logging |
logging |
Specifies an IPv6 routing header type. |
routing-type: Value of the IPv6 routing header type, in the range of 0 to 255. If you specify the type routing-type option, the rule applies to the specified type of IPv6 routing header. If you do not specify the type routing-type option, the rule applies to all types of IPv6 routing headers. |
Specifies an IPv6 Hop-by-Hop Options header type. |
hop-type: Value of the IPv6 Hop-by-Hop Options header type, in the range of 0 to 255. If you specify the type hop-type option, the rule applies to the specified type of IPv6 Hop-by-Hop Options header. If you do not specify the type hop-type option, the rule applies to all types of IPv6 Hop-by-Hop Options header. |
If the protocol argument is tcp (6) or udp (17), set the parameters shown in Table 14.
Table 14 TCP/UDP-specific parameters for IPv6 advanced ACL rules
Parameters |
Function |
The operator argument can be only eq (equal to).. The port argument specifies a TCP or UDP port number in the range of 0 to 65535. TCP port numbers can be represented as: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), dns (53), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80). UDP port numbers can be represented as: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177). |
Specifies one or more TCP flags, including ACK, FIN, PSH, RST, SYN, and URG. |
established |
Parameter specific to TCP. The rule matches TCP packets with the ACK or RST flag bit set. |
If the protocol argument is icmpv6 (58), set the parameters shown in Table 15.
Table 15 ICMPv6-specific parameters for IPv6 advanced ACL rules
Parameters |
Function |
Specifies the ICMPv6 message type and code. |
The icmp6-type argument is in the range of 0 to 255. The icmp6-code argument is in the range of 0 to 255. The icmp6-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 16. |
Table 16 ICMPv6 message names supported in IPv6 advanced ACL rules
ICMPv6 message name |
ICMPv6 message type |
ICMPv6 message code |
echo-reply |
129 |
0 |
echo-request |
128 |
0 |
err-Header-field |
4 |
0 |
frag-time-exceeded |
3 |
1 |
hop-limit-exceeded |
3 |
0 |
host-admin-prohib |
1 |
1 |
host-unreachable |
1 |
3 |
neighbor-advertisement |
136 |
0 |
neighbor-solicitation |
135 |
0 |
network-unreachable |
1 |
0 |
packet-too-big |
2 |
0 |
port-unreachable |
1 |
4 |
redirect |
137 |
0 |
router-advertisement |
134 |
0 |
router-solicitation |
133 |
0 |
unknown-ipv6-opt |
4 |
2 |
unknown-next-hdr |
4 |
1 |
If an IPv6 advanced ACL is used for QoS traffic classification or packet filtering:
· Do not specify the fragment keyword.
· Do not specify the routing, hop-by-hop, or flow-label keyword if the ACL is for outbound application.
To view the existing IPv6 basic and advanced ACL rules, use the display acl ipv6 all command.
The undo rule rule-id command without any optional parameters deletes an entire rule. If you specify optional parameters, the undo rule rule-id command deletes the specified attributes for a rule.
[Sysname-acl-ipv6-adv-3000] rule permit tcp source 2030:5060::/64 destination fe80:5060::/96 destination-port eq 80
# Create IPv6 advanced ACL rules to permit all IPv6 packets but the ICMPv6 packets destined for FE80:5060:1001::/48.
[Sysname] acl ipv6 advanced 3001
[Sysname-acl-ipv6-adv-3001] rule deny icmpv6 destination fe80:5060:1001:: 48
[Sysname-acl-ipv6-adv-3001] rule permit ipv6
# Create IPv6 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl ipv6 advanced 3002
[Sysname-acl-ipv6-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl-ipv6-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl-ipv6-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl-ipv6-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv6 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl ipv6 advanced 3003
[Sysname-acl-ipv6-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl-ipv6-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl-ipv6-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl-ipv6-adv-3003] rule permit udp destination-port eq snmptrap
# Create IPv6 advanced ACL 3004, and configure two rules: one permits packets with the Hop-by-Hop Options header type as 5, and the other one denies packets with other Hop-by-Hop Options header types.
[Sysname] acl ipv6 advanced 3004
[Sysname-acl-ipv6-adv-3004] rule permit ipv6 hop-by-hop type 5
[Sysname-acl-ipv6-adv-3004] rule deny ipv6 hop-by-hop
# Create an IPv6 advanced ACL rule to permit the IPv6 packets with its source IPv6 address as a member of microsegment 1 and its destination IPv6 address as a member of microsegment 2.
[Sysname] acl ipv6 advanced 3006
[Sysname-acl-ipv6-adv-3006] rule permit ipv6 source microsegment 1 destination microsegment 2
acl
display acl
step
time-range
Use rule to create or edit an IPv6 basic ACL rule.
Use undo rule to delete an entire IPv6 basic ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | [ flow-logging | logging ] | routing [ type routing-type ] | source { source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ counting | fragment | [ flow-logging | logging ] | routing | source | time-range | vpn-instance ] *
undo rule { deny | permit } [ counting | fragment | [ flow-logging | logging ] | routing [ type routing-type ] | source { source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
No IPv6 basic ACL rules exist.
IPv6 basic ACL view
routing [ type routing-type ]: Applies the rule to the specified type of IPv6 routing header or all types of IPv6 routing headers. The routing-type argument specifies the value of the IPv6 routing header type, in the range of 0 to 255. If you do not specify the type routing-type option, the rule applies to all types of IPv6 routing headers.
source { source-address source-prefix | source-address/source-prefix | any }: Matches a source IPv6 address. The source-address argument specifies a source IPv6 address. The source-prefix argument specifies an address prefix length in the range of 1 to 128. The any keyword represents any IPv6 source address.
The fragment keyword is not supported for a QoS policy or a packet filter.
The routing keyword is not supported for an outbound QoS policy or packet filter.
The counting keyword in this command enables match counting specific to rules, and the hardware-count keyword in the packet-filter ipv6 command enables match counting in hardware for all rules in an ACL.
# Create an IPv6 basic ACL rule to deny the packets from any source IP subnet but 1001::/16, 3124:1123::/32, or FE80:5060:1001::/48.
[Sysname-acl-ipv6-basic-2000] rule permit source 1001:: 16
[Sysname-acl-ipv6-basic-2000] rule permit source 3124:1123:: 32
[Sysname-acl-ipv6-basic-2000] rule permit source fe80:5060:1001:: 48
[Sysname-acl-ipv6-basic-2000] rule deny source any
acl
display acl
step
time-range
rule (Layer 2 ACL view)
Use rule to create or edit a Layer 2 ACL rule.
Use undo rule to delete an entire Layer 2 ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ cos dot1p | counting | dest-mac dest-address dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac source-address source-mask | time-range time-range-name ] *
undo rule rule-id [ counting | time-range ] *
undo rule { deny | permit } [ cos dot1p | counting | dest-mac dest-address dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac source-address source-mask | time-range time-range-name ] *
No Layer 2 ACL rules exist.
cos dot1p: Matches an 802.1p priority. The 802.1p priority can be specified by one of the following values:
· A priority number in the range of 0 to 7.
· A priority name: best-effort (0), background (1), spare (2), excellent-effort (3), controlled-load (4), video (5), voice (6), or network-management (7).
dest-mac dest-address dest-mask: Matches a destination MAC address range. The dest-address and dest-mask arguments represent a destination MAC address and mask in the H-H-H format.
lsap lsap-type lsap-type-mask: Matches the DSAP and SSAP fields in LLC encapsulation. The lsap-type argument is a hexadecimal number that represents the encapsulation format. The value range for the lsap-type argument is 0 to ffff. The lsap-type-mask argument is a hexadecimal number that represents the LSAP mask. The value range for the lsap-type-mask argument is 0 to ffff.
type protocol-type protocol-type-mask: Matches one or more protocols in the Layer 2. The protocol-type argument is a hexadecimal number that represents a protocol type in Ethernet_II and Ethernet_SNAP frames. The value range for the protocol-type argument is 0 to ffff. The protocol-type-mask argument is a hexadecimal number that represents a protocol type mask. The value range for the protocol-type-mask argument is 0 to ffff.
source-mac source-address source-mask: Matches a source MAC address range. The source-address argument represents a source MAC address, and the sour-mask argument represents a mask in the H-H-H format.
To view the existing Layer 2 ACL rules, use the display acl mac all command.
# Create a rule in Layer 2 ACL 4000 to permit ARP packets and deny RARP packets.
[Sysname-acl-mac-4000] rule permit type 0806 ffff
[Sysname-acl-mac-4000] rule deny type 8035 ffff
acl
display acl
step
time-range
rule comment
Use rule comment to configure a comment for an ACL rule.
Use undo rule comment to delete an ACL rule comment.
rule rule-id comment text
undo rule rule-id comment
A rule does not have a comment.
Layer 2 ACL view
rule-id: Specifies an ACL rule ID in the range of 0 to 65534. The ACL rule must already exist.
text: Specifies a comment about the ACL rule, a case-sensitive string of 1 to 127 characters.
This command adds a comment to a rule if the rule does not have a comment. It modifies the comment for a rule if the rule already has a comment.
# Create a rule for IPv4 basic ACL 2000, and add a comment about the rule.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-ipv4-basic-2000] rule 0 comment This rule is used on ten-gigabitethernet 1/0/1.
display acl
rule remark
Use rule remark to insert a remark for an ACL rule.
Use undo rule remark to delete ACL rule remarks.
rule [ rule-id ] remark text
undo rule [ rule-id ] remark [ text ]
An ACL rule does not have a remark.
Layer 2 ACL view
rule-id: Specifies an ACL rule ID in the range of 0 to 65534. The ACL rule can be an existing or nonexistent one. The rule ID determines the position where a remark is placed:
· For the config match order, if the rule ID is the same as an existing rule ID, the device inserts the remark before the existing rule. If the rule ID is a new rule ID, the device inserts the remark according to ascending order of rule IDs.
· For the auto match order, if the rule ID is the same as an existing rule ID, the device inserts the remark before the existing rule. If the rule ID is a new rule ID, the device inserts the remark at the end of the ACL rules.
text: Specifies a remark for the ACL rule, a case-sensitive string of 1 to 127 characters.
If you do not specify the rule-id argument in the rule remark command, the system automatically assigns a rule ID to the remark. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from 0.
If you do not specify the rule-id or text argument in the undo rule remark command, the system deletes all rule remarks. If you do not specify the rule-id argument but specify the text argument, the system deletes only the specified remark.
# Add remarks Rules for VIP_start and Rules for VIP_end for rule 10 and rule 25, respectively, to indicate that rule 10, rule 15, rule 20, and rule 25 are designed for VIP users.
[Sysname-acl-basic-2000] rule 10 remark Rules for VIP_start
[Sysname-acl-basic-2000] rule 26 remark Rules for VIP_end
[Sysname-acl-basic-2000] display this
acl number 2000
rule 0 permit source 14.1.1.0 0.0.0.255
rule 5 permit source 10.1.1.1 0 time-range work-time
rule 10 permit source 192.168.0.0 0.0.0.255
rule 15 permit source 1.1.1.1 0
rule 20 permit source 10.1.1.1 0
rule 25 permit counting
return
display acl
step
Use step to set a rule numbering step for an ACL.
Use undo step to restore the default.
step step-value [ start start-value ]
undo step
The rule numbering step is 5, and the start rule ID is 0.
Layer 2 ACL view
step-value: Specifies the ACL rule numbering step in the range of 1 to 20.
start start-value: Specifies the start rule ID in the range of 0 to 20.
The rule numbering step sets the increment by which the system numbers rules automatically. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from the start rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 12, the rule is numbered 15.
The wider the numbering step, the more rules you can insert between two rules. Whenever the step or start rule ID changes, the rules are renumbered, starting from the start rule ID. For example, if there are five rules numbered 0, 5, 9, 10, and 15, changing the step from 5 to 2 causes the rules to be renumbered 0, 2, 4, 6, and 8.
# Set the rule numbering step to 2 for IPv4 basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] step 2
display acl
