04-IP Source Guard (IPv6) Configuration Examples | 105.08 KB |
H3C Access Controllers |
Comware 7 IP Source Guard (IPv6) |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring IPv6 source guard (IPv6SG).
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IPv6SG and WLAN.
Example: Configuring IPv6SG
As shown in Figure 1, Client 1 supports stateful IPv6 address configuration and obtains an IPv6 address through the DHCPv6 server. Client 2 is assigned a static IPv6 address. Both of the clients access the same wireless network.
Enable IPv6SG to generate IPv6SG bindings based on DHCPv6 so that the AP forwards the packets only from Client 1.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IPv6 address to the VLAN interface. The AC will establish a CAPWAP tunnel with the AP in this VLAN.
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ipv6 address 2000:10::10/64
[AC-Vlan-interface100] quit
# Create VLAN 200. The AC will use this VLAN for client access.
[AC] vlan 200
[AC-vlan200] quit
# Configure GigabitEthernet 1/0/1 (port that connects the AC and the switch) as a trunk port, remove the port from VLAN 1, and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Set the PVID of GigabitEthernet 1/0/1 to VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure a wireless service:
# Create a service template named 1 and configure the SSID of the service template as service.
[AC] wlan service-template 1
[AC-wlan-st-1] ssid service
# Enable snooping DHCPv6 and ND packets on the service template.
[AC-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
[AC-wlan-st-1] client ipv6-snooping nd-learning enable
# Enable IPv6SG on the service template.
[AC-wlan-st-1] ipv6 verify source
# Enable the service template.
[AC-wlan-st-1] quit
3. Configure an AP:
# Create an AP named officeap with model WA4320i-CAN, and set its serial ID to 210235A1GQB147031200.
[AC] wlan ap officeap model WA4320i-ACN
[AC-wlan-ap-officeap] serial-id 210235A1GQB147031200
# Enter radio view of radio 1, and bind service template 1 to radio 1 and specify VLAN 100 for the service template.
[AC-wlan-ap-officeap] radio 1
[AC-wlan-ap-officeap-radio-1] service-template 1 vlan-id 200
# Enable radio 1.
[AC-wlan-ap-officeap-radio-1] radio enable
[AC-wlan-ap-officeap-radio-1] quit
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnel between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 (port that connects the switch and the AC) as a trunk port, and assign the trunk port to VLAN 100 and VLAN 200.
[Switch] interface GigabitEthernet1/0/1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 (port that connects the switch and the AP) as an access port, and assign the access port to VLAN 100.
[Switch] interface GigabitEthernet1/0/2
# Enable PoE on GigabitEthernet 1/0/2.
# Client 1 at MAC address 0024-d774-e6f4 comes online and obtains IPv6 address 2000:10::2/64 through DHCP. (Details not shown.)
# Client 2 at MAC address 0024-0130-696b comes online and obtains statically configured IPv6 address 2000:10::3/64. (Details not shown.)
# Verify that Client 1 can ping the host on the same subnet.
C:\Users\>ping -S 2000:10::2 2000:10::1
Pinging 2000:10::1 from 2000:10::2 with 32 bytes of data:
Reply from 2000:10::1 : time=22ms
Reply from 2000:10::1 : time=61ms
Reply from 2000:10::1 : time=32ms
Reply from 2000:10::1 : time=16ms
Ping statistics for 2000:10::1 :
Packets: Sent = 4,Received = 4,Lost = 0 (0% loss),
Minimum = 16ms,Maximum = 61ms,Average = 32ms
# Verify that Client 2 cannot ping the host.
C:\Users\>ping -S 2000:10::3 2000:10::1
Pinging 2000:10::1 from 2000:10::3 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2000: 10::1 :
Packets: Sent = 4,Received = 0,Lost = 4 (100% loss),
Configuration files
· AC:
vlan 100
vlan 200
wlan service-template 1 clear
ssid service
ipv6 verify source
interface Vlan-interface100
ip address 2000:10::10/64
radio 1
service-template 1 vlan 200
radio enable
radio 2
· Switch:
vlan 100
vlan 200
port link-mode bridge
port trunk permit vlan 1 100 200
poe enable
Related documentation
· Network Connectivity Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
· Security Command Reference in H3C Access Controllers Command References
· Security Configuration Guide in H3C Access Controllers Configuration Guides
· AP and WT Management Command Reference in H3C Access Controllers Command References
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
