07-Local forwarding
HomeSupportResource CenterH3C Access Controllers Configuration Examples(V7)-6W10207-Local forwarding
06-Policy-Based Local Forwarding Configuration Examples
Comware 7 Policy-Based Local Forwarding
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides a configuration example for configuring policy-based local forwarding.
This document applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access and OpenFlow.
Example: Configuring policy-based local forwarding
As shown in Figure 1, the AC acts as a DHCP server to assign IP addresses to the AP and client. Configure ACL to perform local forwarding for clients matching the specified ACL rule.
Figure 1 Network diagram
Procedures
1.     Configure VLANs:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. APs will use this IP address to establish CAPWAP tunnels with the AC.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.0.100 16
[AC-Vlan-interface100] quit
# Create VLAN 200.
[AC] vlan 200
[AC-vlan200] quit
2.     Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Create DHCP address pool vlan100, specify the subnet for dynamic allocation as 192.168.0.0/24, and specify the gateway address as 192.168.0.100.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 192.168.0.0 mask 255.255.255.0
[AC-dhcp-pool-vlan100] gateway-list 192.168.0.100
[AC-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200, specify the subnet for dynamic allocation as 192.168.1.0/24, and specify the gateway address as 192.168.1.100.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 192.168.1.0 mask 255.255.255.0
[AC-dhcp-pool-vlan200] gateway-list 192.168.1.100
[AC-dhcp-pool-vlan200] quit
3.     Configure policy-based forwarding:
# Create IPv4 basic ACL 2000, and configure an ACL rule to permit matching packets.
[AC] acl basic 2000
[AC-acl-ipv4-basic-2000] rule permit
[AC-acl-ipv4-basic-2000] quit
# Create forwarding policy policy1, and configure the forwarding policy to locally forward packets that match ACL 2000.
[AC] wlan forwarding-policy policy1
[AC-wlan-fp-policy1] classifier acl 2000 behavior local
[AC-wlan-fp-policy1] quit
# Create service template service1, and set the SSID to service1.
[AC] wlan service-template service1
[AC-wlan-st-service1] ssid service1
# Assign clients to join VLAN 200 after coming online through the service template.
[AC-wlan-st-service1] vlan 200
# Apply forwarding policy policy1 to the service template.
[AC-wlan-st-service1] client forwarding-policy-name policy1
# Enable policy-based forwarding.
[AC-wlan-st-service1] client forwarding-policy enable
# Enable the service template.
[AC-wlan-st-service1] service-template enable
[AC-wlan-st-service1] quit
4.     Configure a manual AP:
# Create AP ap1 and specify its serial ID.
[AC] wlan ap ap1 model WA4330-ACN
[AC-wlan-ap-ap1] serial-id 210235A1K6C157001609
# Bind service template service1 to radio 1 and enable radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service1
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
# Display connected controllers' flow entries and verify that the output interface is in Normal status, which indicates that the forwarding policy is issued to APs through OpenFlow.
 [AC] display openflow-controller flow-table
Datapath ID: 0x1005741f4acb9520
Table 0 information:
 total flow entry count: 0
Datapath ID: 0x1004741f4acb9520
Table 10 information:
Table 11 information:
Table 20 information:
Table 21 information:
Table 30 information:
Table 40 information:
 total flow entry count: 1
Flow entry information:
 cookie: 0x114047d000000001, priority: 65535, hard time: 0, idle time: 0,
 flags: flow_send_rem
Match information:
 Ethernet source MAC address: 64b0-a6c6-c25a
 Ethernet source MAC address mask: ffff-ffff-ffff
 Ethernet type: 0x0800
 Experimenter:
  In-BSSID: 741f-4acb-9520
Instruction information:
 Write actions:
  Output interface: Normal
Configuration files
 dhcp enable
vlan 100
vlan 200
 ssid service1
 vlan 200
interface Vlan-interface100
 ip address 192.168.0.100 255.255.255.0
acl basic 2000
 rule 0 permit
radio 1
  radio enable
Related documentation
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
