06-Wireless authentication
HomeSupportResource CenterH3C Access Controllers Configuration Examples(V7)-6W10206-Wireless authentication
Table of Contents
Related Documents
27-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
Comware 7 Remote 802.1X Authentication in WPA3-Enterprise Mode
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example of configuring remote 802.1X authentication in WPA3-Enterprise mode.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access, WLAN security, WLAN access authentication, and 802.1X features.
Example: Configuring remote 802.1X authentication in WPA3-Enterprise mode
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. The RADIUS server is an IMC server.
Configure the AC, the client, the switch, and the RADIUS server to meet the following requirements:
·     The AC uses the RADIUS server to perform authentication, authorization, and accounting for the wireless client. The 802.1X EAP-PEAP authentication method is used.
·     The AC uses the open system authentication for the client at the data link layer. This is the default authentication method at the data link layer.
·     The AC uses the 802.1X AKM mode to secure data transmission between the client and the AP.
·     The cipher suite is GCMP and the security mode is WPA3-Enterprise.
Figure 1 Network diagram
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1.     Configure interfaces:
# Create VLAN 100, create VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 10.1.1.46 24
[AC-Vlan-interface100] quit
# Create VLAN 200, create VLAN-interface 100, and assign an IP address to the VLAN interface. The AC assigns VLAN 200 to a client when the client comes online.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 10.1.2.1 24
[AC-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 (the interface connected to the switch) to trunk, permit traffic from VLAN 100 and VLAN 200 to pass through the interface, and set the PVID to 100.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2.     Configure a RADIUS scheme:
# Create RADIUS scheme radius1 and enter its view.
[AC] radius scheme radius1
# Specify the RADIUS server at 10.1.1.3 as the primary authentication and accounting servers.
[AC-radius-radius1] primary authentication 10.1.1.3
[AC-radius-radius1] primary accounting 10.1.1.3
# Set the shared key to 12345 in plaintext form for secure communication with the RADIUS authentication server.
[AC-radius-radius1] key authentication simple 12345
# Set the shared key to 12345 in plaintext form for secure communication with the RADIUS accounting server.
[AC-radius-radius1] key accounting simple 12345
# Specify IP address 10.1.2.1 as the source IP address for outgoing RADIUS packets.
[AC-radius-radius1] nas-ip 10.1.2.1
[AC-radius-radius1] quit
# Create ISP domain dom1 and enter its view.
[AC] domain dom1
# Configure the ISP domain to use RADIUS scheme radius1 for 802.1X user authentication, authorization, and accounting.
[AC-isp-dom1] authentication lan-access radius-scheme radius1
[AC-isp-dom1] authorization lan-access radius-scheme radius1
[AC-isp-dom1] accounting lan-access radius-scheme radius1
[AC-isp-dom1] quit
3.     Specify EAP relay as the method to exchange packets with the RADIUS server.
[AC] dot1x authentication-method eap
4.     Configure a service template:
# Create service template wpa3_enterprise and enter its view.
[AC] wlan service-template wpa3_enterprise
# Set the SSID to wpa3.
[AC-wlan-st-wpa3_enterprise] ssid wpa3
# Specify VLAN 200 for the service template.
[AC-wlan-st-wpa3_enterprise] vlan 200
# Set the AKM mode to 802.1X.
[AC-wlan-st-wpa3_enterprise] akm mode dot1x
# Specify the GCMP cipher suite and enable the RSN IE in beacon and probe responses. Support for the GCMP cipher suite depends on the AP model.
[AC-wlan-st-wpa3_enterprise] cipher-suite gcmp
[AC-wlan-st-wpa3_enterprise] security-ie rsn
# Set the access authentication mode to 802.1X authentication.
[AC-wlan-st-wpa3_enterprise] client-security authentication-mode dot1x
# Specify ISP domain dom1 for authenticating the 802.1X client.
[AC-wlan-st-wpa3_enterprise] dot1x domain dom1
# Set the WPA3 security mode to WPA3-Enterprise.
[AC-wlan-st-wpa3_enterprise] wpa3 enterprise
# Enable management frame protection in mandatory mode.
[AC-wlan-st-wpa3_enterprise] pmf mandatory
# Enable the service template.
[AC-wlan-st-wpa3_enterprise] service-template enable
[AC-wlan-st-wpa3_enterprise] quit
5.     Configure an AP:
# Create manual AP office and specify the AP model and serial ID.
[AC] wlan ap office model WA6638
[AC-wlan-ap-office] serial-id 219801A24F8198E00012
# Enter the view of radio 1.
[AC-wlan-ap-office] radio 1
# Bind service template wpa3_enterprise to radio 1 and enable the radio.
[AC-wlan-ap-office-radio-1] service-template wpa3_enterprise
[AC-wlan-ap-office-radio-1] radio enable
[AC-wlan-ap-office-radio-1] quit
[AC-wlan-ap-office] quit
Configuring the switch
# Create VLAN 100 and VLAN 200, create VLAN-interface 100 and VLAN-interface 200, and assign IP addresses to the VLAN interfaces. VLAN 100 is used to forward CAPWAP tunnel traffic between the AC and AP. VLAN 200 is used to forward wireless client packet.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 10.1.1.47 24
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 10.1.2.2 24
[Switch-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 (the interface connected to the AC), permit traffic from VLAN 100 and VLAN 200 to pass through the interface, and set the PVID to 100.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Set the link type of GigabitEthernet 1/0/2 (the interface connected to the AP) to access, and permit traffic from VLAN 100 to pass through the interface.
# Enable PoE on GigabitEthernet 1/0/2.
2.     Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named 100, and specify subnet 10.1.1.0/24 and gateway IP address 10.1.1.47 in the DHCP address pool.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 10.1.1.0 mask 255.255.255.0
[Switch-dhcp-pool-100] gateway-list 10.1.1.47
[Switch-dhcp-pool-100] quit
# Create a DHCP address pool named 200, and specify subnet 10.1.2.0/24 and gateway IP address 10.1.2.2 in the DHCP address pool. In this example, the address of the DNS server is 10.1.2.2 (the gateway address). You must replace it with the actual address of the DNS server on your network.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 10.1.2.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 10.1.2.2
[Switch-dhcp-pool-200] dns-list 10.1.2.2
[Switch-dhcp-pool-200] quit
Configuring the RADIUS server
The RADIUS server runs IMC PLAT 7.3 and IMC UAM 7.3.
Make sure the RADIUS server has been installed with the EAP-PEAP certificate.
Adding the AC as an access device to IMC
1.     Log in to IMC and click the User tab.
2.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
3.     Click Add.
The Add Access Device page opens.
4.     In the Access Configuration area, configure the following parameters, as shown in Figure 2:
¡     Enter 12345 in the Shared Key and Confirm Shared Key fields. The shared key must be the same as the authentication and accounting shared keys configured on the AC.
¡     Use the default values for other parameters.
5.     In the Device List area, click Select or Add Manually to add the AC at 10.1.2.1 as an access device.
The IP address must be the source IP address specified for outgoing RADIUS packets in the RADIUS scheme on the AC.
6.     Click OK.
Figure 2 Adding an access device
Adding an access policy
1.     From the navigation tree, select User Access Policy > Access Policy.
2.     Click Add.
3.     On the Add Access Policy page, configure the following parameters, as shown in Figure 3:
¡     Enter dot1x in the Access Policy Name field.
¡     Select EAP-PEAP from the Preferred EAP Type list, and select EAP-MSCHAPv2 from the Subtype list.
The certificate subtype on the IMC server must be the same as the identity authentication method configured on the client.
4.     Click OK.
Figure 3 Adding an access policy
Adding an access service
1.     From the navigation tree, select User Access Policy > Access Service.
2.     Click Add.
3.     On the Add Access Service page, configure the following parameters, as shown in Figure 4:
¡     Enter dot1x in the Service Name field.
¡     Select dot1x from the Default Access Policy list.
4.     Click OK.
Figure 4 Adding an access service
Adding an access user
1.     From the navigation tree, select Access User > Access User.
The access user list opens.
2.     Click Add.
The Add Access User page opens.
3.     In the Access Information area, configure the following parameters, as shown in Figure 5:
a.     Click Select or Add User to associate the user with IMC Platform user user.
b.     Enter dot1x in the Account Name field.
c.     Enter dot1x123 in the Password and Confirm Password fields.
4.     In the Access Service area, select dot1x from the list.
5.     Click OK.
Figure 5 Adding an access user account
Configuring the wireless client
Support for WPA3 depends on the wireless client model.
The configuration procedure is slightly different depending on the wireless client model. The following information only briefly describes the configuration procedure on a mobile phone.
1.     Open the WLAN list page of the mobile phone, and click the wireless network named wpa3. On the page that opens, configure the following parameters:
¡     Set the phase 2 authentication method to MSCHAPv2.
¡     Configure to not validate the CA certificate.
¡     Set the identity to dot1x.
¡     Enter password dot1x123.
2.     Click Connect.
1.     On the client, verify that the client has passed authentication and associated with the AP, and it can access the wireless network. (Details not shown.)
2.     On the AC, perform the following tasks to verify that the user has passed authentication and come online:
# Display detailed WLAN client information.
[AC] display wlan client verbose
Total number of clients: 1
 MAC address                       : ccc9-5de2-512d
 IPv4 address                      : 10.1.2.3
 IPv6 address                      : N/A
 Username                          : dot1x
 AID                               : 1
 AP ID                             : 1
 AP name                           : office
 Radio ID                          : 1
 Channel                           : 52
 SSID                              : wpa3
 BSSID                             : f474-8879-ea60
 VLAN ID                           : 200
 Sleep count                       : 0
 Wireless mode                     : 802.11ax
 Channel bandwidth                 : 80MHz
 SM power save                     : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not supported
 STBC RX capability                : Not supported
 STBC TX capability                : Not supported
 LDPC RX capability                : Supported
 Beamformee STS capability         : N/A
 Number of Sounding Dimensions     : N/A
 SU beamformee capability          : Not supported
 MU beamformee capability          : Not supported
 Block Ack                         : N/A
 Supported VHT-MCS set             : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
 Supported HT MCS set              : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
 Supported rates                   : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 5G 40And80MHz Channel bandwidth   : Supported
 5G 160MHz Channel bandwidth       : Not Supported
 5G 8080MHz Channel bandwidth      : Not Supported
 OFDMA random access RUs           : Not supported
 Supported HE-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
 TWT scheduled                     : no
 QoS mode                          : WMM
 Listen interval                   : 20
 RSSI                              : 0
 Rx/Tx rate                        : 0/0 Mbps
 Speed                             : N/A
 Authentication method             : Open system
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : GCMP
 User authentication mode          : 802.1X
 WPA3 status                       : Enabled
 Authorization CAR                 : N/A
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : SHA384
 PMF status                        : Enabled
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 0minutes 8seconds
 FT status                         : Inactive
 BTM mode                          : Inactive
# Display online 802.1X client information.
[AC] display dot1x connection
Total connections: 1
User MAC address                   : ccc9-5de2-512d
AP name                            : office
Radio ID                           : 1
SSID                               : wpa3
Username                           : dot1x
Authentication domain              : dom1
IPv4 address                       : 192.168.100.17
Authentication method              : EAP
Initial VLAN                       : 200
Authorization VLAN                 : 200
Authorization ACL number           : N/A
Authorization URL                  : N/A
Authorization IPv6 URL             : N/A
Termination action                 : Default
Session timeout last from          : 2021/03/18 14:42:20
Session timeout period             : 86400 s
Online from                        : 2021/03/18 14:42:20
Online duration                    : 0h 2m 44s
Configuration files
·     AC:
vlan 100
vlan 200
 ssid wpa3
 vlan 200
 akm mode dot1x
 cipher-suite gcmp
 security-ie rsn
 wpa3 enterprise
 dot1x domain dom1
 pmf mandatory
interface Vlan-interface100
 ip address 10.1.1.46 255.255.255.0
interface Vlan-interface200
 ip address 10.1.2.1 255.255.255.0
 key authentication cipher $c$3$Bb61SHV2ZsVYPJU2+RFB/8ntk0uCQkmxdA==
 key accounting cipher $c$3$w03NfxnBmfDuedv9/xo7ESnoxKjowmmX9A==
 nas-ip 10.1.2.1
domain dom1
 vlan 100
 radio 1
  type dot11ax
  radio enable
 radio 2
 radio 3
 gigabitethernet 1
 ten-gigabitethernet 1
·     Switch:
 dhcp enable
vlan 100
vlan 200
 dns-list 10.1.2.1
 ip address 10.1.1.47 255.255.255.0
 ip address 10.1.2.2 255.255.255.0
 port trunk permit vlan 1 100 200
 poe enable
Related documentation
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
·     User Access and Authentication Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
