- 06-Wireless authentication
- 01-Local Portal Authentication Configuration Examples
- 02-HTTPS-Based Local Portal Authentication Configuration Examples
- 03-Remote Portal Authentication Configuration Examples
- 04-Local Portal Authentication through LDAP Server Configuration Examples
- 05-Local Portal Authentication and SSID-based Authentication Page Pushing Configuration Examples
- 06-Local Portal MAC-Trigger Authentication Configuration Examples
- 07-Portal MAC-Trigger Authentication Configuration Examples
- 08-Local Forwarding Mode and Local Portal MAC-Trigger Authentication Configuration Examples
- 09-Local Portal Authentication (IPv6) Configuration Examples
- 10-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 11-Remote Portal Authentication (IPv6) Configuration Examples
- 12-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 13-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 14-WiFiDog Portal Authentication Configuration Examples
- 15-Portal Fail-Permit Configuration Examples
- 16-Local MAC Authentication Configuration Examples
- 17-MAC Authentication and PSK Authentication Configuration Examples
- 18-Remote MAC and Portal Authentication and Transparent Authentication Configuration Examples
- 19-Remote AP and Remote Portal MAC-Trigger Authentication Configuration Examples
- 20-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 21-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 22-Local MAC-Then-802.1X Authentication Configuration Examples
- 23-Local 802.1X Authentication Configuration Examples
- 24-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 25-Remote 802.1X Authentication Configuration Examples
- 26-Remote 802.1X Authentication (IPv6) Configuration Examples
- 27-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 28-802.1X Authentication with ACL Assignment Through IMC Server Configuration Examples
- 29-802.1X Authentication with User Profile Assignment Through IMC Server Configuration Examples
- 30-EAD Authentication Configuration Examples
- 31-EAD Authentication (IPv6) Configuration Examples
21-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples | 328.84 KB |
H3C Access Controllers |
Comware 7 MAC Authentication with Guest VLAN Assignment (IPv6) |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring a guest VLAN to accommodate clients that fail MAC authentication on an IPv6 network.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, MAC authentication, WLAN authentication, and WLAN access.
Example: Configuring MAC authentication with guest VLAN assignment (IPv6)
As shown in Figure 1, the AC acts as a DHCPv6 server to provide IPv6 addresses for the AP and its attached clients. The AC centrally forwards client traffic.
To control the access of clients to network resources:
· Configure VLAN 200 as the access VLAN of the clients.
· Use the AC with a RADIUS server to perform MAC authentication for the clients.
· Configure VLAN 300 as the guest VLAN in the service template for the clients. A client is moved to the guest VLAN if it fails authentication and will stay in the guest VLAN until it passes re-authentication, which is performed every 30 seconds.
When you configure MAC authentication for wireless clients, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· To prevent too many packets from entering VLAN 1, configure the switch's interface that connects the switch to the AP to deny packets from VLAN 1.
· Some endpoints by default use random MAC addresses. To ensure successful MAC authentication for such an endpoint, disable the endpoint from using a random MAC address.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IPv6 address to the VLAN interface. The AC will use this IP address to establish CAPWAP tunnels with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ipv6 address 2001::1 64
# Disable RA message suppression on VLAN-interface 100.
[AC-Vlan-interface100] undo ipv6 nd ra halt
# Set the managed address configuration flag (M) to 1 in RA advertisements to be sent.
[AC-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
# Set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
[AC-Vlan-interface100] ipv6 nd autoconfig other-flag
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IPv6 address to the VLAN interface. The client will use VLAN 200 to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ipv6 address 2004::1 64
# Disable RA message suppression on VLAN-interface 200.
[AC-Vlan-interface200] undo ipv6 nd ra halt
[AC-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface200] ipv6 nd autoconfig other-flag
[AC-Vlan-interface200] quit
# Create VLAN 300 and VLAN-interface 300, and assign an IPv6 address to the VLAN interface. The AC will use VLAN 300 as a guest VLAN to accommodate clients that fail MAC authentication.
[AC] vlan 300
[AC-vlan300] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ipv6 address 2003::1 64
# Disable RA message suppression on VLAN-interface 300.
[AC-Vlan-interface300] undo ipv6 nd ra halt
[AC-Vlan-interface300] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface300] ipv6 nd autoconfig other-flag
[AC-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100, 200, and 300.
[AC] interface gigabitEthernet1/0/1
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
# Set the PVID of GigabitEthernet 1/0/1 to VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure the DHCPv6 service:
# Enable the DHCPv6 server on VLAN-interface 100 and VLAN-interface 200, apply address pool vlan100 to VLAN-interface 100, and apply address pool vlan200 to VLAN-interface 200.
[AC-Vlan-interface100] ipv6 dhcp select server
[AC-Vlan-interface100] ipv6 dhcp server apply pool vlan100
[AC-Vlan-interface200] ipv6 dhcp select server
[AC-Vlan-interface200] ipv6 dhcp server apply pool vlan200
# Create a DHCPv6 address pool named vlan100, and specify subnet 2001::/64 in the DHCPv6 address pool.
[AC] ipv6 dhcp pool vlan100
[AC-dhcpv6-pool-vlan100] network 2001::/64
[AC-dhcpv6-pool-vlan100] quit
# Create a DHCPv6 address pool named vlan200, and specify subnet 2004::/64 in the DHCPv6 address pool.
[AC] ipv6 dhcp pool vlan200
[AC-dhcpv6-pool-vlan200] network 2004::/64
[AC-dhcpv6-pool-vlan200] quit
# Create a DHCPv6 address pool named vlan300, and specify subnet 2003::/64 in the DHCPv6 address pool.
[AC] ipv6 dhcp pool vlan300
[AC-dhcpv6-pool-vlan300] network 2003::/64
[AC-dhcpv6-pool-vlan300] quit
3. Configure RADIUS-based MAC authentication:
# Create a RADIUS scheme named office and enter its view.
[AC] radius scheme office
# Specify the IP addresses of the primary authentication and accounting RADIUS servers.
[AC-radius-office] primary authentication ipv6 2001::2 64
[AC-radius-office] primary accounting ipv6 2001::2 64
# Specify the shared keys for RADIUS authentication and accounting.
[AC-radius-office] key authentication simple 123456789
[AC-radius-office] key accounting simple 123456789
# Exclude ISP domain names from usernames sent to the RADIUS servers.
[AC-radius-office] user-name-format without-domain
# Specify IPv6 address 2001::1 as the source IPv6 address of outgoing RADIUS packets.
[AC-radius-office] nas-ip ipv6 2001::1
[AC-radius-office] quit
# Create an ISP domain named office1 and enter its view.
[AC] domain office1
# Apply RADIUS scheme office to ISP domain office1 for LAN user authentication, authorization, and accounting.
[AC-isp-office1] authentication lan-access radius-scheme office
[AC-isp-office1] authorization lan-access radius-scheme office
[AC-isp-office1] accounting lan-access radius-scheme office
# Configure the idle cut feature for clients in ISP domain office1.
[AC-isp-office1] authorization-attribute idle-cut 15 1024
[AC-isp-office1] quit
# Configure the AC to use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation without hyphens, and letters are in lower case. (The configuration in this step is the default configuration. This step is optional.)
[AC] mac-authentication user-name-format mac-address without-hyphen lowercase
4. Configure a wireless service:
# Create a service template named 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID of service template 1 to service.
[AC-wlan-st-1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-1] vlan 200
# Enable snooping ND packets.
[AC-wlan-st-1] client ipv6-snooping nd-learning enable
# Enable snooping DHCPv6 packets.
[AC-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
# Set the authentication mode to MAC authentication.
[AC-wlan-st-1] client-security authentication-mode mac
# Specify the MAC authentication domain as ISP domain office1.
[AC-wlan-st-1] mac-authentication domain office1
5. Configure a guest VLAN:
# Specify VLAN 300 as the guest VLAN for clients that fail MAC authentication on service template 1.
[AC-wlan-st-1] client-security authentication fail-vlan 300
# Enable the service template.
[AC-wlan-st-1] quit
6. Configure manual AP officeap, and bind service template 1 to an AP radio:
# Create a manual AP named officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA4320i-ACN
[AC-wlan-ap-officeap] serial-id 210235A1Q2C159000020
# Enter the view of radio 2, and bind service template 1 to radio 2.
[AC-wlan-ap-officeap] radio 2
[AC-wlan-ap-officeap-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-officeap-radio-2] radio enable
[AC-wlan-ap-officeap-radio-2] quit
[AC-wlan-ap-officeap] quit
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnels between the AC and AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 300. The switch will use this VLAN to forward packets in the guest VLAN.
[Switch] vlan 300
[Switch-vlan300] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port, remove the port from VLAN 1, and assign the trunk port to VLAN 100.
[Switch] interface gigabitEthernet1/0/1
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as an access port. Assign the access port to VLAN 100.
[Switch] interface gigabitEthernet1/0/2
# Enable PoE on GigabitEthernet 1/0/2.
Configuring the RADIUS server
This example uses IMC PLAT 7.1 (E0303P10) and IMC UAM 7.1 (E0303P10) to show the procedure.
1. Add an access device:
a. Log in to IMC.
b. Click the User tab.
c. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
d. Click Add.
The Add Access Device page opens.
e. In the Device List area, click Add IPv6 Dev.
f. Enter 2001::1 as the start IPv6 address, and then click OK.
This IPv6 address is the source IPv6 address specified on the AC for outgoing RADIUS packets.
g. In the Access Configuration area, configure the following parameters, as shown in Figure 2:
- Enter 123456789 in the Shared Key and Confirm Shared Key fields.
The key is consistent with the shared key configured on the AC.
- Use the default values for other parameters.
h. Click OK.
Figure 2 Adding an access device
2. Add an access policy:
a. Click the User tab.
b. From the navigation tree, select User Access Policy > Access Policy.
c. Click Add.
d. On the Add Access Policy page, configure the following parameters, as shown in Figure 3:
- Enter office in the Access Policy Name field.
Figure 3 Adding an access policy
3. Add an access service:
b. From the navigation tree, select User Access Policy > Access Service.
c. Click Add.
d. On the Add Access Service page, configure the following parameters, as shown in Figure 4:
- Enter office_mac in the Service Name field.
- Select office from the Default Access Policy list.
e. Click OK.
Figure 4 Adding an access service
4. Add an access user:
b. From the navigation tree, select Access User > Access User.
The access user list opens.
c. Click Add.
The Add Access User page opens.
d. In the Access Information area, add a user, as shown in Figure 5:
- Click Add User.
- On the dialog box that opens, enter adm_office_mac in the User Name and Identity Number fields.
- Click Check Availability to verify the validity of the username and identity number.
- Click OK.
e. In the Access Information area, configure the MAC authentication user account, as shown in Figure 6:
- Enter admin in the Account Name field.
- Enter 123456 in the Password and Confirm Password fields.
NOTE: To test the guest VLAN functionality, the user account settings in this example are inconsistent with the MAC authentication username and password format configured on the AC. On a live network, you must make sure the usernames and passwords for the clients are their MAC addresses in the format specified on the AC. |
f. In the Access Service area, select office_mac from the list.
g. Click OK.
Figure 6 Adding an access user account
# Attempt to access the network from a client.
# On the AC, verify that the wireless client fails MAC authentication and is assigned to VLAN 300.
[AC] display wlan client
Total Number of Clients : 1
MAC address Username AP name RID IP address IPv6 address VLAN
3ca9-f414-4c20 N/A officeap 2 N/A 2003::2 300
# Verify that the wireless client in the guest VLAN can access network resources only in VLAN 300 before passing MAC authentication. (Details not shown.)
# Modify the username and password on the RADIUS server to the MAC address of the client. The MAC address is in hexadecimal notation without hyphens, and letters are in lower case. (Details not shown.)
# Display MAC authentication information after the wireless client in the guest VLAN passes MAC authentication.
[AC] display mac-authentication
MAC authentication : Enabled
User name format : MAC address in lowercase(xxxxxxxxxxxx)
Username : mac
Password : Not configured
Offline detect period : 300 s
Quiet period : 60 s
Server timeout : 100 s
Authentication domain : Not configured, use default domain
Online MAC-auth wired users : 0
Online MAC-auth wireless users : 1
Silent MAC users:
MAC address VLAN ID From port Port index
AP name: officeap Radio ID: 2 SSID: service
BSSID : 741f-4ad4-8d50
Authentication domain : office1
Max online users : 4096
Authentication attempts : successful 0, failed 42
Configuration files
· AC:
vlan 100
vlan 200
vlan 300
network 2001::/64
network 2004::/64
network 2003::/64
ssid service
vlan 200
interface Vlan-interface100
ipv6 address 2001::1/64
interface Vlan-interface200
ipv6 address 2004::1/64
interface Vlan-interface300
ipv6 address 2003::1/64
key authentication cipher $c$3$IrnigzRDMkG7Jk1FNf2+tm04+zvnCwiaJzI9TA==
key accounting cipher $c$3$ehledYNyJ+vTlcYcyUEisTa+ZXvWqU1O2QlSYg==
nas-ip ipv6 2001::1
domain office1
radio 1
radio 2
radio enable
service-template 1
· Switch:
vlan 100
vlan 200
vlan 300
poe enable
Related documentation
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
· AP and WT Management Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
· Network Connectivity Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
