- 05-WLAN access
- 01-WEP Encryption Configuration Examples
- 02-PSK Encryption Configuration Examples
- 03-WPA3-SAE PSK Encryption Configuration Examples
- 04-WLAN Access (IPv6) Configuration Examples
- 05-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 06-Scheduled Configuration Deployment by AP Group Configuration Examples
- 07-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 08-Service Template and Radio Binding Configuration Examples
- 09-Scheduled WLAN Access Services Configuration Examples
04-WLAN Access (IPv6) Configuration Examples | 84.31 KB |
H3C Access Controllers |
Comware 7 WLAN Access (IPv6) |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an IPv6 access configuration example.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IPv6 basics and WLAN access.
Example: Configuring IPv6 WLAN access
As shown in Figure 1, the Layer 3 switch acts as a DHCP server to assign IPv6 addresses to the AP and Client 1 and assign an IPv6 prefix to Client 2. Configure wireless services to ensure that the WLAN uses IPv6 addresses and Client 1 and Client 2 can access the WLAN. Assume that centralized forwarding is used in this example.
When you configure IPv6 access, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· To prevent too many packets from entering VLAN 1, configure the switch's interface that connects the switch to the AP to deny packets from VLAN 1.
Procedures
Configuring the AC
1. Configure the interfaces of the AC:
# Create VLAN 100 and VLAN-interface 100, and assign the interface an IPv6 address. The AC will use this IPv6 address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ipv6 address 2001::1 64
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN 400. The AC uses the VLANs to forward client traffic.
[AC] vlan 200
[AC-vlan200] quit
[AC] vlan 400
[AC-vlan400] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100, 200, and 400.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
2. Configure IPv6 static routes.
[AC] ipv6 route-static 3001::0 64 2001::2
[AC] ipv6 route-static 4001::0 64 2001::2
3. Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service1.
[AC-wlan-st-1] ssid service1
# Enable the service template.
# Enable snooping DHCPv6 and ND packets.
[AC-wlan-st-2] client ipv6-snooping dhcpv6-learning enable
[AC-wlan-st-2] client ipv6-snooping nd-learning enable
[AC-wlan-st-2] quit
# Create service template 2 and enter its view.
[AC] wlan service-template 2
# Set the SSID to service2.
[AC-wlan-st-2] ssid service2
[AC-wlan-st-2] service-template enable
[AC-wlan-st-2] quit
4. Configure the AP:
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA4320i-ACN
[AC-wlan-ap-officeap] serial-id 210235A1GQC158004457
# Bind service template 1 and VLAN 200 to radio 1.
[AC-wlan-ap-officeap] radio 1
[AC-wlan-ap-officeap-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-officeap-radio-1] radio enable
[AC-wlan-ap-officeap-radio-1] return
# Bind service template 2 and VLAN 400 to radio 2.
[AC-wlan-ap-officeap] radio 2
[AC-wlan-ap-officeap-radio-2] service-template 2 vlan 400
# Enable radio 2.
[AC-wlan-ap-officeap-radio-2] radio enable
[AC-wlan-ap-officeap-radio-2] return
Configuring the switch
1. Configure switch interfaces:
# Create VLAN 100, VLAN 300, VLAN-interface 100, and VLAN-interface 300, and assign IPv6 addresses to the VLAN interfaces. The switch will use VLAN 100 and VLAN 300 to forward packets between AC and AP.
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ipv6 address 2001::2/64
[L3 switch-Vlan-interface100] quit
[L3 switch] vlan 300
[L3 switch-vlan300] quit
[L3 switch] interface vlan-interface 300
[L3 switch-Vlan-interface300] ipv6 address 3001::1/64
[L3 switch-Vlan-interface300] quit
# Create VLAN 200 and VLAN-interface 200 and assign an IPv6 address to the VLAN interface. Client 1 will use this VLAN to access the WLAN.
[L3 switch] vlan 200
[L3 switch-vlan200] quit
[L3 switch] interface vlan-interface 200
[L3 switch-Vlan-interface200] ipv6 address 3000::1/64
[L3 switch-Vlan-interface200] quit
# Create VLAN 400 and VLAN-interface 400 and assign an IPv6 address to the VLAN interface. Client 2 will use this VLAN to access the WLAN.
[L3 switch] vlan 400
[L3 switch-vlan400] quit
[L3 switch] interface vlan-interface 400
[L3 switch-Vlan-interface400] ipv6 address 4000::1/64
[L3 switch-Vlan-interface400] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100, 200, and 400.
[L3 Switch] interface gigabitethernet 1/0/1
[L3 Switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L3 Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
[L3 Switch-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, remove the port from VLAN 1, configure the PVID as VLAN 300, and assign the port to VLANs 200, 300, and 400.
[L3 switch] interface gigabitEthernet 1/0/2
[L3 switch-GigabitEthernet1/0/2] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] port trunk permit vlan 200 300 400
[L3 switch-GigabitEthernet1/0/2] port trunk pvid vlan 300
[L3 switch-GigabitEthernet1/0/2] quit
2. Configure DHCPv6:
# Enable the DHCPv6 server on VLAN-interface 200, VLAN-interface 300, and VLAN-interface 400, respectively.
[L3 switch-Vlan-interface200] ipv6 dhcp select server
[L3 switch-Vlan-interface300] ipv6 dhcp select server
[L3 switch-Vlan-interface400] ipv6 dhcp select server
# Disable RA message suppression, set both the managed address configuration flag (M) and the other stateful configuration flag (O) to 1 in RA advertisements to be sent for the created VLAN interfaces.
[L3 switch-Vlan-interface200] undo ipv6 nd ra halt
[L3 switch-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[L3 switch-Vlan-interface200] ipv6 nd autoconfig other-flag
[L3 switch-Vlan-interface300] undo ipv6 nd ra halt
[L3 switch-Vlan-interface300] ipv6 nd autoconfig managed-address-flag
[L3 switch-Vlan-interface300] ipv6 nd autoconfig other-flag
[L3 switch-Vlan-interface400] undo ipv6 nd ra halt
[L3 switch-Vlan-interface400] ipv6 nd autoconfig managed-address-flag
[L3 switch-Vlan-interface400] ipv6 nd autoconfig other-flag
# Create DHCPv6 address pool 1 to assign an IPv6 address to Client 1, and specify subnet 3000::0/64 in the DHCP address pool.
[L3 switch] ipv6 dhcp pool 1
[L3 switch-dhcp6-pool-1] network 3000::0/64
[L3 switch-dhcp6-pool-1] gateway-list 3000::1
[L3 switch-dhcp6-pool-1] quit
# Create DHCPv6 address pool 2 to assign an IPv6 address to the AP, specify subnet 3001::0/64 in the DHCP address pool, and configure Option 52 that specifies AC IPv6 address 2001:1 in the address pool.
[L3 switch] ipv6 dhcp pool 2
[L3 switch-dhcp6-pool-2] network 3001::0/64
[L3 switch-dhcp6-pool-2] gateway-list 3001::1
[L3 switch-dhcp6-pool-2] option 52 hex 20010000000000000001000000000001
[L3 switch-dhcp6-pool-2] quit
# Create a prefix pool and specify the prefix and the assigned prefix length for the pool.
[L3 switch] ipv6 dhcp prefix-pool 1 prefix 4001::/64 assign-len 64
# Create DHCPv6 address pool 3 to assign an IPv6 address to Client 2, and specify subnet 4001::0/64 in the DHCP address pool.
[L3 switch] ipv6 dhcp pool 3
[L3 switch-dhcp6-pool-3] network 4001::0/64
[L3 switch-dhcp6-pool-3] gateway-list 4001::1
# Apply prefix pool 1 to DHCPv6 address pool 3, so the DHCPv6 server can dynamically select a prefix from the prefix pool for a client.
[L3 switch-dhcp6-pool-3] prefix-pool 1
[L3 switch-dhcp6-pool-3] quit
# Verify that Client 1 and Client 2 have connected to the network successfully.
[AC] display wlan client ipv6
MAC address AP name IPv6 address VLAN
0000-000f-1211 officeap 3000::2 200
0000-000f-1212 officeap 4001::3 400
Configuration files
· AC:
vlan 100
vlan 200
vlan 400
interface Vlan-interface100
ipv6 address 2001::1/64
ssid service
radio 1
radio enable
radio 2
radio enable
· Layer 3 switch:
vlan 100
vlan 200
vlan 300
vlan 400
ipv6 dhcp pool 1
network 3000::0/64
ipv6 dhcp pool 2
network 3001::0/64
option 52 hex 00010000000000000001000000000001
ipv6 dhcp pool 3
network 4001::0/64
prefix-pool 1
interface Vlan-interface200
interface Vlan-interface300
interface Vlan-interface400
ipv6 address 4001::1/64
Related documentation
· AP and WT Management Command Reference in H3C Access Controllers Command References
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
· Network Connectivity Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
