- 05-WLAN access
- 01-WEP Encryption Configuration Examples
- 02-PSK Encryption Configuration Examples
- 03-WPA3-SAE PSK Encryption Configuration Examples
- 04-WLAN Access (IPv6) Configuration Examples
- 05-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 06-Scheduled Configuration Deployment by AP Group Configuration Examples
- 07-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 08-Service Template and Radio Binding Configuration Examples
- 09-Scheduled WLAN Access Services Configuration Examples
03-WPA3-SAE PSK Encryption Configuration Examples | 75.65 KB |
H3C Access Controllers |
Comware 7 WPA3-SAE PSK Encryption |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring PSK encryption with the WPA3-SAE security mode.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN access and WLAN security.
Example: Configuring PSK encryption with the WPA3-SAE security mode
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and the client. Perform the following tasks:
· Configure PSK on the AC to enable the client to use PSK for encryption.
· Configure open system authentication and bypass authentication so that the client can access the WLAN without being authenticated.
· Configure PSK as the authentication and key management (AKM) mode.
· Set the cipher suite to CCMP.
· Set the security IE to RSN.
· Set the security mode to WPA3-SAE.
When you configure PSK encryption with the WPA3-SAE security mode, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· Configure a pre-shared key if the AKM mode is PSK.
Procedures
Configuring the AC
1. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 16
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, set the PVID to VLAN 100, and assign the port to VLANs 100 and 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure wireless services:
# Create service template wpa3_personal and enter its view.
[AC] wlan service-template wpa3_personal
# Configure the SSID as wpa3_personal.
[AC-wlan-st-wpa3_personal] ssid wpa3_personal
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-wpa3_personal] vlan 200
# Set the AKM mode to PSK and configure simple character string of 12345678 as the PSK.
[AC-wlan-st-wpa3_personal] akm mode psk
[AC-wlan-st-wpa3_personal] preshared-key pass-phrase simple 12345678
# Set the cipher suite to CCMP and set the security IE to RSN.
[AC-wlan-st-wpa3_personal] cipher-suite ccmp
[AC-wlan-st-wpa3_personal] security-ie rsn
# Set the WPA3 security mode to personal (WPA3-SAE) and specify the mandatory mode.
[AC-wlan-st-wpa3_personal] wpa3 personal mandatory
# Enable mandatory management frame protection.
[AC-wlan-st-wpa3_personal] pmf mandatory
# Enable the service template.
[AC-wlan-st-wpa3_personal] service-template enable
[AC-wlan-st-wpa3_personal] quit
3. Configure the AP:
# Create manual AP office, and specify the AP model and serial ID.
[AC] wlan ap office model WA6638
[AC-wlan-ap-office] serial-id 219801A24F8198E00012
# Enter radio view of radio 2.
[AC-wlan-ap-office] radio 2
# Bind service template wpa3_personal to radio 2, and then enable the radio.
[AC-wlan-ap-office-radio-2] service-template wpa3_personal
[AC-wlan-ap-office-radio-2] radio enable
[AC-wlan-ap-office-radio-2] quit
[AC-wlan-ap-office] quit
Configuring the switch
1. Configure switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward packets between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 16
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The switch will use VLAN 100 to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, remove the port from VLAN 1, set the PVID to VLAN 100, and assign the port to VLANs 100, and 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as an access port, and assign the port to VLAN 100.
# Enable PoE on GigabitEthernet 1/0/2.
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create DHCP address pool vlan100 to assign an IP address to the AP, specify subnet 192.1.0.0/16 in the DHCP address pool, and specify the gateway address as 192.1.1.2.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.0.0 mask 255.255.0.0
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.2
[Switch-dhcp-pool-vlan100] quit
# Create DHCP address pool vlan200 to assign an IP address to the AP, and specify subnet 192.2.1.0/24 in the DHCP address pool. Specify the gateway address as 192.2.1.2 and specify the DNS server address in the DHCP address pool. In this example, the gateway also acts as the DNS server.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the client has been associated with the WLAN and the AKM mode is PSK.
[AC] display wlan client verbose
Total number of clients: 1
MAC address : ccc9-5de2-512d
IPv4 address : 192.2.1.3
IPv6 address : N/A
Username : N/A
AID : 1
AP ID : 1
AP name : office
Radio ID : 2
Channel : 149
SSID : wpa3_personal
BSSID : f474-8879-ea70
VLAN ID : 200
Sleep count : 0
Wireless mode : 802.11ax
Channel bandwidth : 80MHz
SM power save : Disabled
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
Short GI for 80MHz : Supported
Short GI for 160/80+80MHz : Not supported
STBC RX capability : Not supported
STBC TX capability : Not supported
LDPC RX capability : Supported
Beamformee STS capability : N/A
Number of Sounding Dimensions : N/A
SU beamformee capability : Not supported
MU beamformee capability : Not supported
Block Ack : N/A
Supported VHT-MCS set : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14,
15
Supported rates : 6, 9, 12, 18, 24, 36,
48, 54 Mbps
5G 40And80MHz Channel bandwidth : Supported
5G 160MHz Channel bandwidth : Not Supported
5G 8080MHz Channel bandwidth : Not Supported
OFDMA random access RUs : Not supported
Supported HE-MCS set : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
TWT scheduled : no
QoS mode : WMM
Listen interval : 20
RSSI : 0
Rx/Tx rate : 0/0 Mbps
Speed : N/A
Authentication method : SAE
Security mode : RSN
AKM mode : PSK
Cipher suite : CCMP
User authentication mode : Bypass
WPA3 status : Enabled
Authorization CAR : N/A
Authorization ACL ID : N/A
Authorization user profile : N/A
Roam status : N/A
Key derivation : SHA256
PMF status : Enabled
Forwarding policy name : Not configured
Online time : 0days 0hours 0minutes 10seconds
FT status : Inactive
BTM mode : Inactive
Configuration files
· AC:
vlan 100
vlan 200
ssid wpa3_personal
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$N//5BVbsOqdBTxi+7MJZKT6Zqh5MAmYs2ZzM
cipher-suite ccmp
pmf mandatory
security-ie rsn
interface Vlan-interface100
ip address 192.1.1.1 255.255.0.0
interface Vlan-interface200
ip address 192.2.1.1 255.255.255.0
radio 1
radio 2
radio enable
radio 3
gigabitethernet 1
ten-gigabitethernet 1
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.1.2
poe enable
Related documentation
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Authentication Command Reference in H3C Access Controllers Command References
· WLAN Authentication Configuration Guide in H3C Access Controllers Configuration Guides
