- 06-IP Multicast Configuration Guide
- 01-Multicast overview
- 02-IGMP snooping configuration
- 03-PIM snooping configuration
- 04-Multicast VLAN configuration
- 05-Multicast routing and forwarding configuration
- 06-IGMP configuration
- 07-PIM configuration
- 08-MSDP configuration
- 09-Multicast VPN configuration
- 10-MLD snooping configuration
- 11-IPv6 PIM snooping configuration
- 12-IPv6 multicast VLAN configuration
- 13-IPv6 multicast routing and forwarding configuration
- 14-MLD configuration
- 15-IPv6 PIM configuration
13-IPv6 multicast routing and forwarding configuration | 157.72 KB |
Configuring IPv6 multicast routing and forwarding
IPv6 multicast forwarding across IPv6 unicast subnets
IPv6 multicast routing and forwarding configuration task list
Enabling IPv6 multicast routing
Specifying the longest prefix match principle
Configuring IPv6 multicast load splitting
Configuring an IPv6 multicast forwarding boundary
Enabling IPv6 multicast forwarding between sub-VLANs of a super VLAN
Using mtrace2 to trace an IPv6 multicast path
Setting the maximum number of cached unknown IPv6 multicast packets
Displaying and maintaining IPv6 multicast routing and forwarding
IPv6 multicast forwarding over a GRE tunnel configuration example
Overview
IPv6 multicast routing and forwarding uses the following tables:
· IPv6 multicast protocols' routing tables, such as the IPv6 PIM routing table.
· General IPv6 multicast routing table that summarizes the multicast routing information generated by different IPv6 multicast routing protocols. The IPv6 multicast routing information from IPv6 multicast sources to IPv6 multicast groups are stored in a set of (S, G) routing entries.
· IPv6 multicast forwarding table that guides IPv6 multicast forwarding. The optimal routing entries in the IPv6 multicast routing table are added to the IPv6 multicast forwarding table.
RPF check mechanism
An IPv6 multicast routing protocol uses the reverse path forwarding (RPF) check mechanism to ensure IPv6 multicast data delivery along the correct path and to avoid data loops.
RPF check process
An IPv6 multicast router performs the RPF check on an IPv6 multicast packet as follows:
1. The router chooses an optimal route back to the packet source separately from the IPv6 unicast and IPv6 MBGP routing tables.
In RPF check, the "packet source" means difference things in difference situations:
¡ For a packet that travels along the SPT, the packet source is the IPv6 multicast source.
¡ For a packet that travels along the RPT, the packet source is the RP.
¡ For a bootstrap message originated from the BSR, the packet source is the BSR.
For more information about the concepts of SPT, RPT, source-side RPT, RP, and BSR, see "Configuring IPv6 PIM."
2. The router selects one of the optimal routes as the RPF route as follows:
¡ If the router uses the longest prefix match principle, the route with a higher prefix length becomes the RPF route. If the routes have the same prefix length, the route with a higher route preference becomes the RPF route. If the routes have the same route preference, the IPv6 MBGP route becomes the RPF route.
For more information about the route preference, see Layer 3—IP Routing Configuration Guide.
¡ If the router does not use the longest prefix match principle, the route with a higher route preference becomes the RPF route. If the routes have the same route preference, the IPv6 MBGP route becomes the RPF route.
In the RPF route, the outgoing interface is the RPF interface and the next hop is the RPF neighbor.
3. The router checks whether the packet arrived at the RPF interface. If yes, the RPF check succeeds and the packet is forwarded. If not, the RPF check fails and the packet is discarded.
RPF check implementation in IPv6 multicast
Implementing an RPF check on each received IPv6 multicast packet would heavily burden the router. The use of an IPv6 multicast forwarding table is the solution to this issue. When the router creates an IPv6 multicast forwarding entry for an IPv6 (S, G) packet, it sets the RPF interface of the packet as the incoming interface of the (S, G) entry. After the router receives another (S, G) packet, it looks up its IPv6 multicast forwarding table for a matching (S, G) entry:
· If no match is found, the router first determines the RPF route back to the packet source. Then, it creates a forwarding entry with the RPF interface as the incoming interface and performs one of the following tasks:
¡ If the receiving interface is the RPF interface, the RPF check succeeds and the router forwards the packet out of all outgoing interfaces.
¡ If the receiving interface is not the RPF interface, the RPF check fails and the router discards the packet.
· If a match is found and the matching forwarding entry contains the receiving interface, the router forwards the packet out of all outgoing interfaces.
· If a match is found but the matching forwarding entry does not contain the receiving interface, the router determines the RPF route back to the packet source. Then, the router performs one of the following tasks:
¡ If the RPF interface is the incoming interface, it means that the forwarding entry is correct but the packet traveled along a wrong path. The packet fails the RPF check, and the router discards the packet.
¡ If the RPF interface is not the incoming interface, it means that the forwarding entry has expired. The router replaces the incoming interface with the RPF interface and matches the receiving interface against the RPF interface. If the receiving interface is the RPF interface, the router forwards the packet out of all outgoing interfaces. Otherwise, it discards the packet.
As shown in Figure 1, assume that IPv6 unicast routes are available on the network. IPv6 MBGP is not configured. IPv6 multicast packets travel along the SPT from the multicast source to the receivers. The IPv6 multicast forwarding table on Device C contains the (S, G) entry, with VLAN-interface 20 as the RPF interface.
· If an IPv6 multicast packet arrives at Device C on VLAN-interface 20, the receiving interface is the incoming interface of the (S, G) entry. Device C forwards the packet out of all outgoing interfaces.
· If an IPv6 multicast packet arrives at Device C on VLAN-interface 10, the receiving interface is not the incoming interface of the (S, G) entry. Device C searches its IPv6 unicast routing table and finds that the outgoing interface to the source (the RPF interface) is VLAN-interface 20. This means that the (S, G) entry is correct but the packet traveled along a wrong path. The packet fails the RPF check, and Device C discards the packet.
Routers forward the IPv6 multicast data from an IPv6 multicast source hop by hop along the forwarding tree, but some routers might not support IPv6 multicast protocols in a network. When the IPv6 multicast data is forwarded to a router that does not support IPv6 multicast, the forwarding path is blocked. In this case, you can enable IPv6 multicast data forwarding across the IPv6 unicast subnets by establishing a tunnel between the routers at both ends of the IPv6 unicast subnets.
Figure 2 IPv6 multicast data transmission through a tunnel
As shown in Figure 2, a tunnel is established between the multicast routers Device A and Device B. Device A encapsulates the IPv6 multicast data in unicast IPv6 packets, and forwards them to Device B across the tunnel through unicast routers. Then, Device B strips off the unicast IPv6 header and continues to forward the IPv6 multicast data down toward the receivers.
IPv6 mtrace
IPv6 mtrace uses mtrace2 to trace the path along which IPv6 multicast group data travels from a source to a destination.
Device roles
IPv6 mtrace includes the following roles:
· Last-hop router (LHR)—An LHR is a router that has an IPv6 multicast-enabled interface on the same subnet as the destination and can forward specific IPv6 multicast data to the subnet.
· First-hop router (FHR)—An FHR is a router that is directly connected to the IPv6 multicast source.
· Client—A client is a router that initiates an mtrace2.
Process
The IPv6 mtrace process is as follows:
1. The client sends an mtrace2 Query message (with a hops field indicating the maximum number of hops to be traced) to the destination.
2. The LHR turns the received Query message to an mtrace2 Request message by adding local forwarding information and sends the Request message to the upstream neighbor.
3. Each router along the traced path adds its local forwarding information to the received Request message and sends the Request message to its upstream neighbor.
4. The FHR adds its local forwarding information to the received Request message. Then, it turns the Request message to an mtrace2 Reply message and sends the Reply message to the client.
5. The client interprets forwarding information in the Reply message and displays the information.
Enable IPv6 multicast routing before you configure any Layer 3 IPv6 multicast functionality in the public network or VPN instance.
To enable IPv6 multicast routing:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable IPv6 multicast routing and enter IPv6 MRIB view. |
ipv6 multicast routing [ vpn-instance vpn-instance-name ] |
By default, IPv6 multicast routing is disabled. |
Before you configure IPv6 multicast routing and forwarding, complete the following tasks:
· Configure an IPv6 unicast routing protocol so that all devices in the domain can interoperate at the network layer.
· Configure IPv6 PIM-DM or IPv6 PIM-SM.
You can enable the device to use the longest prefix match principle for RPF route selection. For more information about RPF route selection, see "RPF check process."
To specify the longest prefix match principle for RPF route selection:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter IPv6 MRIB view. |
N/A |
3. Specify the longest prefix match principle for RPF route selection. |
longest-match |
By default, the route preference principle is used. |
You can enable the device to split multiple IPv6 multicast data flows on a per-source basis or on a per-source-and-group basis.
You do not need to enable IPv6 multicast routing before this configuration.
To configure IPv6 multicast load splitting:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure IPv6 multicast load splitting. |
load-splitting {source | source-group } |
By default, IPv6 multicast load splitting is disabled. This command does not take effect on IPv6 BIDIR-PIM. |
You can configure an interface as an IPv6 multicast forwarding boundary for an IPv6 multicast group range. The interface cannot receive or forward IPv6 multicast packets for the groups in the range.
TIP: You do not need to enable IPv6 multicast routing before this configuration. |
To configure an IPv6 multicast forwarding boundary:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure an IPv6 multicast forwarding boundary. |
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } } |
By default, an interface is not an IPv6 multicast forwarding boundary for any IPv6 multicast groups. |
A super VLAN is associated with multiple sub-VLANs. Sub-VLANs are isolated with each other at Layer 2. For information about the super VLAN and sub-VLANs, see Layer 2—LAN Switching Configuration Guide.
To enable IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VLAN interface view. |
interface vlan-interface interface-number |
N/A |
3. Enable IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN. |
ipv6 multicast forwarding supervlan community |
By default, IPv6 multicast data cannot be forwarded among sub-VLANs that are associated with a super VLAN. |
4. Delete all IPv6 multicast forwarding entries with super VLAN interface as the incoming interface. |
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all } |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Specify the UDP port number used by IPv6 mtrace. |
ipv6 mtrace-service port number |
By default, IPv6 mtrace uses UDP port number 10240. For successful IPv6 mtrace, do not use a UDP port number used by other modules. You must specify the same UDP port number on all devices on the traced path. |
3. Use mtrace2 to trace an IPv6 multicast path. |
mtrace v2 ipv6 [ vpn-instance vpn-instance-name ] { source-address | group-address } * [ destination address | port number | wait-time time | max-hop count ] * [ verbose ] |
Execute this command in any view. The UDP port number specified in this command must be the same as that specified in the mtrace-service port command. |
The device caches an IPv6 multicast packet for a period of time if no matching multicast forwarding entry is found for the packet. If a multicast forwarding entry is established for the packet within the time period, the device forwards the packet. This mechanism prevents the device from mistakenly dropping IPv6 multicast packets when the multicast forwarding entries for these packets are to be established.
You can set the maximum number of unknown IPv6 multicast packets that can be cached for an (S, G) entry, in total, or both.
As a best practice, set the value in the ipv6 multicast forwarding-table cache-unknown total command to be far greater than the value in the ipv6 multicast forwarding-table cache-unknown per-entry command.
To set the maximum number of cached unknown IPv6 multicast packets:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the maximum number of unknown IPv6 multicast packets that can be cached for an (S, G) entry. |
ipv6 multicast forwarding-table cache-unknown per-entry per-entry-limit |
By default, the device can cache only one unknown IPv6 multicast packet for an (S, G) entry. |
3. Set the maximum number of unknown IPv6 multicast packets that can be cached in total. |
ipv6 multicast forwarding-table cache-unknown total total-limit |
By default, the device can cache 1024 unknown IPv6 multicast packets in total. |
CAUTION: The reset commands might cause IPv6 multicast data transmission failures. |
Task |
Command |
Display information about the interfaces maintained by the IPv6 MRIB. |
display ipv6 mrib [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] |
Display IPv6 multicast boundary information. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ] |
Display IPv6 multicast fast forwarding entries. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ] |
Display DF information. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ] [ slot slot-number ] |
Display statistics for IPv6 multicast forwarding events. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ] |
Display IPv6 multicast forwarding entries. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number | statistics ] * |
Display information about the DF list in the IPv6 multicast forwarding table. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ] [ slot slot-number ] |
Display IPv6 multicast routing entries. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] * |
Display RPF information for an IPv6 multicast source. |
display ipv6 multicast [ vpn-instance vpn-instance-name ] rpf-info ipv6-source-address [ ipv6-group-address ] |
Clear statistics for IPv6 multicast forwarding events. |
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event |
Delete IPv6 multicast fast forwarding entries. |
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ] |
Clear IPv6 multicast forwarding entries. |
Clear IPv6 multicast routing entries. |
reset ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all } |
NOTE: · When you clear an IPv6 multicast routing entry, the associated IPv6 multicast forwarding entry is also cleared. · When you clear an IPv6 multicast forwarding entry, the associated IPv6 multicast routing entry is also cleared. |
Network requirements
As shown in Figure 3:
· IPv6 multicast routing and IPv6 PIM-DM are enabled on Switch A and Switch C.
· Switch B does not support IPv6 multicast.
· Switch A, Switch B, and Switch C run OSPFv3. The source-side interface VLAN-interface 100 on Switch A does not run OSPFv3.
Configure the switches so that the receiver host can receive the IPv6 multicast data from Source.
Configuration procedure
1. Assign an IPv6 address and prefix length to each interface, as shown in Figure 3. (Details not shown.)
2. Configure OSPFv3 on the switches. Do not run OSPFv3 on VLAN-interface 100 on Switch A. (Details not shown.)
3. Configure a GRE tunnel:
# On Switch A, create service loopback group 1, and specify the unicast tunnel service for the group.
[SwitchA] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/3 to service loopback group 1. (Ten-GigabitEthernet 1/0/3 does not belong to VLAN 100 or VLAN 101.)
[SwitchA] interface ten-gigabitethernet 1/0/3
[SwitchA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[SwitchA-Ten-GigabitEthernet1/0/3] quit
# Create a GRE tunnel interface Tunnel 2, and specify the tunnel mode as GRE/IPv6.
[SwitchA] interface tunnel 2 mode gre ipv6
# Assign an IPv6 address to interface Tunnel 2, and specify its source and destination addresses.
[SwitchA-Tunnel2] ipv6 address 5001::1 64
[SwitchA-Tunnel2] source 2001::1
[SwitchA-Tunnel2] destination 3001::2
[SwitchA-Tunnel2] quit
# On Switch C, create service loopback group 1, and specify the unicast tunnel service for the group.
[SwitchC] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/3 to service loopback group 1. (Ten-GigabitEthernet 1/0/3 does not belong to VLAN 200 or VLAN 102.)
[SwitchC] interface ten-gigabitethernet 1/0/3
[SwitchC-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[SwitchC-Ten-GigabitEthernet1/0/3] quit
[SwitchC] interface tunnel 2 mode gre ipv6
[SwitchC-Tunnel2] ipv6 address 5001::2 64
[SwitchC-Tunnel2] source 3001::2
[SwitchC-Tunnel2] destination 2001::1
[SwitchC-Tunnel2] quit
4. Enable IPv6 multicast routing, IPv6 PIM-DM, and MLD:
# On Switch A, enable IPv6 multicast routing, and enable IPv6 PIM-DM on each interface.
[SwitchA-mrib6] quit
[SwitchA-Vlan-interface100] ipv6 pim dm
[SwitchA-Vlan-interface101] ipv6 pim dm
[SwitchA-Tunnel2] ipv6 pim dm
# On Switch C, enable IPv6 multicast routing.
[SwitchC-mrib6] quit
# Enable MLD on the receiver-side interface VLAN-interface 200.
# Enable IPv6 PIM-DM on VLAN-interface 102.
[SwitchC-Vlan-interface102] ipv6 pim dm
[SwitchC-Tunnel2] ipv6 pim dm
5. On Switch C, configure a static IPv6 route with the destination address 1001::1/64 and the outgoing interface Tunnel 2.
[SwitchC] ipv6 route-static 1001::1 64 tunnel 2
# Send an MLD report from Receiver to join the IPv6 multicast group FF1E::101. (Details not shown.)
# Send IPv6 multicast data from Source to the IPv6 multicast group FF1E::101. (Details not shown.)
# Display IPv6 PIM routing entries on Switch C.
[SwitchC] display ipv6 pim routing-table
(*, FF1E::101)
Protocol: pim-dm, Flag: WC
UpTime: 00:04:25
Upstream interface: NULL
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: Vlan-interface200
Protocol: mld, UpTime: 00:04:25, Expires: -
(1001::100, FF1E::101)
Protocol: pim-dm, Flag: ACT
UpTime: 00:06:14
Upstream interface: Tunnel2
Upstream neighbor: FE80::A01:101:1
RPF prime neighbor: FE80::A01:101:1
Protocol: pim-dm, UpTime: 00:04:25, Expires: -
· Switch A is the RPF neighbor of Switch C.
· IPv6 multicast data from Switch A is delivered over the GRE tunnel to Switch C.
