- 06-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
08-Multicast VPN commands | 131.25 KB |
display bgp routing-table ipv4 mdt
display multicast-vpn data-group receive
display multicast-vpn data-group send
display multicast-vpn default-group
display multicast-vpn ipv6 data-group receive
display multicast-vpn ipv6 data-group send
display multicast-vpn ipv6 default-group
multicast rpf-proxy-vector compatible
address-family ipv4
Use address-family ipv4 to create an MVPN IPv4 address family and enter its view, or enter the view of the existing MVPN IPv4 address family.
Use undo address-family ipv4 to delete the MVPN IPv4 address family and configurations in MVPN IPv4 address family view.
address-family ipv4
No MVPN IPv4 address family exists.
MVPN view
Configurations in MVPN IPv4 address family view of a VPN instance apply only to IPv4 multicast packets of that instance.
# In MVPN view of VPN instance mvpn, create an MVPN IPv4 address family and enter its view.
[Sysname] multicast-vpn vpn-instance mvpn mode mdt
[Sysname-mvpn-mvpn] address-family ipv4
[Sysname-mvpn-mvpn-ipv4]
address-family ipv4 mdt
Use address-family ipv4 mdt to create a BGP IPv4 MDT address family and enter its view, or enter the view of the existing BGP IPv4 MDT address family.
Use undo address-family ipv4 mdt to delete the BGP IPv4 MDT address family and all configurations in BGP IPv4 MDT address family view.
No BGP IPv4 MDT address family exists.
BGP instance view
Execute this command before you use the peer enable command to enable BGP peers to exchange MDT information. MDT information includes the IP address of a PE device and the default-group to which the PE device belongs. On a public network running PIM-SSM, multicast VPN establishes a default-MDT rooted at the PE device (multicast source) based on the MDT information.
Configurations in BGP IPv4 MDT address family view takes effect only on BGP MDT messages, BGP MDT peers, and BGP MDT peer groups.
# In BGP instance view of BGP instance default, create a BGP IPv4 MDT address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 mdt
[Sysname-bgp-default-mdt]
# In BGP instance view of BGP instance abc, create a BGP IPv4 MDT address family and enter its view.
[Sysname-bgp-abc] address-family ipv4 mdt
[Sysname-bgp-abc-mdt]
peer enable (see Layer 3—IP Routing Configuration Guide)
address-family ipv6
Use address-family ipv6 to create an MVPN IPv6 address family and enter its view, or enter the view of the existing MVPN IPv6 address family.
Use undo address-family ipv6 to delete the MVPN IPv6 address family and configurations in MVPN IPv6 address family view.
address-family ipv6
No MVPN IPv6 address family exists.
MVPN view
Configurations in MVPN IPv6 address family view of a VPN instance apply only to IPv6 multicast packets of that instance.
# In MVPN view of VPN instance mvpn, create an MVPN IPv6 address family and enter its view.
[Sysname-mvpn-mvpn] address-family ipv6
[Sysname-mvpn-mvpn-ipv6]
data-delay
Use data-delay to set the data-delay period (delay period before the default-MDT switches to the data-MDT).
Use undo data-delay to restore the default.
data-delay delay
undo data-delay
The data-delay period is 3 seconds.
delay: Specifies a data-delay period in the range of 1 to 60 seconds.
# In MVPN IPv4 address family view of VPN instance mvpn, set the data-delay period to 20 seconds.
[Sysname-mvpn-mvpn-ipv4] data-delay 20
data-group
Use data-group to specify a data group range and optionally configure the criteria for the default-MDT to data-MDT switchover.
Use undo data-group to restore the default.
data-group group-address { mask-length | mask } [ acl acl-number ]
undo data-group
No data group range exists, and the default-MDT to data-MDT switchover never occurs.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
mask-length: Specifies a mask length for the multicast group address. The value range for this argument is 25 to 32.
mask: Specifies a subnet mask for the multicast group address.
acl acl-number: Specifies an advanced ACL by its number in the range of 3000 to 3999. If you specify an ACL, the multicast data permitted by the ACL can trigger the switchover. If you do not specify an ACL, any multicast data can trigger the switchover. For the ACL to take effect, specify the protocol type as IP, and include the source and destination keywords when you create an ACL rule. The source and destination keywords specify a multicast source address range and a multicast group address range, respectively.
On a PE, the data group range for an MVPN cannot include the default-group or data groups of any other MVPN. For an MVPN that transmits both IPv4 and IPv6 multicast packets, the data group ranges in MVPN IPv4 address family view and MVPN IPv6 address family view cannot overlap.
The data group range specified in this command cannot contain the multicast group address for flood traffic specified by using the group command in VXLAN view. For more information about the multicast group address for VXLAN flood traffic, see basic VXLAN feature configuration in VXLAN Configuration Guide.
The data group ranges for different MVPNs on different PE devices cannot overlap with one another if the PIM mode is not PIM-SSM on the public network.
If you execute this command multiple times for an MVPN, the most recent configuration takes effect.
If BIDIR-PIM runs in a VPN instance, the switchover from the default MDT to a data MDT is not supported.
# In MVPN IPv4 address family view of VPN instance mvpn, specify 239.1.2.0 through 239.1.2.255 as the data group range.
[Sysname-mvpn-mvpn-ipv4] data-group 239.1.2.0 25
default-group
Use default-group to specify a default-group.
Use undo default-group to restore the default.
default-group group-address
undo default-group
No default-group exists.
group-address: Specifies a default-group in the range of 224.0.1.0 to 239.255.255.255.
You must specify the same default-group on all PE devices that belong to the same MVPN.
The default-group for an MVPN must be different from the default-group and the data group used by any other MVPN.
The default group address specified in this command must be different from the multicast group address for flood traffic specified by using the group command in VXLAN view. For more information about the multicast group address for VXLAN flood traffic, see basic VXLAN feature configuration in VXLAN Configuration Guide.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same default-group in MVPN IPv4 and IPv6 address family views.
# In MVPN IPv4 address family view and IPv6 address family view of VPN instance mvpn, specify 239.1.1.1 as the default-group.
[Sysname-mvpn-mvpn-ipv4] default-group 239.1.1.1
[Sysname-mvpn-mvpn-ipv4] quit
[Sysname-mvpn-mvpn-ipv6] default-group 239.1.1.1
Use display bgp routing-table ipv4 mdt to display BGP MDT routing information.
display bgp [ instance instance-name ] routing-table ipv4 mdt [ route-distinguisher route-distinguisher ] [ ip-address [ advertise-info ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP MDT routing information for the BGP instance default.
route-distinguisher route-distinguisher: Specifies an RD, a string of 3 to 21 characters. If you do not specify an RD, this command displays BGP MDT routing information for all RDs. An RD can be in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
ip-address: Specifies a multicast source by its IP address. The ip-address argument represents the IP address of the PE device in the default-MDT. If you do not specify a multicast source, this command displays brief information about BGP MDT routes for all multicast sources.
advertise-info: Displays advertisement information. If you do not specify this keyword, no advertisement information is displayed.
# Display brief information about BGP MDT routes for all multicast sources.
<Sysname> display bgp routing-table ipv4 mdt
Route distinguisher: 100:1
Total number of routes: 2
* > 1.1.1.1/32 0.0.0.0 32768 ?
* >i 2.2.2.2/32 2.2.2.2 100 0 ?
# Display detailed information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1
BGP local router ID: 1.1.1.1
Local AS number: 100
Total number of routes: 1
Paths: 1 available, 1 best
BGP MDT information of source 1.1.1.1:
Default-group : 224.1.1.1
Original nexthop: 0.0.0.0
AS-path : (null)
Origin : incomplete
Attribute value : pref-val 32768
State : valid, local, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
# Display advertisement information about BGP MDT routes for multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1 advertise-info
Paths: 1 best
Default-group: 224.1.1.1
6.6.6.6
BGP local router ID |
ID of the local router. |
Status codes |
Codes of route status: · * – valid—Valid route. · > – best—Best route. · d – damped—Dampened route. · h – history—History route. · s – suppressed—Suppressed route. · S – Stale—Stale route. · i – internal—Internal route. · e – external—External route. |
Origin |
Origin of the route information: · i – IGP—Originated in the AS. The origins of the routes advertised by the network command are IGP. · e – EGP—Learned through EGP. · ? – incomplete—Learned by some other means. The origins of routes redistributed by IGP are incomplete. |
Total number of routes |
Total number of BGP MDT routes. |
Network |
Source IP address of the default-MDT. |
NextHop |
IP address of the next hop. |
MED |
Attribute value of Multi-Exit-Discrimination (MED). |
LocPrf |
Local preference value. |
PrefVal |
Preferred value of a route. |
Path/Ogn |
AS PATH attribute and ORIGIN attribute: · AS_PATH—Records the ASs the packet has passed to avoid routing loops. · ORIGIN—Identifies the origin of the BGP MDT routes. |
Paths |
Number of the BGP MDT routes: · available—Number of valid BGP MDT routes. · best—Number of the best BGP MDT routes. |
BGP MDT information of source 1.1.1.1 |
BGP MDT routing information for the multicast source 1.1.1.1. |
Default-group |
Default-group address to which the route belongs. |
Advertised to peers (1 in total) |
Peers to which the route has been advertised and total number of peers. |
From |
IP address of the BGP peer that advertises the BGP MDT route. |
Original nexthop |
IP address of the original next hop. If the BGP MDT route is learned from the BGP update message, this field displays the IP address of the next hop that receives the message. |
AS-path |
AS PATH attribute of the path, recording the ASs that the BGP MDT route has passed to avoid routing loops. |
Attribute value |
Attributes of the BGP MDT routes: · MED—MED value related to destination network. · Localpref—Local preferred value. · pref-val—Preferred value of the route. · pre—Preferred value of the protocol. |
State |
Current states: · valid—Valid routes. · internal—Internal routes. · external—External routes. · local—Local routes. · synchronize—Synchronized routes. · best—Best routes. |
IP precedence |
IP precedence of the route, which is set by the QPPB feature. This field displays N/A if the IP precedence of the route is not set. |
QoS local ID |
QoS local ID of the route, which is set by the QPPB feature. This field displays N/A if the QoS local ID of the route is not set. |
Traffic index |
Traffic index of the route, which is set by the QPPB feature. This field displays N/A if the Traffic index of the route is not set. |
Use display multicast-vpn data-group receive to display information about data groups for IPv4 multicast transmission that are received in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
active: Specifies data groups that have joined the data-MDT.
group group-address: Specifies a data group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies an MVPN source interface by its IP address.
vpn-source-address: Specifies a multicast source address of the specified VPN instance.
vpn-group-address: Specifies a multicast group address of the specified VPN instance. The value range for this argument is 224.0.0.0 to 239.255.255.255.
mask-length: Specifies a mask length of the specified multicast source address or multicast group address. The value range for this argument is 0 to 32, and the default is 32.
mask: Specifies a subnet mask of the specified multicast source address or multicast group address. The default is 255.255.255.255.
# Display detailed information about data groups for IPv4 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn data-group receive
MVPN data-group information received by VPN instance: mvpn
Total 2 data-groups for 8 entries
Total 2 data-groups and 8 entries matched
Data-group: 226.1.1.0 Reference count: 4 Active count: 2
Sender: 172.100.1.1 Active count: 1
(192.6.1.5, 239.1.1.1) expires: 00:03:10 active
(192.6.1.5, 239.1.1.158) expires: 00:03:10
Sender: 181.100.1.1, active count: 1
(195.6.1.2, 239.1.2.12) expires: 00:03:10 active
(195.6.1.2, 239.1.2.197) expires: 00:03:10
Data-group: 229.1.1.0 Reference count: 4 Active count: 2
Sender: 185.100.1.1 Active count: 1
(198.6.1.5, 239.1.3.62) expires: 00:03:10 active
(198.6.1.5, 225.1.1.109) expires: 00:03:10
Sender: 190.100.1.1 Active count: 1
(200.6.1.2, 225.1.4.80) expires: 00:03:10 active
(200.6.1.2, 225.1.4.173) expires: 00:03:10
# Display brief information about data groups for IPv4 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn data-group receive brief
Data group: 226.1.1.0 Reference count: 4 Active count: 2
Data group: 229.1.1.0 Reference count: 4 Active count: 2
MVPN data-group information received by VPN instance: mvpn |
Information about data groups for IPv4 multicast transmission that are received in VPN instance mvpn. |
Total 2 data-groups for 8 entries |
A total of 2 data groups, associated with 8 (S, G) entries. |
Total 2 data-groups and 8 entries matched |
A total of 2 matching data groups, associated with 8 (S, G) entries. |
Data-group |
IP address of the received data group. |
Sender |
BGP peer address of the PE device that sent the data group. |
Reference count |
Number of (S, G) entries that use the data group in the VPN instance. |
Active count |
Number of active (S, G) entries (entries with active receivers) that use the data group in the VPN instance. |
expires |
Remaining time for the (S, G) entry that uses the data group in the VPN instance. |
Use display multicast-vpn data-group send to display information about data groups for IPv4 multicast transmission that are sent in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name data-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
reuse interval: Specifies an interval during which data group reuses occur, in the range of 1 to 2147483647 seconds.
# Display information about data groups for IPv4 multicast transmission that are sent in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn data-group send
MVPN data-group information sent by VPN instance: mvpn
Total 2 data-groups for 6 entries
Total 2 data-groups and 6 entries matched
Reference count of 226.1.1.0: 3
(192.6.1.5, 239.1.1.1) switch time: 00:00:21
(192.6.1.5, 239.1.1.158) switch time: 00:00:21
(192.6.1.5, 239.1.2.50) switch time: 00:00:05
Reference count of 226.1.1.1: 3
(192.6.1.2, 225.1.1.1) switch time: 00:00:21
(192.6.1.2, 225.1.2.50) switch time: 00:00:05
(192.6.1.5, 239.1.1.159) switch time: 00:00:21
# Display reuse information about data groups for IPv4 multicast transmission that are sent in VPN instance mvpn within 30 seconds.
<Sysname> display multicast-vpn vpn-instance mvpn data-group send reuse 30
Total 2 data-groups for 3 entries
Total 2 data-groups and 3 entries matched
Reuse count of 226.1.1.0: 1
Reuse count of 226.1.1.1: 1
Reuse count of 226.1.1.2: 1
MVPN data-group information sent by VPN instance: mvpn |
Information about data groups for IPv4 multicast transmission that are sent in VPN instance mvpn. |
Total 2 data-groups for 6 entries |
A total of 2 data groups, associated with 6 (S, G) entries. |
Total 2 data-groups and 6 entries matched |
A total of 2 matching data groups, associated with 6 (S, G) entries. |
Reference count of 226.1.1.0 |
switch time |
Switchover time of the (S, G) entry that uses the data group in the VPN instance. |
Reuse count of 226.1.1.0 |
Number of times that the data group is reused during the specified length of time. |
Use display multicast-vpn default-group to display information about default-groups for IPv4 multicast transmission.
display multicast-vpn [ vpn-instance vpn-instance-name ] default-group { local | remote }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about default-groups of all VPN instances for IPv4 multicast transmission.
local: Specifies local default-groups for IPv4 multicast transmission.
remote: Specifies remote default-groups for IPv4 multicast transmission.
# Display information about the local default-group for IPv4 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn default-group local
MVPN local default-group information:
Group address Source address Interface VPN instance
239.1.1.1 1.1.1.1 MTunnel0 mvpna
239.2.1.1 1.1.1.1 MTunnel1 mvpnb
239.3.1.1 -- MTunnel2 mvpnc
# Display information about the remote default-group for IPv4 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn default-group remote
MVPN remote default-group information:
Group address Source address Next hop VPN instance
239.1.1.1 1.2.0.1 1.2.0.1 a
239.1.1.1 1.2.0.2 1.2.0.2 a
239.1.1.1 1.2.0.3 1.2.0.3 a
239.1.1.2 1.2.0.1 1.2.0.1 b
239.1.1.2 1.2.0.2 1.2.0.2 b
239.1.1.3 1.2.0.1 1.2.0.1 -
Group address |
IP address of the default-group for IPv4 multicast transmission. |
Source address |
IP address of the MVPN source interface, which is used by the MTI as the source address to encapsulate multicast packets for the VPN instance. |
MTI interface. |
Next hop |
VPN instance |
VPN instance to which the default-group belongs. |
Use display multicast-vpn ipv6 data-group receive to display information about data groups for IPv6 multicast transmission that are received in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name ipv6 data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask-length ] | vpn-group-address [ mask-length ] ] * ]
group group-address: Specifies a data group by its address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies an MVPN source interface by its address.
vpn-source-address: Specifies an IPv6 multicast source address of the specified VPN instance.
vpn-group-address: Specifies an IPv6 multicast group address of the specified VPN instance. The value range for this argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers from 0 to F.
mask-length: Specifies a mask length of the specified IPv6 multicast source address or IPv6 multicast group address. For the IPv6 multicast source address, the value range for this argument is 8 to 128, and the default is 128. For the IPv6 multicast group address, the value range for this argument is 0 to 128, and the default is 128.
# Display detailed information about data groups for IPv6 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group receive
(192::1, ff1e::1)
(192::1, ff1e::2)
expires: 00:03:10
(192::2, ff1e::11)
(192::2, ff1e::12)
expires: 00:03:10
(192::6, ff1e::15)
(192::6, ff1e::16)
expires: 00:03:10
(192::11, ff1e::21)
(192::11, ff1e::22)
expires: 00:03:10
# Display brief information about data groups for IPv6 multicast transmission that are received in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group receive brief
Table 5 Command output
Information about data groups for IPv6 multicast transmission that are received in VPN instance mvpn. |
A total of 2 matching data groups, associated with 8 matching (S, G) entries. |
Data-group |
Sender |
Reference count |
Active count |
Number of active (S, G) entries (entries with receivers) that use the data group in the VPN instance. |
expires |
Use display multicast-vpn ipv6 data-group send to display information about data groups for IPv6 multicast transmission that are sent in a VPN instance.
display multicast-vpn vpn-instance vpn-instance-name ipv6 data-group send [ group group-address | reuse interval | vpn-source-address [ mask-length ] | vpn-group-address [ mask-length ] ] *
mask-length: Specifies a mask length of the specified IPv6 multicast source or IPv6 multicast group address. For the IPv6 multicast source address, the value range for this argument is 8 to 128, and the default is 128. For the IPv6 multicast group address, the value range for this argument is 0 to 128, and the default is 128.
# Display information about data groups for IPv6 multicast transmission that are sent in VPN instance mvpn.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group send
(192::1, ff1e::1)
(192::1, ff1e::2)
(192::1, ff1e::3)
(192::2, ff1e::4)
(192::2, ff1e::5)
(192::2, ff1e::6)
# Display reuse information about data groups for IPv6 multicast transmission that are sent in VPN instance mvpn within 30 seconds.
<Sysname> display multicast-vpn vpn-instance mvpn ipv6 data-group send reuse 30
Table 6 Command output
Information about data groups for IPv6 multicast transmission that are sent in VPN instance mvpn. |
A total of 2 matching data groups, associated with 6 matching (S, G) entries. |
switch time |
Use display multicast-vpn ipv6 default-group to display information about default-groups for IPv6 multicast transmission.
display multicast-vpn [ vpn-instance vpn-instance-name ] ipv6 default-group { local | remote }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about default-groups of all VPN instances for IPv6 multicast transmission.
local: Specifies local default-groups for IPv6 multicast transmission.
remote: Specifies remote default-groups for IPv6 multicast transmission.
# Display information about the local default-group for IPv6 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn ipv6 default-group local
# Display information about the remote default-group for IPv6 multicast transmission in each VPN instance.
<Sysname> display multicast-vpn ipv6 default-group remote
Table 7 Command output
Group address |
IP address of the default-group for IPv6 multicast transmission. |
Source address |
IP address of the MVPN source interface, which is used by the MTI as the source address to encapsulate IPv6 multicast packets of the VPN instance. |
MTI interface. |
Next hop |
VPN instance |
dscp
Use dscp to set the DSCP value for outgoing multicast VPN protocol packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value is 48 for outgoing multicast VPN protocol packets.
MVPN view
dscp-value: Specifies a DSCP in the range of 0 to 63.
The DSCP value determines the packet transmission priority. A greater DSCP value represents a higher priority.
# Set the DSCP value to 63 for outgoing multicast VPN protocol packets.
[Sysname-mvpn-mvpn] dscp 63
log data-group-reuse
Use log data-group-reuse to enable data group reuse logging.
Use undo log data-group-reuse to disable data group reuse logging.
Data-group reuse logging is disabled.
# In MVPN IPv4 address family view of VPN instance mvpn, enable data group reuse logging.
[Sysname-mvpn-mvpn-ipv4] log data-group-reuse
Use multicast rpf-proxy-vector compatible to enable RPF vector compatibility.
Use undo multicast rpf-proxy-vector compatible to disable RPF vector compatibility.
RPF vector compatibility is disabled.
This command enables the device to work with other manufacturers' products on the RPF vector. You must configure this command on all H3C devices on the public network for MVPN inter-AS option B.
# Enable RPF vector compatibility.
[Sysname] multicast rpf-proxy-vector compatible
multicast-vpn
Use multicast-vpn to create an MVPN for a VPN instance and enter its view, or enter the view of the existing MVPN.
Use undo multicast-vpn to delete configurations in MVPN view for a VPN instance.
multicast-vpn vpn-instance vpn-instance-name mode mdt
undo multicast-vpn vpn-instance vpn-instance-name
No MVPN exists.
mode: Specifies the MVPN mode.
mdt: Specifies the MDT mode for the MVPN.
# Create an MVPN in MDT mode for VPN instance mvpn and enter MVPN view.
[Sysname-mvpn-mvpn]
rpf proxy vector
Use rpf proxy vector to enable the RPF vector feature.
Use undo rpf proxy vector to disable the RPF vector feature.
rpf proxy vector
The RPF vector feature is disabled.
MRIB view
This feature enables PE devices to carry the RPF vector information in PIM join messages for other devices to perform RPF check on the messages.
You must enable this feature on PE devices (excluding the PE devices that do not have attached receivers) when you configure MVPN inter-AS option B.
Only the configuration made in MRIB view of a VPN instance takes effect. The configuration made in MRIB view on the public network does not take effect.
# Enable the RPF vector feature for VPN instance mvpn.
[Sysname] multicast routing vpn-instance mvpn mode mdt
[Sysname-mrib-mvpn] rpf proxy vector
source
Use source to specify an MVPN source interface.
Use undo source to restore the default.
source interface-type interface-number
undo source
No MVPN source interface is specified.
For the PE device to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MVPN source interface.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same MVPN source interface in MVPN IPv4 and IPv6 address family views.
# In MVPN IPv4 address family view and IPv6 address family view of VPN instance mvpn, specify Loopback 1 as the MVPN source interface. (Loopback 1 is the source interface used for establishing BGP peer relationship.)
[Sysname-mvpn-mvpn-ipv4] source loopback 1
[Sysname-mvpn-mvpn-ipv6] source loopback 1
