06-IP Multicast Command Reference
HomeSupportSwitchesS6860 SeriesReference GuidesCommand ReferencesH3C S6860 Switch Series Command References-Release 26xx-6W10306-IP Multicast Command Reference
02-PIM snooping commands
02-PIM snooping commands 72.00 KB
display pim-snooping neighbor
Use display pim-snooping neighbor to display PIM snooping neighbor information.
display pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping neighbor information for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays PIM snooping neighbor information for the master device.
verbose: Displays detailed information about PIM snooping neighbors. If you do not specify this keyword, the command displays brief information about PIM snooping neighbors.
# Display detailed information about PIM snooping neighbors for VLAN 2.
<Sysname> display pim-snooping neighbor vlan 2 verbose
Total 2 neighbors.
VLAN 2: Total 2 neighbors.
  10.1.1.2
    Slots (0 in total):
    Ports (1 in total):
      XGE1/0/1                              (02:02:23)    LAN Prune Delay(T)
  10.1.1.3
    Slots (0 in total):
    Ports (1 in total):
      XGE1/0/2                              (02:02:25)
Total 2 neighbors
Total number of PIM snooping neighbors.
Total number of PIM snooping neighbors in VLAN 2.
10.1.1.2
IP address of the PIM snooping neighbor.
Slots (0 in total)
Member IDs and total number of the member devices that have the neighbor, except for the specified member device or the master device when no member device is specified.
Ports (1 in total)
Ports where the PIM snooping neighbors reside, and the total number of the ports.
(02:02:23)
Remaining aging timer for a PIM snooping neighbor on the port.
This field is always displayed for a global port (such as Layer 2 aggregate interfaces, ACs, N-PWs, and U-PWs).
For a non-global port, this field is displayed when one of the following conditions exists:
·     The port is on the specified member device.
·     The port is on the master device and no member device is specified.
LAN Prune Delay
The PIM hello message sent by the PIM snooping neighbor has the LAN_Prune_Delay option.
(T)
The join message suppression feature has been disabled for the PIM snooping neighbor.
XGE1/0/3
Member port.
display pim-snooping router-port
Use display pim-snooping router-port to display PIM snooping router port information.
display pim-snooping router-port [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping router port information for all VLANs.
verbose: Displays detailed information about PIM snooping router ports. If you do not specify this keyword, the command displays brief information about PIM snooping router ports.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays PIM snooping router port information for the master device.
# Display brief information about PIM snooping router ports for VLAN 2.
<Sysname> display pim-snooping router-port vlan 2
VLAN 2:
  Router ports (2 in total):
    XGE1/0/1                              (00:01:30)
    XGE1/0/2                              (00:01:32)
VLAN 2
VLAN ID.
Router slots (0 in total)
Member IDs and total number of the member devices that have router ports, except for the specified member device or the master device when no member device is specified.
Router ports and total number of router ports.
(00:01:30)
Remaining aging time for the router port.
For a global port, this field is always displayed.
XGE1/0/3
Member port.
display pim-snooping routing-table
Use display pim-snooping routing-table to display PIM snooping routing entries.
display pim-snooping routing-table [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping routing entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays PIM snooping routing entries for the master device.
verbose: Displays detailed information about PIM snooping routing entries. If you do not specify the keyword, this command displays brief information about PIM snooping routing entries.
# Display detailed information about PIM snooping routing entries for VLAN 2.
<Sysname> display pim-snooping routing-table vlan 2 verbose
Total 1 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 2: Total 1 entries.
  (172.10.10.1, 225.1.1.1)
    FSM information: dummy
    Upstream neighbor: 20.1.1.1
      Upstream Slots (0 in total):
      Upstream Ports (1 in total):
        XGE1/0/1
      Downstream Slots (0 in total):
      Downstream Ports (2 in total):
        XGE1/0/2
          Expires: 00:03:01, FSM: J
          Downstream Neighbors (2 in total):
            7.1.1.1
              Expires: 00:59:19, FSM: J
            7.1.1.11
              Expires: 00:59:20, FSM: J
        XGE1/0/3
          Expires: 00:02:21, FSM: PP
Total 1 entries
Total number of (S, G) entries and (*, G) entries.
State machine flag of the downstream port:
·     NI—Initial state.
·     J—Join.
·     PP—Prune pending.
Total number of (S, G) entries and (*, G) entries in VLAN 2.
(S, G) entry.
FSM information
Finite state machine information of the entry:
·     delete—The entry attributes have been deleted.
·     dummy—The entry is a new temporary entry.
·     no info—The entry does not exist.
·     normal—The entry is a correct entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Member IDs and total number of the member devices that have the upstream neighbor, except for the specified member device or the master device when no member device is specified.
Upstream ports, and the total number of upstream ports.
This field is displayed when one of the following conditions exists:
Member IDs and total number of the member devices that have downstream ports, except for the specified member device or the master device when no member device is specified.
Downstream ports of the upstream neighbor, and the total number of the downstream ports.
Downstream neighbors of the downstream port, and the total number of the downstream neighbors.
Remaining aging time for the downstream port or downstream neighbor, and the finite state machine information.
XGE1/0/3
Member port.
display pim-snooping statistics
Use display pim-snooping statistics to display statistics for the PIM messages learned through PIM snooping.
# Display statistics for the PIM messages learned through PIM snooping.
<Sysname> display pim-snooping statistics
Received PIMv2 hello:  100
Received PIMv2 join/prune:  100
Received PIMv2 error:  0
Received PIMv2 messages in total:  200
Received PIMv1 messages in total:  0
Number of received PIMv2 hello messages.
Number of received PIMv2 join/prune messages.
Number of received PIMv2 messages with errors.
Total number of received PIMv2 messages.
Total number of received PIMv1 messages.
reset pim-snooping statistics
pim-snooping enable
Use pim-snooping enable to enable PIM snooping for a VLAN.
Use undo pim-snooping enable to disable PIM snooping for a VLAN.
pim-snooping enable
PIM snooping is disabled for a VLAN.
VLAN view
You must enable IGMP snooping globally and for a VLAN before you enable PIM snooping for the VLAN.
PIM snooping does not take effect on sub-VLANs of a multicast VLAN.
# Enable the IGMP snooping feature, and then enable IGMP snooping and PIM snooping for VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] pim-snooping enable
igmp-snooping
pim-snooping graceful-restart join-aging-time
Use pim-snooping graceful-restart join-aging-time to set the aging time for global downstream ports and global router ports on the new master device after a master/subordinate switchover.
Use undo pim-snooping graceful-restart join-aging-time to restore the default.
pim-snooping graceful-restart join-aging-time seconds
The default setting is 210 seconds.
VLAN view
seconds: Specifies an aging time in the range of 210 to 18000 seconds.
You must enable PIM snooping for a VLAN before you execute this command.
Global ports include Layer 2 aggregate interfaces. A global downstream port or a global router port is a global port that acts as a downstream port or router port, respectively.
# In VLAN 2, set the aging time to 600 seconds for global downstream ports and global router ports on the new master device after a master/subordinate switchover.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart join-aging-time 600
pim-snooping enable
pim-snooping graceful-restart neighbor-aging-time
Use pim-snooping graceful-restart neighbor-aging-time to set the aging time for global neighbor ports on the new master device after a master/subordinate switchover.
Use undo pim-snooping graceful-restart neighbor-aging-time to restore the default.
pim-snooping graceful-restart neighbor-aging-time seconds
The default setting is 105 seconds.
VLAN view
seconds: Specifies an aging time in the range of 105 to 18000 seconds.
You must enable PIM snooping in a VLAN before you execute this command.
Global ports include Layer 2 aggregate interfaces. A global neighbor port is a global port that acts as a neighbor port.
# In VLAN 2, set the aging time to 300 seconds for global neighbor ports on the new master device after a master/subordinate switchover.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart neighbor-aging-time 300
pim-snooping enable
Use reset pim-snooping statistics to clear statistics for the PIM messages learned through PIM snooping.
# Clear statistics for the PIM messages learned through PIM snooping.
<Sysname> reset pim-snooping statistics
  • Become a Partner
  • Partner Resources
