02-Layer 2-LAN Switching Configuration Guide
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S12500R Switch Router Series Configuration Guides(R3606)-6W10002-Layer 2-LAN Switching Configuration Guide
14-Cut-through Layer 2 forwarding configuration
Configuring cut-through Layer 2 forwarding
About cut-through Layer 2 forwarding
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
Restrictions and guidelines for cut-through Layer 2 forwarding configuration
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of dropped.
2.     Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
  • Computing
  • Become a Partner
  • Partner Resources
