01-OpenFlow commands | 148.89 KB |
OpenFlow commands
In this chapter, an OpenFlow switch is the same as an OpenFlow instance, unless otherwise specified.
active instance
Use active instance to activate or reactivate an OpenFlow instance.
Use undo active instance to deactivate an OpenFlow instance.
active instance
An OpenFlow instance is not activated.
OpenFlow instance view
An OpenFlow instance takes effect only after it is activated.
Reactivating an OpenFlow instance refreshes the configuration data and interrupts communication with the controllers.
You can reactivate an OpenFlow instance by using the active instance command after you deactivate the OpenFlow instance by using the undo active instance command.
# Activate OpenFlow instance 1.
[Sysname] openflow instance 1
[Sysname-of-inst-1] active instance
classification global
Use classification global to enable the global mode for an OpenFlow instance.
Use undo classification to remove the configuration.
undo classification
An OpenFlow instance is in the VLAN mode.
If you execute the classification global and classification vlan commands multiple times, the most recent configuration takes effect.
By default, an OpenFlow instance is in the VLAN mode. When an OpenFlow instance is associated with VLANs, the flow entries take effect only on packets within those VLANs.
When the global mode is enabled for an OpenFlow instance, the flow entries take effect on packets within the network. All interfaces on the device belong to the OpenFlow instance, including VLAN interfaces and Layer 2 Ethernet interfaces.
# Enable the global mode for OpenFlow instance 1.
[Sysname-of-inst-1] classification global
classification vlan
classification vlan
Use classification vlan to associate VLANs with an OpenFlow instance.
Use undo classification to cancel the association.
classification vlan vlan-id [ mask vlan-mask ] [ loosen ]
undo classification
An OpenFlow instance is not associated with any VLAN.
vlan-id: Specifies the VLAN ID in the range of 1 to 4094.
vlan-mask: Specifies a VLAN mask in the range of 0 to 4095. The default value is 4095.
loosen: Specifies the loosen mode for the OpenFlow instance-VLAN association.
The system calculates the VLANs to be associated according to the specified VLAN ID and mask. To view the associated VLANs, use the display openflow instance command.
When the loosen keyword is specified, a port belongs to an OpenFlow instance only when the VLANs associated with the OpenFlow instance overlap with the VLANs permitted on the port.
When the loosen keyword is not specified, a port belongs to an OpenFlow instance only when the VLANs associated with the OpenFlow instance are a subset of the VLANs permitted on the port.
# Associate an OpenFlow instance with a list of VLANs determined by VLAN ID 255 and VLAN mask 7.
[Sysname-of-inst-1] classification vlan 255 mask 7
controller address
Use controller address to specify a controller for an OpenFlow switch and configure the main connection to the controller.
Use undo controller address to remove the configuration.
controller controller-id address { ip ip-address | ipv6 ipv6-address } [ port port-number ] [ local address { ip ip-address | ipv6 ipv6-address } [ port port-number ]] [ ssl ssl-policy-name ] [ vrf vrf-name ]
undo controller controller-id address
An OpenFlow instance does not have a main connection to a controller.
controller-id: Specifies a controller by its ID in the range of 0 to 63.
ip ip-address: Specifies the IPv4 address of the controller or the device.
ipv6 ipv6-address: Specifies the IPv6 address of the controller or the device.
local address: Specifies the IPv4 or IPv6 address that the device uses to establish connections with the controller.
port port-number: Sets the port number that the device or the controller uses to establish TCP connections between them. The value range for the port number is 1 to 65535. The default value is 6633.
ssl ssl-policy-name: Specifies the SSL client policy that the controller uses to authenticate the OpenFlow switch. The policy name is a case-insensitive string of 1 to 31 characters.
vrf vrf-name: Specifies the name of the VPN instance to which the controller belongs, a case-insensitive string of 1 to 31 characters.
You can specify multiple controllers for an OpenFlow switch. The OpenFlow channel between the OpenFlow switch and each controller can have only one main connection.
The OpenFlow switch exchanges control messages with a controller through the main connection to perform the following tasks:
· Receive flow table entries or data from the controller.
· Report information to the controller.
# Specify controller 10 for OpenFlow instance 1. The controller's IP address is 1.1.1.1 and the port number is 6666.
[Sysname-of-inst-1] controller 10 address ip 1.1.1.1 port 6666
controller connect interval
Use controller connect interval to set a reconnection interval for an OpenFlow instance.
Use undo controller connect interval to restore the default.
controller connect interval interval-value
The reconnection interval is 60 seconds for an OpenFlow instance.
interval-value: Sets a reconnection interval in seconds, in the range of 10 to 120.
The OpenFlow instance waits a reconnection interval before it attempts to reconnect to a controller.
# Set the reconnection interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller connect interval 10
controller echo-request interval
Use controller echo-request interval to set the connection detection interval for an OpenFlow switch. The connection detection interval specifies the interval at which the OpenFlow switch sends an Echo Request message to a controller.
Use undo controller echo-request interval to restore the default.
controller echo-request interval interval-value
The connection detection interval is 5 seconds for an OpenFlow switch.
interval-value: Specifies the connection detection interval in seconds. The value range is 1 to 10.
As a best practice to reduce the CPU load, set the connection detection interval to a large value.
# Set the connection detection interval to 10 seconds for OpenFlow instance 1.
[Sysname-of-inst-1] controller echo-request interval 10
controller mode
Use controller mode to set the controller mode for an OpenFlow instance.
Use undo controller mode to restore the default.
The controller mode is multiple.
multiple: Configures the controller mode as multiple.
single: Configures the controller mode as single.
An OpenFlow instance can connect to one or more controllers, depending on the controller mode the OpenFlow instance uses:
· Single—The OpenFlow instance connects to only one controller at a time. When communication with the current controller fails, the OpenFlow instance uses another controller.
· Multiple—The OpenFlow instance can simultaneously connect to multiple controllers. When communication with any controller fails, the OpenFlow instance attempts to reconnect to the controller after a reconnection interval.
# Configure the controller mode as single for OpenFlow instance 1.
[Sysname-of-inst-1] controller mode single
datapath-id
Use datapath-id to configure the datapath ID for an OpenFlow instance.
Use undo datapath-id to restore the default.
datapath-id datapath-id
undo datapath-id
The datapath ID of an OpenFlow instance contains the instance ID and the bridge MAC address. The upper 16 bits are the instance ID and the lower 48 bits are the bridge MAC address.
datapath-id: Specifies the datapath ID for an OpenFlow instance. The argument is a hexadecimal number and the value range is 1 to 0xFFFFFFFFFFFFFFFF.
# Set the datapath ID to 0x123456 for OpenFlow instance 1.
[Sysname-of-inst-1] datapath-id 123456
default table-miss permit
Use default table-miss permit to change the default action of the table-miss flow entry to forward packets to the normal pipeline.
Use undo default table-miss permit to restore the default.
The default action of the table-miss flow entry is to drop packets after the OpenFlow instance is activated and before the controller deploys flow entries.
# Change the default action of the table-miss flow entry to forward packets to the normal pipeline.
[Sysname-of-inst-1] default table-miss permit
description
Use description to configure a description for an OpenFlow instance.
An OpenFlow instance does not have a description.
text: Specifies a description for the OpenFlow instance, a case-insensitive string of 1 to 255 characters.
# Configure a description for OpenFlow instance 1 as test-desc.
[Sysname-of-inst-1] description test-desc
display openflow controller
Use display openflow controller to display controller information for an OpenFlow instance.
display openflow instance instance-id controller [ controller-id ]
instance-id: Specifies an OpenFlow instance by its ID in the range of 1 to 4094.
controller-id: Specifies a controller by its ID in the range of 0 to 63. If no controller ID is specified, this command displays information about all controllers for an OpenFlow instance.
The controller information includes connection information and packet statistics.
# Display controller information for OpenFlow instance 10.
<Sysname> display openflow instance 10 controller
Instance 10 controller information:
Reconnect interval: 60 (s)
Echo interval : 5 (s)
Controller ID : 1
Controller IP address : 192.168.49.49
Controller port : 6633
Controller role : --
Connect type : TCP
Connect state : Idle
Packets sent : 0
Packets received : 0
SSL policy : --
VRF name : --
Reconnection interval (in seconds) for an OpenFlow instance to reconnect to all controllers. |
Interval (in seconds) at which an OpenFlow instance sends an Echo Request message to all controller. |
IP address of the controller. |
TCP port number of the controller. |
Controller role |
Role of the controller: · Equal—The controller has the same mode as other controllers that are specified for the OpenFlow instance. · Master—The controller is the master controller for the OpenFlow instance. · Slave—The controller is a subordinate controller for the OpenFlow instance. If the controller is not configured with any role, this field displays two hyphens (--). |
Connect type |
Type of the connection between the OpenFlow instance and the controller: TCP or SSL. |
Connect state |
State of the connection between the OpenFlow instance and the controller: Idle or Established. |
Packets sent |
Number of packets that have been sent to the controller. |
Packets received |
Number of packets that have been received from the controller. |
SSL policy |
Name of the SSL client policy used for SSL connections. If no SSL client policy controller is configured, this field displays two hyphens (--). |
VRF name |
Name of the VPN instance to which the controller belongs. |
display openflow flow-table
Use display openflow flow-table to display flow table information for an OpenFlow instance.
display openflow instance instance-id flow-table [ table-id ]
table-id: Specifies a flow table by its ID in the range of 0 to 254.
If you do not specify the flow table ID, this command displays information about all flow tables for the specified OpenFlow instance.
# Display information about all flow tables for OpenFlow instance 10.
<Sysname> display openflow instance 10 flow-table
Instance 10 flow table information:
Table 0 information:
Table type: MAC-IP, flow entry count: 1, total flow entry count: 2
MissRule (default) flow entry information:
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: reset_counts
|no_pkt_counts|no_byte_counts, byte count: --, packet count: --
Match information: any
Instruction information:
Write actions:
Drop
Flow entry 1 information:
cookie: 0x0, priority: 1, hard time: 0, idle time: 0, flags: none,
Match information:
Ethernet destination MAC address: 0000-0000-0001
Ethernet destination MAC address mask: ffff-ffff-ffff
VLAN ID: 100, mask: 0xfff
Write actions:
Output interface: XGE1/0/4
Write metadata/mask: 0x0000000000000001/0xffffffffffffffff
Goto table: 1
Table 1 information:
Table type: Extensibility, flow entry count: 2, total flow entry count: 2
MissRule Flow entry information:
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: none,
byte count: --, packet count: 60
Write actions:
Drop
cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem
|check_overlap, byte count: --, packet count: 1
Match information:
Input interface: XGE1/0/3
Ethernet source MAC address: 0000-0000-0001
Ethernet source MAC address mask: ffff-ffff-ffff
Set meter: 100
Apply actions:
Write actions:
Output interface: Controller, send length: 128 bytes
Table type |
Type of the flow table: MAC-IP or Extensibility. |
flow entry count |
Number of flow entries deployed by controllers. |
total flow entry count |
Total number of flow entries in the table. |
cookie |
Cookie ID of the flow entry. |
priority |
Priority of the flow entry. The larger the value, the higher the priority. |
hard time |
Hard timeout of the flow entry, in seconds. The flow entry is aged out immediately after the hard timeout expires. If the flow entry has no hard timeout, the field displays 0. |
idle time |
Idle timeout of the flow entry, in seconds. The flow entry is aged out if no packet matches the entry within the idle timeout. If the flow entry has no idle timeout, the field displays 0. |
flags |
Flags that the flow entry includes: · flow_send_rem—Sends a flow removed message when the flow entry is removed or expires. · check_overlap—Checks for overlapping flow entries. · reset_counts—Resets flow table counters. · no_pkt_counts—Does not count packets. · no_byte_counts—Does not count bytes. If the flow entry does not include any flags, this field displays none. |
byte count |
Number of bytes that have matched the flow entry. |
packet count |
Number of packets that have matched the flow entry. |
Match information |
Contents in the Match field of the flow entry (see Table 3). |
Instruction information |
Contents in the Instruction field of the flow entry: · Set meter—Sends the matched packet to a specified meter. · Write metadata/mask—Writes the masked metadata value into the metadata fields of the matched packet. Metadata is used for passing messages between flow tables. · Goto table—Sends the matched packet to the next flow table for processing. · Clear actions—Immediately clears all actions in the action set of the matched packet. · Apply actions—Immediately applies specified actions in the action set of the matched packet. · Write actions—Writes specified actions into the action set of the matched packet. For more information about actions, see Table 4. |
Match field |
Match field mask |
Input interface |
N/A |
Ingress port (see Table 5). |
Physical input interface |
N/A |
Ingress physical port. |
Metadata |
Mask |
Metadata and mask that are transmitted between flow tables. |
Ethernet destination MAC address |
Mask |
Ethernet destination MAC address and mask. |
Ethernet source MAC address |
Mask |
Ethernet source MAC address and mask. |
Ethernet type |
N/A |
Ethernet type of the OpenFlow packet payload. |
VLAN ID |
Mask |
VLAN ID and mask. |
VLAN PCP |
N/A |
VLAN priority. |
IP DSCP |
N/A |
Differentiated Services Code Point (DSCP) value. |
IP ECN |
N/A |
Explicit Congestion Notification (ECN) value in the IP header. |
IP protocol |
N/A |
IPv4 or IPv6 protocol number. |
IPv4 source address |
Mask |
IPv4 source address and mask. |
IPv4 destination address |
Mask |
IPv4 destination address and mask. |
TCP source port |
N/A |
TCP source port. |
TCP destination port |
N/A |
TCP destination port. |
UDP source port |
N/A |
UDP source port. |
UDP destination port |
N/A |
UDP destination port. |
ICMPv4 type |
N/A |
ICMPv4 type. |
ICMPv4 code |
N/A |
ICMPv4 code. |
ARP source IPv4 address |
Mask |
Sender IPv4 address and mask in the ARP payload. |
ARP source MAC address |
Mask |
Sender MAC address and mask in the ARP payload. |
IPv6 source address |
Mask |
Source IPv6 address and mask. |
IPv6 destination address |
Mask |
Destination IPv6 address and mask. |
IPv6 flow label |
Mask |
IPv6 flow label and mask. |
ICMPv6 type |
N/A |
ICMPv6 type. |
ICMPv6 code |
N/A |
ICMPv6 code. |
N/A |
Output port. |
Drop |
Drops the matched packet. |
Output interface |
Sends the packet through a specified port. For more information about ports, see Table 5. |
Group |
Specifies a group to process the packet. |
Set queue |
Maps the flow entry to a queue specified by ID. |
Set field |
Modifies a field of the packet. |
Port name |
Ingress port |
Output port |
Normal |
Not supported. |
Supported. |
Normal forwarding workflow of the switch. |
Flood |
Not supported. |
Supported. |
Flooding workflow. |
All |
Not supported. |
Supported. |
All ports. |
Controller |
Supported. |
Supported. |
Channel connected to the controller. |
Local |
Supported. |
Supported. |
Local CPU. |
XGE1/0/3 (port name) |
Supported. |
Supported. |
Name of a physical or logical port, such as a link aggregation port. |
display openflow group
Use display openflow group to display the group table information for an OpenFlow instance.
display openflow instance instance-id group [ group-id ]
group-id: Specifies a group by its ID in the range of 0 to 4294967040. If this argument is not specified, this command displays information about all group entries of the OpenFlow instance.
The group entries are referenced by flow entries to make the OpenFlow device support more packet forwarding functions, for example, multicast and broadcast. Each group table contains multiple action buckets. The actions in the buckets of a group entry are performed for packets matching the group entry.
You cannot configure group entries on the OpenFlow devices. Instead, you can configure group entries on the controller and issue the group entries to the OpenFlow device.
# Display the group table information for OpenFlow instance 10.
<Sysname> display openflow instance 10 group
Instance 10 group table information:
Group count: 1
Group entry 1:
Type: All, byte count: 55116, packet count: 401
Bucket 1 information:
Action count 1, watch port: any, watch group: any
Byte count 55116, packet count 401
Output interface: XGE1/0/11
Bucket 2 information:
Byte count --, packet count --
Output interface: XGE1/0/12
Referenced information:
Count: 3
Flow table 0
Flow entry: 1, 2, 3
Table 6 Output description
Group count |
Number of group entries contained in the OpenFlow instance. |
Type |
Group table type: All—Execute all buckets in the group. This group is used for multicast or broadcast forwarding. |
Action count |
Number of actions in the action bucket. |
Byte count |
Number of bytes processed by the action bucket. |
packet count |
Number of packets processed by the action bucket. |
watch port |
Ports that affect the action bucket status. |
watch group |
Group table IDs of the ports that affect the action bucket status. |
Output interface |
Output interface in the group table. |
Referenced information |
Information about the group entry referenced by flow entries. |
Count |
Total number of flow entries that reference the group entry. |
Flow table |
Flow table to which the flow entries that reference the group entry belong. |
Flow entry |
Flow entries that reference the group entry. |
Use display openflow instance to display detailed information about an OpenFlow instance.
display openflow instance [ instance-id ]
# Display detailed information about OpenFlow instances.
Instance 10 information:
Configuration information:
Description : test-desc
Active status : Active
Inactive configuration:
Active configuration:
Classification :VLAN, loosen mode, total VLANs(1)
2
In-band management VLAN, total VLANs(0)
Empty VLAN
Connect mode: Multiple
MAC address learning: Enabled
Flow table:
Table ID(type): 0(MAC-IP), count: 0
Flow-entry max-limit: 65535
Datapath ID: 0x0000001234567891
Default table-miss: Drop
Forbidden port: None
Port information:
Ten-GigabitEthernet1/0/3
Active channel information:
Controller 1 IP address: 192.168.49.49 port: 6633
Controller 2 IP address: 192.168.43.49 port: 6633
Table 7 Command output
Description of the OpenFlow instance. |
Active status |
Activation status of the OpenFlow instance. |
Inactive configuration |
Inactive OpenFlow instance configuration. |
Active configuration |
Active OpenFlow instance configuration. |
Classification: VLAN, loosen mode, total VLANs |
OpenFlow instance scope, VLANs associated with the OpenFlow instance, the total number of these VLANs. |
In-band management VLAN, total VLANs |
Inband management VLANs and the total number of inband management VLANs. empty VLAN is displayed when no inband management VLAN is configured. |
Connect mode |
Controller mode of the OpenFlow instance: · Multiple. · Single. |
MAC address learning |
MAC address learning status in the VLANs associated with the OpenFlow instance: · Enabled—MAC address learning is enabled in the VLANs associated with the OpenFlow instance. · Disabled—MAC address learning is disabled in the VLANs associated with the OpenFlow instance. |
Flow-entry max-limit |
Maximum number of flow entries allowed in the extensibility flow table. |
Datapath ID |
Datapath ID of the OpenFlow instance. |
Default table-miss |
Default action of the table-miss flow entry: · Permit—Forward packets to the normal pipeline. · Drop—Drop packets. |
Forbidden port |
Port types forbidden to be reported to controllers: · VLAN interface. · Virtual Switch Interface. |
Port information |
Ports added to the OpenFlow instance. |
Flow table |
Flow table information of the OpenFlow instance. |
Table ID(type) |
Flow table ID (flow table type). The flow table type can be MAC-IP or Extensibility. |
count |
Total number of flow entries in the flow table. |
Active channel information |
Information about active control channels. |
Controller id IP address: port: |
Brief information of controllers which have established connections to the OpenFlow instance. This field is displayed only when the OpenFlow instance has established connections to controllers. |
Failopen mode |
Connection interruption mode when the OpenFlow instance is disconnected from all controllers (this field is displayed only when the OpenFlow instance is disconnected from all controllers): · secure—The OpenFlow switch uses flow tables for traffic forwarding after it is disconnected from all controllers. · standalone—The OpenFlow switch uses the normal forwarding process after it is disconnected from all controllers. |
display openflow meter
Use display openflow meter to display meter entry information for an OpenFlow instance.
display openflow instance instance-id meter [ meter-id ]
meter-id: Specifies a meter by its ID in the range of 0 to 4294901760. If no meter ID is specified, this command displays information about all meter entries for an OpenFlow instance.
# Display meter entry information for OpenFlow instance 10.
<Sysname> display openflow instance 10 meter
Meter flags: KBPS -- Rate value in kb/s, PKTPS -- Rate value in packet/sec
BURST -- Do burst size, STATS -- Collect statistics
Instance 10 meter table information:
meter entry count: 2
Meter entry 100 information:
Meter flags: KBPS
Band 1 information
Type: drop, rate: 1024, burst size: 65536
Byte count: --, packet count: 0
Referencedinformation:
Count: 3
Flow table: 0
Flow entry: 1, 2, 3
Meter entry 200 information:
Meter flags: KBPS
Band 1 information
Type: drop, rate: 10240, burst size: 655360
Byte count: --, packet count: --
Count: 0
Table 8 Command output
Group entry count |
Total number of meter entries included in the OpenFlow instance. |
Meter flags |
Flags configured for the meter: · KBPS—The rate value is in kbps. · PKTPS—The rate value is in pps. · BURST—The burst size field in the band is used and the length of the packet or byte burst is determined by the burst size. · STATS—Meter statistics are collected. |
Band |
Bands included in the meter. |
Type |
Type of the band: · drop—Discard the packet. · dscp remark—Modify the drop precedence of the DSCP field in the IP header of the packet. |
Rate |
Rate value above which the corresponding band may apply to packets. |
Burst size |
Length of the packet or byte burst to consider for applying the meter. |
Byte count |
Number of bytes processed by a band. If this field is not supported, the field displays two hyphens (--). |
packet count |
Number of packets processed by a band. If this field is not supported, the field displays two hyphens (--). |
Information about the meter entry referenced by flow entries. |
Count |
Total number of flow entries that reference the meter entry. |
Flow table |
Flow table to which the flow entries that reference the meter entry belong. |
Flow entry |
Flow entries that reference the meter entry. |
display openflow summary
Use display openflow summary to display summary OpenFlow instance information, including OpenFlow instance ID, activation status, and datapath ID.
display openflow instance summary
# Display summary information about OpenFlow instances.
<Sysname> display openflow summary
Fail Open mode: Se -- secure mode, Sa -- standalone mode
ID Status Datapath-ID Channel Table-num Port-num Reactivate
1 active 0x0000000100001221 Connected 2 8 Y
10 deactive - - - - -
4094 active 0x00000ffe00001221 Failed(Sa) 2 0 N
Table 9 Command output
ID |
OpenFlow instance ID. |
Status |
Activation status of the OpenFlow instance: · active—The OpenFlow instance is active. · deactive—The OpenFlow instance is inactive. |
Datapath-ID |
Datapath ID of the OpenFlow instance. A hyphen (-) is displayed when the OpenFlow instance is inactive. |
Channel |
Status of the secure channel between the OpenFlow instance and the controller: · connected—The secure channel between the OpenFlow instance and the controller has been established. · Failed(Se)—The secure channel between the OpenFlow instance and the controller has been disconnected, and the connection interruption mode is secure mode. · Failed(Sa)—The channel between the OpenFlow instance and the controller has been disconnected, and the connection interruption mode is standalone mode. A hyphen (-) is displayed when the OpenFlow instance is inactive. |
Table-num |
Number of flow tables in the OpenFlow instance. A hyphen (-) is displayed when the OpenFlow instance is inactive. |
Port-num |
Number of ports belonging to the OpenFlow instance. A hyphen (-) is displayed when the OpenFlow instance is inactive. |
Reactivate |
Indicates whether the OpenFlow instance needs to be reactivated: · Y—The OpenFlow instance needs to be reactivated. · N—The OpenFlow instance does not need to be reactivated. A hyphen (-) is displayed when the OpenFlow instance is inactive. |
fail-open mode
Use fail-open mode to set the connection interruption mode for an OpenFlow switch.
Use undo fail-open mode to restore the default.
fail-open mode { secure | standalone }
undo fail-open mode
The connection interruption mode is secure, and the controller deploys the table-miss flow entry (the action is Drop) to the OpenFlow instance.
secure: Configures the OpenFlow switch to use flow tables for traffic forwarding after it is disconnected from all controllers.
standalone: Configures the OpenFlow switch to use the normal forwarding process after it is disconnected from all controllers.
# Configure the connection interruption mode to standalone for OpenFlow instance 1.
[Sysname-of-inst-1] fail-open mode standalone
flow-entry max-limit
Use flow-entry max-limit to configure the maximum number of entries that every extensibility flow table can include.
Use undo flow-entry max-limit to restore the default.
flow-entry max-limit limit-value
An extensibility flow table can include up to 65535 flow entries.
limit-value: Specifies the maximum number of flow entries, in the range of 1 to 65535.
# Configure OpenFlow instance 1 to include up to 256 entries in each extensibility flow table.
[Sysname-of-inst-1] flow-entry max-limit 256
flow-table
Use flow-table to configure a flow table for an OpenFlow instance.
Use undo flow-table to restore the default.
flow-table { [ ingress-vlan ingress-table-id ] [ extensibility extensibility-table-id | mac-ip mac-ip-table-id ] * [ egress-vlan egress-table-id ] }
undo flow-table
An OpenFlow instance has an extensibility flow table whose ID is 0.
ingress-vlan ingress-table-id: Specifies a VLAN tagging flow table by its ID in the range of 0 to 254. If you specify this option, the device tags all incoming packets matching the table.
extensibility extensibility-table-id: Specifies an extensibility flow table by its ID in the range of 0 to 254.
mac-ip mac-ip-table-id: Specifies a MAC-IP flow table by its ID in the range of 0 to 254.
egress-vlan egress-table-id: Specifies a VLAN untagging flow table by its ID in the range of 0 to 254. If you specify this option, the device untags all outgoing packets matching the table.
You can specify only one MAC-IP flow table and one extensibility flow table for an OpenFlow instance, and the MAC-IP flow table ID must be smaller than the extensibility flow table ID.
Configure flow tables before you activate an OpenFlow instance.
If you specify the ingress-vlan ingress-table-id option, make sure the VLAN tagging flow table has the smallest ID among all flow tables. If you specify the egress-vlan egress-table-id option, make sure the VLAN untagging flow table has the largest ID among all flow tables. The VLAN tagging flow table and untagging flow table take effect only when the following conditions are met:
· The OpenFlow instance is configured to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
· The device operates in standalone mode.
# Configure a MAC-IP flow table with ID 0 and an extensibility flow table with ID 1 for OpenFlow instance 1.
[Sysname-of-inst-1] flow-table mac-ip 0 extensibility 1
forbidden port
Use forbidden port to forbid an OpenFlow instance from reporting ports of the specified types to controllers.
Use undo forbidden port to restore the default.
forbidden port { l3-physical-interface | vlan-interface } *
undo forbidden port
All ports that belong to an OpenFlow instance are reported to the controllers.
l3-physical-interface: Specifies Layer 3 Ethernet interfaces that belong to an OpenFlow instance. This keyword is not supported in the current software version.
vlan-interface: Specifies VLAN interfaces that belong to an OpenFlow instance.
# Forbid OpenFlow instance 1 from reporting VLAN interfaces that belong to the OpenFlow instance to controllers.
[Sysname-of-inst-1] forbidden port vlan-interface
in-band management vlan
Use in-band management vlan to configure inband management VLANs.
Use undo in-band management vlan to restore the default.
in-band management vlan vlan-list
No inband management VLAN is configured for an OpenFlow instance.
vlan-list: Specifies a list of VLANs in the format of vlan-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>, where vlan-id1 and vlan-id2 are both in the range of 1 to 4094, vlan-id2 cannot be smaller than vlan-id1, and &<1-10> indicates that you can specify up to 10 vlan-id1 [ to vlan-id2 ] parameters.
The inband management VLANs must be a subset of the VLANs associated with the OpenFlow instance.
This command is applicable only to OpenFlow instances that are in the VLAN mode.
# Configure VLAN 10 as an inband management VLAN in OpenFlow instance 1.
[Sysname-of-inst-1] in-band management vlan 10
loop-protection enable
Use loop-protection enable to enable loop guard for an OpenFlow instance.
Use undo loop-protection enable to restore the default.
Loop guard is disabled for an OpenFlow instance.
This feature enables the deactivated OpenFlow instance to create a flow entry for dropping all traffic in the VLANs to which the OpenFlow instance belongs to avoid loops.
# Enable loop guard for OpenFlow instance 1.
[Sysname-of-inst-1] loop-protection enable
mac-ip dynamic-mac aware
Use mac-ip dynamic-mac aware to configure OpenFlow to support dynamic MAC addresses.
Use undo mac-ip dynamic-mac aware to restore the default.
An OpenFlow instance ignores dynamic MAC address messages sent from controllers.
When a MAC-IP flow table is configured for an OpenFlow switch, you can configure OpenFlow to support querying and deleting dynamic MAC addresses in the table.
When this command is configured, the OpenFlow switch does not send change events for the dynamic MAC addresses to controllers.
# Configure OpenFlow instance 1 to support dynamic MAC addresses.
[Sysname-of-inst-1] mac-ip dynamic-mac aware
mac-learning forbidden
Use mac-learning forbidden to configure OpenFlow to forbid MAC address learning for the VLANs associated with the OpenFlow instance.
Use undo mac-learning forbidden to restore the default.
MAC address learning is allowed in the VLANs associated with an OpenFlow instance.
# Forbid MAC address learning in the VLANs associated with OpenFlow instance 1.
[Sysname-of-inst-1] mac-learning forbidden
openflow instance
Use openflow instance to create an OpenFlow instance and enter OpenFlow instance view.
Use undo openflow instance to remove an OpenFlow instance.
undo openflow instance instance-id
No OpenFlow instance exists.
# Create OpenFlow instance 1, and enter the OpenFlow instance view.
[Sysname-of-inst-1]
openflow lossless enable
Use openflow lossless enable to enable packet loss prevention for OpenFlow forwarding.
Use undo openflow lossless enable to disable packet loss prevention for OpenFlow forwarding.
Packet loss prevention for OpenFlow forwarding is disabled.
When this feature is enabled, ACLs cannot match packets by IPv6 address.
After you enable or disable this feature, save the configuration and reboot the switch to make the configuration take effect.
# Enable packet loss prevention for OpenFlow forwarding.
[Sysname] openflow lossless enable
Do you want to change the lossless traffic mode? [Y/N]:y
For the setting to take effect, save the configuration, and then reboot the device.
openflow shutdown
Use openflow shutdown to shut down an interface by OpenFlow.
Use undo openflow shutdown to restore the default.
openflow shutdown
An interface is not shut down by OpenFlow.
After an interface is shut down by OpenFlow, the Current state field displays OFP DOWN in the display interface command output.
You can use the undo openflow shutdown command to bring up an interface shut down by OpenFlow. The interface can also be brought up by port modification messages from controllers.
# Shut down Ten-GigabitEthernet1/0/1 by OpenFlow.
[Sysname] interface ten-gigabitethernet1/0/1
[Sysname-Ten-GigabitEthernet1/0/1] openflow shutdown
permit-port-type member-port
Use permit-port-type member-port to allow link aggregation member ports to be in the deployed flow tables.
Use undo permit-port-type to forbid link aggregation member ports to be in the deployed flow tables.
Link aggregation member ports cannot be in the deployed flow tables.
# Configure OpenFlow instance 1 to allow link aggregation member ports to be in the deployed flow tables.
[Sysname-of-inst-1] permit-port-type member-port
protocol-packet filter slow
Use protocol-packet filter slow to create a highest-priority flow entry for dropping slow protocol packets.
Use undo protocol-packet filter to restore the default.
An OpenFlow instance does not have a highest-priority flow entry for dropping slow protocol packets.
The flow entry created by using this command has a higher priority than the flow entries deployed by the controller.
The slow protocols include LACP, LAMP, and OAM.
# Create a highest-priority flow entry for OpenFlow instance 1 to drop slow protocol packets.
[Sysname-of-inst-1] protocol-packet filter slow
qinq-network enable
Use qinq-network enable to enable an OpenFlow instance to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
Use undo qinq-network enable to restore the default.
qinq-network enable
A double-tagged packet becomes single-tagged after it passes an extensibility flow table.
Execute this command to make double-tagged packets keep double-tagged after the packets pass an extensibility flow table.
# Enable OpenFlow instance 1 to perform QinQ tagging for double-tagged packets passing an extensibility flow table.
[Sysname-of-inst-1] qinq-network enable
reset openflow instance controller statistics
Use reset openflow instance controller statistics to clear statistics on packets that a controller sends and receives for an OpenFlow instance.
reset openflow instance instance-id controller [ controller-id ] statistics
controller-id: Specifies a controller by its ID in the range of 0 to 63. If no controller ID is specified, this command clears statistics on packets that all controllers send and receive for an OpenFlow instance.
# Clear statistics on packets that all controllers send and receive for OpenFlow instance 1.
<Sysname> reset openflow instance 1 controller statistics
tcp dscp
Use tcp dscp to set a DSCP value for OpenFlow packets.
Use undo tcp dscp to restore the default.
tcp dscp dscp-value
undo tcp dscp
The DSCP value for OpenFlow packets is 10.
dscp-value: Specifies a DSCP value for OpenFlow packets, in the range of 0 to 63.
# Set the DSCP value to 63 for OpenFlow packets.
[Sysname-of-inst-1] tcp dscp 63
tcp-connection backup
Use tcp-connection backup to enable OpenFlow connection backup.
Use undo tcp-connection backup to disable OpenFlow connection backup.
OpenFlow connection backup is enabled.
This command enables an OpenFlow instance to back up OpenFlow connections established over TCP. This prevents connection interruption when an active/standby switchover occurs.
# Enable OpenFlow connection backup for OpenFlow instance 1.
[Sysname-of-inst-1] tcp-connection backup
