00-Preface | 21.17 KB |
Preface
This NE preprovisioning guide describes the procedure for preprovisioning NEs managed by the VCF controller.
· Audience
Audience
· Network planners.
· Network administrators working with H3C VCF controllers.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
