09-Security Configuration Examples
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10009-Security Configuration Examples
00-H3C S12500 AAA Configuration Examples
00-H3C S12500 AAA Configuration Examples 312.32 KB
Introduction
This document provides AAA configuration examples for Telnet and SSH users.
This document assumes that you have basic knowledge of AAA.
Example: Configuring HWTACACS authentication and authorization for Telnet users
Network requirements
As shown in Figure 1, configure the device to meet the following requirements:
·     Use the HWTACACS server to provide authentication and authorization services for Telnet users.
·     Permit authenticated users to execute the display commands of all system features and resources.
Add a user account with username user@bbb and password aabbcc on the HWTACACS server.
Figure 1 Network diagram
Requirements analysis
To meet the network requirements, you must perform the following tasks:
·     Configure the Telnet username and password on the HWTACACS server to identify valid users.
·     For Telnet users to perform AAA, set the authentication mode to scheme on VTY user lines.
·     Configure the same shared key on the device and the HWTACACS server to secure HWTACACS communication. When the shared key is configured, the device and the HWTACACS server transfer passwords safely and the device can verify the integrity of each HWTACACS response.
·     Configure HWTACACS authentication and authorization by performing the following tasks on the device:
?     Create an HWTACACS scheme.
?     Specify the authentication and authorization servers.
?     Apply the HWTACACS scheme to the ISP domain to which the Telnet users belong on the device.
·     Assign the user role network-operator to the users, so the users can use all display commands.
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. In this example, the interfaces are already up.
Configuration procedures
Configuring the HWTACACS server
In this example, the server runs ACS 4.0.
Adding a user
1.     In the navigation tree, click User Setup.
2.     Enter user@bbb in the User field and click Add/Edit, as shown in Figure 2.
Figure 2 Adding a user
Configuring the user
1.     On the User Setup page, configure the following parameters, as shown in Figure 3:
?     Enter aabbcc in the Password and Confirm Password fields.
?     Assign the user to user group Group 1.
Figure 3 Configuring the user password
2.     Click Submit.
Configuring the network settings
1.     In the navigation tree, click Network Configuration.
2.     On the Add AAA Client page, configure the following parameters, as shown in Figure 4:
?     Enter an AAA client hostname in the AAA Client Hostname field. This example uses Device.
?     Enter 10.1.1.2 in the AAA Client IP Address field.
Use the IP address assigned to the port that connects the device to the HWTACACS server.
?     Enter imc in the Key field.
Make sure the key is the same as the key configured on the device.
?     Select TACACS+ (Cisco IOS) from the Authenticate Using list.
Figure 4 Configuring the network settings
3.     Click Submit + Apply.
Configuring the user group
1.     In the navigation tree, click Group Setup.
2.     Select 1: Group 1 (29 users) from the Group list and click Edit Settings, as shown in Figure 5.
Figure 5 Selecting a user group
3.     On the TACACS+ Settings page, configure the following parameters, as shown in Figure 6:
?     Select Shell(exec), which enables command execution for all users in the group.
?     Select Custom attributes, and enter roles=\"network-operator\" in the Custom attributes field.
The network-operator user role has access to the display commands of all system features and resources.
?     Configure other settings as needed.
Figure 6 Configuring the user group
4.     Click Submit.
Configuring the device
# Create VLAN 2 and assign GigabitEthernet 2/0/2 to the VLAN.
[Device] vlan 2
[Device-vlan2] port gigabitethernet 2/0/2
[Device-vlan2] quit
# Assign an IP address to VLAN-interface 2.
[Device] interface vlan-interface 2
[Device-Vlan-interface2] ip address 192.168.57.12 255.255.255.0
[Device-Vlan-interface2] quit
# Create VLAN 3 and assign GigabitEthernet 2/0/1 to the VLAN.
[Device] vlan 3
[Device-vlan3] port gigabitethernet 2/0/1
[Device-vlan3] quit
# Assign an IP address to VLAN-interface 3.
[Device] interface vlan-interface 3
[Device-Vlan-interface3] ip address 10.1.1.2 255.255.255.0
[Device-Vlan-interface3] quit
# Enable the Telnet server feature.
[Device] telnet server enable
# Enable scheme authentication on VTY user lines 0 through 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
[Device-line-vty0-63] quit
# Create HWTACACS scheme hwtac.
[Device] hwtacacs scheme hwtac
# Specify the primary HWTACACS server with the IP address 10.1.1.1 and port number 49.
[Device-hwtacacs-hwtac] primary authentication 10.1.1.1 49
[Device-hwtacacs-hwtac] primary authorization 10.1.1.1 49
[Device-hwtacacs-hwtac] primary accounting 10.1.1.1 49
# Specify the shared key as imc for secure HWTACACS communication between the device and HWTACACS server.
[Device-hwtacacs-hwtac] key authentication simple imc
[Device-hwtacacs-hwtac] key authorization simple imc
[Device-hwtacacs-hwtac] key accounting simple imc
[Device-hwtacacs-hwtac] quit
# Create ISP domain bbb, and specify the domain to use HWTACACS scheme hwtac as the AAA methods of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login hwtacacs-scheme hwtac
[Device-isp-bbb] authorization login hwtacacs-scheme hwtac
[Device-isp-bbb] accounting login hwtacacs-scheme hwtac
[Device-isp-bbb] quit
# Telnet to the device, and enter the username user@bbb and password aabbcc. The user logs in to the device. (Details not shown.)
# Verify that the user can use the display commands of all system features and resources. (Details not shown.)
Configuration files
vlan 2 to 3
interface Vlan-interface2
interface Vlan-interface3
interface GigabitEthernet2/0/2
 port link-mode bridge
 port access vlan 2
interface GigabitEthernet2/0/1
 port access vlan 3
line vty 0 63
 user-role network-operator
 key authentication cipher $c$3$6ps2/dT38b2K2MDCMCDGYxrvyJNR+/jiKw==
 key authorization cipher $c$3$xEldxJraE8Yof3rHHlVIgyCIb/uLlrZbgg==
 key accounting cipher $c$3$kySCJbNA8DSs+l3HCqxunl8SE4me3vue5g==
 domain bbb
Example: Configuring RADIUS authentication and authorization for SSH users
As shown in Figure 7, configure the device to meet the following requirements:
·     Use the RADIUS server to provide authentication and authorization services for SSH users.
·     Include domain names in the usernames sent to the RADIUS server.
·     Permit authenticated users to use the display commands of all system features and resources.
IMC is the RADIUS server. Add a user account with username hello@bbb and password aabbcc on the server.
Figure 7 Network diagram
·     Configure the SSH username and password on the RADIUS server to identify valid users.
·     For SSH users to perform AAA, set the authentication mode to scheme on VTY user lines.
·     Configure the same shared key on the device and the RADIUS server to secure RADIUS communication. When the shared key is configured, the device and the RADIUS server transfer passwords safely and the device can verify the integrity of each RADIUS response.
·     Configure RADIUS authentication and authorization by performing the following tasks on the device:
?     Create a RADIUS scheme.
?     Apply the RADIUS scheme to the ISP domain to which the SSH users belong on the device.
Configuring the RADIUS server
In this example, the server runs IMC PLAT 7.0 (E0102) and IMC UAM 7.0 (E0201).
Adding the device to IMC as an access device
1.     Click the User tab.
2.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
The access device list appears.
3.     Click Add.
4.     On the Add Access Device page, configure the following parameters, as shown in Figure 8:
?     Enter 1812 and 1813 in the Authentication Port and Accounting Port fields, respectively.
?     Enter expert in the Shared Key and Confirm Shared Key fields.
?     Select Device Management Service from the Service Type list.
?     Select HP(Comware) from the Access Device Type list.
?     Use the default values for other parameters in the Access Configuration area.
?     In the Device List area, click Select or Add Manually to add the device (10.1.1.2) to IMC as an access device.
Figure 8 Adding an access device
5.     Click OK.
Adding a device management user
2.     From the navigation tree, select Access User > Device User.
The device management user list appears.
3.     Click Add.
4.     On the Add Device User page, configure the following parameters, as shown in Figure 9:
?     Enter hello@bbb in the Account Name field.
?     Enter aabbcc in the User Password and Confirm Password fields.
?     Select SSH from the Service Type list.
?     Enter network-operator in the Role Name field.
?     In the IP Address List of Managed Devices area, click Add to specify an IP segment (from 10.1.1.1 to 10.1.1.255) for management. The IP segment must contain the IP address of the access device.
Figure 9 Adding a device management user
5.     Click OK.
[Device] vlan 2
[Device-vlan2] quit
[Device-Vlan-interface2] ip address 192.168.1.70 255.255.255.0
[Device] vlan 3
[Device-vlan3] quit
# Generate RSA and DSA key pairs.
[Device] public-key local create rsa
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
[Device] public-key local create dsa
Generating Keys...
# Enable the SSH server feature.
[Device] ssh server enable
# Create RADIUS scheme rad.
[Device] radius scheme rad
# Specify the primary authentication RADIUS server with the IP address 10.1.1.1 and port number 1812.
[Device-radius-rad] primary authentication 10.1.1.1 1812
# Specify the primary accounting RADIUS server with the IP address 10.1.1.1 and port number 1813.
[Device-radius-rad] primary accounting 10.1.1.1 1813
# Set the authentication and accounting shared keys to expert in plain text for secure communication between the device and the RADIUS server.
[Device-radius-rad] key authentication simple expert
[Device-radius-rad] key accounting simple expert
# Include domain names in the usernames sent to the RADIUS server.
[Device-radius-rad] user-name-format with-domain
[Device-radius-rad] quit
# Create ISP domain bbb, and configure the ISP domain to use RADIUS scheme rad as the AAA methods of login users.
[Device] domain bbb
[Device-isp-bbb] authentication login radius-scheme rad
[Device-isp-bbb] authorization login radius-scheme rad
[Device-isp-bbb] accounting login radius-scheme rad
# Initiate an SSH connection to the device, and enter the username hello@bbb and password aabbcc. The user logs in to the device. (Details not shown.)
Configuration files
vlan 2 to 3
 port access vlan 2
 port access vlan 3
line vty 0 63
 ssh server enable
radius scheme rad
 key authentication cipher $c$3$63G7LzIQElGq4aFGTiYQafU+loQxS/cbLg==
 key accounting cipher $c$3$tUIVlyGISJ5X/yiTFWrmh8nyjBIF+1LFzQ==
domain bbb
Related documentation
·     H3C S12500 Routing Switch Series Security Configuration Guide-Release 7328
·     H3C S12500 Routing Switch Series Security Command Reference-Release 7328
