Chapters Download(1 MB)
Chapter 2 Getting Started with Configuration
Chapter 3 Web Configuration of VG
3.1 Web Configuration Overview
3.2 Detailed Web Configuration
3.2.3 Static Route Configuration
3.2.4 POTS Voice Entity Configuration
3.2.5 VoIP Voice Entity Configuration
3.2.6 Fax Service Configuration
3.2.7 Voice Subscriber Line Configuration
3.2.8 Voice GK Client Configuration
3.2.9 Dial Program Configuration
3.2.10 Voice AAA Configuration
3.2.11 Voice Quality Configuration
3.2.12 Global Property Configuration
3.4.2 Login Method Configuration
H3C VG is a voice gateway device (hereinafter referred to as VG). It is developed by H3C Technology Co., Ltd. as a new generation of voice and fax access equipment for various sectors and SOHO (small office and home office).
The VG is designed to access voice and fax signal, and convert the analog voice and fax signal to digital signal, then packetize the digital signal into IP packets, and send the IP packets to the IP network through an Ethernet interface at the network side. Additionally, some models, such as VG 10-40/10-41, can implement broadband access of digital service, and provide an Ethernet interface at the user side to connect a PC or a LAN.
The VG is cost-effective, for it integrates various IP telephone features, such as voice over IP (VoIP), fax over IP (FoIP), call control, resource management, and maintenance management, provides multiple coding/decoding modes, and supports dynamic address acquisition.
The VG is compliant with H.323 of ITU-T and guarantees quality of voice and fax data transmission over the IP network through high-performance DSP chips, coding/decoding algorithms with a high compression ratio, echo cancellation, mute compression, comfortable noise, jitter prevention, and relevant security and QoS features.
The VG supports fast and non-fast connection to implement outband transmission of the DTMF (dual tone multifrequency) code and provide busy tone detection, abbreviated dialing, private lines, outgoing prefix, and some special services of program-controlled switch (such as do-not-disturb, call forward on busy, alarm call, and multi-line group access).
At present, the VG provides Ethernet interfaces to connect with LAN and WAN, and FXS (foreign exchange station) interfaces and FXO (foreign exchange office) interfaces to connect with ordinary telephone sets or PBX (private branch exchange).
Apart from providing SOHO users with IP telephone and fax services, the VG can implement simultaneous transmission of voice and data by connecting with LAN through Ethernet interfaces and thus make better use of the resources.
For a VG with two Ethernet interfaces:
The default IP address of the WAN interface is 192.168.192.1, with a subnet mask of 255.255.255.0.
The default IP address of the LAN interface is 192.168.193.1, with a subnet mask of 255.255.255.0.
For a VG with only one Ethernet interface:
The default IP address of the ETH interface is 192.168.192.1, with a subnet mask of 255.255.255.0.
Connect the Ethernet interface WAN or ETH with a PC through a network, and configure the IP address of the PC on the same network segment as the default IP address of the VG, and use the ping command to check the connection between the VG and PC.
& Note:
Users can modify the IP address of an Ethernet interface through Web configuration. Once the IP address is modified, the default IP address will be deleted automatically.
Open the explorer (IE5.0 or later recommended) and input the IP address 192.168.192.1 in the address bar. Press <Enter>, and a language selection page will appear, as shown in Figure 2-1.
Figure 2-1 The language selection interface
Select a language, and click <Enter> to enter the configuration page.
The system information page displays basic system information about the VG.
Figure 2-2 The system information page
Figure 2-3 The list display page
The list display page consists of three parts: navigation bar, data display area and operation button bar.
The navigation bar is located at the uppermost part of the configuration area and used to navigate to the data you want to view. Click the drop-down list box at the top left corner to adjust the number of data displayed on each page. If one page cannot display all data, you can turn to another page by clicking <<<Previous> or <Next>>> at the top right corner.
The data display area is located in the middle of the configuration area and displays the content of data in a table.
l The first column of the table is a check box for deletion option. If the check box is grey, it indicates you cannot delete this entry.
l
On the last column is a property setting button
. Press this button to
enter the page for setting the properties of the current data. A user can both
view details of the data on this page and modify some of properties (refer to
the section 2.3.3 “Configuration Item Page”). If this column is not
available in the table, it means the data in the table cannot be modified. If a
data entry has no modification button, it means this data entry cannot be
modified.
l The other columns of the table display the data information.
The operation button bar is located at the bottom of the configuration area. The list display page supports the following operations:
<Select All>: Selects all the data entries displayed in the current page for the purpose of deletion. Once clicked, the button will change automatically to <Cancel All> for canceling selection of all the entries. When <Cancel All> is clicked, the button will return to <Select All> automatically.
<Del Select>: Deletes the selected data entry (entries). If no data entry is selected, a dialogue box will pop up to prompt you to select a data entry.
<Refresh>: Asks the VG for the latest data of the current page.
The third type of page is a property setting page, which displays in a table the properties you need to set as well as their related information. You can use the input box or drop-down list box to set the properties. This kind of page is usually used to create, modify and view property configuration.
Figure 2-4 The configuration item page
A property setting page consists of two parts: property setting table and operation button bar.
A property setting table contains four columns:
The first one indicates the name of the property.
The second one is a column for inputting a value for the property. There are two means available for inputting a property value: direct typing in a text box and selecting from a drop box.
In some cases two properties are associated. For example, when property A is configured, property B will be made invalid. In such a case, the setting page will perform an automatic check when A is being configured. If A is configured with a value that will make B invalid, the setting page will hide B automatically or turn the input box of B into a disabled state (in grey), making it impossible for a user to input a value.
Besides, for some complex properties, such as the fax service property of the POTS (plain old telephone service) entity, a hyperlink is provided in the input column. Users can click this hyperlink to enter the configuration page.
Caution:
Except the “Voice Subscriber Line Description Information”, no data can contain “?”, space or two-byte character (such as Chinese), or the system will display an error prompt.
The third column describes the range of the property values. This description consists of two parts. The first part indicates the type of data you can input, including digital and string. The second part specifies the size of data. It refers to a length when a string is input and a range when digitals are input. For the string type, if it is 0, it means you are allowed not to input any value for this property. Numbers [1-10] means that you must input a number from 1 to 10 inclusively.
The fourth column is a link for detailed
help information about the property. Click the help icon
in this column to bring up the
current property information.
The operation button bar is located at the bottom of the configuration area. The property setting page supports the following operations:
<Execute>: Submits the configuration data of the current page to the Web server (VG).
Caution:
l Check the validity of each property value before submission.
l If an invalid property value is input, the system will display alarm information, and the data will not be submitted for processing.
l If an error occurs when the VG is performing configuration, an error prompt page will appear to indicate the cause, but the valid data submitted simultaneously are still processed as usual.
l If the configuration is successful, it will return to the previous page of the current configuration node (if there is no previous page, the current page remains.) For example, after the POTS entity is configured successfully, it will return to the POTS entity list display page. If global configuration of voice is successful, it will return to the page for global configuration of voice, because this page has no previous page.
<Reset>: Cancels the modification made by the user to the values in the property input box or drop-down list box.
<Refresh>: Asks the VG for the latest data of this current page. A configuration modification page contains this button, while a newly created page does not.
<Return>: Returns to the previous page.
Caution:
l A list display page, property setting page and configuration error alarm page support return operation, which means to return to the previous page.
l The page classifications and descriptions above are applicable to most pages, but some special pages, such as a configuration wizard page, may be a little different from what have been described. Please refer to the description of specific pages.
The VG provides configuration wizards to guide you through basic configurations. For example, the Voice Set Wizard enables users to configure basic VG functions. Refer to section 3.2.1 “Voice Setup Wizard” for details.
The steps of basic VG configuration are as follows:
Step |
Operation |
Related section |
Remarks |
1. |
Configure an interface |
Select [IP/IP Address] in the directory
tree, and select an interface for accessing the user network in the
configuration page, and click the |
3.2.2 |
Required |
2. |
Configure a static route |
Select [IP/Static IP Route] in the directory tree, and click <New> in the configuration page to create a static route. |
3.2.3 |
Optional |
3. |
Configure a POTS voice entity |
Select [Voice/POTS Entity] in the
directory tree, and click <New> or a |
3.2.4 |
Required |
4. |
Configure a VoIP voice entity |
Select [Voice/VoIP Entity] in the
3.2.5 |
Required |
5. |
Configure fax service |
Select [Voice/VoIP Entity] or [Voice/POTS
Entity] in the directory tree, and click <New> to create a voice
entity; or select a voice entity and click the |
3.2.6 |
Optional |
6. |
Configure a voice subscriber line |
Select [Voice/Phone/Line] in the
directory tree, and click the |
3.2.7 |
Optional |
7. |
Configure a voice gatekeeper (GK) client |
Select [Voice/GK Client/GK Client] in the directory tree, and set proper GK client parameters in the configuration page. |
3.2.8 |
Optional |
8. |
Configure a dial program |
Select [Voice/Dial Program] in the directory tree, select the desired item, and set proper parameters in the configuration page. |
3.2.9 |
Optional |
9. |
Configure voice AAA |
Select [Voice/Voice AAA] in the directory tree, select the desired item, and set proper parameters in the configuration page. |
3.2.10 |
Optional |
10. |
Configure voice quality |
Select [Voice/Voice Quality] in the directory tree, and set proper parameters in the configuration page. |
3.2.11 |
Optional |
11. |
Configure global properties |
Select [Voice/General] in the directory tree, select the desired item, and set proper parameters in the configuration page. |
3.2.12 |
Optional |
12. |
User management |
Select [User Management] in the directory tree, select the desired item, and set proper parameters in the configuration page. |
3.4 |
Optional |
13. |
Save configuration |
Select [Save Configuration] in the directory tree, and click <Confirm>. |
3.5 |
Required |
Step |
Operation |
Remarks |
Basic configuration |
1. |
Configure an IP address for the interface |
Select [Voice Setup Wizard] in the directory tree, and set in the configuration page a proper IP address and IP address mask for the Ethernet interface used for user network access. After finishing the configuration, click <Next>. |
Required |
2. |
Set a POTS voice entity |
Set parameters [Entity Number], [Match Template], and [Line] in the configuration page. After setting these parameters, click <Add> to validate these configurations. Then click <Next>. The configured voice entity will be listed in the lower part of the configuration page. |
Required |
3. |
Set a VoIP voice entity |
Set parameters [Entity Number], [Match Template], and [Address Type] in the configuration page. After setting these parameters, click <Add> to validate them. Click <Finish> to complete the voice setup wizard. Now the VG is configured with basic voice functions. If the [Address Type] is set to [IP], it is necessary to specify the IP address of the peer device. The configured voice entity will be listed in the lower part of the configuration item page. |
Required |
Return to section 3.1 “Web Configuration Overview”. |
& Note:
The IP address and IP address mask take the dotted decimal format.
For configuration details, refer to H3C VG Series Voice Gateways Operation Manual and H3C VG Series Voice Gateways Command Manual.
Step |
Operation |
Remarks |
1. |
Configure an IP address for the Ethernet interface |
Select [IP/IP Address] in the directory tree, click <New>, set [Interface Type] to [Ethernet], and [Interface Number] to 0 or 1 (depending on specific devices), and then set [IP Address], [IP Address Mode] and [IP Mask] properly. To modify the existing configuration,
click the After configuring the parameters, click <Execute> to validate the configurations. If the address you have modified is the one that you use to access the Web, log in to the VG again using the new IP address. Related command: ip address (interface view). |
Required |
2. |
Set the Dialer interface |
Select [IP/IP Address] in the directory tree, click <New> in the configuration page, set [Interface Type] to [Dialer], and [Interface Number] to 0, and then set [IP Address], [IP Address Mode] and [IP Mask] properly. To modify the existing configuration,
click the Only VG 10-40 and VG 10-41 have a Dialer interface. Related command: ip address (interface view). |
Optional |
3. |
Set the LoopBack interface |
Select [IP/IP Address] in the directory tree, click <New> in the configuration page, set [Interface Type] to [LoopBack], and [Interface Number] to 1 or 2, and then set [IP Address], [IP Address Mode] and [IP Mask] properly. To modify the existing configuration,
click the Related command: ip address (interface view). |
Optional |
4. |
Configure a secondary IP address for the interface |
Select [IP/IP Address] in the directory tree, click <New> in the configuration page, set [Interface Type] and [Interface Number], select [sub] as the [IP Address Mode], and then set [IP Address] and [IP Mask] properly. A Dialer interface cannot be configured with a secondary IP address. Related command: ip address (interface view). |
Optional |
Step |
Operation |
Remarks |
1. |
Create a static route |
Select [IP/Static IP Route] in the directory tree, click <New>, and set [Destination IP], [Destination IP Mask], [Next Hop Mode], [Next Hop IP] or [Next Interface] and [Precedence]. You can set only one of [Next Hop IP] and [Next Interface], depending on the value of [Next Hop Mode]. After configuring the parameters, click <Execute> to validate the configurations. Related command: ip route-static (system view). |
Optional |
Step |
Operation |
Remarks |
1. |
Create a POTS voice entity |
Select [Voice/POTS Entity] in the directory tree, and click <New> in the configuration page to set POTS voice entity parameters. |
Required |
2. |
Modify POTS voice entity parameters |
tree, click the |
Required |
3. |
Configure an entity number |
The entity number identifies a voice entity uniquely. POTS voice entities and VoIP voice entities are numbered uniformly for easy management. Related command: entity (voice dial program view). |
Required |
4. |
Configure a called number match template |
The VG implements a voice call by matching the called voice entity with the string configured in this template. Related command: match-template (voice entity view). |
Required |
5. |
Configure a voice port |
The VG associates a voice entity with a voice subscriber line through this port to relate a logical entity and a physical line. Related command: line (POTS voice entity view). |
Required |
6. |
Configure voice entity status |
This parameter is designed to control the running status of a voice entity. If a voice entity is disabled, it cannot receive a voice call. Related command: shutdown (voice entity view). Related command: undo shutdown (voice entity view). |
Advanced configuration |
Configure voice codec type |
Set a voice decoding precedence mode for the VG according to the bandwidth of the user network and different requirements on voice quality. There are four precedence classes. Related command: compression (voice entity view). |
Optional |
Configure voice IP packet precedence |
You can set higher precedence for the voice and fax IP packets related with a voice entity, so that devices on the data transmission path will preferentially process these packets. Related command: ip-precedence (voice entity view). |
Optional |
Configure mute detection |
The VG can detect and delete mute according to the energy levels of voice signal and silence signal of daily conversations, and will not produce and transmit voice signal until it detects abrupt active sound. This can effectively decrease occupancy of network bandwidth. While using this function, you are recommended to enable the comfortable noise function. Related command: vad-on (voice entity view). |
Optional |
Configure DTMF transmission mode |
By default, the inband transmission mode is applied to the DTMF code. Outband transmission means the DTMF code is transported through H.245 and H.225. Related command: outband (voice entity view). |
Optional |
Number of the calling number transform rule table |
This number is used to relate the calling number transform rule table with a voice entity. Related command: substitute calling (voice entity view). |
Optional |
Number of the called number transform rule table |
This number is used to relate the called number transform rule table with a voice entity. Related command: substitute called (voice entity view). |
Optional |
Send Number |
This parameter is used to control how to send a called number to the PSTN. The VG sends a called number in three ways: 1) Sending part of the number extracted from right to left and with a specified length; 2) Sending all digits of the number; 3) Sending the called number by means of truncation. Related command: send-number (POTS voice entity view). |
Optional |
Dial Prefix |
When “truncate” (default) is set for sending a called number, the VG will remove from the called number the left part string that exactly matches the match template. The dial prefix will be added before the remaining string, and the VG will call the new string. Related command: match-template (voice entity view). |
Optional |
Fax Service |
For fax parameter setting, refer to section 3.2.6 “Fax Service Configuration”. |
Optional |
Step |
Operation |
Remarks |
1. |
Create a VoIP voice entity |
Select [Voice/VoIP Entity] in the directory tree, and click <New> in the configuration page to set VoIP voice entity parameters. |
Optional |
2. |
Modify VoIP voice entity parameters |
directory tree, click the |
Optional |
3. |
The entity number uniquely identifies a voice entity. VoIP voice entities and POTS voice entities are numbered uniformly for easy management. Related command: entity (voice dial program view). |
Required |
4. |
Required |
5. |
Configure voice entity routing mode |
After matching a VoIP voice entity with the called number, the VG maps the called number with the called gateway IP address in the voice entity routing mode. The modes available are: l Configuring a static IP address for the called gateway; l Interacting with GK to map the called number and the IP address; l No routing. Related command: address (VoIP voice entity view). |
Required |
6. |
Optional |
Configure an area ID |
In VoIP voice entity view, set a voice area ID, which will be added automatically to the beginning of a called number when a call is made. Related command: area-id (VoIP voice entity view). |
Optional |
Configure voice coding/decoding mode |
Set a voice decoding preference mode for the VG according to the bandwidth of the user network and different requirements on voice quality. There are four precedence classes. Related command: compression (voice entity view). |
Optional |
Optional |
Optional |
Configure fast connection |
This function can reduce information exchanged between the calling and called parties before a call is established, thus quickening setup of the call. This function requires support of both the calling and called parties. Related command: fast-connect (VoIP voice entity view). |
Optional |
Configure tunnel function |
The tunnel function must be enabled when transparent transmission of the DTMF code is performed in the fast connection mode. This parameter can be configured only when the fast connection function is enabled. Related command: tunnel-on (VoIP voice entity view). |
Optional |
Configure ring-back tone |
This parameter is used to configure sending ring-back tone locally. This parameter can be configured only when the fast connection function is enabled. Related command: send-ring (VoIP voice entity view). |
Optional |
Optional |
This number is used to bind the calling number transform rule table with a voice entity. Related command: substitute calling (voice entity view). |
Optional |
This number is used to bind the called number transform rule table with a voice entity. Related command: substitute called (voice entity view). |
Optional |
Fax Service |
Optional |
Step |
Operation |
Remarks |
Configure fax ECM mode |
A fax machine that adopts ECM has the error correction function and can provide ARQ (automatic repeat request) and transmit fax packets in the HDLC frame format. In contrast, a fax machine that adopts a mode (supported) other than ECM has no error correction function, and transmits fax information in the binary format. ECM is applicable to fax only when the fax machines at both ends support ECM and the gateway adopts ECM as well. Related command: fax ecm (voice entity view). |
Optional |
Configure non-standard fax facilities |
In ordinary fax applications, the fax terminals of both parties negotiate through standard facilities (such as V.17 or V.29 rate) by default, that is, they send no NSF (non-standard facilities) message frame. In some cases (such as encrypted fax), non-standard facilities become very important to fax communication. Therefore in such cases, fax terminals of both parties exchange NSF message frames to start the negotiation, and then negotiate on other fax facilities for communication. Related command: fax nsf-on (voice entity view). |
Optional |
Configure fax rate |
If the fax baudrate is set to a value other than “disable” and “voice”, rate negotiation is performed preferentially through the fax protocol corresponding to this rate. The rate configured here is an allowed maximum rate instead of a specified rate in use. Related command: fax baudrate (voice entity view). |
Optional |
Configure fax training mode |
Local training mode means that the gateways join in the rate training between the fax machines at two ends. In this mode, the training is first performed at the two ends respectively (that is, between the receiving fax machine and the receiving gateway, and between the sending fax machine and the sending gateway). Then the receiving gateway sends the training result of the receiving party to the gateway of the sending party, and the gateway of the sending party determines the final packet transmission rate according to the training results of the two parties. Related command: fax train-mode (voice entity view). |
Optional |
Configure energy level of sending fax gateway carrier |
The default energy level of sending gateway carrier applies to most cases. If the faxing fails when other configurations are correct, you can try adjusting the energy level of sending gateway carrier. The smaller the energy level, the larger the energy. Related command: fax level (voice entity view). |
Optional |
Configure fax protocol |
The VG supports two fax start modes: H.323 negotiation start mode and VG negotiation start mode, corresponding respectively to fax protocols H.323-T.38 and T.38. Moreover, the VG can provide transparent transmission fax through two configurations. 1) Configuring the fax protocol to PCM. 2) Configuring the two-party voice coding/decoding negotiation to G.711 and “Fax Baudrate” to “disable” (disable fax forward), and disabling mute detection (VAD) to prevent fax failure. This mode is applicable to transparent transmission interworking with other devices. Related command: fax protocol (voice entity view). |
Optional |
Configure the number of high speed redundancy packets sent via T.38 |
The VG supports control on high speed and low speed redundancy packets. Increasing the number of redundancy packets can improve reliability of network transmission and reduce the trouble caused by packet loss. But too many redundancy packets will largely increase bandwidth utilization, and affect fax quality gravely if the bandwidth is small. Therefore, the number of redundancy packets should be based on network bandwidth. This parameter is available when [Fax Protocol] is set to “h323-t38” or “T.38”. Related command: fax redundancy hb-redundancy (voice entity view). |
Optional |
Configure the number of low speed redundancy packets sent via T.38 |
This parameter is available when [Fax Protocol] is set to “h323-t38” or “T.38”. Related command: fax redundancy lb-redundancy (voice entity view). |
Optional |
Configure fax Passthrough mode |
When the [Fax Protocol] is set to “pcm”, you should set a voice coding/decoding rate for fax transparent transmission. Related command: fax protocol pcm (voice entity view). |
Optional |
Configure fax transmission format |
When the T.38 protocol is applied, the RTP mode (the corresponding parameter is rtp) is often used. To interwork with the VocalTec gateway, set the VT mode (the corresponding parameter is vt). Related command: fax support mode (voice entity view). |
Optional |
Step |
Operation |
Remarks |
1. |
Modify voice subscriber line parameters |
Optional |
2. |
Configure description |
Describe the voice subscriber line. Related command: description (voice subscriber line view). |
Optional |
3. |
Configure comfortable noise |
When VAD is enabled for a voice entity, mute intervals may exist during the voice conversation. You can use this command to produce proper background noise to fill the mute intervals. Related command: cng-on (voice subscriber line view). |
Required |
4. |
Configure a private line number |
If you have configured a private line number, the VG will automatically originate a call to this configured number after you pick up the phone (no other operation is needed). Related command: private-line (voice subscriber line view). |
Optional |
5. |
Configure dial timeout time |
Dial timeout time refers to the timer interval during which the system waits for a user to dial the next digit. When a user dials a digit, this timer is reset. This process is repeated until all digits are dialed. If timeout occurs before dialing is finished, the user will be prompted to hang up and the dialing is ended. Related command: timer dial-interval (voice subscriber line view). |
Optional |
6. |
Configure FXO port binding |
Specify the FXO port to be bound with the current FXS port. After being bound, an FXO port can be used by the corresponding FXS port only. After an FXS-FXO binding is created: l When a call is sent from the FXS port, the bound FXO port has the priority to direct it. l When the FXO receives a call from the PSTN, it directly sends it to the bound FXS port through the dedicated line. Related command: bind (voice subscriber line view). |
Optional |
Configure echo cancellation |
During conversation, your voice is repeated for the line reason and returned to your receiver. This is called echo. The cause is leaking of analog voice signals to your own receiving path. You can solve the echo problem in conversation to some extent through the echo cancellation function provided by the VG. Related command: echo-canceller enable (voice subscriber line view). |
Optional |
Configure echo cancellation duration |
Echo duration means the interval from the time a user makes an original sound to the time the echo is heard. The VG deals with echo cancellation according to this parameter. Related command: echo-canceller tail-length (voice subscriber line view). |
Optional |
Configure voice input gain |
When attenuation of voice signal on a line is large, this command can be used to properly increase voice input gain. Related command: receive gain (voice subscriber line view). |
Optional |
Configure voice output gain |
When the power of voice signal on the output line is small, this command can be used to increase proper voice output attenuation to meet the signal requirements of the output line. Related command: transmit gain (voice subscriber line view). |
Optional |
This number is used to bind the calling number transform rule table with a voice subscriber line. Related command: substitute calling (voice subscriber line view). |
Optional |
This number is used to bind the called number transform rule table with a voice subscriber line. Related command: substitute called (voice subscriber line view). |
Optional |
& Note:
FXO port binding is supported by the VG 31-08 and VG 10-41 only, in Web-based configuration mode.
Step |
Operation |
Remarks |
1. |
Inquire voice GK client status |
Select [Voice/GK Client/GK Client Status], and the information of start status and registration status is listed in the configuration page. |
Optional |
2. |
Configure GK client parameters |
Select [Voice/GK Client/GK Client] in the directory tree, and set GK client parameters in the configuration page. |
Optional |
3. |
Configure a gateway alias |
This parameter is used by the gateway to register and identify a VG in the GK Server. A gateway can have only one alias, and a new alias will override the old one. Related command: gw-id (voice GK view). |
Required |
4. |
Configure a gateway source address |
If a source IP address is configured for the VG (this is also referred to as source address binding), all the packets must use this unified source address, no matter which physical interface the voice IP packets are sent out from. Since the transmitted voice IP packets contain a unified and definite source address, packet filtering becomes very simple, making firewall control easier. Related command: gw-address (voice GK view). |
Required |
5. |
Configure a name for the active GK Server |
When the GK Client function of the VG is enabled, the GK Client will register information about this gateway with the active GK Server, so it is necessary to configure an IP address and name for the active GK Server to make it easier to locate the right GK Server. Related command: gk-id (voice GK view). |
Required |
6. |
Configure an IP address for the active GK Server |
This parameter is designed to configure for the active GK Server an IP address, which is used by the gateway to register with GK. Related command: gk-id (voice GK view). |
Required |
7. |
Configure a port for the active GK Server |
This parameter is designed to configure for the active GK Server a RAS listening port, which is used by the gateway to register with GK. Related command: gk-id (voice GK view). |
Optional |
8. |
Configure GK Client Status |
The VG can communicate normally with GK Server only after the GK Client function is enabled, or it will be unable to set up a connection with GK Server. Related command: ras-on (voice GK view). |
Required |
9. |
Configure GK management on local calls |
Select [Voice/GK Client/GK Client], and select the disable option for [GK Local Call] on the configuration page to enable GK management on local calls. Related command: gk-local-call (voice GK view). |
Optional |
Configure a name for the standby GK Server |
When communication between the GK Client and the active GK Server becomes abnormal (for example, times out), or the active GK Server is unavailable, the VG can alternatively send a registration request to the standby GK Server. Related command: gk-2nd-id (voice GK view). |
Optional |
Configure an IP address for the standby GK Server |
This parameter is designed to configure for the standby GK Server an IP address, which is used by the gateway to register with GK. Related command: gk-2nd-id (voice GK view). |
Optional |
Configure a port for the standby GK Server |
This parameter is designed to configure for the standby GK Server a RAS listening port, which is used by the gateway to register with GK. Related command: gk-2nd-id (voice GK view). |
Optional |
Step |
Operation |
Remarks |
1. |
Configure dial program |
Select [Voice/Dial Program] in the directory tree, select the items you want to configure, and set proper parameters in the configuration page. |
Optional |
2. |
Configure a dial terminator |
A dial terminator is used to notify the VG that the dialing is ended, and the VG should set up a call using the received number. Related command: terminator (voice dial program view). |
Required |
3. |
Configure number match mode |
When a user is dialing a number to set up a call, the direction in which the call is originated depends on the called number template, namely, the number preset in the match template. If longest number match is applied, the system will match as long a number as possible. During dialup, as long as it is still possible for the input number to match a longer called number template, the system will wait for a longer number to be input. In case of wait timeout, the system will use the dialed number for matching. If shortest number match is applied, whenever the input number matches a called number template, a call will be originated, and the digits the user continues to dial will be neglected. Related command: number-match (voice dial program view). |
Required |
Step |
Operation |
Remarks |
1. |
Create a number transform rule table |
Select [Voice/Dial Program/Number Substitution] in the directory tree, and click <New> in the configuration page to set number transform parameters. |
Required |
2. |
Configure a number for the number transform rule table |
This parameter is used to set a unique identification for a number transform rule table. Related command: number-substitute (voice dial program view). |
Required |
3. |
Configure the dot-number match rule |
In the input format of the number transform rule, the numbers that will be retained are marked with “.”, of which the quantity and position are configured in the output format of the number transform rule. Related command: dot-match (voice dial program view). |
Optional |
4. |
Configure a preferred transform tag |
This is the number transform rule that is first applied to the current number transform table. Related command: first-rule (voice number transform view). |
Optional |
5. |
Modify a number transform rule table |
Substitution] in the directory tree, and click the Related command: number-substitute (voice dial program view). |
Required |
6. |
Configure transform rules |
Click the configuration item “Rule Table”, and click <New> to set parameters of number transform rules. Related command: rule (voice number transform view). |
Required |
7. |
Configure transform rule tags |
A transform rule tag is used as a unique identification of a transform rule in the number transform rule table. Related command: rule (voice number transform view). |
Required |
8. |
Configure the input format |
This is an input string for number transformation. Related command: rule (voice number transform view). |
Required |
9. |
Configure the output format |
This is an output string of number transformation. Related command: rule (voice number transform view). |
Required |
Return to 3.1 Web Configuration Overview. |
Step |
Operation |
Remarks |
1. |
Create an access service number |
Select [Voice/Dial Program/Access Service Number] in the directory tree, and click <New> in the configuration page to set access service number parameters. Related command: gw-access-number (voice dial program view). |
Required |
2. |
Modify an access service number |
Number] in the directory tree, and click the Related command: gw-access-number (voice dial program view). |
Required |
3. |
Configure dialing process |
Each access service, corresponding to an access service number, has a specific dialing process. Any user that uses an access service can set up a call only through the corresponding process. Related command: process-config (access service number view). |
Required |
4. |
Configure redial times |
Dialing failure is possible in each dialing stage due to wrong input, so this parameter is designed to set the allowed redial times. Related command: redialtimes (access service number view). |
Optional |
5. |
Configure the digits of a card number |
This parameter is used to set the digits of a card number for the users that use the dual-stage dialing card number process (card number/password authentication). Once the digits of a card number is set, users can use this access service number only through a card number with preset digits. This parameter is valid only when the dialing process is set to “Card Number”. Related command: card-digit (access service number view). |
Optional |
6. |
Configure password digit |
This parameter is used to set the digits of a user’s password needed when the dialing process is set to “Card Number”. Related command: password-digit (access service number view). |
Optional |
7. |
Configure authentication |
For each access service number, you can specify whether to authenticate users that use the corresponding service. If you enable user authentication for an access service, users that use this service cannot be authorized to make IP calls until they pass the authentication. If authentication is disabled, all the users (legal or illegal) that use this number can make IP calls without authentication. Related command: authentication (access service number view). |
Optional |
8. |
Configure authorization |
“Authorization” is to determine what kind of IP call (local, domestic toll, or international toll) a user can place according to the user’s right and application (the called number). Related command: authorization (access service number view). |
Optional |
Step |
Operation |
Remarks |
1. |
For the single-stage dialing (direct dialing without need of an access service number) users, it is impossible to enable authentication on a single user because no access service number is applied. In this case, authentication can be performed only on all users. Related command: authentication-did (access service number view). |
Optional |
2. |
For the single-stage dialing (direct dialing without need of an access service number) users, it is impossible to enable authorization on a single user because no access service number is applied. In this case, authorization can be performed only on all users. Before enabling authorization, be sure to enable authentication. Related command: authorization-did (access service number view). |
Optional |
Step |
Operation |
Remarks |
1. |
Configure the output threshold of call records |
You can save call records by setting an output threshold (in percentage) for them. Related command: cdr threshold (voice AAA service view). |
Optional |
2. |
Configure maximum call records |
You can save call records by setting a maximum number of records. Related command: cdr buffer (voice AAA service view). |
Optional |
3. |
Configure maximum duration for saving detailed call records |
You can save call records by setting maximum saving duration (from the end of conversation). Related command: cdr duration (voice AAA service view). |
Optional |
Return to section 3.1 Web Configuration Overview. |
Step |
Operation |
Remarks |
1. |
Create a local voice user |
Select [Voice/Voice AAA/Local Voice Users] in the directory tree, and click <New> in the configuration page to set parameters for the new local voice user. |
Optional |
2. |
Modify a local voice user |
Select [Voice/Voice AAA/Voice Local User]
in the directory tree, and click the |
Optional |
3. |
Configure a local user name |
When the local voice user database is configured, local authentication is performed preferentially on voice users. If the local authentication succeeds, the subsequent RADIUS authentication will be omitted. If the local authentication fails, authentication will be performed on the RADIUS server. If the RADIUS authentication succeeds, the user can make voice communication; otherwise it will be rejected. At preset, the VG can support up to 200 local users. Related command: local-user (voice AAA service view). |
Required |
4. |
Configure a local user password |
This parameter is used to configure passwords for local voice users. Related command: local-user (voice AAA service view). |
Required |
Step |
Operation |
Remarks |
1. |
Select [Voice/Voice Quality] in the directory tree, and set proper voice quality parameters in the configuration page. Voice data can be forwarded in the normal or fast mode. Fast forwarding is subdivided into fast receiving and fast sending. Users can adopt different forwarding modes to satisfy varied requirements on voice performance. |
Optional |
2. |
Configure voice data receiving process |
Compared with the normal receiving process, the fast receiving process omits the memory application and data copy process, and sends the data directly to the service module for processing, thus quickening voice data receiving. Related command: vqa performance receive (voice view). |
Optional |
3. |
Configure voice data sending process |
The fast sending process packetizes voice data with the aid of interruption mechanism, and then, according to the route and link information, sends the packets directly to the network layer for forwarding. Related command: vqa performance send (voice view). |
Optional |
4. |
Configure voice data statistics |
To locate and debug quickly and accurately a problem occurring to a VoIP call, you can use this parameter to display the voice data statistics. The statistic information includes times of success in searching voice tables, total number of received packets, times of searching voice tables in the fast and ordinary ways, and information of various items (such as voice and fax) on the receiving and sending channel. Related command: vqa data-statistic (voice view). |
Optional |
5. |
Anti-Jitter buffer level |
To relieve negative influence of network status on the voice packets, you can use the Jitter Buffer to process the voice packets. These measures include compensating for the lost packets, adjusting the disordered packets, deleting the packets that cause jitter, and discarding the packets with duplicate serial numbers. Related command: vqa jitter-buffer (voice view). |
Optional |
6. |
Configure global packet precedence |
This parameter is to configure precedence for all voice IP packets (TOS domain of the IP packets). The numeral 0 indicates the highest precedence, and 7 the lowest. Related command: vqa ip-precedence (voice view). |
Optional |
Step |
Operation |
Remarks |
1. |
Configure start mode of the called party |
When the VG is configured as the called party, this parameter is used to negotiate with the peer about the call start mode. Related command: voip call-start (voice view). |
Optional |
2. |
Configure called tunnel function |
To use the H.323 protocol to interwork with a device that does not support tunnel function, you need to use this command to configure the called gateway to disable the tunnel function. Related command: voip calledtunnel (voice view). |
Optional |
3. |
Configure 1:1 binding of analog ports |
After 1:1 binding is configured for the device, all FXS and FXO ports are bound, with port FXSn corresponding to FXOn respectively, and vice versa. Here n ranges from 0 to 7. Being bound, an FXO port serves for the related FXS port only. Related command: bindmode (voice view). |
Optional |
& Note:
1:1 binding for analog ports is supported by the VG 31-08 only, in Web-based configuration mode.
For detailed description on the parameters of the default voice entity properties, refer to sections 3.2.4 “POTS Voice Entity Configuration”, 3.2.5 “VoIP Voice Entity Configuration”, and 3.2.6 "Fax Service Configuration”.
Step |
Operation |
Remarks |
1. |
Bind a number transform rule table |
Select [Voice/General] in the directory tree, select incoming/outgoing and calling/called number substitution, click <New>, and set the bound numbers of the number transform rule tables. |
Optional |
Users can select [System Tools/Telnet] in the directory tree to invoke quickly the Telnet function provided by Microsoft Windows to configure the devices in the network through command lines.
Step |
Configuration item |
Type |
1. |
Adding a User |
Select [User Management/Management] in the directory tree, and click <New> to set user information. The system can support as many as 15 users. |
Required |
2. |
Configure a username |
A username is used as a unique identification of a user. Related command: local-user (system view). |
Required |
3. |
Configure a user password |
This password is used for user authentication. Related command: local-user (system view). |
Required |
4. |
Configure a user type |
The VG classifies users into three classes: “administrator”, “operator” and “guest”. An “administrator” has the highest right; an “operator” has a right to view configuration parameters other than “User Management" through the Web page, but cannot modify the VG configuration. A “guest” has no right to log in to the Web page to configure the VG. Related command: local-user (system view). |
Required |
5. |
Configure a password type |
A password can be set to “simple” or “cipher”, respectively indicating to display a password in plain text or in encrypted text. It is advisable to use the “cipher” mode. Related command: local-user (system view). |
Required |
Step |
Type |
1. |
Configure authentication and authorization for the http login users |
When this function is enabled, the VG will authenticate and authorize the users that log in through the Web. It is advisable to enable this function. Related command: login-method authentication-mode (system view). |
Required |
2. |
Enable AAA (authentication, authorization and accounting) |
The VG has AAA function only when this item is enabled. It is advisable to enable this function. Related command: aaa-enable (system view). |
Required |
After modifying VG configuration through the Web page, you can save the new configuration if you are sure it is correct. Select [Save Configuration] in the directory tree and click <Confirm> in the configuration item page, and the system will start saving the user configuration.
& Note:
Configuration saving may need some time and prevent the system from responding to external request, so perform this operation as less as possible.
