H3C VG Series Voice Gateways Web-based Configuration Manual(V1.01)
DownLoad Chapters Download(294 KB)
00-1Cover
Hangzhou H3C Technology Co., Ltd.
http://www.h3c.com
Manual Version: T2-08014H-20060707-C-1.01
Copyright © 2006, Hangzhou H3C Technology Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technology Co., Ltd.
Trademarks
H3C, Aolynk, , IRF, H3Care, , Neocean, , TOP G, SecEngine, SecPath, COMWARE, VVG, V2G, VnG, PSPT, NetPilot, and XGbus are trademarks of Hangzhou H3C Technology Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
service@h3c.com
http://www.h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C VG Series Voice Gateways documentation set includes the following:
Manual
H3C VG Series Voice Gateways? Operation Manual
It provides guidelines to user operations on the H3C VG Series Voice Gateways.
H3C VG Series Voice Gateways? Command Manual
It provides all commands available in the H3C VG Series Voice Gateways as well as the command usage and examples.
H3C VG Series Voice Gateways? Installation Manual
It describes how to install a VG and provides safety recommendations as well.
Organization
H3C VG Series Voice Gateways Web-based Configuration Manual is organized as follows:
Chapter
1 Introduction to VG
Briefly introduces the usage and features of the VG series voice gateways.
2 Getting Started with Configuration
Introduces the connection, login and configuration GUIs of voice gateways.
3 Web Configuration of VG
Describes how to perform configurations through the voice gateway Web pages in detail.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
? Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
? Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&? Note
Means a complementary description.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
