H3C WA Series WLAN Access Points Documentation Navigator-6W100
HomeSupportResource CenterWLANAccess PointH3C WA2200 Series WLAN Access PointsTechnical DocumentsDocumentation RoadmapDocumentation RoadmapH3C WA Series WLAN Access Points Documentation Navigator-6W100
Read this documentation navigator before you start working with an H3C WA Series WLAN Access Points. This documentation navigator helps you quickly find useful information for completing a task.
Task category
Tasks
Main documents
Auxiliary documents
Getting familiar with the product
See product overview, software/hardware specifications, and networking applications
Marketing brochures
N/A
See technical details of software features
Technology white papers
Configuration Guide
Installation
See regulatory information for the WA series WLAN access points and the safety instructions that must be followed during installation
Compliance and Safety Manual
Declarations of conformity
See installation requirements, and hardware installation of indoor and outdoor APs
Installation Guide
N/A
Connect the power supply, connect the AP to the network, and log in to the AP
Getting Started Guide
Configuration Guide
Configuration
Configure software features
Configuration Guide
Command Reference
Maintenance
Upgrade software and implement cutover
Release notes
N/A
l    The documents are subject to change without notice. To access the up-to-date WA series WLAN access points documentation, see the H3C website at http://www.h3c.com.
l    You can email your comments to info@h3c.com. We appreciate your comments.
