Title | Size | Downloads |
H3C LSV1QGS12SA1 Card Manual-6PW101-book.pdf | 57.38 KB |
12-port 40-GE QSFP+ Fiber Interface Card–LSV1QGS12SA1
1 Card identifier
The mark LSV1QGS12SA1 is printed at the upper right corner of the front panel, and is used to identify the card.
2 Specifications
Table 1 LSV1QGS12SA1 specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core), 1GHz |
SDRAM |
4GB DDR3 SDRAM |
Power consumption |
135 W to 230 W |
Connector |
· MPO · LC |
Ports |
12 QSFP+ ports |
Transmission rate |
40 Gbps |
Transmission medium and max transmission distance |
Compatible device models |
S9800 Switch Series |
System software version |
Release 2101 and later versions |
The LSV1QGS12SA1 supports the following transceiver modules and cables.
Table 2 QSFP+ module specifications
QSFP+ module |
Central wavelength |
Connector |
Cable specifications |
Mode bandwidth |
Max. transmission distance |
LSUM1QSFP0 |
850 nm |
MPO |
Multi-mode 50/125 μm OM3 |
2000(MHz*km) |
100 m (328.08 ft) |
QSFP-40G-LR4-WDM1300 |
1310nm |
LC |
9/125 μm SMF |
N/A |
10 km (6.21 miles) |
Table 3 QSFP+ cable specifications
QSFP+ cable |
Cable length |
Data rate |
LSWM1QSTK0 |
1 m (3.28 ft) |
40 Gbps |
Used for connecting 40 Gbps QSFP+ ports |
LSWM1QSTK1 |
3 m (9.84 ft) |
LSWM1QSTK2 |
5 m (16.40 ft) |
Table 4 QSFP+ to SFP+cable specifications
QSFP+ cable |
Cable length |
Data rate |
LSWM1QSTK3 |
1 m (3.28 ft) |
40 Gbps |
For connecting a 40G QSFP+ port to four 10G SFP+ ports |
LSWM1QSTK4 |
3 m (9.84 ft) |
LSWM1QSTK5 |
5 m (16.40 ft) |
3 Obtaining documentation
For module installation, see H3C S9800 Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
