Title | Size | Downloads |
H3C Series Ethernet Switches Login Password Recovery Manual(V1.01)-book.pdf | 153.79 KB |
1 Introduction to H3C Switch Login Passwords
2 H3C Switch Login Password Recovery
Console Login Password Recovery
Telnet Login Password Recovery
User Level Switching Password Recovery
Web NMS Login Password Recovery
This document describes how to recover or change login passwords for the H3C switches listed in the table below.
Applicable products |
S5820X series |
S5810 series |
S5800 series |
S5600 series |
S5510 series |
S5500-EI series |
S5500-SI series |
S5120-SI series |
S5120-EI series |
S5100-EI series |
S5100-SI series |
S3610 series |
S3600-EI series |
S3600-SI series |
S3100-EI series |
S3100-SI series |
S3100-52P |
l For how to recover passwords for other H3C switches, refer to the corresponding installation manuals or contact your H3C agent.
l Support for the methods of recovering passwords depends on the device model.
l The application scope of this document is subject to change without notice.
Console login is the most basic method to log in to a switch locally, and is also the prerequisite for other login methods. Connect the serial port of your PC to the console port of the H3C switch, and then you can use the terminal emulation program on your PC to configure and manage the switch.
By default, you can log in to the H3C switch locally through the console port only.
To protect the switch from unauthorized accesses through the console port, you can set a console login username and password.
The H3C switch supports three console login authentication methods:
l none: No authentication.
l password: Password authentication.
l scheme: Username and password authentication.
l The scheme authentication method comprises local authentication and RADIUS authentication. For details, refer to the AAA section in the corresponding operation manual.
l For details about the three authentication methods, refer to the operation manual and command manual of the specific device model.
With the password or scheme authentication method configured, the switch prompts you to enter the login authentication information when you log in through the console port.
l Login interface of the password authentication method
* Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
User interface aux0 is available.
Press ENTER to get started.
Login authentication
Password:
l Login interface of the scheme authentication method (with the username admin)
Username:admin
Password:
Telnet offers a common method of remote login and management. You can telnet to a network device from any PC or terminal that can reach the device.
H3C switches support telnet. You can remotely manage an H3C switch via telnet, and prevent unauthorized accesses by setting the telnet username and password.
The H3C switch supports three telnet login authentication methods:
With the password or scheme authentication method configured, the switch prompts you to enter the login authentication information when you log in via telnet.
* Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved. *
Password:
Username:admin
Password:
You can temporarily change the current login user level with the user level switching password provided, thus to flexibly control the privileges of the current user. The change is effective for the current login only.
l To prevent inadvertent operations, you are recommended to log in as a low-level user, and switch to a higher user level for device maintenance.
l To protect the switch configuration, you can switch to a lower user level when you have the switch to be managed by someone else.
Local or RADIUS authentication of the scheme authentication method can be used for switching between user levels. Thus, you must set the user level switching password in the local device or RADIUS server.
For example, a user with the level 0 can use the following commands only:
<H3C> ?
User view commands:
cluster Run cluster command
display Display current system information
ping Ping function
quit Exit from current command view
ssh2 Establish a secure shell client connection
super Set the current user priority level
telnet Establish one TELNET connection
tracert Trace route function
Use the super command and enter the password to switch the current user level to 2.
<H3C> super 2
Password:
User privilege level is 2, and only those commands can be used
whose level is equal or less than this.
Privilege note: 0-VISIT, 1-MONITOR, 2-SYSTEM, 3-MANAGE
Then you can use all commands except the management level commands.
<H3C> ?
User view commands:
backup Backup next startup-configuration file to TFTP server
debugging Enable system debugging functions
free Clear user terminal interface
mtracert Trace route to multicast source
ntdp Run NTDP commands
ping Ping function
refresh Do soft reset
reset Reset operation
save Save current configuration
screen-length Specify the lines displayed on one screen
send Send information to other user terminal interface
stack Switch stack system
system-view Enter the System View
terminal Set the terminal line characteristics
undo Cancel current setting
<H3C>
Boot ROM Password
Boot ROM is a power-on self test (POST) program that initializes hardware and displays hardware information. The Boot ROM menu is the interface for human-computer interactions. It provides functions such as software loading and file management.
Press Ctrl + B when the following displays, and then you are prompted to enter the Boot ROM password.
Starting......
* H3C S5500-28C-PWR-EI BOOTROM, Version 509 *
Copyright (c) 2004-2009 Hangzhou H3C Tech. Co., Ltd.
Creation date : Jan 9 2009, 10:44:09
CPU Clock Speed : 533MHz
BUS Clock Speed : 133MHz
Memory Size : 256MB
Mac Address : 002389294f70
Press Ctrl-B to enter Boot Menu... 1
Password:
By default, there is no Boot ROM password. After the correct password is provided, the Boot ROM menu is displayed as follows:
BOOT MENU
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify bootrom password
6. Enter bootrom upgrade menu
7. Skip current configuration file
8. Set bootrom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9):
You can select 5 to set the Boot ROM password.
The H3C switch has a built-in Web server. It enables you to log in to the switch from a web network management system (NMS) terminal (PC) to manage and maintain the switch through the web interface.
To control accesses to the switch, you are recommended to configure a login username and password.
Figure 1-1 shows the web NMS login page.
The web NMS login page varies with the device model.
l The password recovery method described in this section applies to the password authentication method and local authentication of the scheme authentication method. In RADIUS authentication of the scheme authentication method, login passwords are configured on the RADIUS server. If you fail to log in to the RADIUS server due to password loss or RADIUS server failure, you are recommended to contact the administrator to obtain a new login password.
l If the switch is enabled with the password control function, the console login password is not displayed in the configuration file. Disable this function before performing the following operations.
If the console login password is lost, you can select Skip current configuration file in the Boot ROM menu to recover the password. To do that, follow these steps:
1) Use a configuration cable to connect the serial port of your PC to the console port of the H3C switch, and then you can display the login interface through the terminal emulation program. Table 2-1 shows the default settings of the console port.
Table 2-1 Default setting of the console port
Item |
Default setting |
Baud rate |
9600 bps |
Flow control |
None |
Parity |
None |
Stop bits |
1 |
Data bits |
8 |
2) Restart the switch.
3) When the following output appears, press Ctrl + B and enter the Boot ROM password as prompted to enter the Boot ROM menu.
Starting......
Memory Size : 256MB
Password:
By default, the H3C switch does not have a Boot ROM password. If you have lost your Boot ROM password, recover the password as described in Boot ROM Password Recovery.
4) Select 7 in the Boot ROM menu and type y to confirm your operation.
BOOT MENU
0. Reboot
Enter your choice(0-9): 7
The current setting is running configuration file when reboot.
Are you sure to skip current configuration file when reboot? Yes or No(Y/N) y
Setting......done!
5) When you return to the Boot ROM menu, select 0 to restart the switch.
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
^@System rebooting...
6) The switch skips the configuration file at the next startup and allows you to log in without providing the password.
Configuration file is skipped.
<H3C>
7) At the command line interface (CLI), use the display startup command to view the startup configuration file, and use the more command to view the console login password in the configuration file.
<H3C> display startup
Current startup saved-configuration file: NULL
Next startup saved-configuration file: flash:/startup.cfg
<H3C> more startup.cfg
l If the password authentication method is used, pay attention to the console login password configuration commands, which are gray highlighted.
The password is displayed in plain text:
user-interface aux 0
authentication-mode password
set authentication password simple test
The password is displayed in cipher text:
set authentication password cipher .]@USE=B,53Q=^Q`MAF4<1!!
A plain text password is directly displayed in the set authentication password simple command, and you can use or change it. A cipher text password is converted into cipher text characters, and you are recommended to change it.
l If the scheme authentication method is used, pay attention to the local username and password configuration commands, which are gray highlighted. The username is admin in this example.
local-user admin
password simple 123
service-type terminal
local-user admin
password cipher 7-CZB#/YX]KQ=^Q`MAF4<1!!
l If the switch has multiple local users, view the configuration of the terminal user configured with the service-type terminal command.
l A plain text password is directly displayed in the password simple command, and you can use or change it. A cipher text password is converted into cipher text characters, and you are recommended to change it.
8) Use the copy command to back up the configuration file. In this example, the backup file is named startup_bak.cfg.
<H3C> copy startup.cfg startup_bak.cfg
Copy flash:/startup.cfg to flash:/startup_bak.cfg?[Y/N]:y
%Copy file flash:/startup.cfg to flash:/startup_bak.cfg...Done.
9) You can use File Transfer Protocol (FTP) or Trivial File Transfer Protocol(TFTP) to transfer the configuration file to your PC, and edit the file in the text editor software such as Windows Notepad and WordPad by using any of the following methods:
l Change the keyword of the authentication-mode command to none.
l Change keyword cipher of the set authentication password command to simple, and type a new password (for the password authentication method).
l Change keyword cipher of the password command to simple, and type a new password (for the scheme authentication method).
The none authentication method is for temporary login only. To ensure device security, change the authentication method as soon as possible.
10) Upload the configuration file to the switch to replace the existing configuration file. Then the switch uses the new configuration file at the next startup, and allows you to log in with the new password. Meanwhile, other configurations are retained.
l If the switch is enabled with the password control function, the telnet login password is not displayed in the configuration file. Disable this function before performing the following operations.
If the telnet login password is lost, you can log in to the console through the console port to display and change the telnet login password.
1) Use a configuration cable to connect the serial port of your PC to the console port of the H3C switch, configure the terminal emulation program, and log in to the console. For the settings of the terminal emulation program, refer to Table 2-1.
2) Use the display current-configuration command to view the telnet authentication configuration.
l If the password authentication method is used, pay attention to the telnet password configuration command, which is gray highlighted.
<H3C> display current-configuration | begin user-interface
user-interface vty 0 4
user privilege level 3
set authentication password simple h3c
idle-timeout 0 0
l With the | begin user-interface parameter specified, the display current-configuration command displays the line that matches the user-interface character string and all the subsequent lines. This parameter helps you quickly locate the user interface configuration in the configuration file. For detailed information about the regular expression in display commands, refer to the operation manuals of the switches.
l If the configuration file contains no authentication-mode information, the authentication method is password, which is the default authentication method of the telnet (VTY) user interface.
l For a plain text password, you can use or change it. For a cipher text password, you are recommended to change it.
l If the scheme authentication method is used, pay attention to the telnet password configuration commands, which are gray highlighted.
<H3C> display current-configuration | begin local-user
local-user abc
password simple 123
service-type telnet
local-user admin
service-type telnet terminal
l If the switch has multiple local users, view the configuration of the telnet user configured with the service-type telnet or service-type telnet terminal command.
3) Change the authentication method and password.
l If the password is displayed in plain text, you can telnet to the device by entering the password (for the password authentication method) or username and password (for the scheme authentication method).
l If you want to change the telnet login authentication method, use the authentication-mode command in user view. For example, change the telnet authentication method to none as follows:
<H3C> system-view
[H3C] user-interface vty 0 4
[H3C-ui-vty0-4] authentication-mode none
l If you want to change the login password for the password authentication method, use the set authentication password command to change the password. For example, change the password to new as follows:
<H3C> system-view
[H3C-ui-vty0-4] set authentication password simple new
l If you want to change the login password of a user in the scheme authentication method, use the password command in the user view. For example, change the password of the user admin to new as follows:
<H3C> system-view
[H3C] local-user admin
[H3C-luser-admin] password simple new
When the preceding configuration is complete, you can use the new password and authentication method for the next telnet login.
l The none authentication method is for temporary login only. To ensure device security, change the authentication method as soon as possible.
l After the preceding configuration is complete, save the configuration with the save command. Otherwise, the switch may require you to use the former password and authentication method for login.
If the switch is enabled with the password control function, the user level switching password is not displayed in the configuration file. Disable this function before performing the following operations.
1) The configuration procedure is similar to that of recovering the console login password. Configure the device to skip the configuration file at startup. For detailed procedure, refer to Console Login Password Recovery.
2) After the configuration file is skipped, view the user level switching configuration in the startup configuration file.
l If local authentication is used for switching between user levels, pay attention to the commands for setting the user level switching password.
super password level 2 simple 123
super password level 3 simple 123
super password level 2 cipher 7-CZB#/YX]KQ=^Q`MAF4<1!!
super password level 3 cipher AN$TBB7'VF3Q=^Q`MAF4<1!!
A plain text password is directly displayed the super password command, and you can use or change it. A cipher text password is converted into cipher text characters, and you are recommended to change it.
l If the scheme authentication method is used, you are recommended to contact the RADIUS server administrator to obtain a new login password.
3) Use the copy command to back up the configuration file. In this example, the backup file is named startup_bak.cfg.
4) You can use FTP or TFTP to transfer the configuration file to your PC, and edit the file in the text editor software such as Windows Notepad and WordPad by using any of the following methods:
l Change keyword cipher of the password command to simple, and type a new password (for the password authentication method).
l Delete the super authentication-mode scheme command to set local authentication for user level switching, and set a new password with the super password command (for the scheme authentication method, not recommended).
5) Upload the configuration file to the switch to replace the existing configuration file. Then the switch uses the new configuration file at the next startup, and allows you to switch between user levels with the new password. Meanwhile, other configurations are retained.
Before performing the following operations, make sure that the Boot ROM password recovery function is enabled (default status). If you have disabled this function by selecting 8 in the Boot ROM menu, contact your H3C agent for password recovery.
Follow these steps to recover the Boot ROM password:
1) Use any of the following methods to obtain the MAC address of the switch:
l Use the display device manuinfo command.
<H3C> display device manuinfo
DEVICE_NAME : S5500-28C-PWR-EI
DEVICE_SERIAL_NUMBER : 210235A254H096000016
MAC_ADDRESS : 0023-8929-4F70
MANUFACTURING_DATE : 2009-10-07
VENDOR_NAME : H3C
l Reboot the switch and view its MAC address in the POST information.
* H3C S5500-28C-EI BOOTROM, Version 510 *
Creation date : May 18 2009, 17:01:57
Memory Size : 256MB
Mac Address : 002389294F70
l Check the MAC address label on the chassis.
2) Contact the H3C customer service staff and provide the MAC address. Then you can obtain a Boot ROM super password.
3) Use this password to enter the Boot ROM menu, select 5 in the menu, and change the Boot ROM password.
BOOT MENU
0. Reboot
Enter your choice(0-9):5
Old password: ******(Type the super password.)
New password: ******
Confirm password: ******
Current password has been changed successfully!
If the switch is enabled with the password control function, the local user password is not displayed in the configuration file. Disable this function before performing the following operations.
Log in to the switch through the console port or telnet and then follow these steps to recover the web NMS login password:
1) Use the display current-configuration command to view the local username and password.
local-user abc
password simple 123
service-type telnet
local-user admin
service-type terminal telnet
l If the switch has multiple local users, view the configuration of the telnet user configured with the service-type telnet or service-type terminal telnet command.
2) Change the password. In this example, the password of the user admin is changed to new.
<H3C> system-view
Save the configuration. Then you can use the username admin and password new to log in to the switch through the web NMS.
Copyright ©
2007-2010 Hangzhou H3C Technologies Co., Ltd. All rights reserved.
No part of this manual may be reproduced or transmitted in any form or by any
means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
