Title | Size | Downloads |
Command Index-book.pdf | 134.43 KB |
- H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
- H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
- H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
- H3C S5500-EI Series Ethernet Switches Compliance and Safety Manual-6W101
- H3C S5500-SI Complete Compliance and Safety Manual-6W100
- H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
The command index includes all the commands supported on your S5500-EI series switches, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
abr-summary (OSPF area view) |
Layer 3 - IP Routing Command Reference |
4-1 |
abr-summary (OSPFv3 area view) |
9-1 |
access-limit |
Security Command Reference |
1-2 |
access-limit enable |
1-1 |
accounting |
ACL and QoS Command Reference |
2-7 |
accounting command |
1-2 |
accounting default |
1-3 |
accounting lan-access |
1-4 |
accounting login |
1-5 |
accounting optional |
1-6 |
accounting portal |
1-6 |
acl |
Fundamentals Command Reference |
2-1 |
acl |
1-1 |
acl copy |
1-2 |
acl ipv6 |
1-3 |
acl ipv6 copy |
1-4 |
acl ipv6 logging frequence |
1-5 |
acl ipv6 name |
1-5 |
acl logging frequence |
1-6 |
acl name |
1-6 |
activation-key |
2-1 |
active region-configuration |
Layer 2 - LAN Switching Command Reference |
7-1 |
add-member |
Network Management and Monitoring Command Reference |
9-14 |
administrator-address |
9-14 |
advantage-factor |
2-1 |
aggregate |
6-1 |
aggregate (IPv6 address family view) |
11-1 |
aggregate (IPv6 MBGP address family view) |
IP Multicast Command Reference |
13-1 |
aggregate (MBGP family view) |
7-1 |
apply as-path |
12-1 |
apply comm-list delete |
12-2 |
apply community |
12-2 |
apply cost |
12-3 |
apply cost-type |
12-4 |
apply extcommunity |
12-4 |
apply ip-address next-hop |
12-19 |
apply ipv6 next-hop |
12-24 |
apply isis |
12-5 |
apply local-preference |
12-6 |
apply origin |
12-6 |
apply poe-profile |
5-1 |
apply poe-profile interface |
5-1 |
apply preference |
12-7 |
apply preferred-value |
12-8 |
apply tag |
12-8 |
area (OSPF view) |
4-2 |
area (OSPFv3 view) |
9-2 |
area-authentication-mode |
5-1 |
arp anti-attack active-ack enable |
17-8 |
arp anti-attack source-mac |
17-4 |
arp anti-attack source-mac aging-time |
17-5 |
arp anti-attack source-mac exclude-mac |
17-5 |
arp anti-attack source-mac threshold |
17-6 |
arp anti-attack valid-ack enable |
17-7 |
arp check enable |
Layer 3 - IP Services Command Reference |
1-1 |
arp detection enable |
17-9 |
arp detection mode |
17-9 |
arp detection static-bind |
17-10 |
arp detection trust |
17-11 |
arp detection validate |
17-11 |
arp max-learning-num |
1-2 |
arp rate-limit |
17-3 |
arp resolving-route enable |
17-1 |
arp source-suppression enable |
17-1 |
arp source-suppression limit |
17-2 |
arp static |
1-2 |
arp timer aging |
1-3 |
asbr-summary |
4-2 |
ascii |
3-6 |
attribute |
12-1 |
authentication default |
1-7 |
authentication lan-access |
1-8 |
authentication login |
1-9 |
authentication portal |
1-10 |
2-3 |
4-3 |
authorization command |
1-11 |
authorization default |
1-12 |
authorization lan-access |
1-13 |
authorization login |
1-14 |
authorization portal |
1-15 |
authorization-attribute |
1-15 |
auto-build |
9-15 |
auto-cost enable |
5-2 |
auto-execute command |
2-4 |
auto-rp enable |
5-1 |
backup startup-configuration |
6-1 |
balance (BGP/BGP-VPN instance view) |
6-3 |
balance (IPv6 address family view) |
11-2 |
balance (IPv6 MBGP address family view) |
13-2 |
balance (MBGP family view) |
7-2 |
bandwidth-reference |
9-2 |
bandwidth-reference (IS-IS view) |
5-3 |
bandwidth-reference (OSPF view) |
4-4 |
bestroute as-path-neglect (BGP/BGP-VPN instance view) |
6-3 |
bestroute as-path-neglect (IPv6 address family view) |
11-3 |
bestroute as-path-neglect (IPv6 MBGP address family view) |
13-3 |
bestroute as-path-neglect (MBGP family view) |
7-3 |
bestroute compare-med (BGP/BGP-VPN instance view) |
6-4 |
bestroute compare-med (IPv6 address family view) |
11-3 |
bestroute compare-med (IPv6 MBGP address family view) |
13-3 |
bestroute compare-med (MBGP family view) |
7-4 |
bestroute med-confederation (BGP/BGP-VPN instance view) |
6-5 |
bestroute med-confederation (IPv6 address family view) |
11-4 |
bestroute med-confederation (IPv6 MBGP address family view) |
13-4 |
bestroute med-confederation (MBGP family view) |
7-4 |
bfd authentication-mode |
High Availability Command Reference |
8-1 |
bfd detect-multiplier |
8-2 |
bfd echo-source-ip |
8-2 |
bfd min-echo-receive-interval |
8-3 |
bfd min-receive-interval |
8-3 |
bfd min-transmit-interval |
8-4 |
bfd session init-mode |
8-5 |
bgp |
6-5 |
bims-server |
4-1 |
binary |
3-7 |
bind-attribute |
1-17 |
black-list add-mac |
9-16 |
black-list delete-mac |
9-17 |
bootfile-name |
4-2 |
boot-loader |
7-1 |
bootrom |
7-2 |
bootrom-update security-check enable |
7-3 |
bpdu-drop any |
7-2 |
bpdu-tunnel dot1q |
8-1 |
bpdu-tunnel tunnel-dmac |
8-2 |
broadcast-suppression |
1-1 |
bsr-policy (IPv6 PIM view) |
12-1 |
bsr-policy (PIM view) |
5-1 |
build |
9-17 |
bye |
3-7 |
bye |
14-2 |
ca identifier |
12-2 |
cache-sa-enable |
6-1 |
car |
2-7 |
c-bsr (IPv6 PIM view) |
12-2 |
c-bsr (PIM view) |
5-2 |
c-bsr admin-scope |
5-3 |
c-bsr global |
5-3 |
c-bsr group |
5-4 |
c-bsr hash-length (IPv6 PIM view) |
12-2 |
c-bsr hash-length (PIM view) |
5-5 |
c-bsr holdtime (IPv6 PIM view) |
12-3 |
c-bsr holdtime (PIM view) |
5-5 |
c-bsr interval (IPv6 PIM view) |
12-3 |
c-bsr interval (PIM view) |
5-6 |
c-bsr priority (IPv6 PIM view) |
12-4 |
c-bsr priority (PIM view) |
5-7 |
cd |
3-7 |
cd |
5-1 |
cd |
14-2 |
cdup |
3-8 |
cdup |
14-3 |
certificate request entity |
12-2 |
certificate request from |
12-3 |
certificate request mode |
12-3 |
certificate request polling |
12-4 |
certificate request url |
12-5 |
cfd cc enable |
2-1 |
cfd cc interval |
2-1 |
cfd enable |
2-2 |
cfd linktrace |
2-3 |
cfd linktrace auto-detection |
2-4 |
cfd loopback |
2-5 |
cfd ma |
2-6 |
cfd md |
2-7 |
cfd mep |
2-7 |
cfd mep enable |
2-8 |
cfd mip-rule |
2-9 |
cfd remote-mep |
2-10 |
cfd service-instance |
2-10 |
check region-configuration |
7-2 |
checkzero |
3-1 |
checkzero |
8-1 |
ciphersuite |
15-1 |
circuit-cost |
5-3 |
classifier behavior |
2-15 |
client-verify enable |
15-2 |
clock datetime |
8-1 |
clock summer-time one-off |
8-1 |
clock summer-time repeating |
8-2 |
clock timezone |
8-4 |
close |
3-9 |
close-mode wait |
15-2 |
cluster |
9-18 |
cluster enable |
9-19 |
cluster switch-to |
9-19 |
cluster-local-user |
9-20 |
cluster-mac |
9-21 |
cluster-mac syn-interval |
9-21 |
cluster-snmp-agent community |
9-22 |
cluster-snmp-agent group v3 |
9-23 |
cluster-snmp-agent mib-view included |
9-24 |
cluster-snmp-agent usm-user v3 |
9-25 |
codec-type |
2-1 |
command-alias enable |
1-1 |
command-alias mapping |
1-1 |
command-privilege level |
1-2 |
common-name |
12-6 |
compare-different-as-med (BGP/BGP-VPN instance view) |
6-6 |
compare-different-as-med (IPv6 address family view) |
11-5 |
compare-different-as-med (IPv6 MBGP address family view) |
13-5 |
compare-different-as-med (MBGP family view) |
7-5 |
confederation id |
6-7 |
confederation nonstandard |
6-7 |
confederation peer-as |
6-8 |
control-vlan |
4-1 |
copy |
5-2 |
copyright-info enable |
2-5 |
cost-style |
5-4 |
country |
12-6 |
crl check |
12-7 |
crl update-period |
12-7 |
crl url |
12-8 |
c-rp (IPv6 PIM view) |
12-5 |
c-rp (PIM view) |
5-7 |
c-rp advertisement-interval (IPv6 PIM view) |
12-6 |
c-rp advertisement-interval (PIM view) |
5-9 |
c-rp holdtime (IPv6 PIM view) |
12-6 |
c-rp holdtime (PIM view) |
5-9 |
crp-policy (IPv6 PIM view) |
12-7 |
crp-policy (PIM view) |
5-10 |
cut connection |
1-18 |
dampening (BGP/BGP-VPN instance view) |
6-9 |
dampening (IPv6 address family view) |
11-5 |
dampening (IPv6 MBGP address family view) |
13-5 |
dampening (MBGP family view) |
7-5 |
databits |
2-6 |
data-fill |
2-2 |
data-flow-format (HWTACACS scheme view) |
3-1 |
data-flow-format (RADIUS scheme view) |
2-1 |
data-size |
2-3 |
debugging |
3-9 |
debugging |
1-8 |
default |
4-4 |
default cost |
9-3 |
default cost (RIP view) |
3-1 |
default cost (RIPng view) |
8-1 |
default ipv4-unicast |
6-10 |
default local-preference (BGP/BGP-VPN instance view) |
6-11 |
default local-preference (IPv6 address family view) |
11-6 |
default local-preference (IPv6 MBGP address family view) |
13-6 |
default local-preference (MBGP family view) |
7-6 |
default med (BGP/BGP-VPN instance view) |
6-11 |
default med (IPv6 address family view) |
11-7 |
default med (IPv6 MBGP address family view) |
13-7 |
default med (MBGP family view) |
7-7 |
default-cost (OSPF area view) |
4-5 |
default-cost (OSPFv3 area view) |
9-4 |
default-route |
3-2 |
default-route imported (BGP/BGP-VPN instance view) |
6-12 |
default-route imported (IPv6 address family view) |
11-8 |
default-route imported (IPv6 MBGP address family view) |
13-8 |
default-route imported (MBGP family view) |
7-8 |
default-route-advertise |
9-4 |
default-route-advertise (IS-IS view) |
5-5 |
default-route-advertise (OSPF view) |
4-6 |
delete |
3-11 |
delete |
5-2 |
delete |
14-3 |
delete ip rpf-route-static |
3-1 |
delete ipv6 static-routes all |
7-1 |
delete static-routes all |
2-1 |
delete-member |
9-26 |
description |
1-2 |
description |
2-1 |
description |
5-1 |
description |
9-1 |
description |
14-1 |
description |
1-7 |
description (any NQA test type view) |
2-4 |
description (OSPF/OSPF area view) |
4-7 |
destination |
13-1 |
destination ip |
2-5 |
destination port |
2-5 |
dhcp enable |
4-2 |
dhcp relay address-check |
5-1 |
dhcp relay information circuit-id format-type |
5-2 |
dhcp relay information circuit-id string |
5-3 |
dhcp relay information enable |
5-3 |
dhcp relay information format |
5-4 |
dhcp relay information remote-id format-type |
5-5 |
dhcp relay information remote-id string |
5-5 |
dhcp relay information strategy |
5-6 |
dhcp relay release ip |
5-7 |
dhcp relay security refresh enable |
5-8 |
dhcp relay security static |
5-7 |
dhcp relay security tracker |
5-9 |
dhcp relay server-detect |
5-10 |
dhcp relay server-group |
5-10 |
dhcp relay server-select |
5-11 |
dhcp select relay |
5-12 |
dhcp select server global-pool |
4-4 |
dhcp server apply ip-pool |
4-3 |
dhcp server detect |
4-4 |
dhcp server forbidden-ip |
4-5 |
dhcp server ip-pool |
4-6 |
dhcp server ping packets |
4-6 |
dhcp server ping timeout |
4-7 |
dhcp server relay information enable |
4-7 |
dhcp-snooping |
7-1 |
dhcp-snooping information circuit-id format-type |
7-2 |
dhcp-snooping information circuit-id string |
7-2 |
dhcp-snooping information enable |
7-3 |
dhcp-snooping information format |
7-4 |
dhcp-snooping information remote-id format-type |
7-4 |
dhcp-snooping information remote-id string |
7-5 |
dhcp-snooping information strategy |
7-6 |
dhcp-snooping trust |
7-7 |
dir |
3-11 |
dir |
5-3 |
dir |
14-4 |
disconnect |
3-12 |
display acl |
1-7 |
display acl ipv6 |
1-9 |
display acl resource |
1-10 |
display arp |
1-4 |
display arp anti-attack source-mac |
17-7 |
display arp detection |
17-12 |
display arp detection statistics |
17-13 |
display arp ip-address |
1-6 |
display arp source-suppression |
17-3 |
display arp timer aging |
1-6 |
display arp vpn-instance |
1-7 |
display bfd debugging-switches |
8-5 |
display bfd interface |
8-6 |
display bfd paf |
8-7 |
display bfd session |
8-8 |
display bgp group |
6-13 |
display bgp ipv6 group |
11-8 |
display bgp ipv6 multicast group |
13-11 |
display bgp ipv6 multicast network |
13-12 |
display bgp ipv6 multicast paths |
13-13 |
display bgp ipv6 multicast peer |
13-14 |
display bgp ipv6 multicast routing-table |
13-15 |
display bgp ipv6 multicast routing-table as-path-acl |
13-17 |
display bgp ipv6 multicast routing-table community |
13-18 |
display bgp ipv6 multicast routing-table community-list |
13-19 |
display bgp ipv6 multicast routing-table dampened |
13-20 |
display bgp ipv6 multicast routing-table dampening parameter |
13-20 |
display bgp ipv6 multicast routing-table different-origin-as |
13-21 |
display bgp ipv6 multicast routing-table flap-info |
13-22 |
display bgp ipv6 multicast routing-table peer |
13-23 |
display bgp ipv6 multicast routing-table regular-expression |
13-24 |
display bgp ipv6 multicast routing-table statistic |
13-25 |
display bgp ipv6 network |
11-10 |
display bgp ipv6 paths |
11-11 |
display bgp ipv6 peer |
11-12 |
display bgp ipv6 routing-table |
11-13 |
display bgp ipv6 routing-table as-path-acl |
11-15 |
display bgp ipv6 routing-table community |
11-15 |
display bgp ipv6 routing-table community-list |
11-16 |
display bgp ipv6 routing-table dampened |
11-17 |
display bgp ipv6 routing-table dampening parameter |
11-18 |
display bgp ipv6 routing-table different-origin-as |
11-19 |
display bgp ipv6 routing-table flap-info |
11-19 |
display bgp ipv6 routing-table peer |
11-20 |
display bgp ipv6 routing-table regular-expression |
11-21 |
display bgp ipv6 routing-table statistic |
11-22 |
display bgp multicast group |
7-12 |
display bgp multicast network |
7-13 |
display bgp multicast paths |
7-14 |
display bgp multicast peer |
7-15 |
display bgp multicast routing-table |
7-17 |
display bgp multicast routing-table as-path-acl |
7-19 |
display bgp multicast routing-table cidr |
7-19 |
display bgp multicast routing-table community |
7-20 |
display bgp multicast routing-table community-list |
7-21 |
display bgp multicast routing-table dampened |
7-22 |
display bgp multicast routing-table dampening parameter |
7-23 |
display bgp multicast routing-table different-origin-as |
7-23 |
display bgp multicast routing-table flap-info |
7-24 |
display bgp multicast routing-table peer |
7-25 |
display bgp multicast routing-table regular-expression |
7-26 |
display bgp multicast routing-table statistic |
7-27 |
display bgp network |
6-14 |
display bgp paths |
6-15 |
display bgp peer |
6-16 |
display bgp routing-table |
6-18 |
display bgp routing-table as-path-acl |
6-20 |
display bgp routing-table cidr |
6-21 |
display bgp routing-table community |
6-21 |
display bgp routing-table community-list |
6-22 |
display bgp routing-table dampened |
6-23 |
display bgp routing-table dampening parameter |
6-24 |
display bgp routing-table different-origin-as |
6-24 |
display bgp routing-table flap-info |
6-25 |
display bgp routing-table label |
6-26 |
display bgp routing-table peer |
6-27 |
display bgp routing-table regular-expression |
6-28 |
display bgp routing-table statistic |
6-28 |
display bgp vpnv4 vpn-instance group |
14-1 |
display bgp vpnv4 vpn-instance network |
14-3 |
display bgp vpnv4 vpn-instance paths |
14-4 |
display bgp vpnv4 vpn-instance peer |
14-5 |
display bgp vpnv4 vpn-instance routing-table |
14-7 |
display boot-loader |
7-4 |
display bootp client |
8-1 |
display brief interface |
1-3 |
display cfd linktrace-reply |
2-11 |
display cfd linktrace-reply auto-detection |
2-12 |
display cfd ma |
2-14 |
display cfd md |
2-15 |
display cfd mep |
2-16 |
display cfd mp |
2-19 |
display cfd remote-mep |
2-20 |
display cfd service-instance |
2-21 |
display cfd status |
2-22 |
display channel |
13-1 |
display clipboard |
1-3 |
display clipboard |
8-5 |
display clock |
8-5 |
display cluster |
9-26 |
display cluster base-topology |
9-28 |
display cluster black-list |
9-30 |
display cluster candidates |
9-30 |
display cluster current-topology |
9-32 |
display cluster members |
9-34 |
display command-alias |
1-4 |
display connection |
1-19 |
display cpu-usage |
8-6 |
display cpu-usage history |
8-9 |
display current-configuration |
6-2 |
display debugging |
1-9 |
display default-configuration |
6-3 |
display device |
8-11 |
display device manuinfo |
8-12 |
display dhcp client |
6-1 |
display dhcp relay |
5-12 |
display dhcp relay information |
5-13 |
display dhcp relay security |
5-14 |
display dhcp relay security statistics |
5-15 |
display dhcp relay security tracker |
5-16 |
display dhcp relay server-group |
5-16 |
display dhcp relay statistics |
5-17 |
display dhcp server conflict |
4-8 |
display dhcp server expired |
4-9 |
display dhcp server forbidden-ip |
4-10 |
display dhcp server free-ip |
4-10 |
display dhcp server ip-in-use |
4-11 |
display dhcp server statistics |
4-12 |
display dhcp server tree |
4-14 |
display dhcp-snooping |
7-7 |
display dhcp-snooping information |
7-8 |
display dhcp-snooping packet statistics |
7-9 |
display dhcp-snooping trust |
7-10 |
display diagnostic-information |
8-6 |
display dldp |
3-1 |
display dldp statistics |
3-3 |
display dns domain |
9-1 |
display dns dynamic-host |
9-2 |
display dns ipv6 dynamic-host |
12-1 |
display dns ipv6 server |
12-2 |
display dns server |
9-3 |
display domain |
1-20 |
display dot1x |
4-1 |
display environment |
8-13 |
display fan |
8-14 |
display fib |
10-1 |
display fib ip-address |
10-3 |
display fib vpn-instance |
14-10 |
display fib vpn-instance ip-address |
14-12 |
display ftp client configuration |
3-13 |
display ftp-server |
3-1 |
display ftp-user |
3-2 |
display garp statistics |
12-1 |
display garp timer |
12-2 |
display gvrp local-vlan |
12-2 |
display gvrp state |
12-3 |
display gvrp statistics |
12-4 |
display gvrp status |
12-5 |
display gvrp vlan-operation |
12-6 |
display habp |
10-1 |
display habp table |
10-1 |
display habp traffic |
10-2 |
display history-command |
1-4 |
display hotkey |
1-5 |
display hwtacacs |
3-1 |
display icmp statistics |
10-4 |
display igmp group |
4-1 |
display igmp group port-info |
4-2 |
display igmp interface |
4-4 |
display igmp proxying group |
4-6 |
display igmp routing-table |
4-8 |
display igmp ssm-mapping |
4-9 |
display igmp ssm-mapping group |
4-10 |
display igmp-snooping group |
1-1 |
display igmp-snooping statistics |
1-2 |
display info-center |
13-2 |
display interface |
1-5 |
display interface loopback |
2-2 |
display interface null |
2-4 |
display interface tunnel |
13-2 |
display interface vlan-interface |
9-2 |
display ip as-path |
12-9 |
display ip check source |
16-1 |
display ip community-list |
12-10 |
display ip extcommunity-list |
12-10 |
display ip host |
9-4 |
display ip http |
2-6 |
display ip https |
2-7 |
display ip interface |
3-1 |
display ip interface brief |
3-3 |
display ip ip-prefix |
12-20 |
display ip ipv6-prefix |
12-25 |
display ip multicast routing-table |
7-8 |
display ip multicast routing-table ip-address |
7-10 |
display ip routing-table |
1-1 |
display ip routing-table acl |
1-5 |
display ip routing-table ip-address |
1-7 |
display ip routing-table ip-prefix |
1-9 |
display ip routing-table protocol |
1-10 |
display ip routing-table statistics |
1-11 |
display ip routing-table vpn-instance |
14-12 |
display ip socket |
10-5 |
display ip statistics |
10-8 |
display ip vpn-instance |
14-13 |
display ipc channel |
4-1 |
display ipc link |
4-2 |
display ipc multicast-group |
4-3 |
display ipc node |
4-4 |
display ipc packet |
4-4 |
display ipc performance |
4-5 |
display ipc queue |
4-6 |
display ip-subnet-vlan interface |
9-29 |
display ip-subnet-vlan vlan |
9-30 |
display ipv6 fib |
12-3 |
display ipv6 host |
12-4 |
display ipv6 interface |
12-5 |
display ipv6 interface tunnel |
13-4 |
display ipv6 multicast routing-table |
13-8 |
display ipv6 multicast routing-table ipv6-address prefix-length |
13-10 |
display ipv6 neighbors |
12-9 |
display ipv6 neighbors count |
12-11 |
display ipv6 pathmtu |
12-12 |
display ipv6 routing-table |
1-12 |
display ipv6 routing-table acl |
1-13 |
display ipv6 routing-table ipv6-address |
1-13 |
display ipv6 routing-table ipv6-address1 ipv6-address2 |
1-14 |
display ipv6 routing-table ipv6-prefix |
1-15 |
display ipv6 routing-table protocol |
1-16 |
display ipv6 routing-table statistics |
1-17 |
display ipv6 routing-table verbose |
1-17 |
display ipv6 socket |
12-13 |
display ipv6 statistics |
12-14 |
display irf |
IRF Command Reference |
1-1 |
display irf configuration |
1-2 |
display irf topology |
1-3 |
display isis brief |
5-5 |
display isis debug-switches |
5-7 |
display isis graceful-restart status |
5-7 |
display isis interface |
5-9 |
display isis license |
5-11 |
display isis lsdb |
5-13 |
display isis mesh-group |
5-15 |
display isis name-table |
5-16 |
display isis peer |
5-17 |
display isis route |
5-20 |
display isis route ipv6 |
10-1 |
display isis spf-log |
5-22 |
display isis statistics |
5-24 |
display isolate-user-vlan |
10-1 |
display lacp system-id |
5-2 |
display link-aggregation load-sharing mode |
5-2 |
display link-aggregation member-port |
5-4 |
display link-aggregation summary |
5-7 |
display link-aggregation verbose |
5-8 |
display lldp local-information |
15-1 |
display lldp neighbor-information |
15-5 |
display lldp statistics |
15-10 |
display lldp status |
15-11 |
display lldp tlv-config |
15-13 |
display local-proxy-arp |
2-1 |
display local-user |
1-22 |
display logbuffer |
13-4 |
display logbuffer summary |
13-6 |
display loopback-detection |
1-10 |
display mac-address |
3-1 |
display mac-address aging-time |
3-2 |
display mac-authentication |
6-1 |
display mac-vlan |
9-19 |
display mac-vlan interface |
9-21 |
display memory |
8-14 |
display mib-style |
7-1 |
display mirroring-group |
10-1 |
display mld group |
11-1 |
display mld group port-info |
11-2 |
display mld interface |
11-4 |
display mld proxying group |
11-6 |
display mld routing-table |
11-7 |
display mld ssm-mapping |
11-8 |
display mld ssm-mapping group |
11-9 |
display mld-snooping group |
8-1 |
display mld-snooping statistics |
8-3 |
display monitor-link group |
6-1 |
display msdp brief |
6-2 |
display msdp peer-status |
6-3 |
display msdp sa-cache |
6-6 |
display msdp sa-count |
6-7 |
display multicast boundary |
3-2 |
display multicast forwarding-table |
3-2 |
display multicast ipv6 boundary |
10-1 |
display multicast ipv6 forwarding-table |
10-2 |
display multicast ipv6 routing-table |
10-5 |
display multicast ipv6 rpf-info |
10-6 |
display multicast routing-table |
3-5 |
display multicast routing-table static |
3-7 |
display multicast rpf-info |
3-8 |
display multicast-vlan |
2-1 |
display multicast-vlan ipv6 |
9-1 |
display ndp |
9-1 |
display nqa history |
2-6 |
display nqa result |
2-7 |
display nqa server status |
2-37 |
display nqa statistics |
2-11 |
display ntdp |
9-7 |
display ntdp device-list |
9-8 |
display ntdp single-device mac-address |
9-9 |
display ntp-service sessions |
3-1 |
display ntp-service status |
3-5 |
display ntp-service trace |
3-7 |
display oam |
1-1 |
display oam configuration |
1-5 |
display oam critical-event |
1-6 |
display oam link-event |
1-7 |
display ospf abr-asbr |
4-7 |
display ospf asbr-summary |
4-8 |
display ospf brief |
4-10 |
display ospf cumulative |
4-12 |
display ospf error |
4-14 |
display ospf interface |
4-16 |
display ospf lsdb |
4-18 |
display ospf nexthop |
4-20 |
display ospf peer |
4-21 |
display ospf peer statistics |
4-24 |
display ospf request-queue |
4-25 |
display ospf retrans-queue |
4-26 |
display ospf routing |
4-27 |
display ospf sham-link |
4-29 |
display ospf vlink |
4-29 |
display ospfv3 |
9-5 |
display ospfv3 graceful-restart status |
9-7 |
display ospfv3 interface |
9-8 |
display ospfv3 lsdb |
9-9 |
display ospfv3 lsdb statistic |
9-12 |
display ospfv3 next-hop |
9-13 |
display ospfv3 peer |
9-14 |
display ospfv3 peer statistic |
9-16 |
display ospfv3 request-list |
9-17 |
display ospfv3 retrans-list |
9-18 |
display ospfv3 routing |
9-20 |
display ospfv3 statistics |
9-21 |
display ospfv3 topology |
9-22 |
display ospfv3 vlink |
9-23 |
display packet-drop interface |
1-11 |
display packet-drop summary |
1-11 |
display patch information |
7-5 |
display pim bsr-info |
5-11 |
display pim claimed-route |
5-12 |
display pim control-message counters |
5-13 |
display pim grafts |
5-15 |
display pim interface |
5-16 |
display pim ipv6 bsr-info |
12-8 |
display pim ipv6 claimed-route |
12-9 |
display pim ipv6 control-message counters |
12-11 |
display pim ipv6 grafts |
12-12 |
display pim ipv6 interface |
12-13 |
display pim ipv6 join-prune |
12-15 |
display pim ipv6 neighbor |
12-16 |
display pim ipv6 routing-table |
12-18 |
display pim ipv6 rp-info |
12-20 |
display pim join-prune |
5-18 |
display pim neighbor |
5-19 |
display pim routing-table |
5-21 |
display pim rp-info |
5-23 |
display pki certificate |
12-8 |
display pki certificate access-control-policy |
12-10 |
display pki certificate attribute-group |
12-11 |
display pki crl domain |
12-12 |
display poe device |
5-2 |
display poe interface |
5-3 |
display poe interface power |
5-7 |
display poe pse |
5-8 |
display poe pse interface |
5-10 |
display poe pse interface power |
5-11 |
display poe-profile |
5-12 |
display poe-profile interface |
5-14 |
display port |
9-10 |
display port combo |
1-12 |
display portal acl |
7-1 |
display portal connection statistics |
7-3 |
display portal free-rule |
7-6 |
display portal interface |
7-7 |
display portal server |
7-8 |
display portal server statistics |
7-9 |
display portal tcp-cheat statistics |
7-11 |
display portal user |
7-12 |
display port-group manual |
1-13 |
display port-isolate group |
6-1 |
display port-security |
8-1 |
display port-security mac-address block |
8-4 |
display port-security mac-address security |
8-5 |
display power |
8-15 |
display protocol-vlan interface |
9-23 |
display protocol-vlan vlan |
9-24 |
display proxy-arp |
2-1 |
display public-key local public |
11-1 |
display public-key peer |
11-2 |
display qos gts interface |
4-1 |
display qos lr interface |
4-2 |
display qos map-table |
3-1 |
display qos policy |
2-17 |
display qos policy global |
2-18 |
display qos policy interface |
2-19 |
display qos sp interface |
5-1 |
display qos trust interface |
3-4 |
display qos vlan-policy |
2-21 |
display qos wfq interface |
5-1 |
display qos wred interface |
6-1 |
display qos wred table |
6-1 |
display qos wrr interface |
5-2 |
display radius scheme |
2-2 |
display radius statistics |
2-4 |
display reboot-type |
8-16 |
display rip |
3-3 |
display rip database |
3-5 |
display rip interface |
3-6 |
display rip route |
3-7 |
display ripng |
8-2 |
display ripng database |
8-3 |
display ripng interface |
8-4 |
display ripng route |
8-5 |
display rmon alarm |
8-1 |
display rmon event |
8-2 |
display rmon eventlog |
8-3 |
display rmon history |
8-5 |
display rmon prialarm |
8-8 |
display rmon statistics |
8-9 |
display route-policy |
12-11 |
display router id |
1-19 |
display rps |
8-16 |
display rrpp brief |
4-2 |
display rrpp ring-group |
4-4 |
display rrpp statistics |
4-4 |
display rrpp verbose |
4-7 |
display saved-configuration |
6-3 |
display schedule job |
8-17 |
display schedule reboot |
8-18 |
display service-loopback group |
16-1 |
display sflow |
12-1 |
display sftp client source |
14-5 |
display smart-link flush |
5-1 |
display smart-link group |
5-2 |
display snmp-agent community |
6-1 |
display snmp-agent group |
6-2 |
display snmp-agent local-engineid |
6-3 |
display snmp-agent mib-view |
6-4 |
display snmp-agent statistics |
6-5 |
display snmp-agent sys-info |
6-7 |
display snmp-agent trap queue |
6-8 |
display snmp-agent trap-list |
6-9 |
display snmp-agent usm-user |
6-9 |
display ssh client source |
13-8 |
display ssh server |
13-1 |
display ssh server-info |
13-9 |
display ssh user-information |
13-2 |
display ssl client-policy |
15-3 |
display ssl server-policy |
15-4 |
display startup |
6-5 |
display stop-accounting-buffer |
2-7 |
3-4 |
display storm-constrain |
1-14 |
display stp |
7-3 |
display stp abnormal-port |
7-9 |
display stp down-port |
7-10 |
display stp history |
7-11 |
display stp region-configuration |
7-12 |
display stp root |
7-13 |
display stp tc |
7-14 |
display switchover state |
1-5 |
display system-failure |
8-18 |
display tcp ipv6 statistics |
12-18 |
display tcp ipv6 status |
12-21 |
display tcp statistics |
10-10 |
display tcp status |
10-12 |
display telnet client configuration |
2-8 |
display tftp client configuration |
4-1 |
display this |
6-6 |
display time-range |
1-11 |
display track |
9-1 |
display traffic behavior |
2-9 |
display traffic classifier |
2-1 |
display transceiver |
8-25 |
display transceiver alarm |
8-21 |
display transceiver diagnosis |
8-24 |
display transceiver manuinfo |
8-27 |
display trapbuffer |
13-7 |
display udp ipv6 statistics |
12-22 |
display udp statistics |
10-13 |
display udp-helper server |
11-1 |
display user-bind |
16-2 |
display user-group |
1-24 |
display user-interface |
2-8 |
display user-profile |
9-1 |
display users |
2-10 |
display version |
8-19 |
display vlan |
9-3 |
display voice vlan oui |
11-1 |
display voice vlan state |
11-2 |
display vrrp |
7-1 |
display vrrp ipv6 |
7-15 |
display vrrp ipv6 statistics |
7-18 |
display vrrp statistics |
7-4 |
display web users |
2-11 |
dldp authentication-mode |
3-4 |
dldp delaydown-timer |
3-5 |
dldp enable |
3-5 |
dldp interval |
3-6 |
dldp reset |
3-7 |
dldp unidirectional-shutdown |
3-7 |
dldp work-mode |
3-8 |
dns domain |
9-4 |
dns proxy enable |
9-5 |
dns resolve |
9-6 |
dns server |
9-6 |
dns server ipv6 |
12-23 |
dns-list |
4-15 |
domain |
1-25 |
domain default enable |
1-25 |
domain ring |
4-10 |
domain-authentication-mode |
5-25 |
domain-id |
14-15 |
domain-name |
4-16 |
dot1x |
4-4 |
dot1x authentication-method |
4-5 |
dot1x free-ip |
5-1 |
dot1x guest-vlan |
4-6 |
dot1x handshake |
4-8 |
dot1x handshake secure |
4-8 |
dot1x mandatory-domain |
4-9 |
dot1x max-user |
4-10 |
dot1x multicast-trigger |
4-11 |
dot1x port-control |
4-11 |
dot1x port-method |
4-13 |
dot1x quiet-period |
4-14 |
dot1x re-authenticate |
4-14 |
dot1x retry |
4-15 |
dot1x timer |
4-16 |
dot1x timer ead-timeout |
5-2 |
dot1x url |
5-2 |
duplex |
1-15 |
ebgp-interface-sensitive |
6-29 |
embedded-rp |
12-21 |
enable link-local-signaling |
4-30 |
enable log |
4-31 |
enable log updown |
13-8 |
enable out-of-band-resynchronization |
4-32 |
enable snmp trap updown |
5-11 |
6-11 |
encap-data-enable |
6-8 |
escape-key |
2-12 |
execute |
5-5 |
exit |
14-5 |
expiration-date |
1-26 |
expired |
4-17 |
export route-policy |
14-16 |
ext-community-type |
14-16 |
fast-leave (IGMP-Snooping view) |
1-3 |
fast-leave (MLD-Snooping view) |
8-4 |
file prompt |
5-6 |
filename |
2-16 |
filter |
4-32 |
filter |
2-11 |
filter-policy export |
14-17 |
filter-policy export (BGP/BGP-VPN instance view) |
6-30 |
filter-policy export (IPv6 address family view) |
11-22 |
filter-policy export (IPv6 MBGP address family view) |
13-25 |
filter-policy export (IS-IS view) |
5-26 |
filter-policy export (MBGP family view) |
7-27 |
filter-policy export (OSPF view) |
4-33 |
filter-policy export (OSPFv3 view) |
9-24 |
filter-policy export (RIP view) |
3-9 |
filter-policy export (RIPng view) |
8-6 |
filter-policy import |
14-18 |
filter-policy import (BGP/BGP-VPN instance view) |
6-31 |
filter-policy import (IPv6 address family view) |
11-23 |
filter-policy import (IPv6 MBGP address family view) |
13-26 |
filter-policy import (IS-IS view) |
5-28 |
filter-policy import (MBGP Family view) |
7-28 |
filter-policy import (OSPF view) |
4-34 |
filter-policy import (OSPFv3 view) |
9-26 |
filter-policy import (RIP view) |
3-11 |
filter-policy import (RIPng view) |
8-8 |
fixdisk |
5-6 |
flash-flood |
5-29 |
flow-control |
2-13 |
flow-control |
1-16 |
flow-interval |
1-16 |
flush enable |
5-3 |
forbidden-ip |
4-17 |
format |
5-7 |
fqdn |
12-13 |
free ftp user |
3-3 |
free user-interface |
2-14 |
free web-users |
2-14 |
frequency |
2-16 |
ftp |
3-13 |
ftp client source |
3-14 |
ftp ipv6 |
3-16 |
ftp server acl |
3-3 |
ftp server enable |
3-4 |
ftp timeout |
3-4 |
ftp update |
3-5 |
ftp-server |
9-36 |
garp timer hold |
12-6 |
garp timer join |
12-7 |
garp timer leave |
12-7 |
garp timer leaveall |
12-8 |
gateway-list |
4-18 |
get |
3-16 |
get |
14-6 |
graceful-restart (BGP view) |
6-32 |
graceful-restart (IS-IS view) |
5-30 |
graceful-restart (OSPF view) |
4-35 |
graceful-restart enable |
9-27 |
graceful-restart help |
4-36 |
graceful-restart helper enable |
9-27 |
graceful-restart helper strict-lsa-checking |
9-28 |
graceful-restart interval |
9-29 |
graceful-restart interval (IS-IS view) |
5-30 |
graceful-restart interval (OSPF view) |
4-37 |
graceful-restart suppress-sa |
5-31 |
graceful-restart timer restart |
6-33 |
graceful-restart timer wait-for-rib |
6-33 |
gratuitous-arp-learning enable |
1-9 |
gratuitous-arp-sending enable |
1-8 |
group |
1-27 |
group (BGP/BGP-VPN instance view) |
6-34 |
group (IPv6 address family view) |
11-24 |
group-member |
1-17 |
group-policy (IGMP-Snooping view) |
1-4 |
group-policy (MLD-Snooping view) |
8-4 |
gvrp |
12-9 |
gvrp registration |
12-9 |
habp enable |
10-3 |
habp server vlan |
10-3 |
habp timer |
10-4 |
handshake timeout |
15-5 |
header |
8-19 |
hello-option dr-priority (IPv6 PIM view) |
12-22 |
hello-option dr-priority (PIM view) |
5-24 |
hello-option holdtime (IPv6 PIM view) |
12-23 |
hello-option holdtime (PIM view) |
5-25 |
hello-option lan-delay (IPv6 PIM view) |
12-23 |
hello-option lan-delay (PIM view) |
5-26 |
hello-option neighbor-tracking (IPv6 PIM view) |
12-24 |
hello-option neighbor-tracking (PIM view) |
5-26 |
hello-option override-interval (IPv6 PIM view) |
12-24 |
hello-option override-interval (PIM view) |
5-27 |
help |
14-6 |
history-command max-size |
2-15 |
history-records |
2-17 |
holdtime |
9-37 |
holdtime assert (IPv6 PIM view) |
12-25 |
holdtime assert (PIM view) |
5-27 |
holdtime join-prune (IPv6 PIM view) |
12-26 |
holdtime join-prune (PIM view) |
5-28 |
host-advertise |
4-38 |
host-aging-time (IGMP-Snooping view) |
1-5 |
host-aging-time (MLD-Snooping view) |
8-5 |
host-route |
3-12 |
hotkey |
1-6 |
http-version |
2-18 |
hwtacacs nas-ip |
3-4 |
hwtacacs scheme |
3-5 |
idle-cut enable |
1-27 |
idle-timeout |
2-15 |
if-match |
2-2 |
if-match acl |
12-21 |
if-match as-path |
12-11 |
if-match community |
12-12 |
if-match cost |
12-13 |
if-match extcommunity |
12-13 |
if-match interface |
12-14 |
if-match ip |
12-22 |
if-match ip-prefix |
12-22 |
if-match ipv6 |
12-26 |
if-match route-type |
12-15 |
if-match tag |
12-15 |
igmp |
4-12 |
igmp enable |
4-12 |
igmp group-limit |
4-13 |
igmp group-policy |
4-14 |
igmp last-member-query-interval |
4-15 |
igmp max-response-time |
4-15 |
Igmp proxying enable |
4-16 |
Igmp proxying forwarding |
4-17 |
igmp require-router-alert |
4-17 |
igmp robust-count |
4-18 |
igmp send-router-alert |
4-19 |
igmp ssm-mapping enable |
4-19 |
igmp startup-query-count |
4-20 |
igmp startup-query-interval |
4-20 |
igmp static-group |
4-21 |
igmp timer other-querier-present |
4-22 |
igmp timer query |
4-22 |
igmp version |
4-23 |
igmp-snooping |
1-6 |
igmp-snooping drop-unknown |
1-6 |
igmp-snooping enable |
1-7 |
igmp-snooping fast-leave |
1-7 |
igmp-snooping general-query source-ip |
1-8 |
igmp-snooping group-limit |
1-9 |
igmp-snooping group-policy |
1-10 |
igmp-snooping host-aging-time |
1-11 |
igmp-snooping host-join |
1-11 |
igmp-snooping last-member-query-interval |
1-12 |
igmp-snooping max-response-time |
1-13 |
igmp-snooping overflow-replace |
1-14 |
igmp-snooping querier |
1-14 |
igmp-snooping query-interval |
1-15 |
igmp-snooping router-aging-time |
1-16 |
igmp-snooping source-deny |
1-16 |
igmp-snooping special-query source-ip |
1-17 |
igmp-snooping static-group |
1-17 |
igmp-snooping static-router-port |
1-18 |
igmp-snooping version |
1-19 |
import |
3-2 |
import route-policy |
14-19 |
import-route |
8-9 |
import-route (BGP/BGP-VPN instance view) |
6-35 |
import-route (IPv6 address family view) |
11-25 |
import-route (IPv6 MBGP address family view) |
13-26 |
import-route (IS-IS view) |
5-31 |
import-route (MBGP family view) |
7-29 |
import-route (OSPF view) |
4-38 |
import-route (OSPFv3 view) |
9-29 |
import-route (RIP view) |
3-12 |
import-route isis level-2 into level-1 |
5-33 |
import-route limit (IS-IS view) |
5-34 |
import-source |
6-9 |
info-center channel name |
13-9 |
info-center console channel |
13-9 |
info-center enable |
13-10 |
info-center logbuffer |
13-11 |
info-center loghost |
13-11 |
info-center loghost source |
13-12 |
info-center monitor channel |
13-13 |
info-center snmp channel |
13-14 |
info-center source |
13-15 |
info-center synchronous |
13-17 |
info-center timestamp |
13-18 |
info-center timestamp loghost |
13-20 |
info-center trapbuffer |
13-20 |
instance |
7-15 |
interface |
1-17 |
interface bridge-aggregation |
5-11 |
2-4 |
interface null |
2-5 |
interface tunnel |
13-8 |
9-5 |
ip (PKI entity view) |
12-14 |
ip address |
9-6 |
ip address |
3-5 |
ip address bootp-alloc |
8-2 |
ip address dhcp-alloc |
6-3 |
ip as-path |
12-16 |
ip binding vpn-instance |
4-40 |
14-19 |
ip check source |
16-3 |
ip community-list |
12-17 |
12-18 |
ip forward-broadcast (interface view) |
10-15 |
ip forward-broadcast (system view) |
10-15 |
ip host |
9-7 |
ip http acl |
2-16 |
ip http enable |
2-17 |
ip http port |
2-17 |
ip https acl |
2-18 |
ip https certificate access-control-policy |
2-19 |
ip https enable |
2-19 |
ip https port |
2-20 |
ip https ssl-server-policy |
2-20 |
ip ip-prefix |
12-23 |
ip ipv6-prefix |
12-27 |
ip redirects enable |
10-16 |
ip route-static |
2-2 |
ip route-static default-preference |
2-4 |
3-9 |
ip ttl-expires enable |
10-16 |
ip unreachables enable |
10-17 |
ip urpf strict |
18-1 |
ip vpn-instance |
14-20 |
ipc performance enable |
4-8 |
ip-pool |
9-38 |
ip-subnet-vlan |
9-30 |
ipv4-family multicast |
7-29 |
ipv4-family vpn-instance |
14-20 |
ipv6 |
12-24 |
ipv6 address |
12-24 |
ipv6 address auto link-local |
12-25 |
ipv6 address eui-64 |
12-26 |
ipv6 address link-local |
12-27 |
ipv6 default-route-advertise |
10-3 |
ipv6 enable |
10-4 |
ipv6 filter-policy export |
10-5 |
ipv6 filter-policy import |
10-6 |
ipv6 hoplimit-expires enable |
12-27 |
ipv6 host |
12-28 |
ipv6 icmp-error |
12-29 |
ipv6 icmpv6 multicast-echo-reply enable |
12-29 |
ipv6 import-route |
10-7 |
ipv6 import-route isisv6 level-2 into level-1 |
10-8 |
ipv6 import-route limit |
10-9 |
ipv6 maximum load-balancing |
10-9 |
ipv6 nd autoconfig managed-address-flag |
12-30 |
ipv6 nd autoconfig other-flag |
12-30 |
ipv6 nd dad attempts |
12-31 |
ipv6 nd hop-limit |
12-31 |
ipv6 nd ns retrans-timer |
12-32 |
ipv6 nd nud reachable-time |
12-33 |
ipv6 nd ra halt |
12-33 |
ipv6 nd ra interval |
12-34 |
ipv6 nd ra prefix |
12-35 |
ipv6 nd ra router-lifetime |
12-35 |
ipv6 neighbor |
12-36 |
ipv6 neighbors max-learning-num |
12-37 |
ipv6 pathmtu |
12-38 |
ipv6 pathmtu age |
12-38 |
ipv6 preference |
10-10 |
ipv6 route-static |
7-2 |
ipv6 summary |
10-11 |
ipv6-family |
11-26 |
ipv6-family multicast |
13-27 |
irf auto-update enable |
1-6 |
irf link-delay |
1-7 |
irf mac-address persistent |
1-7 |
irf member irf-port |
1-10 |
irf member priority |
1-8 |
irf member renumber |
1-9 |
irf switch-to |
1-11 |
isis |
5-34 |
isis authentication-mode |
5-35 |
isis bfd enable |
8-11 |
isis circuit-level |
5-36 |
isis circuit-type p2p |
5-37 |
isis cost |
5-38 |
isis dis-name |
5-38 |
isis dis-priority |
5-39 |
isis enable |
5-40 |
isis ipv6 enable |
10-12 |
isis mesh-group |
5-41 |
isis mib-binding |
5-41 |
isis silent |
5-42 |
isis small-hello |
5-43 |
isis timer csnp |
5-43 |
isis timer hello |
5-44 |
isis timer holding-multiplier |
5-45 |
isis timer lsp |
5-46 |
isis timer retransmit |
5-47 |
is-level |
5-48 |
is-name |
5-48 |
is-name map |
5-49 |
isolate-user-vlan |
10-2 |
isolate-user-vlan enable |
10-4 |
is-snmp-traps enable |
5-49 |
jp-pkt-size (IPv6 PIM view) |
12-26 |
jp-pkt-size (PIM view) |
5-29 |
jp-queue-size (IPv6 PIM view) |
12-27 |
jp-queue-size (PIM view) |
5-29 |
jumboframe enable |
1-18 |
key (HWTACACS scheme view) |
3-5 |
key (RADIUS scheme view) |
2-8 |
lacp port-priority |
5-12 |
lacp system-priority |
5-12 |
last-listener-query-interval (MLD view) |
11-11 |
last-listener-query-interval (MLD-Snooping view) |
8-6 |
last-member-query-interval (IGMP view) |
4-24 |
last-member-query-interval (IGMP-Snooping view) |
1-20 |
lcd |
3-17 |
ldap-server |
12-14 |
5-13 |
link-aggregation mode |
5-15 |
link-delay |
1-19 |
lldp admin-status |
15-15 |
lldp check-change-interval |
15-15 |
lldp compliance admin-status cdp |
15-16 |
lldp compliance cdp |
15-16 |
lldp enable |
15-17 |
lldp encapsulation snap |
15-17 |
lldp fast-count |
15-18 |
lldp hold-multiplier |
15-19 |
lldp management-address-format string |
15-19 |
lldp management-address-tlv |
15-20 |
lldp notification remote-change enable |
15-21 |
lldp timer notification-interval |
15-21 |
lldp timer reinit-delay |
15-22 |
lldp timer tx-delay |
15-22 |
lldp timer tx-interval |
15-23 |
lldp tlv-enable |
15-23 |
locality |
12-15 |
local-proxy-arp enable |
2-2 |
local-user |
1-28 |
local-user password-display-mode |
1-29 |
lock |
2-21 |
logging-host |
9-39 |
log-peer-change |
4-40 |
log-peer-change |
6-36 |
log-peer-change |
9-30 |
log-peer-change (IS-IS view) |
5-50 |
loopback |
1-19 |
loopback-detection control enable |
1-20 |
loopback-detection enable |
1-21 |
loopback-detection interval-time |
1-22 |
loopback-detection per-vlan enable |
1-22 |
ls |
3-18 |
ls |
14-7 |
lsa-arrival-interval |
4-41 |
lsa-generation-interval |
4-42 |
lsdb-overflow-limit |
4-42 |
lsp-fragments-extend |
5-51 |
lsp-length originate |
5-51 |
lsp-length receive |
5-52 |
mac-address (Interface view) |
3-3 |
mac-address (system view) |
3-4 |
mac-address information enable (Ethernet interface view) |
4-1 |
mac-address information enable (system view) |
4-2 |
mac-address information interval |
4-2 |
mac-address information mode |
4-3 |
mac-address information queue-length |
4-3 |
mac-address mac-learning disable |
3-5 |
mac-address max-mac-count (Interface view) |
3-5 |
mac-address station-move |
1-4 |
mac-address timer |
3-6 |
6-3 |
mac-authentication domain |
6-4 |
mac-authentication guest-vlan |
6-5 |
mac-authentication timer |
6-5 |
mac-authentication user-name-format |
6-6 |
mac-vlan enable |
9-21 |
mac-vlan mac-address |
9-22 |
management-vlan |
9-39 |
management-vlan synchronization enable |
9-40 |
maximum load-balancing (IS-IS view) |
5-53 |
maximum load-balancing (OSPF view) |
4-43 |
maximum load-balancing (OSPFv3 view) |
9-31 |
maximum load-balancing (RIP view) |
3-14 |
maximum load-balancing (RIPng view) |
8-9 |
maximum-routes |
4-43 |
max-response-time (IGMP view) |
4-24 |
max-response-time (IGMP-Snooping view) |
1-20 |
max-response-time (MLD view) |
11-11 |
max-response-time (MLD-Snooping view) |
8-7 |
mdi |
1-23 |
mib-style |
7-1 |
mirroring-group |
10-2 |
mirroring-group mirroring-port |
10-3 |
mirroring-group monitor-egress |
10-3 |
mirroring-group monitor-port |
10-4 |
mirroring-group remote-probe vlan |
10-5 |
mirroring-port |
10-6 |
mirror-to cpu |
11-1 |
mirror-to interface |
11-2 |
mkdir |
3-19 |
mkdir |
5-8 |
mkdir |
14-7 |
mld |
11-12 |
mld enable |
11-13 |
mld group-limit |
11-13 |
mld group-policy |
11-14 |
mld last-listener-query-interval |
11-15 |
mld max-response-time |
11-16 |
mld proxying enable |
11-17 |
mld proxying forwarding |
11-18 |
mld require-router-alert |
11-16 |
mld robust-count |
11-18 |
mld send-router-alert |
11-19 |
mld ssm-mapping enable |
11-20 |
mld startup-query-count |
11-20 |
mld startup-query-interval |
11-21 |
mld static-group |
11-22 |
mld timer other-querier-present |
11-22 |
mld timer query |
11-23 |
mld version |
11-24 |
mld-snooping |
8-7 |
mld-snooping drop-unknown |
8-8 |
mld-snooping enable |
8-8 |
mld-snooping fast-leave |
8-9 |
mld-snooping general-query source-ip |
8-10 |
mld-snooping group-limit |
8-11 |
mld-snooping group-policy |
8-12 |
mld-snooping host-aging-time |
8-13 |
mld-snooping host-join |
8-13 |
mld-snooping last-listener-query-interval |
8-15 |
mld-snooping max-response-time |
8-15 |
mld-snooping overflow-replace |
8-16 |
mld-snooping querier |
8-17 |
mld-snooping query-interval |
8-17 |
mld-snooping router-aging-time |
8-18 |
mld-snooping source-deny |
8-19 |
mld-snooping special-query source-ip |
8-19 |
mld-snooping static-group |
8-20 |
mld-snooping static-router-port |
8-21 |
mld-snooping version |
8-22 |
6-2 |
monitor-port |
10-7 |
more |
5-8 |
move |
5-9 |
msdp |
6-10 |
mtracert |
3-10 |
3-12 |
multicast forwarding-table downstream-limit |
3-13 |
multicast forwarding-table route-limit |
3-14 |
10-7 |
multicast ipv6 forwarding-table downstream-limit |
10-8 |
multicast ipv6 forwarding-table route-limit |
10-9 |
multicast ipv6 load-splitting |
10-9 |
multicast ipv6 longest-match |
10-10 |
multicast ipv6 routing-enable |
10-10 |
multicast load-splitting |
3-14 |
multicast longest-match |
3-15 |
multicast routing-enable |
3-15 |
multicast-suppression |
1-23 |
multicast-vlan |
2-2 |
9-2 |
name |
9-7 |
nas-ip (HWTACACS scheme view) |
3-6 |
nas-ip (RADIUS scheme view) |
2-9 |
nbns-list |
4-19 |
ndp enable |
9-4 |
ndp timer aging |
9-5 |
ndp timer hello |
9-6 |
nest |
13-1 |
netbios-type |
4-19 |
network |
4-20 |
network |
3-14 |
network (BGP/BGP-VPN instance view) |
6-36 |
network (IPv6 address family view) |
11-26 |
network (IPv6 MBGP address family view) |
13-28 |
network (MBGP family view) |
7-30 |
network (OSPF area view) |
4-44 |
network ip range |
4-21 |
network mask |
4-21 |
network short-cut (BGP/BGP-VPN instance view) |
6-37 |
network-entity |
5-53 |
next-hop |
2-18 |
nm-interface vlan-interface |
9-41 |
nqa |
2-19 |
nqa agent enable |
2-20 |
nqa agent max-concurrent |
2-20 |
nqa schedule |
2-21 |
nqa server enable |
2-38 |
nqa server tcp-connect |
2-39 |
nqa server udp-echo |
2-40 |
nssa |
4-45 |
ntdp enable |
9-10 |
ntdp explore |
9-11 |
ntdp hop |
9-11 |
ntdp timer |
9-12 |
ntdp timer hop-delay |
9-12 |
ntdp timer port-delay |
9-13 |
ntp-service access |
3-8 |
ntp-service authentication enable |
3-9 |
ntp-service authentication-keyid |
3-10 |
ntp-service broadcast-client |
3-11 |
ntp-service broadcast-server |
3-11 |
ntp-service in-interface disable |
3-12 |
ntp-service max-dynamic-sessions |
3-12 |
ntp-service multicast-client |
3-13 |
ntp-service multicast-server |
3-14 |
ntp-service reliable authentication-keyid |
3-14 |
ntp-service source-interface |
3-15 |
ntp-service unicast-peer |
3-16 |
ntp-service unicast-server |
3-17 |
oam enable |
1-10 |
oam errored-frame period |
1-10 |
oam errored-frame threshold |
1-11 |
oam errored-frame-period period |
1-11 |
oam errored-frame-period threshold |
1-12 |
oam errored-frame-seconds period |
1-12 |
oam errored-frame-seconds threshold |
1-13 |
oam errored-symbol period |
1-13 |
oam errored-symbol threshold |
1-14 |
oam loopback |
1-14 |
oam mode |
1-15 |
opaque-capability enable |
4-46 |
open |
3-19 |
open ipv6 |
3-20 |
operation (FTP test type view) |
2-22 |
operation (HTTP test type view) |
2-22 |
operation interface |
2-23 |
option |
4-22 |
organization |
12-15 |
organization-unit |
12-16 |
originating-rp |
6-10 |
ospf |
4-46 |
ospf authentication-mode |
4-47 |
ospf bfd enable |
8-11 |
ospf cost |
4-48 |
ospf dr-priority |
4-49 |
ospf mib-binding |
4-50 |
ospf mtu-enable |
4-50 |
ospf network-type |
4-51 |
ospf packet-process prioritized-treatment |
4-52 |
ospf timer dead |
4-53 |
ospf timer hello |
4-53 |
ospf timer poll |
4-54 |
ospf timer retransmit |
4-55 |
ospf trans-delay |
4-55 |
ospfv3 |
9-31 |
ospfv3 area |
9-32 |
ospfv3 cost |
9-33 |
ospfv3 dr-priority |
9-33 |
ospfv3 mtu-ignore |
9-34 |
ospfv3 network-type |
9-34 |
ospfv3 peer |
9-35 |
ospfv3 timer dead |
9-36 |
ospfv3 timer hello |
9-36 |
ospfv3 timer poll |
9-38 |
ospfv3 timer retransmit |
9-37 |
ospfv3 trans-delay |
9-38 |
output-delay |
3-15 |
overflow-replace (IGMP-Snooping view) |
1-21 |
overflow-replace (MLD-Snooping view) |
8-22 |
packet-filter |
1-12 |
packet-filter ipv6 |
1-13 |
parity |
2-22 |
passive |
3-21 |
password |
1-29 |
password (FTP test type view) |
2-23 |
patch active |
7-6 |
patch deactive |
7-6 |
patch delete |
7-7 |
patch install |
7-8 |
patch load |
7-9 |
patch location |
7-9 |
patch run |
7-10 |
peer |
3-15 |
peer |
4-56 |
peer advertise-community (BGP/BGP-VPN instance view) |
6-38 |
peer advertise-community (IPv6 address family view) |
11-27 |
peer advertise-community (IPv6 MBGP address family view) |
13-28 |
peer advertise-community (MBGP family view) |
7-31 |
peer advertise-ext-community (BGP/BGP-VPN instance view) |
6-39 |
peer advertise-ext-community (IPv6 address family view) |
11-28 |
peer advertise-ext-community (IPv6 MBGP address family view) |
13-29 |
peer advertise-ext-community (MBGP family view) |
7-31 |
peer allow-as-loop |
14-21 |
peer allow-as-loop (BGP/BGP-VPN instance view) |
6-39 |
peer allow-as-loop (IPv6 address family view) |
11-28 |
peer allow-as-loop (IPv6 MBGP address family view) |
13-30 |
peer allow-as-loop (MBGP family view) |
7-32 |
peer as-number (BGP/BGP-VPN instance view) |
6-40 |
peer as-number (IPv6 address family view) |
11-29 |
peer as-path-acl (BGP/BGP-VPN instance view) |
6-41 |
peer as-path-acl (IPv6 address family view) |
11-30 |
peer as-path-acl (IPv6 MBGP address family view) |
13-31 |
peer as-path-acl (MBGP family view) |
7-33 |
peer capability-advertise conventional |
6-42 |
peer capability-advertise route-refresh |
6-43 |
11-30 |
peer connect-interface |
6-11 |
peer connect-interface (BGP/BGP-VPN instance view) |
6-43 |
peer connect-interface (IPv6 address family view) |
11-31 |
peer default-route-advertise |
11-32 |
peer default-route-advertise (BGP/BGP-VPN instance view) |
6-44 |
peer default-route-advertise (IPv6 MBGP address family view) |
13-31 |
peer default-route-advertise (MBGP family view) |
7-34 |
peer description |
6-12 |
peer description (BGP/BGP-VPN instance view) |
6-45 |
peer description (IPv6 address family view) |
11-32 |
peer ebgp-max-hop (BGP/BGP-VPN instance view) |
6-46 |
peer ebgp-max-hop (IPv6 address family view) |
11-33 |
peer enable (BGP view) |
6-47 |
peer enable (IPv6 MBGP address family view) |
13-32 |
peer enable (MBGP family view) |
7-34 |
peer fake-as (BGP/BGP-VPN instance view) |
6-47 |
peer fake-as (IPv6 address family view) |
11-34 |
peer filter-policy (BGP/BGP-VPN instance view) |
6-48 |
peer filter-policy (IPv6 address family view) |
11-34 |
peer filter-policy (IPv6 MBGP address family view) |
13-33 |
peer filter-policy (MBGP family view) |
7-35 |
peer group |
14-22 |
peer group (BGP/BGP-VPN instance view) |
6-49 |
peer group (IPv6 address family view) |
11-35 |
peer group (IPv6 MBGP address family view) |
13-34 |
peer group (MBGP family view) |
7-36 |
peer ignore (BGP/BGP-VPN instance view) |
6-50 |
peer ignore (IPv6 address family view) |
11-36 |
peer ip-address bfd |
8-12 |
peer ip-prefix |
6-50 |
peer ip-prefix (MBGP family view) |
7-36 |
peer ipv6-prefix |
11-36 |
peer ipv6-prefix (IPv6 MBGP address family view) |
13-34 |
peer keep-all-routes (BGP/BGP-VPN instance view) |
6-51 |
peer keep-all-routes (IPv6 address family view) |
11-37 |
peer keep-all-routes (IPv6 MBGP address family view) |
13-35 |
peer keep-all-routes (MBGP family view) |
7-37 |
peer log-change (BGP/BGP-VPN instance view) |
6-52 |
peer log-change (IPv6 address family view) |
11-38 |
peer mesh-group |
6-12 |
peer minimum-ttl |
6-13 |
peer next-hop-local (BGP/BGP-VPN instance view) |
6-53 |
peer next-hop-local (IPv6 address family view) |
11-38 |
peer next-hop-local (IPv6 MBGP address family view) |
13-36 |
peer next-hop-local (MBGP family view) |
7-38 |
peer password |
6-53 |
peer preferred-value (BGP/BGP-VPN instance view) |
6-54 |
peer preferred-value (IPv6 address family view) |
11-39 |
peer preferred-value (IPv6 MBGP address family view) |
13-36 |
peer preferred-value (MBGP family view) |
7-38 |
peer public-as-only (BGP/BGP-VPN instance view) |
6-55 |
peer public-as-only (IPv6 address family view) |
11-40 |
peer public-as-only (IPv6 MBGP address family view) |
13-37 |
peer public-as-only (MBGP family view) |
7-39 |
peer reflect-client (BGP/BGP-VPN instance view) |
6-56 |
peer reflect-client (IPv6 address family view) |
11-40 |
peer reflect-client (IPv6 MBGP address family view) |
13-38 |
peer reflect-client (MBGP family view) |
7-40 |
peer request-sa-enable |
6-13 |
peer route-limit (BGP/BGP-VPN instance view) |
6-57 |
peer route-limit (IPv6 address family view) |
11-41 |
peer route-limit (IPv6 MBGP address family view) |
13-39 |
peer route-limit (MBGP family view) |
7-41 |
peer route-policy (BGP/BGP-VPN instance view) |
6-58 |
peer route-policy (IPv6 address family view) |
11-42 |
peer route-policy (IPv6 MBGP address family view) |
13-40 |
peer route-policy (MBGP family view) |
7-42 |
peer route-update-interval (BGP/BGP-VPN instance view) |
6-59 |
peer route-update-interval (IPv6 address family view) |
11-43 |
peer sa-cache-maximum |
6-14 |
peer sa-policy |
6-15 |
peer sa-request-policy |
6-16 |
peer substitute-as (BGP/BGP-VPN instance view) |
6-59 |
peer substitute-as (IPv6 address family view) |
11-44 |
peer timer (BGP/BGP-VPN instance view) |
6-60 |
peer timer (IPv6 address family view) |
11-44 |
peer-public-key end |
11-3 |
pim |
5-30 |
pim bsr-boundary |
5-30 |
pim dm |
5-31 |
pim hello-option dr-priority |
5-32 |
pim hello-option holdtime |
5-32 |
pim hello-option lan-delay |
5-33 |
pim hello-option neighbor-tracking |
5-34 |
pim hello-option override-interval |
5-34 |
pim holdtime assert |
5-35 |
pim holdtime join-prune |
5-35 |
pim ipv6 |
12-27 |
pim ipv6 bsr-boundary |
12-28 |
pim ipv6 dm |
12-29 |
pim ipv6 hello-option dr-priority |
12-29 |
pim ipv6 hello-option holdtime |
12-30 |
pim ipv6 hello-option lan-delay |
12-31 |
pim ipv6 hello-option neighbor-tracking |
12-31 |
pim ipv6 hello-option override-interval |
12-32 |
pim ipv6 holdtime assert |
12-32 |
pim ipv6 holdtime join-prune |
12-33 |
pim ipv6 neighbor-policy |
12-33 |
pim ipv6 require-genid |
12-34 |
pim ipv6 sm |
12-35 |
pim ipv6 state-refresh-capable |
12-35 |
pim ipv6 timer graft-retry |
12-36 |
pim ipv6 timer hello |
12-36 |
pim ipv6 timer join-prune |
12-37 |
pim ipv6 triggered-hello-delay |
12-38 |
pim neighbor-policy |
5-36 |
pim require-genid |
5-36 |
pim sm |
5-37 |
pim state-refresh-capable |
5-38 |
pim timer graft-retry |
5-38 |
pim timer hello |
5-39 |
pim timer join-prune |
5-39 |
pim triggered-hello-delay |
5-40 |
ping |
1-1 |
ping ipv6 |
1-4 |
12-16 |
12-17 |
pki delete-certificate |
12-18 |
pki domain |
12-18 |
pki entity |
12-19 |
pki import-certificate |
12-19 |
pki request-certificate domain |
12-20 |
pki retrieval-certificate |
12-21 |
pki retrieval-crl domain |
12-21 |
pki validate-certificate |
12-22 |
pki-domain |
15-6 |
poe disconnect |
5-15 |
poe enable |
5-16 |
poe legacy enable |
5-17 |
poe max-power |
5-17 |
poe mode |
5-18 |
poe pd-description |
5-19 |
poe pd-policy priority |
5-19 |
poe priority |
5-20 |
poe update |
5-21 |
poe utilization-threshold |
5-22 |
poe-profile |
5-22 |
port |
9-11 |
port |
5-3 |
port |
6-2 |
port (IPv6 multicast VLAN view) |
9-3 |
port (multicast VLAN view) |
2-2 |
port access vlan |
9-11 |
port hybrid ip-subnet-vlan |
9-31 |
port hybrid protocol-vlan |
9-25 |
port hybrid pvid |
9-12 |
port hybrid vlan |
9-14 |
port link-aggregation group |
5-15 |
port link-type |
9-15 |
port monitor-link group |
6-3 |
port multicast-vlan |
2-3 |
port multicast-vlan ipv6 |
9-3 |
port service-loopback group |
16-2 |
port smart-link group |
5-4 |
port trunk permit vlan |
9-16 |
port trunk pvid |
9-18 |
portal auth-network |
7-13 |
portal delete-user |
7-14 |
portal domain |
7-14 |
portal free-rule |
7-15 |
portal server |
7-16 |
portal server method |
7-17 |
port-group manual |
1-25 |
port-isolate enable |
6-1 |
port-security authorization ignore |
8-7 |
port-security enable |
8-7 |
port-security intrusion-mode |
8-8 |
8-9 |
port-security max-mac-count |
8-10 |
port-security ntk-mode |
8-11 |
port-security oui |
8-11 |
port-security port-mode |
8-12 |
port-security timer disableport |
8-15 |
port-security trap |
8-16 |
preemption delay |
5-5 |
preemption mode |
5-6 |
prefer-cipher |
15-6 |
preference |
3-16 |
preference |
4-57 |
preference |
8-10 |
preference |
9-39 |
6-61 |
11-45 |
13-41 |
preference (IS-IS view) |
5-54 |
7-42 |
primary accounting (HWTACACS scheme view) |
3-7 |
primary accounting (RADIUS scheme view) |
2-10 |
primary authentication (HWTACACS scheme view) |
3-8 |
primary authentication (RADIUS scheme view) |
2-10 |
primary authorization |
3-8 |
probe count |
2-24 |
probe packet-interval |
2-25 |
probe packet-number |
2-25 |
probe packet-timeout |
2-26 |
probe timeout |
2-27 |
probe-interval (IPv6 PIM view) |
12-38 |
probe-interval (PIM view) |
5-40 |
protected-vlan |
4-11 |
protected-vlan |
5-6 |
protocol inbound |
2-23 |
protocol-vlan |
9-27 |
proxy-arp enable |
2-2 |
public-key local create |
11-5 |
public-key local destroy |
11-6 |
public-key local export dsa |
11-7 |
public-key local export rsa |
11-8 |
public-key peer |
11-9 |
public-key peer import sshkey |
11-9 |
public-key-code begin |
11-3 |
public-key-code end |
11-4 |
put |
3-22 |
put |
14-8 |
pwd |
3-22 |
pwd |
5-10 |
pwd |
14-8 |
qinq enable |
13-3 |
qinq enable downlink |
14-1 |
qinq enable uplink |
14-2 |
qinq ethernet-type |
13-3 |
qinq vid |
13-5 |
qos apply policy (Interface view, port group view) |
2-23 |
qos apply policy (user-profile view) |
2-24 |
qos apply policy global |
2-25 |
qos bandwidth queue |
5-3 |
qos gts |
4-2 |
qos lr outbound |
4-3 |
qos map-table |
3-2 |
qos policy |
2-25 |
qos priority |
3-3 |
qos sp |
5-4 |
qos trust |
3-5 |
qos vlan-policy |
2-26 |
qos wfq |
5-5 |
qos wfq weight |
5-5 |
qos wred apply |
6-2 |
qos wred queue table |
6-3 |
qos wrr |
5-6 |
qos wrr group |
5-6 |
queue |
6-4 |
quit |
1-7 |
quit |
3-23 |
quit |
14-9 |
radius client |
2-11 |
radius nas-ip |
2-12 |
radius scheme |
2-13 |
radius trap |
2-14 |
raw-vlan-id inbound |
13-2 |
reaction |
2-27 |
reaction trap |
2-28 |
reboot |
8-28 |
reboot member |
9-41 |
redirect |
2-11 |
reflect between-clients (BGP view) |
6-62 |
reflect between-clients (IPv6 address family view) |
11-46 |
reflect between-clients (IPv6 MBGP address family view) |
13-41 |
reflect between-clients (MBGP family view) |
7-43 |
reflector cluster-id (BGP view) |
6-62 |
reflector cluster-id (IPv6 address family view) |
11-46 |
reflector cluster-id (IPv6 MBGP address family view) |
13-42 |
reflector cluster-id (MBGP family view) |
7-44 |
refresh bgp |
6-63 |
refresh bgp ipv4 multicast |
7-44 |
refresh bgp ipv6 |
11-47 |
refresh bgp ipv6 multicast |
13-43 |
refresh bgp vpn-instance |
14-22 |
region-name |
7-15 |
register-policy (IPv6 PIM view) |
12-39 |
register-policy (PIM view) |
5-41 |
register-suppression-timeout (IPv6 PIM view) |
12-39 |
register-suppression-timeout (PIM view) |
5-42 |
register-whole-checksum (IPv6 PIM view) |
12-40 |
register-whole-checksum (PIM view) |
5-42 |
remark customer-vlan-id |
14-2 |
remark dot1p |
2-12 |
remark drop-precedence |
2-13 |
remark dscp |
2-13 |
remark ip-precedence |
2-14 |
remark local-precedence |
2-14 |
remark service-vlan-id |
14-3 |
remotehelp |
3-23 |
remove |
14-9 |
rename |
5-10 |
rename |
14-10 |
report-aggregation (IGMP-Snooping view) |
1-22 |
report-aggregation (MLD-Snooping view) |
8-23 |
require-router-alert (IGMP view) |
4-25 |
require-router-alert (MLD view) |
11-24 |
reset acl counter |
1-14 |
reset acl ipv6 counter |
1-14 |
reset arp |
1-8 |
reset arp detection statistics |
17-14 |
reset bfd session statistics |
8-12 |
reset bgp |
6-64 |
reset bgp dampening |
6-64 |
reset bgp flap-info |
6-65 |
reset bgp ipv4 all |
6-65 |
reset bgp ipv4 multicast |
7-45 |
reset bgp ipv4 multicast dampening |
7-46 |
reset bgp ipv4 multicast flap-info |
7-46 |
reset bgp ipv6 |
11-48 |
reset bgp ipv6 dampening |
11-48 |
reset bgp ipv6 flap-info |
11-49 |
reset bgp ipv6 multicast |
13-44 |
reset bgp ipv6 multicast dampening |
13-44 |
reset bgp ipv6 multicast flap-info |
13-45 |
reset bgp vpn-instance |
14-23 |
reset bgp vpn-instance dampening |
14-23 |
reset bgp vpn-instance flap-info |
14-24 |
reset counters interface |
1-25 |
2-5 |
5-16 |
9-7 |
13-9 |
reset dhcp relay statistics |
5-19 |
reset dhcp server conflict |
4-23 |
reset dhcp server ip-in-use |
4-23 |
reset dhcp server statistics |
4-24 |
reset dhcp-snooping |
7-11 |
reset dhcp-snooping packet statistics |
7-11 |
reset dldp statistics |
3-8 |
reset dns dynamic-host |
9-7 |
reset dns ipv6 dynamic-host |
12-39 |
reset dot1x statistics |
4-17 |
reset garp statistics |
12-10 |
reset hwtacacs statistics |
3-9 |
reset igmp group |
4-25 |
reset igmp group port-info |
4-26 |
reset igmp ssm-mapping group |
4-27 |
reset igmp-snooping group |
1-22 |
reset igmp-snooping statistics |
1-23 |
reset ip ip-prefix |
12-24 |
reset ip ipv6-prefix |
12-28 |
reset ip routing-table statistics protocol |
1-20 |
reset ip statistics |
10-17 |
reset ipc performance |
4-8 |
reset ipv6 neighbors |
12-39 |
reset ipv6 pathmtu |
12-40 |
reset ipv6 routing-table statistics |
1-20 |
reset ipv6 statistics |
12-40 |
reset isis all |
5-55 |
reset isis peer |
5-55 |
reset lacp statistics |
5-17 |
reset logbuffer |
13-21 |
reset mac-authentication statistics |
6-8 |
reset mld group |
11-25 |
reset mld group port-info |
11-26 |
reset mld ssm-mapping group |
11-26 |
reset mld-snooping group |
8-24 |
reset mld-snooping statistics |
8-24 |
reset msdp peer |
6-16 |
reset msdp sa-cache |
6-17 |
reset msdp statistics |
6-17 |
reset multicast forwarding-table |
3-16 |
reset multicast ipv6 forwarding-table |
10-11 |
reset multicast ipv6 routing-table |
10-12 |
reset multicast routing-table |
3-17 |
reset ndp statistics |
9-6 |
reset oam |
1-16 |
reset ospf counters |
Layer 3 - IP Routing Command Reference |
4-58 |
reset ospf process |
4-58 |
reset ospf redistribution |
4-59 |
reset packet-drop interface |
Layer 2 - LAN Switching Command Reference |
1-26 |
reset pim control-message counters |
5-43 |
reset pim ipv6 control-message counters |
12-40 |
reset portal connection statistics |
Security Command Reference |
7-18 |
reset portal server statistics |
7-18 |
reset portal tcp-cheat statistics |
7-19 |
reset qos policy global |
ACL and QoS Command Reference |
2-27 |
reset qos vlan-policy |
2-27 |
reset radius statistics |
2-14 |
reset recycle-bin |
Fundamentals Command Reference |
5-11 |
reset rip statistics |
3-17 |
reset rrpp statistics |
4-12 |
reset saved-configuration |
6-7 |
reset smart-link statistics |
5-7 |
reset stop-accounting-buffer |
2-15 |
3-10 |
reset stp |
7-16 |
reset tcp ipv6 statistics |
12-41 |
reset tcp statistics |
10-18 |
reset trapbuffer |
Network Management and Monitoring Command Reference |
13-21 |
reset udp ipv6 statistics |
12-41 |
reset udp statistics |
10-18 |
reset udp-helper packet |
11-1 |
reset unused porttag |
8-29 |
reset vrrp ipv6 statistics |
7-20 |
reset vrrp statistics |
7-6 |
restore startup-configuration |
6-8 |
retry |
2-15 |
retry realtime-accounting |
2-16 |
retry stop-accounting (HWTACACS scheme view) |
3-10 |
retry stop-accounting (RADIUS scheme view) |
2-17 |
return |
1-8 |
revision-level |
7-17 |
rfc1583 compatible |
4-59 |
ring |
4-13 |
ring enable |
4-15 |
rip |
3-17 |
rip authentication-mode |
3-18 |
rip bfd enable |
8-13 |
rip default-route |
3-19 |
rip input |
3-20 |
rip metricin |
3-20 |
rip metricout |
3-21 |
rip mib-binding |
3-22 |
rip output |
3-23 |
rip poison-reverse |
3-23 |
rip split-horizon |
3-24 |
rip summary-address |
3-24 |
rip version |
3-25 |
ripng |
8-11 |
ripng default-route |
8-11 |
ripng enable |
8-12 |
ripng metricin |
8-13 |
ripng metricout |
8-13 |
ripng poison-reverse |
8-14 |
ripng split-horizon |
8-14 |
ripng summary-address |
8-15 |
rmdir |
3-26 |
rmdir |
5-13 |
rmdir |
14-10 |
rmon alarm |
8-12 |
rmon event |
8-14 |
rmon history |
8-15 |
rmon prialarm |
8-16 |
rmon statistics |
8-18 |
robust-count (IGMP view) |
IP Multicast Command Reference |
4-28 |
robust-count (MLD view) |
11-27 |
root-certificate fingerprint |
12-22 |
route-distinguisher |
14-25 |
route-option bypass-route |
2-29 |
route-policy |
12-18 |
router id |
1-19 |
router-aging-time (IGMP-Snooping view) |
1-23 |
router-aging-time (MLD-Snooping view) |
8-25 |
router-id |
6-66 |
router-id |
9-40 |
router-id |
11-49 |
route-tag |
4-60 |
routing-table limit |
14-25 |
rrpp domain |
4-16 |
rrpp enable |
4-16 |
rrpp ring-group |
4-17 |
rule (Ethernet frame header ACL view) |
1-15 |
rule (IPv4 advanced ACL view) |
1-16 |
rule (IPv4 basic ACL view) |
1-21 |
rule (IPv6 advanced ACL view) |
1-23 |
rule (IPv6 basic ACL view) |
1-27 |
rule (PKI CERT ACP view) |
12-23 |
rule comment |
1-28 |
save |
6-9 |
schedule job |
8-30 |
schedule reboot at |
8-31 |
schedule reboot delay |
8-33 |
screen-length |
2-23 |
screen-length disable |
1-8 |
secondary accounting (HWTACACS scheme view) |
3-11 |
secondary accounting (RADIUS scheme view) |
2-18 |
secondary authentication (HWTACACS scheme view) |
3-11 |
secondary authentication (RADIUS scheme view) |
2-19 |
secondary authorization |
3-12 |
security-policy-server |
2-20 |
self-service-url enable |
1-30 |
send |
2-24 |
send-router-alert (IGMP view) |
4-28 |
send-router-alert (MLD view) |
11-28 |
server-type |
2-20 |
16-3 |
service-loopback-group |
Layer 3 - IP Services Command Reference |
13-9 |
service-type |
1-31 |
session |
15-7 |
set authentication password |
2-25 |
set-overload |
5-56 |
sflow agent ip |
12-2 |
sflow collector ip |
12-3 |
sflow enable |
12-3 |
sflow interval |
12-4 |
sflow sampling-mode |
12-4 |
sflow sampling-rate |
12-5 |
sftp |
14-11 |
sftp client ipv6 source |
14-12 |
14-12 |
sftp ipv6 |
14-13 |
sftp server enable |
14-1 |
sftp server idle-timeout |
14-1 |
sham-link |
4-61 |
shell |
2-26 |
shutdown |
1-26 |
shutdown |
2-6 |
shutdown |
5-17 |
shutdown |
9-8 |
shutdown (MSDP view) |
6-18 |
shutdown-interval |
8-34 |
silent-interface (OSPF view) |
4-62 |
silent-interface (RIP view) |
3-26 |
silent-interface(OSPFv3 view) |
9-40 |
slave auto-update config |
6-11 |
smart-link flush enable |
High Availability Command Reference |
5-8 |
smart-link group |
5-9 |
snmp-agent |
6-11 |
snmp-agent calculate-password |
6-12 |
6-13 |
snmp-agent group |
6-15 |
6-16 |
snmp-agent log |
6-17 |
6-18 |
snmp-agent packet max-size |
6-19 |
6-19 |
snmp-agent target-host |
6-20 |
snmp-agent trap enable |
6-22 |
snmp-agent trap enable bfd |
8-14 |
snmp-agent trap enable ospf |
4-63 |
snmp-agent trap if-mib link extended |
6-24 |
snmp-agent trap life |
6-25 |
snmp-agent trap queue-size |
6-25 |
snmp-agent trap source |
6-26 |
snmp-agent usm-user { v1 | v2c } |
6-27 |
6-28 |
snmp-host |
9-42 |
source |
13-10 |
source interface |
2-30 |
source ip |
2-30 |
source port |
2-31 |
source-deny (IGMP-Snooping view) |
1-24 |
source-deny (MLD-Snooping view) |
8-25 |
source-lifetime (IPv6 PIM view) |
12-41 |
source-lifetime (PIM view) |
5-43 |
source-policy (IPv6 PIM view) |
12-41 |
source-policy (PIM view) |
5-44 |
speed |
2-26 |
speed |
1-27 |
speed auto |
1-28 |
spf timers |
9-41 |
spf-schedule-interval |
4-64 |
spt-switch-threshold infinity (IPv6 PIM view) |
12-42 |
spt-switch-threshold infinity (PIM view) |
5-44 |
ssh client authentication server |
13-9 |
ssh client first-time enable |
13-10 |
ssh client ipv6 source |
13-11 |
ssh client source |
13-11 |
ssh server authentication-retries |
13-3 |
ssh server authentication-timeout |
13-4 |
ssh server compatible-ssh1x enable |
13-5 |
ssh server enable |
13-5 |
ssh server rekey-interval |
13-6 |
ssh user |
13-7 |
ssh2 |
13-12 |
ssh2 ipv6 |
13-13 |
ssl client-policy |
15-8 |
ssl server-policy |
15-8 |
ssm-mapping (IGMP view) |
4-29 |
ssm-mapping (MLD view) |
11-28 |
ssm-policy (IPv6 PIM view) |
12-43 |
ssm-policy (PIM view) |
5-46 |
startup bootrom-access enable |
8-35 |
startup saved-configuration |
6-11 |
startup-query-count (IGMP view) |
4-30 |
startup-query-count (MLD view) |
11-29 |
startup-query-interval (IGMP view) |
4-30 |
startup-query-interval (MLD view) |
11-30 |
state |
1-32 |
state |
2-21 |
state |
12-24 |
state-refresh-hoplimit |
12-44 |
state-refresh-interval (IPv6 PIM view) |
12-45 |
state-refresh-interval (PIM view) |
5-46 |
state-refresh-rate-limit (IPv6 PIM view) |
12-45 |
state-refresh-rate-limit (PIM view) |
5-47 |
state-refresh-ttl |
5-47 |
static-bind client-identifier |
4-24 |
static-bind ip-address |
4-25 |
static-bind mac-address |
4-26 |
static-rp (IPv6 PIM view) |
12-46 |
static-rp (PIM view) |
5-48 |
static-rpf-peer |
6-18 |
statistics hold-time |
2-32 |
statistics interval |
2-33 |
statistics max-group |
2-32 |
step |
1-29 |
stop-accounting-buffer enable (HWTACACS scheme view) |
3-13 |
stop-accounting-buffer enable (RADIUS scheme view) |
2-22 |
stopbits |
2-27 |
storm-constrain |
1-29 |
storm-constrain control |
1-30 |
storm-constrain enable log |
1-31 |
storm-constrain enable trap |
1-31 |
storm-constrain interval |
1-32 |
stp bpdu-protection |
7-17 |
stp bridge-diameter |
7-18 |
stp compliance |
7-19 |
stp config-digest-snooping |
7-19 |
stp cost |
7-20 |
stp edged-port |
7-21 |
stp enable |
7-22 |
stp loop-protection |
7-23 |
stp max-hops |
7-24 |
stp mcheck |
7-25 |
stp mode |
7-25 |
stp no-agreement-check |
7-26 |
stp pathcost-standard |
7-27 |
stp point-to-point |
7-28 |
stp port priority |
7-29 |
stp port-log |
7-30 |
stp priority |
7-31 |
7-31 |
stp root primary |
7-32 |
stp root secondary |
7-33 |
stp root-protection |
7-33 |
stp tc-protection |
7-34 |
stp tc-protection threshold |
7-35 |
stp timer forward-delay |
7-35 |
stp timer hello |
7-36 |
stp timer max-age |
7-37 |
stp timer-factor |
7-38 |
stp transmit-limit |
7-38 |
stub (OSPF area view) |
4-65 |
stub (OSPFv3 area view) |
9-41 |
stub-router |
4-66 |
subvlan (IPv6 multicast VLAN view) |
9-4 |
subvlan (multicast VLAN view) |
2-4 |
summary |
3-27 |
summary (IS-IS view) |
5-57 |
summary automatic |
6-66 |
summary automatic (MBGP family view) |
7-47 |
super |
1-9 |
super password |
1-9 |
synchronization (BGP view) |
6-67 |
synchronization (IPv6 address family view) |
11-50 |
sysname |
8-35 |
system-failure |
8-36 |
system-view |
1-10 |
tcp ipv6 timer fin-timeout |
12-42 |
tcp ipv6 timer syn-timeout |
12-42 |
tcp ipv6 window |
12-43 |
tcp timer fin-timeout |
10-19 |
tcp timer syn-timeout |
10-19 |
tcp window |
10-20 |
telnet |
2-28 |
telnet client source |
2-30 |
telnet ipv6 |
2-29 |
telnet server enable |
2-30 |
terminal debugging |
13-22 |
terminal logging |
13-23 |
terminal monitor |
13-23 |
terminal trapping |
13-24 |
terminal type |
2-31 |
tftp |
4-2 |
tftp client source |
4-4 |
tftp ipv6 |
4-5 |
tftp-server |
9-42 |
tftp-server acl |
4-1 |
tftp-server domain-name |
4-27 |
tftp-server ip-address |
4-27 |
timer |
4-17 |
timer |
9-43 |
6-68 |
11-51 |
timer hello (IPv6 PIM view) |
12-47 |
timer hello (PIM view) |
5-49 |
timer join-prune (IPv6 PIM view) |
12-47 |
timer join-prune (PIM view) |
5-49 |
timer lsp-generation |
5-58 |
timer lsp-max-age |
5-59 |
timer lsp-refresh |
5-60 |
timer other-querier-present (IGMP view) |
4-31 |
timer other-querier-present (MLD view) |
11-30 |
timer query (IGMP view) |
4-31 |
timer query (MLD view) |
11-31 |
timer quiet (HWTACACS scheme view) |
3-14 |
timer quiet (RADIUS scheme view) |
2-23 |
timer realtime-accounting (HWTACACS scheme view) |
3-14 |
timer realtime-accounting (RADIUS scheme view) |
2-23 |
timer response-timeout (HWTACACS scheme view) |
3-15 |
timer response-timeout (RADIUS scheme view) |
2-24 |
timer retry |
6-19 |
timer spf |
5-60 |
time-range |
1-30 |
timers |
3-27 |
timers |
8-16 |
topology accept |
9-44 |
topology restore-from |
9-44 |
topology save-to |
9-45 |
tos |
2-34 |
tracert |
1-5 |
tracert ipv6 |
1-7 |
track bfd echo |
9-2 |
track nqa |
9-3 |
traffic behavior |
2-15 |
2-6 |
transmit-pacing |
4-66 |
ttl |
2-34 |
tunnel-protocol |
13-11 |
type |
2-35 |
udp-helper enable |
11-2 |
udp-helper port |
11-2 |
udp-helper server |
11-3 |
undelete |
5-13 |
unicast-suppression |
1-33 |
url |
2-36 |
user |
3-26 |
user privilege level |
2-32 |
user-bind |
16-4 |
user-group |
1-33 |
user-interface |
2-31 |
username (FTP test type view) |
2-36 |
user-name-format (HWTACACS scheme view) |
3-16 |
user-name-format (RADIUS scheme view) |
2-25 |
user-profile |
9-2 |
user-profile enable |
9-2 |
validate-source-address |
3-28 |
verbose |
3-27 |
version |
3-29 |
version |
15-9 |
version (IGMP view) |
4-32 |
version (MLD view) |
11-31 |
virtual-cable-test |
1-34 |
virtual-system |
5-61 |
vlan |
9-8 |
vlan precedence |
9-23 |
vlan-mapping modulo |
7-39 |
vlink-peer (OSPF area view) |
4-67 |
vlink-peer (OSPFv3 area view) |
9-42 |
voice vlan aging |
11-3 |
voice vlan enable |
11-4 |
voice vlan mac-address |
11-4 |
voice vlan mode auto |
11-6 |
voice vlan security enable |
11-6 |
voice-config |
4-28 |
vpn-instance (ICMP echo test type view) |
2-37 |
vpn-instance-capability simple |
14-26 |
vpn-target |
14-27 |
vrrp ipv6 method |
7-21 |
vrrp ipv6 vrid authentication-mode |
7-21 |
vrrp ipv6 vrid preempt-mode |
7-22 |
vrrp ipv6 vrid priority |
7-23 |
vrrp ipv6 vrid timer advertise |
7-24 |
vrrp ipv6 vrid track interface |
7-25 |
vrrp ipv6 vrid virtual-ip |
7-26 |
vrrp method |
7-7 |
vrrp un-check ttl |
7-8 |
vrrp vrid authentication-mode |
7-8 |
vrrp vrid preempt-mode |
7-9 |
vrrp vrid priority |
7-10 |
vrrp vrid timer advertise |
7-11 |
vrrp vrid track |
7-12 |
vrrp vrid track interface |
7-13 |
vrrp vrid virtual-ip |
7-14 |
