Title | Size | Downloads |
High Availability Command Reference-book.pdf | 616.62 KB |
- H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
- H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
- H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
- H3C S5500-EI Series Ethernet Switches Compliance and Safety Manual-6W101
- H3C S5500-SI Complete Compliance and Safety Manual-6W100
- H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
Click the link on the right to download the complete book.
Preface
The H3C S5500-EI documentation set includes 10 command references, which describe the commands and command syntax options for the S5500-EI Release 2202.
The High Availability Command Reference describes fault detection and fast failover configuration commands. With these commands, you can detect and diagnose your network, and rapidly recover your network when failures occur.
This preface includes:
l Audience
l About the H3C S5500-EI Documentation Set
Audience
This documentation set is intended for:
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the S5500-EI series
Document Organization
The High Availability Command Reference comprises these parts:
Ethernet OAM Configuration Commands |
CFD Configuration Commands |
DLDP Configuration Commands |
RRPP Configuration Commands |
Smart Link Configuration Commands |
Monitor Link Configuration Commands |
VRRP Configuration Commands |
BFD Configuration Commands |
Track Configuration Commands |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means a complementary description. |
The H3C S5500-EI documentation set also includes:
Category |
Documents |
Purposes |
Product description and specifications |
Describe product specifications and benefits. |
Provide an in-depth description of software features and technologies. |
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products. |
Describes the appearances, features, and specifications of the RPS units available for the products. |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Describes the appearance and specifications of the interface card. |
Hardware installation |
Provides regulatory information and the safety instructions that must be followed during installation. Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Describes how to install the interface card. |
Software configuration |
Describe software features and configuration procedures. |
Provide a quick reference to all available commands. |
Operations and maintenance |
Tells how to find the lost password or recover the password when the login password is lost. |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
