Title | Size | Downloads |
H3C S5500-EI Series Ethernet Switches Installation Guide(V1.04)-book.pdf | 4.62 MB |
- H3C Low-End and Mid-Range Ethernet Switches Configuration Examples(V1.01)
- H3C S5500-SI Series Ethernet Switches Command Manual(V1.01)
- H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
- H3C S5500-EI Series Ethernet Switches Compliance and Safety Manual-6W101
- H3C S5500-SI Complete Compliance and Safety Manual-6W100
- H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
Preface
H3C S5500-EI Switch Series Installation Guide describes the appearance, installation, power-on, maintenance, and troubleshooting of the S5500-EI switches.
This preface includes:
· Audience
· About the H3C S5500-EI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-EI series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-EI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manual CE DOCs |
Provide regulatory information and the safety instructions that must be followed during installation. |
Quick start |
Guides you through initial installation and setup procedures to help you quickly set up your device. |
Installation guide |
Provides a complete guide to switch installation and specifications. |
H3C PSR150-A & PSR150-D Series Power Modules User Manual |
Describe the specifications, installation, and replacement of hot swappable 150W power modules. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Helps you order RPSs for switches that can work with an RPS. |
User manuals for RPSs |
Describe the specifications, installation, and replacement of RPSs. |
User manuals for interface cards |
Describe the specifications, installation, and replacement of expansion interface cards. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the specifications of pluggable transceiver modules. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
H3C Series Ethernet Switches Login Password Recovery Manual |
Helps you deal with switch login password loss. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions. [Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
