Title | Size | Downloads |
10 High Availability Configuration Guide-book.pdf | 2.21 MB |
Preface
The H3C S5500-HI documentation set includes 12 configuration guides, which describe the software features for the H3C S5500-HI Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The High Availability Configuration Guide describes high availability fundamentals and configuration. The high availability technologies include fault detection and fault failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery.
This preface includes:
· Audience
· About the H3C S5500-HI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-HI series
Added and modified features
Compared to Release 5206, Release 5501 does not contain any changes to high availability.
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-HI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochure |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manual CE DOCs |
Provide regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Guides you through initial installation and setup procedures to help you quickly set up your device. |
Installation guide |
Provides a complete guide to switch installation and specifications. |
LSPM1FAN and LSPM1FANB Installation Manual |
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products. |
User manuals for power modules |
Describe the specifications, installation, and replacement of hot swappable power modules. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Helps you order RPSs for switches that can work with an RPS. |
User manuals for RPSs |
Describe the specifications, installation, and replacement of RPSs. |
User manuals for interface cards |
Describe the specifications, installation, and replacement of expansion interface cards. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the specifications of pluggable transceiver modules. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
