Title | Size | Downloads |
09 Security Configuration Guide-book.pdf | 4.13 MB |
Preface
The H3C S5500-HI documentation set includes 11 configuration guides, which describe the software features for the H3C S5500-HI Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Security Configuration Guide describes security fundamentals and configuration. It covers the authentication features (including AAA, 802.1X, MAC authentication, portal authentication, and so on) and attack protection features (including IP source guard, ARP attack protection, and so on).
This preface includes:
· Audience
· About the H3C S5500-HI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-HI series
Added and modified features
This documentation set is for Release 52xx. The following describes the feature changes between releases:
· Release 5206 has the following feature changes over Release 5203:
Configuration guide |
Added and modified features |
AAA |
Added feature: Specifying multiple secondary HWTACACS servers |
MAC authentication |
Added feature: Enabling MAC authentication multi-VLAN mode |
IP source guard |
Added feature: 802.1X-based dynamic IPv4 source guard binding entries. |
ARP attack protection |
Added feature: ARP Detection logging function. |
· Release 5203 has the following feature changes over Release 5101:
AAA |
Added features: · Setting a DSCP value for an ISP domain. · Setting the DSCP value for RADIUS protocol packets. · Configuring status detection for RADIUS authentication/authorization servers · RADIUS/HWTACACS authentication, authorization, and accounting support ciphertext shared key configuration. · Setting ciphertext shared keys for secure RADIUS communication. Modified feature: Configuring a password for the local user. Removed feature: Setting the password display mode for all local users. |
802.1X |
Added features: · Configuring 802.1X critical VLAN. · Specifying supported domain name delimiters. · Configuring a port to send EAPOL frames untagged. · Setting the maximum number of authentication request attempts. Configuring an 802.1X VLAN group. |
EAD fast deployment |
N/A |
Added features: · Configuring a MAC authentication critical VLAN. Configuring MAC authentication delay. |
Portal |
Added features: · Configuring IPv6 portal. Setting a ciphertext shared key. |
Triple authentication |
N/A |
Port security |
N/A |
User profile |
N/A |
Password control |
Modified features: Clearing all users from the password control blacklist. |
HABP |
N/A |
Public Key |
N/A |
PKI |
Added feature: Setting a ciphertext password for certificate revocation. |
IPsec |
Added features: · Configuring ACL-based IPsec. Configuring IKE. |
SSH2.0 |
Added features: · Configuring the service type as SCP for SSH users. · Configuring the device as an SCP client. · Setting the DSCP value for IPv4 or IPv6 protocol packets sent by the SSH server. · Setting the DSCP value for IPv4 or IPv6 protocol packets sent by the Stelnet client. Setting the DSCP value for IPv4 or IPv6 protocol packets sent by the SFTP client. |
SSL |
N/A |
TCP attack protection |
N/A |
IP source guard |
N/A |
Added feature: Configuring a user validity check rule. |
ND attack defense |
N/A |
URPF |
N/A |
MFF |
N/A |
SAVI |
Added feature: Setting the deletion delay time for SAVI. |
Black list |
N/A |
FIPS |
FIPS is a newly added feature. |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-HI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochure |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manual CE DOCs |
Provide regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Guides you through initial installation and setup procedures to help you quickly set up your device. |
Installation guide |
Provides a complete guide to switch installation and specifications. |
LSPM1FAN and LSPM1FANB Installation Manual |
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products. |
User manuals for power modules |
Describe the specifications, installation, and replacement of hot swappable power modules. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Helps you order RPSs for switches that can work with an RPS. |
User manuals for RPSs |
Describe the specifications, installation, and replacement of RPSs. |
User manuals for interface cards |
Describe the specifications, installation, and replacement of expansion interface cards. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the specifications of pluggable transceiver modules. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
