Title | Size | Downloads |
About the S5500-HI Configuration Guides-book.pdf | 50.71 KB |
The H3C S5500-HI configuration guides are part of the H3C S5500-HI documentation set. They describe the software features for the H3C S5500-HI Switch Series Release 5101, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios. The H3C S5500-HI documentation set includes 11 configuration guides:
Configuration guide |
Content |
01 Fundamentals Configuration Guide |
Describes how to use the command line interface of the switch, log in to and set up the switch. This guide includes: · CLI configuration · Login methods · CLI login · Web login · NMS login · User login control · FTP configuration · TFTP configuration · File system management · Configuration file management · Software upgrade configuration · ISSU configuration · ISSU configuration example · Device management · Automatic configuration |
02 IRF Configuration Guide |
Describes the H3C proprietary Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability. IRF creates a virtual device from multiple switches. The switches that form the IRF virtual device appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers. |
03 Layer 2 – LAN Switching Configuration Guide |
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, Spanning Tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, remark VLAN tags, This guide includes: · Ethernet interface configuration · Loopback and null interface configuration · Interface Range Configuration · MAC address table configuration · MAC Information configuration · Ethernet link aggregation configuration · Port isolation configuration · Spanning tree configuration · BPDU tunneling configuration · VLAN configuration · Super VLAN configuration · Isolate-user-VLAN configuration · Voice VLAN configuration · GVRP configuration · QinQ configuration · VLAN mapping configuration · LLDP configuration · Service loopback group configuration |
04 Layer 3 – IP Services Configuration Guide |
Describes how to configure IP addressing, DHCP, IP performance optimization, ARP, DNS, IPv6 basics, DHCPv6,and Tunneling. This guide includes: · ARP configuration · Gratuitous ARP configuration · Proxy ARP configuration · ARP snooping configuration · IP addressing configuration · DHCP overview · DHCP server configuration · DHCP relay agent configuration · DHCP client configuration · DHCP snooping configuration · IPv4 DNS configuration · IRDP Configuration · IP performance optimization configuration · UDP helper configuration · IPv6 basics configuration · DHCPv6 overview · DHCPv6 relay agent configuration · DHCPv6 client configuration · DHCPv6 snooping configuration · Tunneling configuration · GRE configuration |
05 Layer 3 – IP Routing Configuration Guide |
Covers the routing technologies for IPv4 and IPv6 networks of different sizes. This guide includes: · Static routing configuration · RIP configuration · OSPF configuration · IS-IS configuration · BGP configuration · IPv6 static routing configuration · RIPng configuration · OSPFv3 configuration · IPv6 IS-IS configuration · IPv6 BGP configuration · Routing policy configuration · Policy-based routing configuration |
06 IP Multicast Configuration Guide |
Describes Layer 2 and Layer 3 multicast fundamentals and configuration. This guide includes: · Mulitcast overview · IGMP snooping configuration · Multicast VLAN configuration · Multicast routing and forwarding configuration · MBGP configuration · Multicast VPN configuration · MLD snooping configuration · IPv6 PIM snooping configuration · IPv6 multicast VLAN configuration |
07 MPLS Configuration Guide |
Describes fundamentals and configuration of MPLS and its extended functions, including MCE, IPv6 MCE, MPLS basics, MPLS TE tunnels, VPLS, L2VPN, L3VPN and IPv6 L3VPN implemented by using MPLS labels. This guide includes: · MCE configuration · IPv6 MCE configuration · MPLS Basics configuration · MPLS TE configuration · VPLS configuration · MPLS L2VPN configuration · MPLS L3VPN configuration · IPv6 MPLS L3VPN configuration |
08 ACL and QoS Configuration Guide |
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. This guide includes: · QoS overview · QoS configuration approaches · Configuring priority mapping · Configuring traffic policing, traffic shaping, and line rate · Configuring congestion management · Configuring congestion avoidance · Configuring traffic filtering · Configuring priority marking · Configuring traffic redirecting · Configuring class-based accounting · HQoS configuration · Appendix A Default priority mapping tables |
09 Security Configuration Guide |
Covers security features. The major security features available on the switch include identity authentication (AAA), access security (802.1X, MAC authentication, portal, and port security), secure management (SSH), and attack protection (IP source guard, ARP attack protection, and URPF). This guide includes: · AAA configuration · 802.1X fundamentals · 802.1X configuration · EAD fast deployment configuration · MAC authentication configuration · Portal configuration · Triple authentication configuration · Port security configuration · User profile configuration · Password control configuration · HABP configuration · Public key configuration · PKI configuration · IPsec configuration · SSH2.0 configuration · SFTP configuration · SSL configuration · TCP attack protection configuration · IP source guard configuration · ARP attack protection configuration · ND attack defense configuration · URPF configuration · Blacklist configuration |
10 High Availability Configuration Guide |
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: · Ethernet OAM configuration · CFD configuration · DLDP configuration · RRPP configuration · Smart Link configuration · Monitor Link configuration · VRRP configuration · Stateful failover configuration · BFD configuration · Track configuration |
11 Network Management and Monitoring Configuration Guide |
Describes features that help you manage and monitor your network, for example, manage system events, sample packets, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, and test network connectivity. This guide includes: · System maintenance and debugging · Information center configuration · Port mirroring configuration · Traffic mirroring configuration · sFlow configuration · NetStream configuration · IPv6 NetStream configuration · Sampler configuration · Cluster management configuration · CWMP configuration |
