- H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
- 00-1Cover
- 00-2Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Confiugration Operation
- 06-GVRP Operation
- 07-Port Basic Configuration Operation
- 08-Link Aggregation Operation
- 09-Port Isolation Operation
- 10-DLDP Operation
- 11-MAC Address Table Operation
- 12-MSTP Operation
- 13-Multicast Operation
- 14-Routing Protocol Operation
- 15-802.1x Operation
- 16-AAA-RADIUS-HWTACACS Operation
- 17-Centralized MAC Address Authentication Operation
- 18-DHCP Operation
- 19-ARP Operation
- 20-ACL Operation
- 21-QoS Operation
- 22-Mirroring Operation
- 23-Cluster Operation
- 24-SNMP and RMON Operation
- 25-NTP Operation
- 26-SSH Terminal Service Operation
- 27-File System Management Operation
- 28-FTP and TFTP Operatio
- 29-Information Center Operation
- 30-System Maintenance and Debugging Operation
- 31-VLAN VPN Operation
- 32-HWPing Operation
- 33-DNS Operation
- 34-Appendix
20-ACL Operation | 152.91 KB |
Table of Contents
1.1.1 ACLs Referenced by Upper-level Modules
1.1.4 Types of ACLs Supported by the Ethernet Switch
1.3.1 Configuration Preparation
1.4 Advanced ACL Configuration
1.4.1 Configuration Preparation
1.5.1 Configuration Preparation
1.6 User-Defined ACL Configuration
1.6.1 Configuration Preparation
1.7 Displaying ACL Configuration
Chapter 1 ACL Configuration
1.1 ACL Overview
An access control list (ACL) is mainly used for traffic classification. To filter data packets, a network device needs to be configured with a series of ACLs to identify the packets to be filtered. A network device can permit/deny specific packets in a predefined way only after the traffic is classified.
ACLs classify packets using a series of conditions known as rules. The conditions can be based on source addresses, destination addresses and port numbers carried in the packets.
The rules of an ACL can be referenced by other functions that need traffic classification, such as QoS.
According to their application purposes, ACLs fall into the following four types.
l Basic ACL. Rules are created based on Layer 3 source IP addresses only.
l Advanced ACL. Rules are created based on the Layer 3 and Layer 4 information such as the source and destination IP addresses, the type of the protocols carried by IP, protocol-specific features, and so on.
l Layer 2 ACL. Rules are created based on the Layer 2 information such as source and destination MAC addresses, VLAN priorities, Layer 2 protocols, and so on.
l User-defined ACL. An ACL of this type matches packets by comparing specific strings retrieved from the packets with specified strings.
ACL can also be used to filter and classify the packets to be processed by software. In this case, the rules in an ACL can be matched in one of the following two ways:
l config, where rules in an ACL are matched in the order defined by the user.
l auto, where the rules in an ACL are matched in the order determined by the system, namely the “depth-first” order.
When applying ACLs in this way, you can specify the order in which the rules in the ACL are matched. The matching order cannot be modified once it is determined unless you delete all the rules in the ACL.
An ACL is referenced by an upper-layer module when it is
l Referenced by route policies
l Used to control login users
1.1.2 ACL Matching Order
An ACL can contain multiple rules, each of which matches specific type of packets. So the order in which the rules of an ACL are matched needs to be determined.
The order in which the rules of an ACL are matched can be:
l The order the rules are created.
With the depth-first rule adopted, the rules of an ACL are matched according to:
1) Protocol range. The range for IP is 1 to 255 and those of other protocols are their protocol numbers. The smaller the protocol range, the higher the priority.
2) Range of source IP address. The smaller the source IP address range (that is, the longer the mask), the higher the priority.
3) Range of destination IP address. The smaller the destination IP address range (that is, the longer the mask), the higher the priority.
4) Range of Layer 4 port number, that is, of TCP/UDP port number. The smaller the range, the higher the priority.
If rule A and rule B are the same in all the four ACEs (access control elements) above, and also in their numbers of other ACEs to be considered in deciding their priority order, the weighting principles will be used in deciding their priority order, as listed below.
l Each ACE is given a fixed weighting value. This weighting value and the value of the ACE itself will jointly decide the final matching order.
l The weighting values of ACEs rank in the following descending order: DSCP, ToS, ICMP, established, VPN-instance, precedence, fragment.
l A fixed weighting value is deducted from the weighting value of each ACE of the rule. The smaller the weighting value left, the higher the priority.
l If the number and type of ACEs are the same for multiple rules, then the sum of ACE values of a rule determines its priority. The smaller the sum, the higher the priority.
1.1.3 Time Range-based ACL
A time range-based ACL takes effect only in specified time ranges.
You can specify a time range for each rule in an ACL. An ACL rule cannot take effect if you do not configure the time range for it. It takes effect only when the time range is configured and the system time is within the time range. If you remove the time range of an ACL rule, the ACL rule becomes invalid after the ACL rule timer refreshes.
The following types of ACLs are supported by the Ethernet switch:
l User-defined ACL
1.2 Time Range Configuration
A time range can contain multiple time sections in a time range. The time sections in an ACL are of the logical OR relationship.
A time section can be periodic or absolute. A periodic time section is defined by specifying days of a week, while an absolute time section is defined by specifying the start time and the end time.
1.2.1 Configuration Procedure
Table 1-1 Configure a time range
Operation |
Command |
Enter system view |
system-view |
Create a time range |
time-range time-name { start-time to end-time days-of-the-week [ from start-time start-date ] [ to end-time end-date ] | from start-time start-date [ to end-time end-date ] | to end-time end-date } |
Required |
Display a time range or all the time ranges |
display time-range { all | time-name } |
Optional This command can be executed in any view. |
If only a periodic time section is defined in a time range, the time range is active only when the system time within the defined periodic time section.
If only an absolute time section is defined in a time range, the time range is active only when the system time within the defined absolute time section.
If the start time is not specified, the time section starts on the current date and ends on the end date.
If the end date is not specified, the time section ends on the most forward time the system can hold.
1.2.2 Configuration Example
# Define a time range that will be active from 8:00 to 18:00 on Monday through Friday.
<H3C> system-view
[H3C] time-range test 8:00 to 18:00 working-day
[H3C] display time-range test
Current time is 13:27:32 4/16/2005 Saturday
Time-range : test ( Inactive )
08:00 to 18:00 working-day
1.3 Basic ACL Configuration
A basic ACL filters packets based on their Layer 3 source IP addresses.
A basic ACL can be numbered from 2000 to 2999.
To configure a time range-based basic ACL rule, you need to create the corresponding time range first. For information about time range configuration, refer to section 1.2 “Time Range Configuration”.
The source IP addresses based on which the ACL filters packets are determined.
1.3.2 Configuration Procedure
Table 1-2 Define a basic ACL rule
Operation |
Command |
Enter system view |
system-view |
Create an ACL or enter basic ACL view |
acl number acl-number [ match-order { config | auto } ] |
By the default, the matching order is config. |
Define an ACL rule |
rule [ rule-id ] { permit | deny } [ fragment | source { sour-addr sour-wildcard | any } | time-range time-name ]* |
Required |
Assign a description string to the ACL |
description text |
Optional |
Display the information about an ACL or all the ACLs |
display acl { all | acl-number } |
When you define an ACL rule using the rule command with the rule-id argument provided,
l If the ACL rule identified by the rule-id argument already exists, the settings specified in the rule command overwrite the corresponding settings of the existing rule. And the existing settings remain unchanged if the corresponding settings are not specified in the command.
l If the ACL rule identified by the rule-id argument does not exist, you will create a new rule.
If you do not specify the rule-id argument when creating an ACL rule, the rule will be numbered automatically.
1.3.3 Configuration Example
# Configure ACL 2000 to deny packets whose source IP addresses are 1.1.1.1.
<H3C> system-view
[H3C] acl number 2000
[H3C-acl-basic-2000] rule deny source 1.1.1.1 0
[H3C-acl-basic-2000] display acl 2000
Basic ACL 2000, 1 rule
Acl's step is 1
rule 0 deny source 1.1.1.1 0
An advanced ACL can filter packets by their source and destination IP addresses, the protocols carried by IP. The rules in an advanced ACL rule can based on protocol-specific features such as TCP/UDP source and destination ports, TCP flag bit, ICMP protocol type, code, and so on.
An advanced ACL can be numbered from 3000 to 3999.
Using advanced ACLs, you can define classification rules that are more accurate, more abundant, and more flexible than those defined for basic ACLs.
To configure an time range-based advanced ACL rule, you need to create the corresponding time ranges first. For information about of time range configuration, refer to section 1.2 “Time Range Configuration”.
The settings to be specified in the rule, such as source and destination IP addresses, the protocols carried by IP, and protocol-specific features, are determined.
1.4.2 Configuration Procedure
Table 1-3 Define an advanced ACL rule
Operation |
Command |
Enter system view |
system-view |
Create an advanced VLAN or enter advanced ACL view |
By the default, the match order is config. |
rule [ rule-id ] { permit | deny } rule-string |
Required |
Assign a description string to the ACL rule |
rule rule-id comment text |
Optional |
description text |
Optional |
The rule-string argument of the rule command listed in Table 1-3 can be a combination of the argument/keywords described in Table 1-4. Note that the rule-string argument must begin with the protocol argument.
Table 1-4 Description on the argument/keywords used in the rule-string argument
Arguments/Keywords |
Type |
Function |
protocol |
Protocol type |
Type of the protocols carried by IP |
When expressed in numerals, this argument ranges from 1 to 255. When expressed with a name, the value can be GRE, ICMP, IGMP, IP, IPinIP, OSPF, TCP, and UDP. |
Source address |
Specifies the source address information for the ACL rule |
The sour-addr sour-wildcard arguments specify the source address of the packets, expressed in dotted decimal notation. You can specify the IP address of a host as the source address by providing 0 for the sour-wildcard argument. any represents any source address. |
destination { dest-addr dest-wildcard | any } |
Destination address |
Specifies the destination address information for the ACL rule |
The dest-addr dest-wildcard arguments specify the destination address of the packets, expressed in dotted decimal notation. You can specify the IP address of a host as the destination address by providing 0 for the dest-wildcard argument. any represents any destination address. |
precedence precedence |
Packet priority |
IP precedence |
The precedence argument ranges from 0 to 7. |
tos tos |
Packet priority |
ToS |
The tos argument ranges from 0 to 15. |
dscp dscp |
Packet priority |
DSCP |
The dscp argument ranges from 0 to 63. |
fragment |
Fragment information |
Specifies that the rule is effective for the packets that are not the first fragments. |
time-range time-name |
Time range information |
Specifies the time range in which the rule is active. |
If you specify the dscp keyword, you can directly input a value ranging from 0 to 63 or input one of the keywords listed in Table 1-5 as the DSCP.
Table 1-5 DSCP values and the corresponding keywords
Keyword |
DSCP value in decimal |
DSCP value in binary |
ef |
46 |
101110 |
af11 |
10 |
001010 |
af12 |
12 |
001100 |
af13 |
14 |
001110 |
af21 |
18 |
010010 |
af22 |
20 |
010100 |
af23 |
22 |
010110 |
af31 |
26 |
011010 |
af32 |
28 |
011100 |
af33 |
30 |
011110 |
af41 |
34 |
100010 |
af42 |
36 |
100100 |
af43 |
38 |
100110 |
cs1 |
8 |
001000 |
cs2 |
16 |
010000 |
cs3 |
24 |
011000 |
cs4 |
32 |
100000 |
cs5 |
40 |
101000 |
cs6 |
48 |
110000 |
Cs7 |
56 |
111000 |
be (default) |
0 |
000000 |
If you specify the precedence keyword, you can directly input a value ranging from 0 to 7 or input one of the keywords listed in Table 1-6 as the IP precedence.
Table 1-6 IP precedence values and the corresponding keywords
Keyword |
IP Precedence in decimal |
IP Precedence in binary |
routine |
0 |
000 |
priority |
1 |
001 |
immediate |
2 |
010 |
flash |
3 |
011 |
flash-override |
4 |
100 |
critical |
5 |
101 |
internet |
6 |
110 |
network |
7 |
111 |
If you specify the tos keyword, you can directly input a value ranging from 0 to 15 or input one of the keywords listed in Table 1-7 as the ToS value.
Table 1-7 ToS value and the corresponding keywords
Keyword |
ToS in decimal |
ToS in binary |
normal |
0 |
0000 |
min-monetary-cost |
1 |
0001 |
max-reliability |
2 |
0010 |
max-throughput |
4 |
0100 |
min-delay |
8 |
1000 |
If the protocol type is TCP or UDP, you can also define the information listed in Table 1-8.
Table 1-8 TCP/UDP-specific ACL rule information
Parameter |
Type |
Function |
source-port operator port1 [ port2 ] |
Source port |
Defines the source port information of UDP/TCP packets |
The value of operator can be lt (less than), gt (greater than), eq (equal to), neq (not equal to) or range (within the range of). Only the “range” operator requires two port numbers as the operands. Other operators require only one port number as the operand. port1 and port2: TCP/UDP port numbers, expressed as port names or port numbers. When expressed as numbers, the value range is 0 to 65535. |
destination-port operator port1 [ port2 ] |
Destination port |
Defines the destination port information of UDP/TCP packets |
established |
TCP connection flag |
Specifies that the rule applies to TCP packets with the ack or rst flag (Packets of this type are TCP connection packets.) |
TCP-specific argument |
If the protocol type is ICMP, you can also define the information listed in Table 1-9.
Table 1-9 ICMP-specific ACL rule information
Parameter |
Type |
Function |
icmp-type icmp-type icmp-code |
Type and message code information of ICMP packets |
Specifies the type and message code information of ICMP packets in the rule |
icmp-type: ICMP message type, ranging from 0 to 255 icmp-code: ICMP message code, ranging from 0 to 255 |
If the protocol type is ICMP, you can also just input the ICMP message name after the icmp-type keyword. Table 1-10 lists some common ICMP messages.
Name |
ICMP type |
ICMP code |
echo |
Type=8 |
Code=0 |
echo-reply |
Type=0 |
Code=0 |
fragmentneed-DFset |
Type=3 |
Code=4 |
host-redirect |
Type=5 |
Code=1 |
host-tos-redirect |
Type=5 |
Code=3 |
host-unreachable |
Type=3 |
Code=1 |
information-reply |
Type=16 |
Code=0 |
information-request |
Type=15 |
Code=0 |
net-redirect |
Type=5 |
Code=0 |
net-tos-redirect |
Type=5 |
Code=2 |
net-unreachable |
Type=3 |
Code=0 |
parameter-problem |
Type=12 |
Code=0 |
port-unreachable |
Type=3 |
Code=3 |
protocol-unreachable |
Type=3 |
Code=2 |
reassembly-timeout |
Type=11 |
Code=1 |
source-quench |
Type=4 |
Code=0 |
source-route-failed |
Type=3 |
Code=5 |
timestamp-reply |
Type=14 |
Code=0 |
timestamp-request |
Type=13 |
Code=0 |
ttl-exceeded |
Type=11 |
Code=0 |
l The content of a modified or created rule cannot be identical with the content of any existing rules; otherwise the rule modification or creation will fail, and the system prompts that the rule already exists.
1.4.3 Configuration Example
# Configure ACL 3000 to permit the packets sourced from the network 129.9.0.0 and destined for the network 202.38.160.0 and with the destination port number being 80.
<H3C>system-view
[H3C] acl number 3000
[H3C-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
[H3C-acl-adv-3000] display acl 3000
Advanced ACL 3000, 1 rule
Acl's step is 1
rule 0 permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq www
1.5 Layer 2 ACL Configuration
A Layer 2 ACL can be numbered from 4000 to 4999.
To configure a time range-based Layer 2 ACL rule, you need to create the corresponding time ranges first. For information about time range configuration, refer to section 1.2 “Time Range Configuration”.
1.5.2 Configuration Procedure
Table 1-11 Define a Layer 2 ACL rule
Operation |
Command |
Enter system view |
system-view |
Create a Layer 2 ACL or enter layer 2 ACL view |
acl number acl-number |
Required |
Required |
Optional |
description text |
Optional |
Display the information about an ACL or all the ACLs. |
The rule-string argument of the rule command can be a combination of the arguments/keywords described in Table 1-12.
Table 1-12 Layer 2 ACL rule information
Parameter |
Type |
Function |
format-type |
Link layer encapsulation type |
Specifies the link layer encapsulation type for the ACL rule |
This argument can be 802.3/802.2, 802.3, ether_ii, or snap. |
lsap lsap-code lsap-wildcard |
lsap field |
Specifies the lsap field for the ACL rule |
lsap-code: Encapsulation format of data frames, a 16-bit hexadecimal number. lsap-wildcard: Mask of the lsap value, a 16-bit hexadecimal number used to specify the mask bits. |
source { source-addr source-mask | vlan-id }* |
Source MAC address information |
Specifies the source MAC address range for the ACL rule |
source-addr: Source MAC address, in the format of H-H-H. source-mask: Mask of the source MAC address, in the format of H-H-H. vlan-id: Source VLAN ID, in the range of 1 to 4094. |
dest dest-addr dest-mask |
Destination MAC address information |
Specifies the destination MAC address range for the ACL rule |
dest-addr: Destination MAC address, in the format of H-H-H. dest-mask: Mask of the destination MAC address, in the format of H-H-H. |
cos vlan-pri |
Priority |
Specifies the 802.1p priority for the rule |
vlan-pri: VLAN priority, in the range of 0 to 7. |
Specifies the time range in which the ACL rule is active |
time-name: Specifies the name of the time range in which the rule is active, a string comprising 1 to 32 characters. |
type protocol-type protocol-mask |
Protocol type of Ethernet frames |
Specifies the protocol type of Ethernet frames for the ACL rule |
protocol-type: Protocol type. protocol-mask: Protocol type mask. |
If you specify the cos keyword, you can directly input a value ranging from 0 to 7 or input one of the keywords listed in Table 1-6 as the CoS value.
Table 1-13 CoS value and the corresponding keywords
Keyword |
CoS in decimal |
CoS in binary |
best-effort |
0 |
000 |
background |
1 |
001 |
spare |
2 |
010 |
excellent-effort |
3 |
011 |
controlled-load |
4 |
100 |
video |
5 |
101 |
voice |
6 |
110 |
network-management |
7 |
111 |
1.5.3 Configuration Example
# Configure ACL 4000 to deny packets sourced from the MAC address 000d-88f5-97ed, destined for the MAC address 0011-4301-991e, and with their 802.1p priority being 3.
<H3C> system-view
[H3C] acl number 4000
[H3C-acl-ethernetframe-4000] rule deny cos 3 source 000d-88f5-97ed ffff-ffff-ffff dest 0011-4301-991e ffff-ffff-ffff
[H3C-acl-ethernetframe-4000] display acl 4000
Ethernet frame ACL 4000, 1 rule
Acl's step is 1
rule 0 deny cos excellent-effort source 000d-88f5-97ed ffff-ffff-ffff dest 0011-4301-991e ffff-ffff-ffff
A user-defined ACL filters packets by comparing specific bytes in packet headers with specified string.
A user-defined ACL can be numbered from 5000 to 5999.
To configure a time range-based user-defined ACL rule, you need to define the corresponding time ranges first. For information about time range configuration, refer to section 1.2 “Time Range Configuration”.
1.6.2 Configuration Procedure
Table 1-14 Define a user-defined ACL rule
Operation |
Command |
Enter system view |
system-view |
Create a user-defined ACL or enter user-defined ACL view |
Required |
rule [ rule-id ] { permit | deny } [ rule-string rule-mask offset ] &<1-8> [ time-range name ] |
Required |
description text |
Optional |
Optional |
& Note:
The bytes in packet headers and to be compared with the specified string are determined by the offset from the beginning of the packet headers. You can specify the offset through the offset argument when executing the rule command. Note the following when you specify the offset.
l Each packet that is processed by a switch internally carries a VLAN tag. A VLAN tag is four bytes in size.
l A switch with the VLAN VPN function enabled inserts a VLAN tag to each packet it processes no matter whether or not the packet already carries a VLAN tag before being processed. Each packet carries two VLAN tags after being processed by a switch of this type.
1.6.3 Configuration Example
# Configure ACL 5001 to deny all the TCP packets. The ACL is active from 18:00 to 23:00 on each Saturday.
<H3C> system-view
[H3C] time-range t1 18:00 to 23:00 sat
[H3C] acl number 5001
[H3C-acl-user-5001] rule 25 deny 06 ff 35 time-range t1
[H3C-acl-user-5001] display acl 5001
User defined ACL 5001, 1 rules
Acl's step is 1
rule 25 deny 06 ff 35 time-range t1 (Inactive)
After the above configuration, you can execute the display commands in any view to view the ACL running information, so as to verify the configuration.
Table 1-15 Display ACL configuration
Operation |
Command |
Display a configured ACL or all the ACLs |
These commands can be executed in any view. |
