- H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
- 00-1Cover
- 00-2Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Confiugration Operation
- 06-GVRP Operation
- 07-Port Basic Configuration Operation
- 08-Link Aggregation Operation
- 09-Port Isolation Operation
- 10-DLDP Operation
- 11-MAC Address Table Operation
- 12-MSTP Operation
- 13-Multicast Operation
- 14-Routing Protocol Operation
- 15-802.1x Operation
- 16-AAA-RADIUS-HWTACACS Operation
- 17-Centralized MAC Address Authentication Operation
- 18-DHCP Operation
- 19-ARP Operation
- 20-ACL Operation
- 21-QoS Operation
- 22-Mirroring Operation
- 23-Cluster Operation
- 24-SNMP and RMON Operation
- 25-NTP Operation
- 26-SSH Terminal Service Operation
- 27-File System Management Operation
- 28-FTP and TFTP Operatio
- 29-Information Center Operation
- 30-System Maintenance and Debugging Operation
- 31-VLAN VPN Operation
- 32-HWPing Operation
- 33-DNS Operation
- 34-Appendix
00-1Cover | 397.89 KB |
H |
Operation Manual |
Hangzhou H http://www.h
Manual Version: 20071123-C-1.02 Product Version: Release 1500 |
Copyright
? 2006-2007, Hangzhou H
All Rights Reserved
No part of this manual may be reproduced
or transmitted in any form or by any means without prior written consent of Hangzhou H
Trademarks
H
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h
Technical Support
customer_service@h
http://www. h
About This Manual
Related Documentation
In addition
to this manual, each H
Manual |
H |
It provides information for the system installation and setup. |
H |
It is used for assisting the users in using various commands. |
Organization
H
Part |
Contents |
0 Overview |
Introduces the characteristics, services, and network implementations of S3100-52P Ethernet Switches. |
1 CLI |
Introduces the command hierarchy, command view, and CLI features of the Ethernet switch. |
2 Login |
Introduces the ways to log into the Ethernet switch. |
3 Configuration File Management |
Introduces configuration file and the related configuration. |
4 VLAN |
Introduces VLAN and the related configuration. |
5 IP Address and Performance Configuration |
Introduces IP address, IP performance, and the related configuration. |
6 GVRP |
Introduces GVRP and the related configuration. |
7 Port Basic Configuration |
Introduces basic port configuration. |
8 Link Aggregation |
Introduces link aggregation and the related configuration. |
9 Port Isolation |
Introduces port isolation and the related configuration. |
10 DLDP |
Introduces DLDP and the related configuration. |
11 MAC Address Table |
Introduces MAC address forwarding table management. |
12 MSTP |
Introduces STP and the related configuration. |
13 Multicast |
Introduces IGMP Snooping, multicast MAC address, unknown multicast packet dropping, and the related configuration. |
14
Routing Protocol |
Introduces static route configuration. |
15 802.1x |
Introduces 802.1x and the related configuration. |
16
AAA-RADIUS-HWTACACS |
Introduces AAA, RADIUS, HWTACACS, and the related configuration. |
17 Centralized MAC Address Authentication |
Introduces centralized MAC address authentication and the related configuration. |
18
DHCP |
Introduces DHCP-Snooping and the related configuration. |
19 ARP |
Introduces ARP and the related configuration. |
20 ACL |
Introduces ACL and the related configuration. |
21
QoS |
Introduces QoS and the related configuration. |
22 Mirroring |
Introduces port mirroring and the related configuration. |
23 Cluster |
Introduces the configuration for cluster management implemented through HGMPv2. |
24
SNMP and RMON |
Introduces the configuration for network device management implemented through SNMP-RMON. |
25 NTP |
Introduces NTP and the related configuration. |
26
SSH Terminal Service |
Introduces SSH2.0 and the related configuration. |
27 File System Management |
Introduces basic configuration for file system management. |
28
FTP and TFTP |
Introduces basic configuration for FTP and TFTP, and the applications. |
29 Information Center |
Introduces the configuration for analyzing/diagnosing a network through information center. |
30
System Maintenance and Debugging |
Introduces daily system maintenance and debugging. |
31 VLAN VPN |
Introduces VLAN VPN and the related configuration. |
32
HWPing |
Introduces HWPing and the related configuration. |
33 DNS |
Introduces domain name resolution and the related configuration. |
34
Appendix |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Warning |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Caution |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
