Title | Size | Downloads |
00-About the H3C S12500X-AF Command References-book.zip | 6.42 MB |
About the H3C S12500X-AF command references
CAUTION: For information about modules supported by software Release 3203 and later, see the release notes for H3C S12500X-AF Release 3203 and later. |
The H3C S12500X-AF command references describe the commands and command syntax options available in Release 3203 and later versions of the H3C S12500X-AF Switch Series.
Command reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up an H3C S12500X-AF switch. This command reference includes: · CLI. · RBAC. · Logging in to the switch. · FTP and TFTP. · File system management. · Configuration file management. · Software upgrade. · ISSU. · Preprovisioning. · Device management. · Tcl. · Python. · License. |
Virtual Technologies Command Reference |
Covers the commands for configuring the Hewlett Packard Enterprise proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF fabric, connecting the IRF links, and detecting and maintaining the IRF fabric. |
Layer 2—LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Ethernet interface. · Loopback, null, and inloopback interfaces. · Bulk interface configuration. · MAC address table and MAC Information. · Ethernet link aggregation. · DRNI. · Port isolation. · Spanning tree. · Loop detection. · VLAN (including super VLAN, private VLAN, and voice VLAN). · MVRP. · QinQ. · VLAN mapping. · LLDP. · Service loopback group. · Cut-through forwarding. |
Layer 3—IP Services Command Reference |
Covers the commands for configuring and managing IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6. This command reference includes: · ARP (ARP, gratuitous ARP, proxy ARP, ARP snooping, ARP fast reply, and ARP direct route advertisement). · IP addressing. · DHCP. · DNS and DDNS. · IP forwarding basics and load sharing. · Fast forwarding. · Adjacency table. · IRDP. · IP performance optimization. · UDP Helper. · IPv6 basics. · DHCPv6. · IPv6 fast forwarding. · Tunneling. · GRE. |
Layer 3—IP Routing Command Reference |
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing. This command reference includes: · Basic IP routing. · Static routing. · RIP. · OSPF. · IS-IS. · BGP. · Policy-based routing. · IPv6 static routing. · RIPng. · OSPFv3. · IPv6 policy-based routing. · Routing policy. |
IP Multicast Command Reference |
Covers the commands for Layer 2 IPv4 multicast protocols (including IGMP snooping, and multicast VLAN), Layer 3 IPv4 multicast protocols (including IGMP and PIM), Layer 2 IPv6 multicast protocols (including MLD snooping and IPv6 multicast VLAN), and Layer 3 IPv6 multicast protocols (including MLD, IPv6 PIM, and MSDP). This command reference includes: · IGMP snooping. · PIM snooping. · Multicast VLAN. · Multicast routing and forwarding. · IGMP. · PIM. · MSDP. · MLD snooping. · IPv6 multicast VLAN. · IPv6 multicast routing and forwarding. · MLD. · IPv6 PIM. |
MPLS Command Reference |
Covers the MPLS commands. This command reference includes: · Basic MPLS. · LDP. · MPLS TE. · Static CRLSP. · RSVP. · Tunnel policy. · MPLS L3VPN and IPv6 MPLS L3VPN. · MPLS L2VPN. · VPLS. · MPLS OAM. · MCE and IPv6 MCE. · MPLS SR. |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL. · QoS, including commands for the following features: ? QoS policy. ? Priority mapping. ? Congestion management. ? Congestion avoidance. ? QPPB. ? Control plane packet-drop logging. · Time range. |
Security Command Reference |
Covers security feature commands. Available security features include identity authentication, secure management, and attack protection. This command reference includes: · AAA. · 802.1X. · MAC authentication. · Portal. · Port security. · User profile. · Password control. · Keychain. · Public key management. · PKI. · IPsec, IKE, and IKEv2. · SSH. · SSL. · Attack detection and prevention. · TCP attack prevention. · IP source guard. · ARP attack protection. · ND attack defense. · uRPF. · Crypto engine. · FIPS. |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM. · CFD. · DLDP. · RRPP. · ERPS. · Smart Link. · Monitor Link. · VRRP. · BFD. · Track. |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events and test network connectivity. This command reference includes: · System maintenance and debugging (ping, tracert, and system debugging). · NTP and SNTP. · PTP. · Event MIB. · NETCONF. · CWMP. · EAA. · Process monitoring and maintenance. · Sampler. · Mirroring (including port mirroring and flow mirroring). · NetStream. · IPv6 NetStream. · sFlow. · GOLD. · Packet capture. · VCF fabric. |
Telemetry Command Reference |
Covers the commands that help you configure telemetry. This command reference includes gRPC and INT. |
FCoE Command Reference |
Covers the commands for configuring FCoE. |
OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
VXLAN Command Reference |
Covers the commands for configuring VXLAN. |
EVPN Command Reference |
Covers the commands for configuring EVPN. |
