12-FCoE Command Reference
HomeSupportSwitchesH3C S12500X-AF Switch SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R26xx)-6W10212-FCoE Command Reference
Download Book
Title Size Downloads
12-FCoE Command Reference-book.pdf 435.08 KB
Table of Contents
Related Documents
Preface
This command reference describes the FCoE configuration commands.
·           Audience.
·           Conventions.
·           Documentation feedback.
Audience
·           Network planners.
·           Field technical support and servicing engineers.
·           Network administrators working with the S12500X-AF switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card.
We appreciate your comments.
