Title | Size | Downloads |
09-Security Command Reference-book.pdf | 963.28 KB |
Preface
This command reference describes the security configuration commands. It includes the commands for configuring authentication features (including AAA), data security features (public key management and SSH), and attack protection features (including IP source guard, ARP attack protection, and uRPF).
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500X-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
Documentation feedback
We appreciate your comments.
