Title | Size | Downloads |
02-Virtual Technologies Command Reference-book.pdf | 175.53 KB |
Preface
This command reference describes IRF configuration commands for setting up and maintaining an IRF fabric, including:
· Commands for IRF port binding configuration.
· Commands for IRF member ID and priority configuration.
· Commands for detecting IRF splits and maintaining the IRF fabric.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500X-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
Documentation feedback
We appreciate your comments.
