Title | Size | Downloads |
00-About the S12500X-AF Command References-book.pdf | 24.52 KB |
About the H3C S12500X-AF command references
CAUTION: For information about modules supported by software Release 2609 and later, see the release notes for H3C S12500X-AF Release 2609 and later. |
Command reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up an S12500X-AF switch. This command reference includes: · CLI (command privilege settings and CLI management commands). · RBAC. · Logging in to the switch. · FTP and TFTP. · File system management. · Configuration file management. · Software upgrade. · ISSU. · Device management. · Tcl. · Python. · License management. · Preprovisioning. |
Virtual Technologies Command Reference |
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF fabric, connecting the IRF links, and detecting and maintaining the IRF fabric. |
Layer 2—LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Ethernet interface. · Loopback, null, and inloopback interfaces. · Bulk interface configuration. · MAC address table and MAC Information. · Ethernet link aggregation. · Port isolation. · Spanning tree. · Loop detection. · VLAN. · VLAN mapping. · LLDP. · Service loopback group. |
Layer 3—IP Services Command Reference |
Covers the commands for configuring and managing IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6. This command reference includes: · ARP (including gratuitous ARP, proxy ARP, ARP snooping, and ARP fast-reply). · IP addressing. · DHCP. · DNS. · Basic IP forwarding and load sharing. · IRDP. · IP performance optimization. · UDP helper. · IPv6 basics. · DHCPv6. · Tunneling. · GRE. |
Layer 3—IP Routing Command Reference |
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing. This command reference includes: · Basic IP routing. · Static routing. · RIP. · OSPF. · IS-IS. · BGP. · Policy-based routing. · IPv6 static routing. · RIPng. · OSPFv3. · IPv6 IS-IS. · IPv6 policy-based routing. · Routing policy. |
IP Multicast Command Reference |
Covers the commands for Layer 2 IPv4 multicast protocols (including IGMP snooping and multicast VLAN), Layer 3 IPv4 multicast protocols (including IGMP and PIM), Layer 2 IPv6 multicast protocols (including MLD snooping), and Layer 3 IPv6 multicast protocols (including MSDP). This command reference includes: · IGMP snooping. · PIM snooping. · Multicast VLAN. · Multicast routing and forwarding. · IGMP. · PIM. · MSDP. · MLD snooping. |
MPLS Command Reference |
Covers the MPLS commands. This command reference includes: · Basic MPLS. · LDP. · MPLS TE. · Static CRLSP. · RSVP. · Tunnel policy. · MPLS L3VPN. · MCE and IPv6 MCE. · Static SR over MPLS. |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL. · QoS (including QoS policy, priority mapping, GTS and rate limit, congestion management, congestion avoidance, aggregate CAR, and queue-based accounting). · Time range. · Data buffer. |
Security Command Reference |
Covers security feature commands. This command reference includes: · AAA. · Password control. · Keychain. · SSH. · Attack detection and prevention. · TCP attack prevention. · IP source guard. · ARP attack protection. · ND attack defense. · uRPF. · FIPS. |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM. · DLDP. · RRPP. · Smart Link. · Monitor Link. · VRRP. · BFD. · Track. · Process placement. |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity. This command reference includes: · System maintenance and debugging (ping, tracert, and system debugging). · NTP and SNTP. · SNMP. · RMON. · Event MIB. · NETCONF. · EAA. · Sampler. · Mirroring (including both port and traffic mirroring). · NetStream. · IPv6 NetStream. · sFlow. · Information center. · GOLD. · Packet capture. · VCF fabric. |
FCoE Command Reference |
Covers the commands for configuring FCoE. |
SPB Command Reference |
Covers the commands for configuring SPB. |
OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
VXLAN Command Reference |
Covers the commands for configuring VXLAN. |
EVPN Command Reference |
Covers the commands for configuring EVPN. |
