Title | Size | Downloads |
H3C S12508X-AF LSXM1SFH08D1 Card Manual-6PW102-book.pdf | 58.07 KB |
LSXM1SFH08D1 switching fabric module
1 Identifier
The card identifier LSXM1SFH08D1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1 GHz |
SDRAM |
4 GB DDR3 SDRAM |
Power consumption |
159 W to 255 W |
Compatible device models |
S12508X-AF |
Compatible interface cards |
Type H interface cards |
IMPORTANT: · Before you install the card on the switch, make sure the system software supports the card. For information about software and hardware compatibilities with the system software, see the release notes for the system software. · Remove the protection box from the card before you install the card. · You must install the cards before you install the fan trays, and remove the fan trays before you remove the cards. · Follow these instructions to use the ejector levers on the card: ? Before you install the card, release the ejector levers by pressing the spring clips. ? After the card is fully seated into slot, press the ejector levers inward until the spring clips lock it in place. · Before you remove the card, release the ejector levers by pressing the spring clips. · This card can be used only with Type H interface cards, which have an H in their card identifiers (for example, LSXM1CGQ36HB1). This card cannot operate correctly if it is used with an interface card that is not Type H. · Only switching fabric modules of the same model can be installed on the same switch. |
3 Related documentation
For module installation, see H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2018 New H3C Technologies Co., Ltd.
