Title | Size | Downloads |
H3C S12500X-AF LSXM3TGS48FX1 Card Manual-6PW101-book.pdf | 30.57 KB |
LSXM3TGS48FX1 48-port 10-GE SFP+
fiber interface card
1 Card identifier
The card identifier LSXM3TGS48FX1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1.2 GHz. |
SDRAM |
4 GB DDR3 SDRAM. |
Power consumption |
160 W to 275 W. |
Interfaces |
48 SFP+ ports. |
Transmission rate |
10/1 Gbps. |
Transmission medium and max transmission distance |
Compatible device models |
S12500X-AF Switch Series. |
Compatible switching fabric modules |
Type F switching fabric modules. |
IMPORTANT: · To verify the compatibility of the module with the software release you are using, see the release notes. · This card can be used only with Type F switching fabric modules, which have a character string of SFF in their card identifiers (for example, LSXM1SFF16C1). This card cannot operate correctly if it is used with a switching fabric module that is not Type F. |
NOTE: Switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules when the switch is operating, use the display device command. |
The card supports transceiver modules and cables described in Table 2, Table 3, and Table 4.
Table 2 10-Gigabit SFP+ transceiver module specifications
10-Gigabit SFP+ transceiver module |
Central wavelength |
Connector type |
Fiber specifications |
Modal bandwidth ( MHz*km) |
Max transmission distance |
SFP-XG-SX-MM850-A |
850 nm |
LC |
50/125 μm, MMF |
2000 |
300 m (984.26 ft.) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125 μm, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 nm |
LC |
9/125 μm, SMF |
N/A |
10 km (6.21 miles) |
SFP-XG-LH40-SM1550 |
1550nm |
LC |
9/125 μm, SMF |
N/A |
40 km (24.86 miles) |
SFP-XG-LH80-SM1550 |
1550nm |
LC |
9/125 μm, SMF |
N/A |
80 km (49.71 miles) |
SFP-XG-LH80-Tunable |
1528.773 to 1566.723 nm |
LC |
9/125 μm, SMF |
N/A |
NOTE: · The SFP-XG-LH80-Tunable module supports wavelength adjustment. You can use the itu-channel command in Ethernet interface view to adjust the wavelength of the module. To display ITU channel information for transceiver modules, execute the display transceiver itu-channel command. · Cold-staring the SFP-XG-LH80-Tunable module takes a longer time (usually not exceeding 90s) than cold-starting any other SFP+ modules. |
Table 3 10-Gigabit SFP+ cable specifications
10-Gigabit SFP+ cable |
Length |
Data rate |
Type |
Remarks |
LSWM2STK |
1.2 m (3.94 ft.) |
10.31 Gbps |
SFP+ cable |
Dedicated to interconnecting SFP+ ports |
LSWM3STK |
3 m (9.84 ft.) |
LSTM1STK |
5 m (16.40 ft.) |
Table 4 Gigabit SFP transceiver module specifications
Gigabit SFP transceiver module |
Connector type |
Modal bandwidth (MHz*km) |
Maximum transmission distance |
SFP-GE-SX-MM850-A |
850 nm |
LC |
50/125 μm, MMF |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
62.5/125 μm, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 nm |
LC |
9/125 μm, SMF |
N/A |
50/125 μm, MMF |
500 |
400 |
62.5/125 μm, MMF |
500 |
SFP-GE-LH40-SM1310 |
1310 nm |
LC |
9/125 μm, SMF |
N/A |
40 km (18.64 miles) |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1550 |
1550 nm |
LC |
9/125 μm, SMF |
N/A |
70 km (43.50 miles) |
SFP-GE-LH100-SM1550 |
1550 nm |
LC |
9/125 μm, SMF |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 nm RX: 1490 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 nm RX: 1310 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1470-CW |
1470 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1490-CW |
1490 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1510-CW |
1510 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1530-CW |
1530 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1550-CW |
1550 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1570-CW |
1570 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1590-CW |
1590 nm |
LC |
9/125 μm, SMF |
N/A |
SFP-GE-LH70-SM1610-CW |
1610 nm |
LC |
9/125 μm, SMF |
N/A |
IMPORTANT: You must use the SFP-GE-LX-SM1310-BIDI and the SFP-GE-LX-SM1490-BIDI in pairs. |
3 Obtaining documentation
For card installation, see the H3C S12500X-AF Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
