Title | Size | Downloads |
H3C S12500X-AF LSXM1TGS48QGHA1 Card Manual-6PW101-book.pdf | 21.23 KB |
LSXM1TGS48QGHA1 48-port 10G (SFP+) + 4-port 40G (QSFP+) fiber interface card
1 Identifier
The card identifier LSXM1TGS48QGHA1 is at the upper right corner of the front panel.
2 Specifications
CAUTION: This card can be used only with Type H switching fabric modules, which have a character string of SFH in their card identifiers (for example, LSXM1SFH16C1). Card damage will occur if this card is used with a switching fabric module that is not Type H. |
NOTE: Switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules when the switch is operating, use the display device command. |
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1.0 GHz |
SDRAM |
4 GB DDR3 SDRAM |
Power consumption |
87 W to 287 W |
Interfaces |
· 48 × 10G SFP+ port · 4 × 40G QSFP+ port |
Transmission rate |
· SFP+ port: 10 Gbps · QSFP+ port: 40 Gbps |
Compatible device models |
S12500X-AF Switch Series |
Compatible switching fabric modules |
Type H switching fabric modules |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · For the card to start up correctly on an S12516X-AF/S12512X-AF/S12508X-AF/S12504X-AF switch, make sure the four switching fabric module slots with the greatest slot IDs take precedence over other slots for switching fabric module installation. · For information about transceiver modules and cables available for the card, see H3C S12500X-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes. |
3 Related documentation
For card installation, see H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2018 New H3C Technologies Co., Ltd.
