Title | Size | Downloads |
H3C S12500X-AF LSXM1CGQ6QGHB1 Card Manual-6PW102-book.pdf | 27.77 KB |
LSXM1CGQ6QGHB1 6-port 100G QSFP28/12-port 40G QSFP+ fiber interface card
1 Identifier
The card identifier LSXM1CGQ6QGHB1 is at the upper right corner of the front panel.
2 Specifications
Figure 1 Interface types and numbers
(1) QSFP+ ports |
(2) QSFP28 ports |
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1.2 GHz |
SDRAM |
8 GB DDR3 SDRAM |
Power consumption |
145 W to 204 W |
Interfaces |
6 × 100G QSFP28 port + 6 × 40G QSFP+ port Or 12 × 40G QSFP+ port NOTE: A QSFP28 port acts as a QSFP+ port when operating at 40 Gbps. |
Transmission rate |
· QSFP28 port: 100/40 Gbps · QSFP+ ports: 40 Gbps |
Compatible device models |
S12500X-AF Switch Series |
Compatible switching fabric modules |
Type H switching fabric modules |
CAUTION: This card can be used only with Type H switching fabric modules, which have a character string of SFH in their card identifiers (for example, LSXM1SFH16C1). Card damage will occur if this card is used with a switching fabric module that is not Type H. |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · For the card to start up correctly, make sure the three switching fabric module slots with the greatest slot IDs take precedence over other slots for switching fabric module installation. · For information about transceiver modules and cables available for the card, see H3C S12500X-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes. |
NOTE: Switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules while the switch is operating, use the display device command. |
3 Related documentation
For card installation, see H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2018 New H3C Technologies Co., Ltd.
