Title | Size | Downloads |
H3C S12500X-AF LSXM1CGQ36TD1 Card Manual-APW101-book.pdf | 26.64 KB |
LSXM1CGQ36TD1 36-port 100G QSFP28 fiber interface card
1 Card identifier
The card identifier LSXM1CGQ36TD1 is at the upper right corner of the front panel.
2 Specifications
CAUTION: This card can be used only with Type T switching fabric modules, which have a character string of SFT in their card identifiers (for example, LSXM1SFT16E1). Card damage will occur if this card is used with a switching fabric module that is not Type T. |
NOTE: Switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules while the switch is operating, use the display device command. |
Table 1 Card specifications
Item |
Specification |
Processor |
Intel Processor (Quad Core) @ 2.4 GHz |
SDRAM |
8 GB DDR3 SDRAM |
Power consumption |
590 W to 1050 W |
Interfaces |
36 × QSFP28 ports |
Transmission rate |
100/40 Gbps |
Transmission medium and max transmission distance |
Compatible device models |
S12516X-AF/S12508X-AF installed with high performance fan trays |
Compatible switching fabric modules |
Type T switching fabric modules |
IMPORTANT: To verify compatibility of the card with the software release you are using, see the release notes. |
Table 2, Table 3, and Table 4 describe the transceiver modules, DAC cables, and AOC cables available for the card, respectively.
Table 2 Transceiver modules available for the card
Transceiver module |
Central wavelength |
Connector |
Cable specifications |
Modal bandwidth |
Maximum transmission distance |
QSFP-100G-SR4-MM850 |
850 nm |
MPO (PC polished, 12-fiber) |
50/125 µm, SMF |
2000 MHz*km |
70 m (229.66 ft) |
4700 MHz*km |
100 m (328.08 ft) |
QSFP-100G-eSR4-MM850 |
850 nm |
50/125 µm, SMF |
2000 MHz*km |
200 m (656.17 ft) |
4700 MHz*km |
300 m (984.25 ft) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 1295 nm · 1300 nm · 1304 nm · 1309 nm |
LC |
9/125 µm, SMF |
N/A |
10 km (6.21 miles) |
QSFP-40G-SR4-MM850 |
850 nm |
50/125 µm, MMF |
2000 |
100 m (328.08 ft) |
4700 |
150 m (492.12 ft) |
QSFP-40G-CSR4-MM850 |
850 nm |
50/125 µm, MMF |
2000 |
300 m (984.25 ft) |
4700 |
400 m (1312.33 ft) |
QSFP-40G-LR4L-WDM1300 |
Four lanes: · 1271 nm · 1291 nm · 1311 nm · 1331 nm |
LC |
9/125 µm, SMF |
N/A |
2 km (1.24 miles) |
QSFP-40G-LR4-WDM1300 |
LC |
9/125 µm, SMF |
N/A |
QSFP-40G-ER4-WDM1300 |
LC |
9/125 µm, SMF |
N/A |
40 km (24.86 miles) |
NOTE: · PC is the acronym for physical contact. A PC-polished connector has the end face polished without an angle. · APC is the acronym for angle-polished contact. An angle-polished contact has the end face polished with an angle, typically 8°. |
Table 3 DAC cables available for the card
DAC cable |
Cable length |
Data rate |
QSFP-100G-D-CAB-1M |
1 m (3.28 ft) |
100 Gbps |
QSFP-100G-D-CAB-3M |
3 m (9.84 ft) |
Table 4 AOC cables available for the card
AOC cable |
Cable length |
Data rate |
QSFP-40G-D-AOC-7M |
7 m (22.97 ft) |
40 Gbps |
QSFP-40G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-40G-D-AOC-20M |
20 m (65.62 ft) |
QSFP-100G-D-AOC-7M |
7 m (22.97 ft) |
100 Gbps |
QSFP-100G-D-AOC-10M |
10 m (32.81 ft) |
QSFP-100G-D-AOC-20M |
20 m (65.62 ft) |
3 Obtaining documentation
For card installation, see H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2018 New H3C Technologies Co., Ltd.
