Title | Size | Downloads |
H3C LSXM1GT48FX1 Card Manual-6PW101-book.pdf | 26.05 KB |
48-port 10/100/1000Base-T Gigabit Ethernet Card–LSXM1GT48FX1
1 Card identifier
The mark LSXM1GT48FX1 is printed at the upper right corner of the front panel, and is used to identify the card.
2 Specifications
Table 1 LSXM1GT48FX1 specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core), 1.0GHz. |
SDRAM |
4GB DDR3 SDRAM. |
Power consumption |
122 W to 145 W. |
Connector |
RJ-45. |
Ports |
48 10/100/1000Base-T Gigabit Ethernet ports. |
Transmission rate |
10/100/1000 Mbps (half/full duplex). |
Transmission medium and max transmission distance |
Category-5 twisted pair; maximum transmission distance: 100 m (328 ft). |
Compatible device models |
· S12500-X Switch Series. · S12500X-AF Switch Series. |
Compatible switching fabric modules |
· S12500-X switch: All types of switching fabric modules. · S12500X-AF switch: Type F switching fabric modules. |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · For an S12500X-AF switch, this card can be used only with Type F switching fabric modules, which have a character string of SFF in their card identifiers (for example, LSXM1SFF16C1). This card cannot operate correctly if it is used with a switching fabric module that is not Type F. · Remove the protection box from the card before you install the card. · Follow these guidelines to install the card: ? On an S12500-X switch, install the card directly in the target slot. ? On an S12500X-AF switch, install an interface module adapter in the target slot before you install the card. No interface module adapter is provided with the card, purchase one before installation. |
NOTE: On an S12500X-AF switch, switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules while the switch is operating, use the display device command. |
3 Obtaining documentation
For module installation, see H3C S12500-X Switch Series Installation Guide or H3C S12500X-AF Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
