Title | Size | Downloads |
H3C LSXM1GP48FX1 Card Manual-6PW102-book.pdf | 49.06 KB |
48-port GE SFP Ethernet Interface Card–LSXM1GP48FX1
1 Card identifier
The mark LSXM1GP48FX1 is printed at the upper right corner of the front panel, and is used to identify the card.
2 Specifications
Table 1 LSXM1GP48FX1 specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core), 1.0GHz. |
SDRAM |
4GB DDR3 SDRAM. |
Power consumption |
115 W to 165 W. |
Ports |
48 SFP ports. |
Transmission rate |
1 Gbps (full duplex). |
Transmission medium and max transmission distance |
see Table 2. |
Compatible device models |
· S12500-X Switch Series. · S12500X-AF Switch Series. |
Compatible switching fabric modules |
· S12500-X switch: All types of switching fabric modules. · S12500X-AF switch: Type F switching fabric modules. |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · For an S12500X-AF switch, this card can be used only with Type F switching fabric modules, which have a character string of SFF in their card identifiers (for example, LSXM1SFF16C1). This card cannot operate correctly if it is used with a switching fabric module that is not Type F. · Remove the protection box from the card before you install the card. · Follow these guidelines to install the card: ? On an S12500-X switch, install the card directly in the target slot. ? On an S12500X-AF switch, install an interface module adapter in the target slot before you install the card. No interface module adapter is provided with the card, purchase one before installation. |
NOTE: On an S12500X-AF switch, switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules while the switch is operating, use the display device command. |
The LSXM1GP48FX1 supports the following transceiver modules.
Table 2 Gigabit SFP module specifications
Gigabit SFP module |
Central wavelength |
Connector |
Cable specifications |
Mode bandwidth |
Maximum transmission distance |
SFP-GE-SX- |
850 nm |
LC |
50/125 μm multi-mode optical fiber |
500 MHz*km |
550 m (1804.46 ft) |
400 MHz*km |
500 m (1640.42 ft) |
62.5/125 μm multi-mode optical fiber |
200 MHz*km |
275 m (902.23 ft) |
160 MHz*km |
220 m (721.78 ft) |
SFP-GE-LX- |
1310 nm |
LC |
9/125 μm single-mode optical fiber |
N/A |
10 km (6.21 miles) |
500 MHz*km |
400 MHz*km |
500 MHz*km |
SFP-GE-LH40-SM1310 |
1310 nm |
LC |
N/A |
40 km (24.86 miles) |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
N/A |
SFP-GE-LH70-SM1550 |
1550 nm |
LC |
N/A |
70 km (43.49 miles) |
SFP-GE-LH100-SM1550 |
1550 nm |
LC |
N/A |
100 km (62.14 miles) |
SFP-GE-LX- |
TX: 1310 nm RX: 1490 nm |
LC |
N/A |
SFP-GE-LX- |
TX: 1490 nm RX: 1310 nm |
LC |
N/A |
SFP-GE-LH70-SM1470-CW |
1470 nm |
LC |
N/A |
70 km (43.50 miles) |
SFP-GE-LH70-SM1490-CW |
1490 nm |
LC |
N/A |
SFP-GE-LH70-SM1510-CW |
1510 nm |
LC |
N/A |
SFP-GE-LH70-SM1530-CW |
1530 nm |
LC |
N/A |
SFP-GE-LH70-SM1550-CW |
1550 nm |
LC |
N/A |
SFP-GE-LH70-SM1570-CW |
1570 nm |
LC |
N/A |
SFP-GE-LH70-SM1590-CW |
1590 nm |
LC |
N/A |
SFP-GE-LH70-SM1610-CW |
1610 nm |
LC |
N/A |
IMPORTANT: You must use the SFP-GE-LX-SM1310-BIDI and the SFP-GE-LX-SM1490-BIDI in pairs. |
3 Obtaining documentation
For module installation, see H3C S12500-X Switch Series Installation Guide or H3C S12500X-AF Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
