Title | Size | Downloads |
H3C LSXM1CGQ8FX1 Card Manual-APW101-book.pdf | 29.38 KB |
LSXM1CGQ8FX1 8-port 100G
QSFP28 fiber
interface card
1 Card identifier
The card identifier LSXM1CGQ8FX1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1.2 GHz. |
SDRAM |
4 GB DDR3 SDRAM. |
Power consumption |
278 W to 358 W. |
Interfaces |
8 x QSFP28 ports. |
Transmission rate |
100 Gbps. |
Transmission medium and max transmission distance |
Compatible device models |
· S12500-X Switch Series. · S12500X-AF Switch Series. |
Compatible switching fabric modules |
· S12500-X switch: All types of switching fabric modules. · S12500X-AF switch: Type F switching fabric modules. |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · For an S12500X-AF switch, this card can be used only with Type F switching fabric modules, which have a character string of SFF in their card identifiers (for example, LSXM1SFF16C1). This card cannot operate correctly if it is used with a switching fabric module that is not Type F. · Remove the protection box from the card before you install the card. · Follow these guidelines to install the card: ? On an S12500-X switch, install the card directly in the target slot. ? On an S12500X-AF switch, install an interface module adapter in the target slot before you install the card. No interface module adapter is provided with the card, purchase one before installation. |
NOTE: On an S12500X-AF switch, switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules while the switch is operating, use the display device command. |
Table 2 and Table 3 describe the transceiver modules and cables available for the card, respectively.
Table 2 Transceiver modules available for the card
Transceiver module |
Central wavelength |
Connector |
Cable specifications |
Modal bandwidth |
Maximum transmission distance |
QSFP-100G-SR4-MM850 |
850 nm |
MPO (PC polished, 12-fiber) |
50/125 μm multimode optical fiber |
2000 MHz*km |
70 m (229.66 ft) |
4700 MHz*km |
100 m (328.08 ft) |
QSFP-100G-LR4-WDM1300 |
Four lanes: · 1295 nm · 1300 nm · 1304 nm · 1309 nm |
LC |
9/125 μm single-mode optical fiber |
N/A |
10 km (6.21 miles) |
QSFP-100G-LR4L-WDM1300 |
Four lanes: · 1271 nm · 1291 nm · 1311 nm · 1331 nm |
LC |
N/A |
2km (1.24 miles) |
NOTE: PC is the acronym for physical contact. A PC-polished connector has the end face polished without an angle. |
Table 3 Cables available for the card
Cable |
Cable length |
Data rate |
QSFP-100G-D-CAB-1M |
1 m (3.28 ft) |
100 Gbps |
QSFP-100G-D-CAB-3M |
3 m (9.84 ft) |
3 Obtaining documentation
For module installation, see H3C S12500-X Switch Series Installation Guide or H3C S12500X-AF Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
