H3C LSXM1CGP8FX1 Card Manual-6PW101
HomeSupportSwitchesH3C S12500X-AF Switch SeriesInstall & UpgradeService Module Card ManualsH3C LSXM1CGP8FX1 Card Manual-6PW101
Download Book
Title Size Downloads
H3C LSXM1CGP8FX1 Card Manual-6PW101-book.pdf 27.39 KB
LSXM1CGP8FX1 8-port 100-GE CFP2 fiber
interface card
1  Card identifier
The card identifier LSXM1CGP8FX1 is at the upper right corner of the front panel.
2  Specifications
Table 1 Card specifications
Item
Specification
Processor
MIPS64 (Dual Core) @ 1.2 GHz.
SDRAM
4 GB DDR3 SDRAM.
Power consumption
253 W to 410 W.
Interfaces
8 CFP2 ports.
Transmission rate
100 Gbps.
Transmission medium and max transmission distance
See Table 2.
Compatible device models
·     S12500-X Switch Series.
·     S12500X-AF Switch Series.
Compatible switching fabric modules
·     S12500-X switch: All types of switching fabric modules.
·     S12500X-AF switch: Type F switching fabric modules.
IMPORTANT
IMPORTANT:
·     To verify compatibility of the card with the software release you are using, see the release notes.
·     For an S12500X-AF switch, this card can be used only with Type F switching fabric modules, which have a character string of SFF in their card identifiers (for example, LSXM1SFF16C1). This card cannot operate correctly if it is used with a switching fabric module that is not Type F.
·     Remove the protection box from the card before you install the card.
·     Follow these guidelines to install the card:
?     On an S12500-X switch, install the card directly in the target slot.
?     On an S12500X-AF switch, install an interface module adapter in the target slot before you install the card. No interface module adapter is provided with the card, purchase one before installation.
On an S12500X-AF switch, switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules while the switch is operating, use the display device command.
The card supports CFP2 modules described in Table 2.
Table 2 CFP2 module specifications
CFP2 module
Central wavelength
Connector
Cable specifications
Max. transmission distance
CFP2-100G-LR4-WDM1300
Four lanes:
·     1295.56 nm
·     1300.05 nm
·     1304.58 nm
·     1309.14 nm
LC
9/125 μm single-mode optical fiber
10 km (6.21 miles)
3  Obtaining documentation
For module installation, see H3C S12500-X Switch Series Installation Guide or H3C S12500X-AF Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
  • Become a Partner
  • Partner Resources
