Title | Size | Downloads |
H3C S12504X-AF LSXM1SUP04H1 Card Manual-6PW102-book.pdf | 60.95 KB |
LSXM1SUP04H1 service processing engine
1 Identifier
The card identifier LSXM1SUP04H1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Quad Core) @ 1.2 GHz. |
SDRAM |
16GB DDR3 SDRAM (two DIMM slots). |
Flash |
1 GB (NAND flash). |
NVRAM |
512 KB. |
Power consumption |
46 W to 50 W. |
Connector |
· RJ-45. · LC. · USB (Type A). |
Interfaces |
· 1 × console port. · 2 × 10/100/1000Base-T port for management and upgrade. · 2 × SFP port for management and upgrade. · 1 × USB port (USB 2.0, Host port). |
Transmission rate |
· Console port: 9600 bps (default) to 115200 bps. · 10/100/1000Base-T port: 10/100/1000 Mbps. · SFP port: 1000 Mbps. |
Transmission medium and max transmission distance of the console port |
15 m (49.21 ft) over asynchronous serial cable. |
Transmission medium and max transmission distance of the 10/100/1000Base-T port |
100 m (328.08 ft) over category-5 UTP. |
Compatible device models |
S12504X-AF. |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · The USB port outputs power as prescribed by USB 2.0. You can only connect a USB 2.0-compliant device to the USB port. · Set the same speed and duplex mode for a management Ethernet interface and its peer port. · If multiple management ports are connected to one remote switch, you must assign their peer ports to different VLANs on the remote switch. Login or file transfer will fail if the peer ports are in the same VLAN. · To transfer files from the BootWare menu through TFTP or FTP, you can use only the management port M0/0/3. This port is marked with a number of 3 on the card panel. · For information about transceiver modules and cables available for the card, see H3C S12500X-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes. |
3 Installing the card
1. Insert the card into the slot.
2. Pull up the handle and push the card slowly from above the handle until the handle breaks touch the slot edges tightly.
When you push the card, the handle is pulled down gradually. If you push the card from below the handle, your hands might be injured.
3. Continue to push the MPU handle until the MPU is secure in position.
4. Fasten the captive screw.
4 Related documentation
For module installation, see H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2018 New H3C Technologies Co., Ltd.
