Title | Size | Downloads |
H3C S12502X-AF LSXM1SUP02B1 Card Manual-6PW102-book.pdf | 59.62 KB |
LSXM1SUP02B1 service processing engine
1 Identifier
The card identifier LSXM1SUP02B1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1.0 GHz. |
SDRAM |
8GB DDR3 SDRAM (one DIMM slot). |
Flash |
1 GB (NAND flash). |
NVRAM |
512 KB. |
Power consumption |
20 W to 21 W. |
Connector |
· RJ-45. · LC. · USB (Type A). |
Interfaces |
· 1 × console port. · 1 × 10/100/1000Base-T port for management and upgrade. · 1 × SFP port for management and upgrade. · 1 × USB port (USB 2.0, Host port). |
Transmission rate |
· Console port: 9600 bps (default) to 115200 bps. · 10/100/1000Base-T port: 10/100/1000 Mbps. · SFP port: 1000 Mbps. |
Transmission medium and max transmission distance of the console port |
15 m (49.21 ft) over asynchronous serial cable. |
Transmission medium and max transmission distance of 10/100/1000Base-T port |
100 m (328.08 ft) over category-5 UTP. |
Compatible device models |
S12502X-AF. |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · The USB port outputs power as prescribed by USB 2.0. You can only install a USB 2.0-compliant device to the USB port. · Set the same speed and duplex mode for a management Ethernet interface and its peer port. · If you connect the two management ports to the same remote switch, you must assign their peer ports to different VLANs on the remote switch. Login or file transfer will fail if the peer ports are in the same VLAN. · To transfer files from the BootWare menu through TFTP or FTP, you can use only the 10/100/1000BASE-T management port M0/0/1. This port is marked with a number of 1 on the card panel. · For information about transceiver modules and cables available for the card, see H3C S12500X-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes. |
3 Related documentation
For module installation, see H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2018 New H3C Technologies Co., Ltd.
