Title | Size | Downloads |
H3C S12500X-AF LSXM1SUPA1 Card Manual-6PW101-book.pdf | 76.53 KB |
LSXM1SUPA1 service processing engine
1 Card identifier
The card identifier LSXM1SUPA1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Quad Core) @ 1.2 GHz |
SDRAM |
8 GB DDR3 SDRAM (2 DIMM slots) |
Flash |
1GB (NAND flash) |
NVRAM |
512 KB |
Power consumption |
46 W to 55 W |
Connector |
· RJ-45 · USB (Type A) |
Interfaces |
· 1 × console port · 1 × 10/100/1000Base-T port for management and upgrade · 1 × USB port (USB 2.0, Host port) |
Transmission rate |
· Console port: 9600 bps (default) to 115200 bps · 10/100/1000Base-T port: 10/100/1000 Mbps |
Transmission medium and max transmission distance |
· Console port: 15 m (49.21 ft) over asynchronous serial cable · 10/100/1000Base-T port: 100 m (328.08 ft) over category-5 UTP |
Compatible device models |
S12516X-AF and S12508X-AF |
IMPORTANT: · To verify compatibility of the card with the software release you are using, see the release notes. · The USB port outputs power as prescribed by USB 2.0. You can only install a USB 2.0-compliant device to the USB port. · Set the same speed and duplex mode for a management Ethernet interface and its peer port. |
3 Obtaining documentation
For card installation, see the H3C S12500X-AF Switch Series Installation Guide.
For software upgrade, see the H3C S12500X-AF Switch Series Software Upgrade Guide.
Take the following steps to get the latest documentation from the H3C website at www.h3c.com.
· Go to http://www.h3c.com/portal/Technical_Documents.
· Choose the desired product category and model.
Copyright © 2015 Hangzhou H3C Technologies Co., Ltd.
