- Released At: 06-11-2020
- Page Views:
- Downloads:
About the H3C S12500G-AF command references
Command reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up the switch. This command reference includes: · CLI · RBAC · Login management · FTP and TFTP · File system management · Configuration file management · Software upgrade · ISSU · Device management · Tcl · Python · License management |
Virtual Technologies Command Reference |
Covers the commands for configuring virtual technologies features. This command reference includes: · IRF · MDC |
Interface Command Reference |
Covers the commands for configuring interfaces. This command reference includes: · Bulk interface · Ethernet interface · Loopback, null, and inloopback interface |
Layer 2—LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. You can use these commands to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, customer network packets transparent to the service provider network, remark VLAN tags, and so on. This command reference includes: · MAC address table · Ethernet link aggregation · DRNI · Port isolation · VLAN · MVRP · QinQ · VLAN mapping · Loop detection · Spanning tree · LLDP · L2PT · Service loopback group |
Layer 3—IP Services Command Reference |
Covers the commands for configuring IP services features. You can use these command to configure IP addressing, IP performance optimization, ARP, DNS, UDP helper, and interoperation between IPv4 and IPv6. This command reference includes: · DHCP · DNS · mDNS relay · IP forwarding basics · Fast forwarding · Adjacency table · IRDP · IP performance optimization · IPv6 fast forwarding · Tunneling · GRE · HTTP redirect |
Layer 3—IP Routing Command Reference |
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing. This command reference includes: · Basic IP routing · Static routing · RIP · OSPF · IS-IS · BGP · Policy-based routing · IPv6 static routing · RIPng · OSPFv3 · IPv6 policy-based routing · Routing policy · DCN |
IP Multicast Command Reference |
Covers the commands for Layer 2 and Layer 3 multicast protocols. This command reference includes: · IGMP snooping · PIM snooping · Multicast VLAN · Multicast routing and forwarding · IGMP · PIM · MSDP · Multicast VPN · MLD snooping · IPv6 PIM snooping · IPv6 multicast VLAN · IPv6 multicast routing and forwarding · MLD · IPv6 PIM |
MPLS Command Reference |
Covers the commands for configuring MPLS features, including basic MPLS, LDP, MPLS TE, and MPLS label-based L2VPN and L3VPN. This command reference includes: · Basic MPLS · Static LSP · LDP · MPLS TE · Static CRLSP · RSVP · Tunnel policy · MPLS L3VPN · MPLS L2VPN · VPLS · MPLS OAM · MCE |
Segment Routing Command Reference |
Covers the commands for configuring Segment Routing. This command reference includes: · MPLS SR |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL · QoS · Time range · Data buffer |
Security Command Reference |
Covers security feature commands. Available security features include identity authentication, access security, secure management, and attack protection. This command reference includes: · AAA · 802.1X · MAC authentication · Portal · Port security · Password control · Keychain · PKI · IPsec, IKE, and IKEv2 · SSH · SSL · Attack detection and prevention · TCP attack prevention · IP source guard · ARP attack protection · ND attack defense · uRPF · MFF · FIPS · 802.1X client · Web authentication · Object group · Microsegmentation |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM · CFD · DLDP · RRPP · ERPS · Smart Link · Monitor Link · VRRP · Reth interface · BFD · Track |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, and test network connectivity. This command reference includes: · System maintenance and debugging · NQA · NTP · PTP · SNMP · RMON · Event MIB · NETCONF · SmartMC · CWMP · EAA · Process monitoring and maintenance · Sampler · Mirroring · sFlow · Information center · GOLD · Packet capture · VCF fabric · eMDI · SQA · Cloud connection |
Telemetry Command Reference |
Covers the commands for configuring Telemetry. This command reference includes: · gRPC · INT |
FCoE Command Reference |
Covers the commands for configuring FCoE. |
OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
VXLAN Command Reference |
Covers the commands for configuring VXLAN. |
EVPN Command Reference |
Covers the commands for configuring EVPN. This command reference includes: · EVPN · MVXLAN |
